PSMN030-150B
N-channel TrenchMOS SiliconMAX standard level FET
Rev. 02 — 13 December 2010
Product data sheet
1. Product profile
1.1 General description
SiliconMAX standard level N-channel enhancement mode Field-Effect Transistor (FET) in
a plastic package using TrenchMOS technology. This product is designed and qualified for
use in computing, communications, consumer and industrial applications only.
1.2 Features and benefits
Higher operating power due to low
thermal resistance
Low conduction losses due to low
on-state resistance
Suitable for high frequency
applications due to fast switching
characteristics
1.3 Applications
DC-to-DC converters
Switched-mode power supplies
1.4 Quick reference data
Table 1.
Symbol
Parameter
Min
Typ
Max Unit
VDS
drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C
Conditions
150
ID
drain current
55.5 A
Ptot
total power
dissipation
250
W
VGS = 10 V; ID = 25 A; Tj = 25 °C
24
30
mΩ
VGS = 10 V; ID = 55.5 A;
VDS = 120 V; Tj = 25 °C
38
50
nC
Tmb = 25 °C
V
Static characteristics
RDSon
drain-source
on-state resistance
Dynamic characteristics
QGD
gate-drain charge
PSMN030-150B
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
G
gate
2
D
drain[1]
Simplified outline
Graphic symbol
mb
3
S
source
mb
D
mounting base; connected to drain
D
G
mbb076
S
2
1
3
SOT404 (D2PAK)
[1]
It not possible to make a connection to pin 2.
3. Ordering information
Table 3.
Type number
Package
PSMN030-150B
Name
Description
Version
D2PAK
plastic single-ended surface-mounted package (D2PAK); 3 leads SOT404
(one lead cropped)
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
150
V
VDGR
drain-gate voltage
Tj ≤ 175 °C; Tj ≥ 25 °C; RGS = 20 kΩ
150
V
VGS
gate-source voltage
ID
drain current
-20
V
Tmb = 25 °C
55.5
A
Tmb = 100 °C
39
A
222
A
IDM
peak drain current
pulsed; Tmb = 25 °C
Ptot
total power dissipation
Tmb = 25 °C
250
W
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
Source-drain diode
IS
source current
Tmb = 25 °C
55.5
A
ISM
peak source current
pulsed; Tmb = 25 °C
222
A
Avalanche ruggedness
EDS(AL)S
non-repetitive drain-source
avalanche energy
VGS = 10 V; Tj(init) = 25 °C; ID = 35 A;
Vsup ≤ 50 V; unclamped; RGS = 50 Ω;
tp = 100 µs
300
mJ
IAS
non-repetitive avalanche current
Vsup ≤ 50 V; VGS = 10 V; Tj(init) = 25 °C;
RGS = 50 Ω; unclamped
35
A
PSMN030-150B
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 12
PSMN030-150B
Nexperia
003aaf138
100
Pder
80
003aaf139
100
ID
80
60
60
40
40
100
150
200
100
150
Tmb (°C)
Fig 1.
Normalized total power dissipation as a
function of mounting base temperature
003aaf140
103
IDM
(A)
200
Tmb (°C)
Fig 2.
Normalized continuous drain current as a
003aaf155
102
lAS
(A)
RDS(on) = VDS / ID
102
tp = 10 μs
10
25 °C
10
100 μs
1 ms
D.C.
Tj prior to avalanche = 150 °C
10 ms
100 ms
1
1
10
102
1
10−3
103
10−2
10−1
1
VDS (V)
Tmb = 25 °C; IDM is single pulse
Fig 3.
unclamped inductive load
Safe operating area; continuous and peak drain
currents as a function of drain-source voltage
PSMN030-150B
Product data sheet
10
tAV (ms)
Fig 4.
Single-shot avalanche rating; avalanche
current as a function of avalanche period
3 of 12
PSMN030-150B
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Rth(j-mb)
thermal resistance from
junction to mounting base
Rth(j-a)
junction to ambient
minimum footprint ; FR4 board
10−1
Max
Unit
0.6
K/W
50
K/W
δ = 0.5
0.2
0.1
0.05
10−2
δ=
P
0.02
tp
T
single pulse
t
tp
10−3
10−6
Fig 5.
