BUK7905-40ATE,127
BUK7905-40ATE,127
    NEXPERIA(安世)
    TO-220-5
    MOSFET N-CH 40V 75A TO220AB
BUK7905-40ATE,127 数据手册
BUK7905-40ATE N-channel TrenchPLUS standard level FET Rev. 02 — 10 February 2009 Product data sheet 1. Product profile 1.1 General description Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. The devices include TrenchPLUS diodes for temperature sensing and ElectroStatic Discharge (ESD) protection. This product has been designed and qualified to the appropriate AEC standard for use in automotive critical applications. 1.2 Features and benefits „ Allows responsive temperature monitoring due to integrated temperature sensor „ Low conduction losses due to low on-state resistance „ Electrostatically robust due to integrated protection diodes „ Suitable for standard level gate drive sources „ Q101 compliant 1.3 Applications „ Electrical Power Assisted Steering (EPAS) „ Variable Valve Timing for engines 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 40 V - 4.5 5 mΩ Static characteristics RDSon drain-source on-state VGS = 10 V; ID = 50 A; resistance Tj = 25 °C; see Figure 7; see Figure 8 SF(TSD) temperature sense diode temperature coefficient IF = 250 µA; Tj ≥ -55 °C; Tj ≤ 175 °C -1.4 -1.54 -1.68 mV/K VF(TSD) temperature sense diode forward voltage IF = 250 µA; Tj = 25 °C 648 658 668 mV VF(TSD)hys temperature sense diode forward voltage hysteresis IF ≤ 250 µA; Tj = 25 °C; IF ≥ 125 µA 25 32 50 mV BUK7905-40ATE Nexperia N-channel TrenchPLUS standard level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 G gate 2 A anode 3 D drain 4 K cathode 5 S source mb D mounting base; connected to drain Graphic symbol mb D A G S K mbl317 12 3 4 5 SOT263B (TO-220) 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BUK7905-40ATE TO-220 plastic single-ended package; heatsink mounted; 1 mounting hole; 5-lead SOT263B TO-220 © BUK7905-40ATE_2 Product data sheet Rev. 02 — 10 February 2009 Nexperia B.V. 2017. All rights reserved 2 of 15 BUK7905-40ATE Nexperia N-channel TrenchPLUS standard level FET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 40 V VGS gate-source voltage ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 2; see Figure 3 Tmb = 100 °C; VGS = 10 V; see Figure 2 -20 20 V [1] - 155 A [2] - 75 A [2] - 75 A Tmb = 25 °C; tp ≤ 10 µs; pulsed; see Figure 3 IDM peak drain current - 620 A Ptot total power dissipation Tmb = 25 °C; see Figure 1 - 272 W IGS(CL) gate-source clamping current continuous - 10 mA pulsed; tp = 5 ms; δ = 0.01 - 50 mA Visol(FET-TSD) FET to temperature sense diode isolation voltage -100 100 V Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C [1] - 155 A [2] - 75 A tp ≤ 10 µs; pulsed; Tmb = 25 °C - 620 A ID = 75 A; Vsup ≤ 40 V; RGS = 50 Ω; VGS = 10 V; Tj(init) = 25 °C; unclamped - 1.46 J HBM; C = 100 pF; R = 1.5 kΩ - 6 kV Source-drain diode IS ISM source current Tmb = 25 °C peak source current Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy Electrostatic discharge Vesd electrostatic discharge voltage [1] Current is limited by power dissipation chip rating. [2] Continuous current is limited by package. © BUK7905-40ATE_2 Product data sheet Rev. 02 — 10 February 2009 Nexperia B.V. 2017. All rights reserved 3 of 15 BUK7905-40ATE Nexperia N-channel TrenchPLUS standard level FET 03na19 120 03ng16 160 ID (A) Pder (%) 120 80 80 capped at 75A due to package 40 40 0 0 0 50 100 150 200 0 50 100 150 Tmb (°C) Fig 2. Fig 1. 