PHK5NQ15T,518
PHK5NQ15T,518
    NEXPERIA(安世)
    SO-8
    MOSFET N-CH 150V 5A SOT96-1
PHK5NQ15T,518 数据手册
PHK5NQ15T N-channel TrenchMOS standard level FET 2 August 2013 Product data sheet 1. General description Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product is designed and qualified for use in computing, communications, consumer and industrial applications only. 2. Features and benefits • Low conduction losses due to low on-state resistance 3. Applications • • DC-to-DC convertors switching General purpose switching 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C - - 150 V ID drain current Tsp = 25 °C; VGS = 10 V; Fig. 1; Fig. 3 - - 5 A Ptot total power dissipation Tsp = 25 °C; Fig. 2 - - 6.25 W VGS = 10 V; ID = 5 A; Tj = 25 °C; Fig. 9; - 56 75 mΩ - 12 - nC Static characteristics RDSon drain-source on-state resistance Fig. 10 Dynamic characteristics QGD gate-drain charge VGS = 10 V; ID = 5 A; VDS = 75 V; Tj = 25 °C; Fig. 11 PHK5NQ15T Nexperia N-channel TrenchMOS standard level FET 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 S source 2 S source 3 S source 4 G gate 5 D drain 6 D drain 7 D drain 8 D drain Simplified outline 8 Graphic symbol 5 D G 1 4 mbb076 S SO8 (SOT96-1) 6. Ordering information Table 3. Ordering information Type number Package PHK5NQ15T Name Description Version SO8 plastic small outline package; 8 leads; body width 3.9 mm SOT96-1 7. Marking Table 4. Marking codes Type number Marking code PHK5NQ15T K5NQ15T 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C - 150 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 150 °C; RGS = 20 kΩ - 150 V VGS gate-source voltage -20 20 V ID drain current Tsp = 100 °C; VGS = 10 V; Fig. 1 - 3.23 A Tsp = 25 °C; VGS = 10 V; Fig. 1; Fig. 3 - 5 A IDM peak drain current Tsp = 25 °C; pulsed; tp ≤ 10 µs; Fig. 3 - 20 A Ptot total power dissipation Tsp = 25 °C; Fig. 2 - 6.25 W PHK5NQ15T Product data sheet All information provided in this document is subject to legal disclaimers. 2 August 2013 © Nexperia B.V. 2017. All rights reserved 2 / 12 PHK5NQ15T Nexperia N-channel TrenchMOS standard level FET Symbol Parameter Tstg Tj Conditions Min Max Unit storage temperature -55 150 °C junction temperature -55 150 °C Source-drain diode IS source current Tsp = 25 °C - 5 A ISM peak source current Tsp = 25 °C; pulsed; tp ≤ 10 µs - 20 A 03aa25 120 03aa17 120 Ider (%) Pder (%) 80 80 40 40 0 Fig. 1. 0 50 100 150 Tsp (°C) 0 200 Normalized continuous drain current as a function of solder point temperature Fig. 2. 0 50 100 150 Tsp (°C) 200 Normalized total power dissipation as a function of solder point temperature 003aag937 102 ID (A) 10 tp =10 µ s Limit RDSon = V DS / ID 100 µ s 1 10 ms DC 100 ms 10-1 10-2 10-1 Fig. 3. 1 10 102 VDS (V) 103 Safe operating area; continuous and peak drain currents as a function of drain-source voltage PHK5NQ15T Product data sheet All information provided in this document is subject to legal disclaimers. 2 August 2013 © Nexperia B.V. 2017. All rights reserved 3 / 12 PHK5NQ15T Nexperia N-channel TrenchMOS standard level FET 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Rth(j-sp) thermal resistance from junction to solder point Fig. 4 - - 20 K/W Rth(j-a) thermal resistance from junction to ambient minimum footprint ; mounted on printed-circuit board - 70 - K/W 003aaa243 102 Zth(j-sp) (K/W) δ = 0.5 10 0.2 0.1 0.05 1 0.02 P single pulse δ= tp T 10- 1 tp 10- 2 10- 4 Fig. 4. 