PMK35EP
P-channel TrenchMOS extremely low level FET
Rev. 02 — 29 April 2010
Product data sheet
1. Product profile
1.1 General description
Extremely low level P-channel enhancement mode Field-Effect Transistor (FET) in a
plastic package using TrenchMOS technology. This product is designed and qualified for
use in computing, communications, consumer and industrial applications only.
1.2 Features and benefits
Low conduction losses due to low
on-state resistance
1.3 Applications
Battery management
Load switching
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max Unit
VDS
drain-source
voltage
25 °C ≤ Tj ≤ 150 °C
-30
V
ID
drain current
Tsp = 25 °C; VGS = -10 V; see
Figure 1; see Figure 3
-14.
9
A
Ptot
total power
dissipation
Tsp = 25 °C; see Figure 2
6.9
W
VGS = -10 V; ID = -9.2 A;
Tj = 25 °C; see Figure 9
16
19
mΩ
6
nC
Static characteristics
RDSon
drain-source
on-state
resistance
Dynamic characteristics
QGD
gate-drain charge VGS = -10 V; ID = -9.2 A;
VDS = -15 V; Tj = 25 °C;
see Figure 11; see Figure 12
PMK35EP
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
S
source
2
S
source
3
S
source
4
G
gate
5
D
drain
6
D
drain
7
D
drain
8
D
drain
Simplified outline
8
Graphic symbol
D
5
G
1
4
S
SOT96-1 (SO8)
001aaa025
3. Ordering information
Table 3.
Type number
Package
PMK35EP
Name
Description
Version
SO8
plastic small outline package; 8 leads; body width 3.9 mm
SOT96-1
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
25 °C ≤ Tj ≤ 150 °C
-30
V
VDGR
drain-gate voltage
25 °C ≤ Tj ≤ 150 °C; RGS = 20 kΩ
-30
V
VGS
gate-source voltage
-25
25
V
ID
drain current
Tsp = 25 °C; VGS = -10 V; see Figure 1;
see Figure 3
-14.9
A
Tsp = 100 °C; VGS = -10 V; see Figure 1
-7
A
-28.8
A
IDM
peak drain current
Tsp = 25 °C; tp ≤ 10 µs; pulsed;
see Figure 3
Ptot
total power dissipation
6.9
W
Tstg
storage temperature
-55
150
°C
Tj
junction temperature
-55
150
°C
Source-drain diode
IS
source current
Tsp = 25 °C
-5.8
A
ISM
peak source current
-23
A
PMK35EP
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 12
PMK35EP
Nexperia
003aab604
120
003aab948
120
Pder
Ider
80
80
40
40
100
150
50
100
150
Fig 1.
200
Tsp (°C)
Tj (°C)
Normalized continuous drain current as a
function of solder point temperature
Fig 2.
Normalized total power dissipation as a
003aab603
−102
Limit RDSon = VDS / ID
ID
(A)
tp = 10 μs
−10
1 ms
10 ms
DC
−1
100 ms
−10−1
−10−1
−1
−10
−102
VDS (V)
Tsp = 25 °C; IDM is single pulse
Fig 3.
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-sp)
thermal resistance
from junction to solder
point
see Figure 4
18
K/W
PMK35EP
Product data sheet
3 of 12
PMK35EP
Nexperia
003aab605
102
Zth(j−sp)
(K / W)
δ = 0.5
10
0.2
0.1
1
0.05
0.02
δ=
P
single pulse
10−1
tp
T
t
tp
T
10−2
10−4
10−3
10−2
10−1
1
10
tp (s)
Fig 4.
Transient thermal impedance from junction to solder point as a function of pulse duration
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
drain-source
breakdown voltage
ID = -250 µA; VGS = 0 V; Tj = 25 °C
-30
V
ID = -250 µA; VGS = 0 V; Tj = -55 °C
-27
V
gate-source threshold
voltage
ID = -250 µA; VDS = VGS; Tj = 25 °C;
see Figure 7; see Figure 8
-1
-3
V
ID = -250 µA; VDS = VGS; Tj = 150 °C;
-0.7
V
ID = -250 µA; VDS = VGS; Tj = -55 °C;
-3.3
V
VDS = -30 V; VGS = 0 V; Tj = 25 °C
-1
µA
VDS = -30 V; VGS = 0 V; Tj = 70 °C
-10
µA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
-100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
-100
nA
VGS = -10 V; ID = -9.2 A; Tj = 25 °C;
see Figure 9
16
19
mΩ
VGS = -10 V; ID = -9.2 A; Tj = 150 °C;
see Figure 9
25
31
mΩ
VGS = -4.5 V; ID = -6.8 A; Tj = 25 °C;
see Figure 10; see Figure 9
26
35
mΩ
ID = -9.2 A; VDS = -15 V; VGS = -10 V;
Tj = 25 °C; see Figure 11; see Figure 12
42
nC
8
nC
6
nC
V(BR)DSS
VGS(th)
IDSS
drain leakage current
IGSS
gate leakage current
RDSon
drain-source on-state
resistance
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
PMK35EP
Product data sheet
4 of 12
PMK35EP
Nexperia
Table 6.