200 Tmb (°C) Normalized total power dissipation as a function of mounting base temperature Continuous drain current as a function of mounting base temperature 103 03ng17 ID (A) Limit RDSon = VDS/ID tp = 10 µs 100 µs 102 Capped at 75 A due to package 1 ms DC 10 ms 10 100 ms 1 1 Fig 3. 10 102 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage © BUK7905-40ATE_2 Product data sheet Rev. 02 — 10 February 2009 Nexperia B.V. 2017. All rights reserved 4 of 15 BUK7905-40ATE Nexperia N-channel TrenchPLUS standard level FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-a) Rth(j-mb) Conditions Min Typ Max Unit thermal resistance from vertical in still air junction to ambient - 60 - K/W thermal resistance from see Figure 4 junction to mounting base - - 0.55 K/W 03ni64 1 Z th(j-mb) (K/W) 10-1 δ = 0.5 0.2 0.1 0.05 0.02 10-2 δ= P tp T single shot t tp T 10-3 10-6 Fig 4. 10-5 10-4 10-3 10-2 10-1 1 tp (s) 10 Transient thermal impedance from junction to mounting base as a function of pulse duration © BUK7905-40ATE_2 Product data sheet Rev. 02 — 10 February 2009 Nexperia B.V. 2017. All rights reserved 5 of 15 BUK7905-40ATE Nexperia N-channel TrenchPLUS standard level FET 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min Typ Max Unit drain-source breakdown voltage ID = 0.25 mA; VGS = 0 V; Tj = 25 °C 40 - - V ID = 0.25 mA; VGS = 0 V; Tj = -55 °C 36 - - V gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 9 2 3 4 V ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 9 1 - - V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 9 - - 4.4 V VDS = 40 V; VGS = 0 V; Tj = 25 °C - 0.1 10 µA VDS = 40 V; VGS = 0 V; Tj = 175 °C - - 250 µA 20 22 - V IG = -1 mA; VDS = 0 V; Tj ≤ 175 °C; Tj ≥ -55 °C 20 22 - V VDS = 0 V; VGS = 10 V; Tj = 25 °C - 22 1000 nA VDS = 0 V; VGS = -10 V; Tj = 25 °C - 22 1000 nA VDS = 0 V; VGS = 10 V; Tj = 175 °C - - 10 µA VDS = 0 V; VGS = -10 V; Tj = 175 °C - - 10 µA VGS = 10 V; ID = 50 A; Tj = 25 °C; see Figure 7; see Figure 8 - 4.5 5 mΩ VGS = 10 V; ID = 50 A; Tj = 175 °C; see Figure 7; see Figure 8 - - 9.5 mΩ Static characteristics V(BR)DSS VGS(th) IDSS V(BR)GSS IGSS RDSon drain leakage current gate-source breakdown IG = 1 mA; VDS = 0 V; Tj ≤ 175 °C; voltage Tj ≥ -55 °C gate leakage current drain-source on-state resistance VF(TSD) temperature sense diode forward voltage IF = 250 µA; Tj = 25 °C 648 658 668 mV SF(TSD) temperature sense diode temperature coefficient IF = 250 µA; Tj ≥ -55 °C; Tj ≤ 175 °C -1.4 -1.54 -1.68 mV/K VF(TSD)hys temperature sense diode forward voltage hysteresis IF ≤ 250 µA; IF ≥ 125 µA; Tj = 25 °C 25 32 50 mV ID = 25 A; VDS = 32 V; VGS = 10 V; Tj = 25 °C; see Figure 14 - 118 - nC - 16 - nC - 57 - nC - 4500 - pF - 1500 - pF - 960 - pF Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance VGS = 0 V; VDS = 25 V; f = 1 MHz; Tj = 25 °C; see Figure 12 © BUK7905-40ATE_2 Product data sheet Rev. 02 — 10 February 2009 Nexperia B.V. 2017. All rights reserved 6 of 15 BUK7905-40ATE Nexperia N-channel TrenchPLUS standard level FET Table 6. Characteristics …continued Symbol Parameter Conditions Min Typ Max Unit td(on) turn-on delay time - 35 - ns tr rise time VDS = 30 V; RL = 1.2 Ω; VGS = 10 V; RG(ext) = 10 Ω; Tj = 25 °C - 115 - ns td(off) turn-off delay time - 155 - ns tf fall time - 110 - ns LD internal drain inductance from upper edge of mounting base to centre of die; Tj = 25 °C - 2.5 - nH LS internal source inductance from source lead to source bond pad; Tj = 