RG series
SUSUMU CO.,LTD
Ultra precision 0.01% Tol, 2ppm TCR
Thin Film Chip Resistor
FEATURES
• High Reliability and Excellent Stability at different environmental conditions
• Low noise, THIN FILM(NiCr) construction
• EIA Standard case size(0402, 0603, 0805, 1206)
• RoHS Compliance and 100% Lead-Free (Matte Sn termination finished)
APPLICATIONS
• Automotive
• Test & Measurement
• Optical & Telecommunication
• Medical and Industrial Equipment
Electrical Specification
Type
Size
Power Rating ar 85 oC Resistance Resistance
Rnage
Tolerance
Ultra
(ohm)
(Code)
Regular
Reliability
Temperature
Cofficient (Code)
(ppm/oC)
Max.
operating
Voltage
RG1005
0402
0.063W
0.032W
240 - 3.9K
5 (V)
25V
RG1608
0603
0.1W
0.063W
240 - 7.5K
5 (V)
75V
+0.01% (L)
RG2012
0805
0.125W
0.1W
250 - 36K
RG3216
1206
0.25W
0.125W
250 - 68K
Resistance
Packaging
Vaues
(E-series)
T05:500pcs
E-24, E-96 T1:1000pcs
5 (V)
2 (L)
5 (V)
2 (L)
150V
200V
Reliability Test Data
Item
Test Methode
Performance of High Reliability
Rgluar
Ultra-Reliability
Typical
Short Time Overload
2.5 times of Rated Load X 5sec.
+/- 0.05%
+/- 0.05%
+/- 0.01%
Load Life
85oC Rated Load 90min. On/ 30min. Off
per Cycle X1000
+/- 0.25%
+/- 0.1%
+/- 0.01%
Temp. Hum. Biasa
85oC 85% RH 1/10 power loaded 90min. On/ 30min. Off
per Cycle X1000
+/- 0.25%
+/- 0.1%
+/- 0.05%
Temperature Cycles
-55oC (30min)/room temp.(2min) /
+125oC(30min)/room temp.(2min) No Load per Cycle X1000
+/- 0.1%
+/- 0.1%
+/- 0.05%
High Temperature
155oC for 1000h with No Load
+/- 0.1%
+/- 0.1%
+/- 0.01%
Remarks: Depending on customer's reliability requirements, power rating between high power, regular power and
low power can be selected.
www.susumu.co.jp
RG series
SUSUMU CO.,LTD
Dimensions & Footprints
L
P
Dimensions inch (mm)
L
W
P
T
.040±.002
.020±.002
.008±.004
.014±.002
(1.0 ± 0.05)
(0.5 ± 0.05)
(0.2 ± 0.1)
(0.35 ± 0.05)
.063 ± .008
.031 ± .008
.012 ± .008
0.016 ± .004
(1.6 ± 0.2)
(0.8 ± 0.2)
(0.3 ± 0.2)
(0.4 ± 0.1)
.079 ± .008
.049 ± .008
.016 ± .008
0.016 ± .004
(2.0 ± 0.2)
(1.25 ± 0.2)
(0.4 ± 0.2)
(0.4 ± 0.1)
.126 ± .008
.063 ± .008
.02 ± .01
0.016 ± .004
(3.2 ± 0.2)
(1.6 ± 0.2)
(0.5 ± 0.25)
(0.4 ± 0.1)
P
RG1005
W
RG1608
RG2012
T
RG3216
Recommended Mounting Footprints
Dimensions (mm)
c
a
a
b
c
RG1005
0.5
1.6
0.6
RG1608
1.0
3.0
1.2
RG2012
1.2
4.0
1.7
RG3216
2.0
5.0
2.0
b
Ordering information
RG
2012
TYPE
Size
1005
1608
2012
3216
L
TCR
V = 5ppm/oC
L = 2ppm/oC
104
L
R-Values
3 digits for E24 series
(Ex.101=100 ohm)
4 digits for E96 series
(Ex.4992=49.9K ohm)
T05
Tolerance
Package
L = 0.01%
(Tpae & Reel)
T01 = 100pcs
T05 = 500pcs
T1 = 1000pcs
RG3216 Only 4digits for
all values E24 & E96
(Ex. 1000=100 ohm)
www.susumu.co.jp
SUSUMU CO.,LTD
RG series
Power Derating Curve
For operation above 85degC, power rating must be derated according to the following chart.
Recommended Reflow Curve
S ld e rin g T e m p e ra t u re P ro file
300
P e a k T e m p e ra tu re 2 6 0 oC
250
1 - 5 oC / S e c .
1 - 5 oC / S e c .
200
150
100
10 Sec.
120 Sec.
50
1 - 9 oC / S e c .
Tape & Reel Dimensions (mm)
www.susumu.co.jp
很抱歉,暂时无法提供与“RG2012L-681-L-T05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+21.76487500+2.82937
- 1500+20.415151500+2.65391
- 国内价格 香港价格
- 1+32.310811+4.20030
- 10+26.7111210+3.47236
- 50+23.5223150+3.05783
- 100+22.34303100+2.90452
