392-116-558-203
392-116-558-203
    弯插,P=2.54mm
    2.54MM P数:116
392-116-558-203 数据手册
Mounting Option 03-.116 (2.95) I.D. Floating Eyelets Contact Detail 558-90 Degree Bend (Code 541 Contacts) .100 [2.54] Contact Spacing x .200 [5.08] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 6.600 167.64 6.322 160.58 6.046 153.57 0.100 2.54 Card Slot Accepts .054 [1.37] to .070 [1.78] Thick P.C. Board 0.410 10.41 0.240 6.10 Point of Contact 0.370 9.40 5.900 149.86 0.270 6.86 0.590 14.99 A SECTION A-A A See Accompanying Pages for: • Contact Bend Details • Mounting Options 342 / 392 Card Edge Connector Part Number: 392-116-558-203 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 342 Assembly 342 ENG MASTER DATE: OCT. 06/09 DATE: SHEET 1 OF 3 ISSUE 1 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. 0.120 3.05 0.645 16.38 0.645 16.38 0.245 6.22 0.295 7.49 0.095 2.41 0.255 6.48 .125 [3.18] to .185 [4.70] Outside Tails .045 [1.14] to .060 [1.52] Between Tails .045 [1.14] to .060 [1.52] Between Tails 556 Contact Code 1 0.165 4.19 0.180 4.57 .125 [3.18] to .210 [5.33] Outside Tails 555 Contact Code ORIGINAL 0.385 9.78 0.200 5.08 0.060 1.52 558 Contact Code 0.150 3.81 .125 [3.18] to .210 [5.33] Outside Tails .045 [1.14] to .060 [1.52] Between Tails 0.060 1.52 559 Contact Code 560 Contact Code 342 / 392 Series Card Edge Connector Contact Bend Detail EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 342 Assembly 342 ENG MASTER DATE: OCT. 06/09 DATE: SHEET 2 OF 3 ISSUE 1 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .010 [0.25] Radial Float .156 [3.96] Dia Through Holes 0.116 2.95 I.D. Floating Eyelets .128 [3.25] x .146 [3.71] Slot M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert 0.250 6.35 Dia. 0.135 3.43 .128 [3.25] Dia Through Holes 0.005 0.13 0.348 8.84 Code x01 Code x02 Code x03 Code x04 Code x07 Code x08 342 / 392 Card Edge Connector Mounting Options EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x12 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 342 Assembly 342 ENG MASTER DATE: OCT. 06/09 DATE: SHEET 3 OF 3 ISSUE 1
392-116-558-203 价格&库存
很抱歉,暂时无法提供与“392-116-558-203”相匹配的价格&库存,您可以联系我们找货