10- 3 10- 2 10- 1 1 t T 10 tp (s) Transient thermal impedance from junction to ambient as a function of pulse duration 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 250 µA; VGS = 0 V; Tj = -55 °C 134 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 150 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = -55 °C; - - 4.5 V 1.2 - - V ID = 1 mA; VDS = VGS; Tj = 25 °C; Fig. 8 2 3 4 V VDS = 120 V; VGS = 0 V; Tj = 25 °C - - 1 µA VDS = 120 V; VGS = 0 V; Tj = 150 °C - - 100 µA VGS = 10 V; VDS = 0 V; Tj = 25 °C - 10 100 nA Static characteristics V(BR)DSS VGS(th) Fig. 8 ID = 1 mA; VDS = VGS; Tj = 150 °C; Fig. 8 IDSS IGSS drain leakage current gate leakage current PHK5NQ15T Product data sheet All information provided in this document is subject to legal disclaimers. 2 August 2013 © Nexperia B.V. 2017. All rights reserved 4 / 12 PHK5NQ15T Nexperia N-channel TrenchMOS standard level FET Symbol Conditions Min Typ Max Unit VGS = -10 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = 10 V; ID = 5 A; Tj = 150 °C; - 129 173 mΩ VGS = 5 V; ID = 3 A; Tj = 25 °C - 60 80 mΩ VGS = 10 V; ID = 5 A; Tj = 25 °C; Fig. 9; - 56 75 mΩ f = 1 MHz - 1.9 3.8 Ω total gate charge ID = 5 A; VDS = 75 V; VGS = 10 V; - 29 41 nC QGS gate-source charge Tj = 25 °C; Fig. 11 - 3 - nC QGD gate-drain charge - 12 - nC Ciss input capacitance VDS = 25 V; VGS = 0 V; f = 1 MHz; - 1150 1553 pF Coss output capacitance Tj = 25 °C; Fig. 12 - 187 252 pF Crss reverse transfer capacitance - 61 85 pF td(on) turn-on delay time VDS = 75 V; RL = 15 Ω; VGS = 10 V; - 12 - ns tr rise time RG(ext) = 6 Ω; Tj = 25 °C; ID = 5 A - 12 - ns td(off) turn-off delay time - 35 - ns tf fall time - 18 - ns IS = 5 A; VGS = 0 V; Tj = 25 °C; Fig. 13 - 0.8 1.2 V RDSon Parameter drain-source on-state resistance Fig. 9; Fig. 10 Fig. 10 RG gate resistance Dynamic characteristics QG(tot) Source-drain diode VSD source-drain voltage trr reverse recovery time IS = 5 A; dIS/dt = -100 A/µs; VGS = 0 V; - 87 113 ns recovered charge VDS = 90 V; Tj = 25 °C - 162 - nC Qr PHK5NQ15T Product data sheet All information provided in this document is subject to legal disclaimers. 2 August 2013 © Nexperia B.V. 2017. All rights reserved 5 / 12 PHK5NQ15T Nexperia N-channel TrenchMOS standard level FET 003aaa244 4 10 V ID (A) 3.8 V 003aaa245 8 VGS = 3.6 V ID (A) 6 3 4 2 Tj = 150 °C 3.4 V 25 °C 2 1 3.2 V 0 Fig. 5. 3.0 V 0 0.5 1 1.5 VDS (V) 0 2 Fig. 6. Output characteristics: drain current as a function of drain-source voltage; typical values 03aa35 10- 1 ID (A) min 10- 2 typ max 4 2 10- 5 1 Fig. 7. 4 VGS (V) 0 - 60 6 Sub-threshold drain current as a function of gate-source voltage PHK5NQ15T Product data sheet 03aa32 VGS(th) (V) 10- 4 2 4 VGS (V) 5 3 0 3 Transfer characteristics: drain current as a function of gate-source voltage; typical values 10- 3 10- 6 2 Fig. 8. typ min 0 60 120 Tj (°C) 180 Gate-source threshold voltage as a function of junction temperature All information provided in this document is subject to legal disclaimers. 2 August 2013 max © Nexperia B.V. 2017. All rights reserved 6 / 12 PHK5NQ15T Nexperia N-channel TrenchMOS standard level FET 003aaa246 200 RDSon (mΩ) 03al51 3 a 3.4 V 150 3.6 V 3.8 V 2 100 VGS = 5 V 1 50 10 V 0 Fig. 9. 