SCIHP1338-2R2M
SCIHP1338-2R2M
    SIGNAL
    非标准
    FIXED IND 2.2UH 16A 8 MOHM SMD
SCIHP1338-2R2M 数据手册
SCIHP1338 SMD POWER INDUCTORS MARKING ● Features 1. Lowest DCR/uH in this small package size. 2. Frequency range up to 5.0MHZ. 3. -55℃ to +125℃ operating temperature. 4. Handles high transient current spikes without saturation. 5. Composite construction providing extremely low buzz noise. ELECTRICAL CHARACTERISTICS Part Number Inductance Test (uH) Frequency (1) Saturation Temperature DC Current Current Resistance (4) (3) (Ω MAX) (A) (A) 100 (2) 200KHZ 2.0m 48 25 SCIHP1338-R56M 0.56 200KHZ 2.3m 47 24 SCIHP1338-R82M 0.82 200KHZ 3.0m 39 23 SCIHP1338-1R0M 1.0 200KHZ 3.5m 38 22 SCIHP1338-2R2M 2.2 200KHZ 8.0m 25 16 SCIHP1338-3R3M 3.3 200KHZ 12m 22 12 SCIHP1338-4R7M 4.7 200KHZ 15m 18 10 SCIHP1338-5R6M 5.6 200KHZ 18m 16 9.5 SCIHP1338-6R8M 6.8 200KHZ 22m 14 9 10 Inductance (uH) Inductance (µH) 0.47 1. 0 0. 1 0 100 1000 DC DC current(mA) current (mA) 10000 100000 SCIHP1338Temperature Temperature rise BCIHP1338 riseby bycurrent current Temperature rise Temperature rise°C℃ SCIHP1338-R47M SCIHP1338 Inductance decrease by current BCIHP1338 Inductance by current 80 70 60 50 40 30 20 10 0 5000 10000 15000 20000 25000 30000 35000 DC DCcurrent(mA) current (mA) (1). Inductance tolerance ±20% tested at 0.25V, 0ADC and 25℃ (2). DCR measured at 25℃. (3). The DC current at which the inductance decreases by 20% from its initial value. (4). The DC current that results in a 40℃ temperature rise from 25℃ ambient (*). Part temperature (ambient + temp rise) should not exceed 125℃ under worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provisions may affect the temperature of the part. Part temperature should be verified in the end application. Click here for QUANTITY PER REEL & PACKING INFORMATION Custom versions available upon request. belfuse.com/signal © 2019 Signal Transformer –Specification subject to change without notice. 12.19 175 128 Atlantic Avenue, Lynbrook, NY 11563 Toll Free 866-239-5777 • Tel 516-239-5777 • Fax 516-239-7208 Sales@signaltransformer.com • techhelp@signaltransformer.com
SCIHP1338-2R2M
PDF文档中提到的物料型号为SCIHP1338,这是一款SMD功率电感器。
以下是该物料的详细信息:
器件简介: - 该电感器具有在小尺寸封装中最低的DCR/uH比。
- 频率范围可达5.0MHz。
- 工作温度范围为-55℃至+125℃。
- 能够处理高瞬态电流尖峰而不饱和。
- 采用复合结构,提供极低的嗡嗡声。
引脚分配: - 文档中未提供具体的引脚分配信息。
参数特性: - 电感值范围从0.47uH到6.8uH。
- 测试频率为200kHz。
- DC电阻(最大值)从2.0mΩ到22mΩ不等。
- 饱和电流从25A到14A不等。
- 温度电流(40℃温升时的电流)从25A到9A不等。
功能详解: - 电感值随电流变化的图表显示了不同电流下的电感值变化。
- 电流引起的温升图表显示了不同电流下的温升情况。
应用信息: - 文档中未提供具体的应用信息
封装信息: - 文档中未提供具体的封装信息
请注意,文档中提到的所有参数特性功能详解都应以实际产品规格为准,并且可能需要进一步的验证以确保其在特定应用中的适用性。
SCIHP1338-2R2M 价格&库存
很抱歉,暂时无法提供与“SCIHP1338-2R2M”相匹配的价格&库存,您可以联系我们找货
