PHK13N03LT
N-channel TrenchMOS logic level FET
Rev. 02 — 17 March 2009
Product data sheet
1. Product profile
1.1 General description
Logic level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product is designed and qualified for use in
computing, communications, consumer and industrial applications only.
1.2 Features and benefits
Low conduction losses due to low
on-state resistance
Simple gate drive required due to low
gate charge
Suitable for high frequency
applications due to fast switching
characteristics
1.3 Applications
DC-to-DC convertors
Notebook computers
Lithium-ion battery applications
Portable equipment
1.4 Quick reference data
Table 1.
Quick reference
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C
30
V
ID
drain current
Tsp = 25 °C; VGS = 10 V;
see Figure 1; see Figure 3
13.8
A
Ptot
total power
dissipation
Tsp = 25 °C; see Figure 2
6.25
W
VGS = 5 V; ID = 8 A;
VDS = 15 V; Tj = 25 °C;
see Figure 11
3.9
nC
VGS = 10 V; ID = 8 A;
Tj = 25 °C; see Figure 9;
see Figure 10
17
mΩ
Dynamic characteristics
QGD
gate-drain charge
Static characteristics
RDSon
drain-source
on-state resistance
PHK13N03LT
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol
Description
1
S
source
2
S
source
3
S
source
4
G
gate
5
D
drain
6
D
drain
7
D
drain
8
D
drain
Simplified outline
8
Graphic symbol
D
5
G
1
mbb076
4
S
SOT96-1
(SO8)
3. Ordering information
Table 3.
Type number
Package
Name
Description
PHK13N03LT
SO8
plastic small outline package; 8 leads; body width 3.9 mm
Version
SOT96-1
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
30
V
VDGR
drain-gate voltage
Tj ≥ 25 °C; Tj ≤ 150 °C; RGS = 20 kΩ
VGS
gate-source voltage
ID
drain current
30
V
-20
V
Tsp = 25 °C; VGS = 10 V; see Figure 1; see Figure 3
13.8
A
Tsp = 100 °C; VGS = 10 V; see Figure 1
8.7
A
IDM
peak drain current
Tsp = 25 °C; tp ≤ 10 µs; pulsed; see Figure 3
55
A
Ptot
total power dissipation
6.25
W
Tstg
storage temperature
-55
150
°C
Tj
junction temperature
-55
150
°C
Source-drain diode
IS
source current
Tsp = 25 °C
5.7
A
ISM
peak source current
55
A
PHK13N03LT_2
Product data sheet
2 of 12
Nexperia B.V. 2017. All rights reserved
PHK13N03LT
Nexperia
03aa25
120
03aa17
120
Ider
Pder
80
80
40
40
100
150
200
100
150
Tsp (°C)
Fig 1.
200
Tsp (°C)
Fig 2.
Normalized continuous drain current as a
function of solder point temperature
Normalized total power dissipation as a
003aaa487
102
ID
(A)
Limit RDSon = VDS / ID
10
tp = 10 μs
1 ms
10 ms
DC
1
100 ms
10−1
10−1
1
102
10
VDS (V)
Fig 3.
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
PHK13N03LT_2
Product data sheet
3 of 12
PHK13N03LT
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Rth(j-sp)
Rth(j-a)
Conditions
Min
Typ
Max
Unit
thermal resistance from see Figure 4
junction to solder point
K/W
thermal resistance from minimum footprint; mounted on a
junction to ambient
printed-circuit board
70
K/W
003aaa324
102
Zth(j-sp)
(K/W)
10
δ = 0.5
0.2
0.1
0.05
0.02
1
δ=
P
tp
T
single pulse
t
tp
T
10−1
10−4
10−3
10−2
10−1
1
10
tp (s)
Fig 4.
Transient thermal impedance from junction to ambient as a function of pulse duration
PHK13N03LT_2
Product data sheet
4 of 12
PHK13N03LT
Nexperia
6. Characteristics
Table 6.