Characteristics …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VGS(pl)
gate-source plateau
voltage
ID = -9.2 A; VDS = -15 V; Tj = 25 °C;
-2.5
V
Ciss
input capacitance
VDS = -25 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; see Figure 13
2100
pF
365
pF
275
pF
9
ns
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
VDS = -25 V; RL = 6 Ω; VGS = -10 V;
RG(ext) = 6 Ω; Tj = 25 °C
tr
rise time
9
ns
td(off)
turn-off delay time
50
ns
tf
fall time
24
ns
-0.8
-1.2
V
Source-drain diode
source-drain voltage
VSD
IS = -3.45 A; VGS = 0 V; Tj = 25 °C;
see Figure 14
003aab606
−30
VGS (V) = −5
−4
ID
(A)
003aab608
−30
ID
(A)
−3.5
−20
−10
−20
−10
−3
Tj = 150 °C
25 °C
−2.8
−0.5
−1
−1.5
VDS (V)
−2
Tj = 25 °C
Fig 5.
Product data sheet
−2
−3
VGS (V)
−4
VDS > ID x RDSon
Output characteristics: drain current as a
function of drain-source voltage; typical values
PMK35EP
−1
Fig 6.
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
5 of 12
PMK35EP
Nexperia
003aab613
−4
VGS(th)
(V)
003aab612
−10−3
ID
(A)
−3
max.
−10−4
min.
−2
typ.
−1
min.
typ.
max.
−10−5
−60
120
180
−10−6
−2
−3
−4
VGS (V)
Tj = 25 °C; VDS = -5 V
ID = -1 mA; VDS = VGS
Fig 7.
−1
Tj (°C)
Gate-source threshold voltage as a function of
003aab614
2
a
Fig 8.
Sub-threshold drain current as a function of
gate-source voltage
003aab607
100
VGS (V) = −3
−3.5
RDSon
(mΩ)
1.5
75
1
50
−4
−4.5
0.5
−60
25
−5
120
180
Tj (°C)
−10
−20
ID (A)
−30
Tj = 25 °C
Fig 9.
Normalized drain-source on-state resistance
factor as a function of junction temperature
PMK35EP
Product data sheet
Fig 10. Drain-source on-state resistance as a function
of drain current; typical values
6 of 12
PMK35EP
Nexperia
003aab611
−10
VDS = −5 V
ID = −9.2 A
Tj = 25 °C
VGS
(V)
VDS
ID
−7.5
VGS(pl)
VGS(th)
−5
VGS
QGS1
−2.5
QGS2
QGS
QGD
QG(tot)
003aaa508
25
37.5
50
QG (nC)
Fig 11. Gate-source voltage as a function of gate
charge; typical values
003aab610
104
Fig 12. Gate charge waveform definitions
003aab609
−24
IS
(A)
C
(pF)
−18
Ciss
−12
103
Tj = 150 °C
25 °C
−6
Coss
Crss
102
−10−1
−1
−10
VDS (V)
−102
Product data sheet
−0.4
−0.8
−1.2
VSD (V)
−1.6
VGS = 0 V
Fig 13. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
PMK35EP
Fig 14. Source current as a function of source-drain
7 of 12
PMK35EP
Nexperia
7. Package outline
SO8: plastic small outline package; 8 leads; body width 3.9 mm
SOT96-1
D
E
A
X
c
y
HE
v M A
Z
5
8
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
5.0
4.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100
0.014 0.0075
0.20
0.19
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
2. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT96-1
076E03
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
Fig 15. Package outline SOT96-1 (SO8)
PMK35EP
Product data sheet
8 of 12
PMK35EP
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PMK35EP_2
20100429
Product data sheet
PMK35EP_1
Modifications:
PMK35EP_1
PMK35EP
Product data sheet
Various changes to content.
20070917
Product data sheet
9 of 12
PMK35EP
Nexperia
9. Legal information
9.1
Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
PMK35EP
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on a weakness or default in the
customer application/use or the application/use of customer’s third party
customer(s) (hereinafter both referred to as “Application”). It is customer’s
sole responsibility to check whether the Nexperia product is
suitable and fit for the Application planned. Customer has to do all necessary
testing for the Application in order to avoid a default of the Application and the
product. Nexperia does not accept any liability in this respect.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Limiting values — Stress above one or more limiting values (as defined in the
Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
10 of 12
PMK35EP
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
non-automotive qualified products in automotive equipment or applications.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PMK35EP
Product data sheet
11 of 12
Nexperia
PMK35EP
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2
Thermal characteristics . . . . . . . . . . . . . . . . . . .3
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .4
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .8
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . .9
Legal information. . . . . . . . . . . . . . . . . . . . . . . .10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . . 11
Date of release: 29 April 2010
