BUK725R0-40C,118
BUK725R0-40C,118
    NEXPERIA(安世)
    TO-252(DPAK)
    MOSFET N-CH 40V 75A DPAK
BUK725R0-40C,118 数据手册
BUK725R0-40C N-channel TrenchMOS standard level FET Rev. 01 — 23 March 2009 Product data sheet 1. Product profile 1.1 General description Standard level gate drive N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using advanced TrenchMOS technology. This product has been designed and qualified to the appropriate AEC standard for use in high performance automotive applications. 1.2 Features and benefits „ AEC Q101 compliant „ Suitable for standard level gate drive „ Avalanche robust „ Suitable for thermally demanding environment up to 175°C rating 1.3 Applications „ 12V Motor, lamp and solenoid loads „ High performance automotive power systems „ High performance Pulse Width Modulation (PWM) applications 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions Min Typ Max Unit - - 40 V - - 75 A - - 157 W - - 240 mJ VGS = 10 V; ID = 25 A; VDS = 32 V; Tj = 25 °C; see Figure 15 - 27 - nC VGS = 10 V; ID = 25 A; Tj = 25 °C; see Figure 12; see Figure 13 - 4.1 5 mΩ VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C ID drain current VGS = 10 V; Tmb = 25 °C; see Figure 1; see Figure 3; Ptot total power dissipation Tmb = 25 °C; see Figure 2 [1] Avalanche ruggedness EDS(AL)S non-repetitive drain-source ID = 75 A; Vsup ≤ 40 V; RGS = 50 Ω; VGS = 10 V; avalanche energy Tj(init) = 25 °C; unclamped Dynamic characteristics QGD gate-drain charge Static characteristics RDSon drain-source on-state resistance [1] Current is limited by package. BUK725R0-40C Nexperia N-channel TrenchMOS standard level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 D drain 3 S source mb D mounting base; connected to drain Graphic symbol mb D G mbb076 S 2 1 3 SOT428 (SC-63; DPAK) 3. Ordering information Table 3. Ordering information Type number Package Name Description BUK725R0-40C SC-63; plastic single-ended surface-mounted package (DPAK); 3 leads (one DPAK lead cropped) © BUK725R0-40C_1 Product data sheet Rev. 01 — 23 March 2009 Version SOT428 Nexperia B.V. 2017. All rights reserved 2 of 13 BUK725R0-40C Nexperia N-channel TrenchMOS standard level FET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 40 V VDGR drain-gate voltage RGS = 20 kΩ VGS gate-source voltage ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1; see Figure 3; Tmb = 100 °C; VGS = 10 V; see Figure 1 IDM peak drain current Tmb = 25 °C; tp ≤ 10 µs; pulsed; see Figure 3 Ptot total power dissipation Tmb = 25 °C; see Figure 2 Tstg Tj - 40 V -20 20 V [1] - 75 A [1] - 75 A - 490 A - 157 W storage temperature -55 175 °C junction temperature -55 175 °C - 75 A - 490 A - 240 mJ - - J Source-drain diode IS source current Tmb = 25 °C; ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C [2] Avalanche ruggedness EDS(AL)S non-repetitive ID = 75 A; Vsup ≤ 40 V; RGS = 50 Ω; VGS = 10 V; drain-source avalanche Tj(init) = 25 °C; unclamped energy EDS(AL)R repetitive drain-source avalanche energy see Figure 4 [1] Current is limited by package. [2] Continuous current is limited by package. [3] Single-pulse avalanche rating limited by maximum junction temperature of 175 °C. [4] Repetitive avalanche rating limited by average junction temperature of 170 °C. [5] Refer to application note AN10273 for further information. © BUK725R0-40C_1 Product data sheet [3][4] [5] Rev. 01 — 23 March 2009 Nexperia B.V. 2017. All rights reserved 3 of 13 BUK725R0-40C Nexperia N-channel TrenchMOS standard level FET 003aac066 140 ID (A) 03na19 120 Pder (%) 120 100 80 80 (1) 60 40 40 20 0 0 0 Fig 1. 