Typ
003aaf141
1
Zth(j-mb)
(K/W)
Min
T
10−5
10−4
10−3
10−2
10−1
1
tp (s)
Transient thermal impedance from junction to mounting base as a function of pulse duration
PSMN030-150B
Product data sheet
4 of 12
PSMN030-150B
Nexperia
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ID = 0.25 mA; VGS = 0 V; Tj = -55 °C
133
V
V(BR)DSS
drain-source breakdown
voltage
150
V
VGS(th)
gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 175 °C
1
V
ID = 1 mA; VDS = VGS; Tj = -55 °C
6
V
ID = 1 mA; VDS = VGS; Tj = 25 °C
2
3
4
V
IDSS
IGSS
RDSon
ID = 0.25 mA; VGS = 0 V; Tj = 25 °C
drain leakage current
gate leakage current
drain-source on-state
resistance
VDS = 150 V; VGS = 0 V; Tj = 25 °C
0.05
10
µA
VDS = 150 V; VGS = 0 V; Tj = 175 °C
500
µA
VGS = 10 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -10 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = 10 V; ID = 25 A; Tj = 175 °C
81
mΩ
24
30
mΩ
ID = 55.5 A; VDS = 120 V; VGS = 10 V;
Tj = 25 °C
98
nC
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
16
nC
38
50
nC
Ciss
input capacitance
3680
pF
Coss
output capacitance
470
pF
Crss
reverse transfer capacitance
td(on)
turn-on delay time
220
pF
18
ns
tr
rise time
71
ns
td(off)
turn-off delay time
97
ns
tf
fall time
LD
internal drain inductance
measured from tab to centre of die ;
Tj = 25 °C
76
ns
3.5
nH
LS
internal source inductance
measured from source lead to source
bond pad ; Tj = 25 °C
7.5
nH
VDS = 25 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C
VDS = 75 V; RL = 1.5 Ω; VGS = 10 V;
RG(ext) = 5.6 Ω; Tj = 25 °C
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS = 0 V; Tj = 25 °C
0.85
1.2
V
trr
reverse recovery time
109
ns
Qr
recovered charge
IS = 20 A; dIS/dt = -100 A/µs;
VGS = 0 V; VDS = 30 V; Tj = 25 °C
610
nC
PSMN030-150B
Product data sheet
5 of 12
PSMN030-150B
Nexperia
003aaf142
80
003aaf143
0.07
4.4
ID
(A)
VGS (V) = 10
RDS(on)
(Ω)
8
60
6
4.6
4.8
5
5.2
0.05
5.4
40
5.4
5.2
5
6
8
0.03
4.8
4.4
VGS (V) = 10
0.8
1.2
1.6
2
VDS (V)
40
50
ID (A)
Tj = 25 °C
Fig 6.
10
Tj = 25 °C
Output characteristics: drain current as a
function of drain-source voltage; typical values
Fig 7.
003aaf144
50
ID
(A)
40
Drain-source on-state resistance as a function
of drain current; typical values
003aaf145
60
gfs
(S)
Tj = 25 °C
40
30
Tj = 175 °C
Tj = 175 °C
Tj = 25 °C
4
6
10
40
VDS > ID x RDSon
Fig 8.
50
ID (A)
VGS (V)
VDS > ID x RDSon
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
003aaf146
2.9
a
Fig 9.
Forward transconductance as a function of
003aaf148
5
VGS(th)
(V)
4
maximum
2.1
3
typical
2
minimum
1.3
1
0.5
−60
180
Tj (°C)
−60
180
Tj (°C)
Fig 10. Normalized drain-source on-state resistance
factor as a function of junction temperature
PSMN030-150B
Product data sheet
Fig 11. Gate-source threshold voltage as a function of
6 of 12
PSMN030-150B
Nexperia
003aaf149
10−1
lD
(A)
10−2
003aaf151
104
Ciss
C
(pF)
10−3
minimum
10−4
typical
103
maximum
Coss
10−5
Crss
10−6
102
2
3
4
5
10−1
1
102
10
VDS (V)
VGS (V)
Tj = 25 °C; VDS = VGS
Fig 12. Sub-threshold drain current as a function of
gate-source voltage
003aaf152
16
VGS
(V)
12
VDD = 30 V
8
Fig 13. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
003aaf154
50
IF
(A)
40
30
VDD = 120 V
Tj = 175 °C
Tj = 25 °C
10
80
120
160
0.8
1.2
QG (nC)
Tj = 25 °C; ID = 55.5 A
VGS = 0 V
Fig 14. Gate-source voltage as a function of gate
charge; typical values
PSMN030-150B
Product data sheet
VSDS (V)
Fig 15. Source (diode forward) current as a function of
source-drain (diode forward) voltage; typical
values
7 of 12
PSMN030-150B
Nexperia
7. Package outline
SOT404
Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped)
A
A1
E
mounting
base
D1
D
HD
2
Lp
1
3
c
b
e
e
Q
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
c
D
max.
D1
E
e
Lp
HD
Q
mm
4.50
4.10
1.40
1.27
0.85
0.60
0.64
0.46
11
1.60
1.20
10.30
9.70
2.54
2.90
2.10
15.80
14.80
2.60
2.20
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-02-11
06-03-16
SOT404
Fig 16. Package outline SOT404 (D2PAK)
PSMN030-150B
Product data sheet
8 of 12
PSMN030-150B
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PSMN030-150B v.2
20101213
Product data sheet
PSMN030-150B v.1
Modifications:
PSMN030-150B v.1
PSMN030-150B
Product data sheet
The format of this data sheet has been redesigned to comply with the new identity guidelines
of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
20001201
Product data sheet
9 of 12
PSMN030-150B
Nexperia
9. Legal information
9.1
Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
PSMN030-150B
Product data sheet
10 of 12
PSMN030-150B
Nexperia
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PSMN030-150B
Product data sheet
11 of 12
Nexperia
PSMN030-150B
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .8
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . .9
Legal information. . . . . . . . . . . . . . . . . . . . . . . .10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . . 11
Date of release: 13 December 2010