0 2 4 6 ID (A) 0 - 75 8 Drain-source on-state resistance as a function of drain current; typical values 25 75 125 Tj (°C) 175 Fig. 10. Normalized drain-source on-state resistance factor as a function of junction temperature 003aaa249 10 - 25 003aaa248 104 VGS (V) C (pF) 8 Ciss 103 6 Coss 4 102 Crss 2 0 0 10 20 QG (nC) Fig. 11. Gate-source voltage as a function of gate charge; typical values PHK5NQ15T Product data sheet 10 30 10- 1 1 10 VDS (V) 102 Fig. 12. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. 2 August 2013 © Nexperia B.V. 2017. All rights reserved 7 / 12 PHK5NQ15T Nexperia N-channel TrenchMOS standard level FET 003aaa247 4 IS (A) 3 150 °C 2 Tj = 25 °C 1 0 0 0.2 0.4 0.6 0.8 1 VSD (V) Fig. 13. Source current as a function of source-drain voltage; typical values PHK5NQ15T Product data sheet All information provided in this document is subject to legal disclaimers. 2 August 2013 © Nexperia B.V. 2017. All rights reserved 8 / 12 PHK5NQ15T Nexperia N-channel TrenchMOS standard level FET 11. Package outline SO8: plastic small outline package; 8 leads; body width 3.9 mm SOT96-1 D E A X c y HE v M A Z 5 8 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 4 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 5.0 4.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.20 0.014 0.0075 0.19 0.16 0.15 inches 0.010 0.057 0.069 0.004 0.049 0.05 0.244 0.039 0.028 0.041 0.228 0.016 0.024 0.01 0.01 0.028 0.004 0.012 θ o 8 o 0 Notes 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT96-1 076E03 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 Fig. 14. Package outline SO8 (SOT96-1) PHK5NQ15T Product data sheet All information provided in this document is subject to legal disclaimers. 2 August 2013 © Nexperia B.V. 2017. All rights reserved 9 / 12 PHK5NQ15T Nexperia N-channel TrenchMOS standard level FET In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 12. Legal information 12.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. PHK5NQ15T Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the All information provided in this document is subject to legal disclaimers. 2 August 2013 © Nexperia B.V. 2017. All rights reserved 10 / 12 PHK5NQ15T Nexperia N-channel TrenchMOS standard level FET grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PHK5NQ15T Product data sheet All information provided in this document is subject to legal disclaimers. 2 August 2013 © Nexperia B.V. 2017. All rights reserved 11 / 12 PHK5NQ15T Nexperia N-channel TrenchMOS standard level FET 13. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................2 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 4 11 Package outline ..................................................... 9 12 12.1 12.2 12.3 12.4 Legal information .................................................10 Data sheet status ............................................... 10 Definitions ...........................................................10 Disclaimers .........................................................10 Trademarks ........................................................ 11 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 02 August 2013 PHK5NQ15T Product data sheet All information provided in this document is subject to legal disclaimers. 2 August 2013 © Nexperia B.V. 2017. All rights reserved 12 / 12
PHK5NQ15T,518 价格&库存
很抱歉,暂时无法提供与“PHK5NQ15T,518”相匹配的价格&库存,您可以联系我们找货