50 100 150 Tmb (°C) 200 0 50 100 150 200 Tmb (°C) Continuous drain current as a function of mounting base temperature Fig 2. Normalized total power dissipation as a function of mounting base temperature 003aac305 103 ID (A) Limit RDSon = VDS / ID 10 μs 10 2 100 μs 10 DC 1 ms 100 ms 1 10 ms 10-1 10-1 Fig 3. 1 10 102 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage © BUK725R0-40C_1 Product data sheet Rev. 01 — 23 March 2009 Nexperia B.V. 2017. All rights reserved 4 of 13 BUK725R0-40C Nexperia N-channel TrenchMOS standard level FET 003aac068 102 (1) IAL (A) 10 (2) (3) 1 10-1 10-3 Fig 4. 10-2 10-1 1 t (ms) 10 AL Single-pulse and repetitive avalanche rating; avalanche current as a function of avalanche time 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-mb) Rth(j-a) Conditions Min Typ Max Unit thermal resistance from see Figure 5 junction to mounting base - 0.65 0.95 K/W thermal resistance from vertical in still air; mounted on a printed junction to ambient circuit board; minimum foot-print - 70 - K/W 003aac067 1 Zth(j-mb) (K/W) δ = 0.5 0.2 0.1 10-1 0.05 0.02 δ= P 10-2 tp T single shot t tp T 10 -3 10-6 Fig 5. 10-5 10-4 10-3 10-2 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration © BUK725R0-40C_1 Product data sheet Rev. 01 — 23 March 2009 Nexperia B.V. 2017. All rights reserved 5 of 13 BUK725R0-40C Nexperia N-channel TrenchMOS standard level FET 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 0.25 mA; VGS = 0 V; Tj = 25 °C 40 - - V ID = 0.25 mA; VGS = 0 V; Tj = -55 °C 36 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 10 1 - - V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 10 - - 4.4 V ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 10; see Figure 11 2 3 4 V Static characteristics V(BR)DSS VGS(th) IDSS IGSS RDSon drain leakage current gate leakage current drain-source on-state resistance VDS = 40 V; VGS = 0 V; Tj = 175 °C - - 500 µA VDS = 40 V; VGS = 0 V; Tj = 25 °C - 0.05 1 µA VDS = 0 V; VGS = 20 V; Tj = 25 °C - 2 100 nA VDS = 0 V; VGS = -20 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 25 A; Tj = 175 °C; see Figure 12 - - 9.5 mΩ VGS = 10 V; ID = 25 A; Tj = 25 °C; see Figure 12; see Figure 13 - 4.1 5 mΩ ID = 25 A; VDS = 32 V; VGS = 10 V; Tj = 25 °C; see Figure 15 - 60 - nC - 12 - nC - 27 - nC Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance VGS = 0 V; VDS = 25 V; f = 1 MHz; Tj = 25 °C; see Figure 16 VDS = 30 V; RL = 1.2 Ω; VGS = 10 V; RG(ext) = 10 Ω; Tj = 25 °C - 2870 3820 pF - 540 650 pF - 350 490 pF - 27 - ns - 73 - ns td(on) turn-on delay time tr rise time td(off) turn-off delay time - 82 - ns tf fall time - 63 - ns LD internal drain inductance measured from drain to centre of die; Tj = 25 °C - 2.5 - nH LS internal source inductance measured from source lead to source bond pad; Tj = 25 °C - 7.5 - nH Source-drain diode VSD source-drain voltage IS = 25 A; VGS = 0 V; Tj = 25 °C; see Figure 14 - 0.85 1.2 V trr reverse recovery time - 50 - ns Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = -10 V; VDS = 30 V; Tj = 25 °C - 25 - nC © BUK725R0-40C_1 Product data sheet Rev. 01 — 23 March 2009 Nexperia B.V. 2017. All rights reserved 6 of 13 BUK725R0-40C Nexperia N-channel TrenchMOS standard level FET 003aac244 50 ID (A) 003aac245 300 20 10 8 ID (A) 40 VGS (V) = 7.5 7 200 30 6.5 6 20 100 5.5 Tj = 175 °C 10 5 Tj = 25 °C 4.5 0 0 0 Fig 6. 2 4 VGS (V) 0 6 Transfer characteristics: drain current as a function of gate-source voltage; typical values Fig 7. 003aac248 100 gfs (S) 2 4 6 8 10 VDS (V) Output characteristics: drain current as a function of drain-source voltage; typical values 003aac249 30 RDSon (mΩ) 80 20 60 40 10 20 0 0 0 Fig 8. 