Symbol
Characteristics
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
VGS(th)
IDSS
IGSS
RDSon
drain-source
breakdown voltage
gate-source threshold
voltage
drain leakage current
gate leakage current
drain-source on-state
resistance
ID = 250 µA; VGS = 0 V; Tj = 25 °C
30
V
ID = 250 µA; VGS = 0 V; Tj = -55 °C
27
V
ID = 250 µA; VDS = VGS; Tj = 150 °C;
see Figure 8
0.5
V
ID = 250 µA; VDS = VGS; Tj = -55 °C;
see Figure 8
2.2
V
ID = 250 µA; VDS = VGS; Tj = 25 °C;
see Figure 8
1
1.5
2
V
VDS = 24 V; VGS = 0 V; Tj = 25 °C
1
µA
VDS = 24 V; VGS = 0 V; Tj = 100 °C
5
µA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = 4.5 V; ID = 7 A; Tj = 25 °C;
see Figure 9
21
26
mΩ
VGS = 10 V; ID = 8 A; Tj = 150 °C;
see Figure 10; see Figure 9
33
mΩ
VGS = 10 V; ID = 8 A; Tj = 25 °C;
see Figure 9; see Figure 10
17
mΩ
ID = 8 A; VDS = 15 V; VGS = 5 V;
Tj = 25 °C; see Figure 11
10.7
nC
2.7
nC
3.9
nC
752
pF
200
pF
130
pF
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
VDS = 15 V; RL = 10 Ω; VGS = 10 V;
RG(ext) = 6 Ω; Tj = 25 °C; ID = 1.5 A
6
ns
tr
rise time
RG(ext) = 6 Ω; ID = 1.5 A; Tj = 25 °C
7
ns
td(off)
turn-off delay time
23
ns
tf
fall time
11
ns
VDS = 15 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; see Figure 12
Source-drain diode
VSD
source-drain voltage
IS = 7 A; VGS = 0 V; Tj = 25 °C;
see Figure 13
0.86
1.1
V
trr
reverse recovery time
25
ns
Qr
recovered charge
IS = 7 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 30 V; Tj = 25 °C
5
nC
PHK13N03LT_2
Product data sheet
5 of 12
PHK13N03LT
Nexperia
003aaa325
10
10 V 5 V
ID
(A)
003aaa326
10
VGS (V) =
3V
VDS > ID × RDSon
ID
(A)
2.8 V
8
8
2.7 V
6
6
2.6 V
4
4
2.5 V
2.4 V
2
Tj = 150 °C
2
25 °C
2.3 V
Fig 5.
0.2
0.4
0.6
0.8
1
VDS (V)
Output characteristics: drain current as a
function of drain-source voltage; typical values
3
VGS (V)
Fig 6.
003aaa426
10−1
1
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
03aa33
2.5
VGS(th)
(V)
ID
(A)
10−2
2
10−3
max
1.5
typ
10−4
1
min
10−5
0.5
min
typ
max
10−6
2
3
120
VGS (V)
Fig 7.
Sub-threshold drain current as a function of
gate-source voltage
Fig 8.
Tj (°C)
180
Gate-source threshold voltage as a function of
PHK13N03LT_2
Product data sheet
6 of 12
PHK13N03LT
Nexperia
003aaa327
80
2.5 V
2.6 V
03aa27
2
2.8 V
RDSon
(mΩ)
a
60
1.5
40
1
3V
4V
5V
0.5
10 V
VGS (V) =
4
6
8
10
120
ID (A)
Fig 9.
Drain-source on-state resistance as a function
of drain current; typical values
003aaa330
5
VGS
(V)
Tj (°C)
180
Fig 10. Normalized drain-source on-state resistance
factor as a function of junction temperature
003aaa328
104
C
(pF)
4
103
Ciss
3
2
Coss
Crss
102
1
10
15
10
10−1
1
10
102
QG (nC)
VDS (V)
Fig 11. Gate-source voltage as a function of gate
charge; typical values
Fig 12. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
PHK13N03LT_2
Product data sheet
7 of 12
PHK13N03LT
Nexperia
003aaa329
5
IS
(A)
4
3
2
1
Tj = 25 °C
150 °C
0.4
0.6
0.8
1
VSD (V)
Fig 13. Source current as a function of source-drain voltage; typical values
PHK13N03LT_2
Product data sheet
8 of 12
PHK13N03LT
Nexperia
7. Package outline
SO8: plastic small outline package; 8 leads; body width 3.9 mm
SOT96-1
D
E
A
X
c
y
HE
v M A
Z
5
8
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
4
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
5.0
4.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100
0.014 0.0075
0.20
0.19
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
2. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT96-1
076E03
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
Fig 14. Package outline SOT96-1 (SO8)
PHK13N03LT_2
Product data sheet
9 of 12
PHK13N03LT
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PHK13N03LT_2
20090317
Product data sheet
PHK13N03LT-01
Modifications:
PHK13N03LT-01
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
20030623
Product data sheet
PHK13N03LT_2
Product data sheet
10 of 12
PHK13N03LT
Nexperia
9. Legal information
9.1
Data sheet status
Document status [1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
9.3
Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PHK13N03LT_2
Product data sheet
11 of 12
Nexperia
PHK13N03LT
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10
Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . . 11
Date of release: 17 March 2009
很抱歉,暂时无法提供与“PHK13N03LT,518”相匹配的价格&库存,您可以联系我们找货
