CJ25
JOYSTICK ENCODER
■ FEATURES
RoHS compliant
● Multi-function device … Joystick, optical encoder, and
push switch functions in one package.
● Suitable size for panels. Smooth operational feel.
● Long life … Joystick 500K cycles, encoder & switch 1M
cycles
● RoHS compliant
■ APPLICATIONS
Operation panels for;
● Medical device
● Broadcast equipment
● Surveillance camera etc.
■ PART NUMBER DESIGNATION
CJ25 - 4 20 1 0
Series name
Interface
0:Connector
Joystick
Push switch function
4:4 方向 Directions
8:8 方向 Directions
1:With push switch
Encoder
20:20 Positions (5P/R)
■ LIST OF PART NUMBERS
Part number
Joystick
CJ25-42010
4 directions
CJ25-82010
8 directions
Encoder
Interface
20 Positions(5P/R)
With push switch
Connector
CJ25
JOYSTICK ENCODER
■ STANDARD SPECIFICATIONS
● Electrical characteristics
● Mechanical characteristics
Encoder
Mounting Torque
1.17N · m maximum (12kgf · cm maximum)
Input voltage
DC5 V ± 5 %
Actuator Strength
19.6N maximum (2kg maximum)
Input current
20mA maximum at 5V
Max. Shaft Pull-out Strength
98N maximum (10kg maximum)
Incremental signal (Square wave)
Max. Shaft Push-out Strength
Output wave form
Pulses Per Rotation
5P/R
Maximum frequencies
response
10Hz
Encoder
Click Torque
Open collector,Pull-up resistor 2.2KΩ
Output
Output Code
2-Bit, Channel A/B,Phase difference 90°
Output Signal
High : 3.8V minimum
Low : 0.4V maximum
Output Sink Current
6 mA maximum
Joystick
Input current
5mA maximum at 5V
Output Code
2-Bit (X,Y)
Output Signal
Neutral : 2.5±0.5V
High : 4.5V minimum
Low : 0.5V maximum
Switch
9.8±4.9mN · m (100±50gf · cm)
Clicks Per Rotation
Rotational Life
1 million cycles
Joystick
Angle of Throw
All directions 9±2°
Operating Force
X,Y 1.47±0.74N (150±75gf)
Joystick Life
500,000 actuation each in directions (X, Y)
Switch
Operating Force
Stroke
Rating
DC5V, 10mA
Switching Life
3.43±1.47N (350±150gf)
0.5±0.2mm
1 million cycles
10Ω maximum
Contact Resistance
Switching : 4ms make
Non-switching : 10ms break
Contact Bouncing
● Environmental characteristics
Operating Temp. Range
Storage Temp. Range
0°C ~ + 50°C
−20 ~ 80°C
■ RELIABILITY TEST
Test item
Test conditions
Vibration
Power OFF
Amplitude : 1.52mm or 98.1m/s2 (10G)whichever is smaller.
10 ~ 500Hz excursion 15 min/cycle, 8 cycles each for X, Z, directions.
Shock
Power OFF
3 times each in directions (X, Z) at 490m/s2 (50G), 11ms.
Power OFF
80 °C 96 h
Power ON
50 °C 96 h
Power OFF
− 20 °C 96 h
Power ON
0 °C 96 h
Humidity
Power OFF
(To be measured after wiping out moisture and leaving samples for 1 h at normal temperature and humidity after the test.)
Thermal shock
Power OFF
To be done 10 cycles with the following condition
(To be measured after leaving samples for 1 h at normal temperature and humidity after the test.)
80 °C 0.5 h、− 20 °C 0.5 h
High temperature
exposure
Low temperature
exposure
CJ25
JOYSTICK ENCODER
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance: ± 0.4 (Unit: mm)
14.65
PIN ASSIGNMENT
Joystick"X"
2
Joystick"Y"
3
4
Power"+5V"
Output"A"
5
Output"B"
6
Switch
7
Switch
8
GND
Nut
18
1
24
M17 P=1.0
±0.1
〈Panel cut-out dimensions〉
φ1.5
+0.05
-0.1
JST
PIN No.8
.1
.2
6.35
M17 P=1.0
4.44
14.5
±0
17
φ
9.65 ±0.1
17.3
15.6
SM08B-GHS-TB
出力
Connector
PIN No.1
3
6.2
φ1.2
4
5.
φ2
5.56 ±0.05
9.65 ±0.05
Locating pin
Pivot point
15.8 ±0.1
1
〈Accessories〉
5.3
Function
φ6.35 -0.07
Pin No.
16.4
■ OUTPUT
ジョイスティック
JOYSTICK 各アングル説明
エンコーダ
出力波形
● ENCODER
Output
Y(High)
X
(Low)
2.5V
スイッチ
回路図
● SWITCH
Waveform
Switch
High
X(High)
A
Low
B
Low
High
1 2 3 4 5 6
Y(Low)
Switch
→CW
Position number: 1∼6…(Clockwise rotation)
Position
"Y (High)" defined by locating pin.
Output
A
B
1
2
ポジション
1
2
3※
4
3
A相
4
オプション(ワイヤーハーネス)
■ OPTION(Wire harnesses)
±5
● =High
blank=Low
Code repeats every
4●positions.
= High
※1∼4ポジション繰り返し
150
B相
空欄 = Low
OUTPUT CIRCUITRY AND RECEIVING CIRCUITRY
出力回路及び受け回路図
10 ±1
1
Joystick “X” Direction
2
Joystick “Y” Direction
3
1 2 3 4 5 6 7 8
(Br)
(O)
(R)
(Y)
(G)
(Bl)
(P)
(B)
Wire color
Br: Brown
O : Orange
R : Red
Y : Yellow
G : Green
Bl : Blue
P : Purple
B : Black
Optional wire harnesses are available upon request.
4
5
2.2kΩ
Power “+5V”
Output “A”
Output “B”
6
Switch
7
Switch
8
Output Circuitry
2.2kΩ
GND
Receiving Circuitry
很抱歉,暂时无法提供与“CJ25-WH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+76.689441+9.92534
- 20+67.4392720+8.72816
- 40+65.4533940+8.47114
- 60+64.3202760+8.32449
- 100+62.92070100+8.14335
- 260+60.38145260+7.81472
- 500+58.70263500+7.59744
- 1000+56.973771000+7.37369