20 40 ID (A) 60 Forward transconductance as a function of drain current; typical values 5 Fig 9. 15 VGS (V) 20 Drain-source on-state resistance as a function of gate-source voltage; typical values © BUK725R0-40C_1 Product data sheet 10 Rev. 01 — 23 March 2009 Nexperia B.V. 2017. All rights reserved 7 of 13 BUK725R0-40C Nexperia N-channel TrenchMOS standard level FET 03aa32 5 ID (A) VGS(th) (V) 4 typ max 10−3 typ 2 min 10−2 max 3 10−4 min 10−5 1 0 −60 03aa35 10−1 10−6 0 60 120 0 180 2 4 6 Tj (°C) VGS (V) Fig 10. Gate-source threshold voltage as a function of junction temperature 03aa27 2 Fig 11. Sub-threshold drain current as a function of gate-source voltage 003aac250 16 5.5 a 5 RDSon (mΩ) 7 VGS (V) = 6 1.5 12 8 1 8 0.5 10 20 0 -60 4 0 60 120 Tj (°C) 180 Fig 12. Normalized drain-source on-state resistance factor as a function of junction temperature 0 200 300 ID (A) 400 Fig 13. Drain-source on-state resistance as a function of drain current; typical values © BUK725R0-40C_1 Product data sheet 100 Rev. 01 — 23 March 2009 Nexperia B.V. 2017. All rights reserved 8 of 13 BUK725R0-40C Nexperia N-channel TrenchMOS standard level FET 003aac251 60 003aac247 10 VGS (V) IS (A) 8 40 VDS = 32 V 6 4 20 Tj = 175 °C 0 0.0 Tj = 25 °C 2 0 0.5 1.0 VSD (V) 0 1.5 Fig 14. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values 20 40 60 QG (nC) 80 Fig 15. Gate-source voltage as a function of gate charge; typical values 003aac246 5000 C (pF) Ciss 4000 3000 Coss 2000 Crss 1000 0 10-1 1 10 VDS (V) 102 Fig 16. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values © BUK725R0-40C_1 Product data sheet Rev. 01 — 23 March 2009 Nexperia B.V. 2017. All rights reserved 9 of 13 BUK725R0-40C Nexperia N-channel TrenchMOS standard level FET 7. Package outline Plastic single-ended surface-mounted package (DPAK); 3 leads (one lead cropped) SOT428 y E A A A1 b2 E1 mounting base D2 D1 HD 2 L L2 1 L1 3 b1 b w M c A e e1 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1 b2 c D1 D2 min E E1 min e e1 HD L L1 min L2 w y max mm 2.38 2.22 0.93 0.46 0.89 0.71 1.1 0.9 5.46 5.00 0.56 0.20 6.22 5.98 4.0 6.73 6.47 4.45 2.285 4.57 10.4 9.6 2.95 2.55 0.5 0.9 0.5 0.2 0.2 OUTLINE VERSION SOT428 REFERENCES IEC JEDEC JEITA TO-252 SC-63 EUROPEAN PROJECTION ISSUE DATE 06-02-14 06-03-16 Fig 17. Package outline SOT428 (DPAK) © BUK725R0-40C_1 Product data sheet Rev. 01 — 23 March 2009 Nexperia B.V. 2017. All rights reserved 10 of 13 BUK725R0-40C Nexperia N-channel TrenchMOS standard level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes BUK725R0-40C_1 20090323 Product data sheet - - © BUK725R0-40C_1 Product data sheet Rev. 01 — 23 March 2009 Nexperia B.V. 2017. All rights reserved 11 of 13 BUK725R0-40C Nexperia N-channel TrenchMOS standard level FET 9. Legal information 9.1 Data sheet status Document status [1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 9.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com © BUK725R0-40C_1 Product data sheet Rev. 01 — 23 March 2009 Nexperia B.V. 2017. All rights reserved 12 of 13 Nexperia BUK725R0-40C N-channel TrenchMOS standard level FET 11. Contents 3 2 1 1.1 1.2 1.3 1.4 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . .10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . .12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Contact information. . . . . . . . . . . . . . . . . . . . . .12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 23 March 2009
BUK725R0-40C,118 价格&库存
很抱歉,暂时无法提供与“BUK725R0-40C,118”相匹配的价格&库存,您可以联系我们找货