25 °C - 7.5 - nH Source-drain diode VSD source-drain voltage IS = 40 A; VGS = 0 V; Tj = 25 °C; see Figure 17 - 0.85 1.2 V trr reverse recovery time - 96 - ns Qr recovered charge IS = 20 A; dIS/dt = -100 A/µs; VGS = -10 V; VDS = 30 V; Tj = 25 °C - 224 - nC © BUK7905-40ATE_2 Product data sheet Rev. 02 — 10 February 2009 Nexperia B.V. 2017. All rights reserved 7 of 15 BUK7905-40ATE Nexperia N-channel TrenchPLUS standard level FET 03ni86 400 ID (A) Label is VGS (V) 10 8 RDSon (mΩ) 7.5 20 300 03ni88 12 7 8 6.5 200 6 5.5 100 4 5 4.5 4 0 0 0 Fig 5. 2 4 6 8 10 VDS (V) Output characteristics: drain current as a function of drain-source voltage; typical values 4 Fig 6. 16 VGS (V) 20 Drain-source on-state resistance as a function of gate-source voltage; typical values 03ni30 a VGS = 5.5 V 6 V RDSon (mΩ) 12 2.0 03ni87 20 8 6.5 V 7V 1.6 15 1.2 10 0.8 8V 10 V 5 0.4 20 V 0 0 Fig 7. 100 200 0 −60 300 I (A) 400 D Drain-source on-state resistance as a function of drain current; typical values Fig 8. 60 120 180 Tj (°C) Normalized drain-source on-state resistance factor as a function of junction temperature © BUK7905-40ATE_2 Product data sheet 0 Rev. 02 — 10 February 2009 Nexperia B.V. 2017. All rights reserved 8 of 15 BUK7905-40ATE Nexperia N-channel TrenchPLUS standard level FET 03aa32 5 ID (A) VGS(th) (V) 4 typ max 10−3 typ 2 min 10−2 max 3 10−4 min 10−5 1 0 −60 Fig 9. 03aa35 10−1 10−6 0 60 120 0 180 2 4 6 Tj (°C) VGS (V) Gate-source threshold voltage as a function of junction temperature Fig 10. Sub-threshold drain current as a function of gate-source voltage 03ne67 8 03ni89 90 C (nF) gfs (S) 6 60 Ciss 4 30 2 Coss Crss 0 0 25 50 75 100 0 10−1 1 102 10 ID (A) VDS (V) Fig 11. Forward transconductance as a function of drain current; typical values Fig 12. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values © BUK7905-40ATE_2 Product data sheet Rev. 02 — 10 February 2009 Nexperia B.V. 2017. All rights reserved 9 of 15 BUK7905-40ATE Nexperia N-channel TrenchPLUS standard level FET 03ni26 10 03ni90 100 VGS (V) ID (A) 8 75 VDS = 14 V 6 32 V 50 4 175 °C 25 Tj = 25 °C 2 0 0 0 2 4 VGS (V) 40 80 120 QG (nC) Fig 13. Transfer characteristics: drain current as a function of gate-source voltage; typical values 03ne84 700 0 6 VF (mV) Fig 14. Gate-source voltage as a function of turn-on gate charge; typical values 03ne85 −1.70 max SF (mV/K) −1.60 600 typ −1.50 500 min 400 0 50 100 150 200 −1.40 645 655 665 675 Tj (°C) VF (mV) Fig 15. Forward voltage of temperature sense diode as a function of junction temperature; typical values Fig 16. Temperature coefficient of temperature sense diode as a function of forward voltage; typical values © BUK7905-40ATE_2 Product data sheet Rev. 02 — 10 February 2009 Nexperia B.V. 2017. All rights reserved 10 of 15 BUK7905-40ATE Nexperia N-channel TrenchPLUS standard level FET 03ni91 100 ID (A) 80 60 40 175 °C 20 Tj = 25 °C 0 0.0 0.4 0.8 1.2 VSD (V) 1.6 Fig 17. Drain current as a function of source-drain diode voltage; typical values © BUK7905-40ATE_2 Product data sheet Rev. 02 — 10 February 2009 Nexperia B.V. 2017. All rights reserved 11 of 15 BUK7905-40ATE Nexperia N-channel TrenchPLUS standard level FET 7. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 5-lead TO-220 SOT263B E p1 A ∅p A1 q D1 mounting base D L1 Q L2 m L 1 5 e b c w M 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b c D D1 E e L mm 4.5 4.1 1.39 1.27 0.85 0.70 0.7 0.4 15.8 15.2 6.4 5.9 10.3 9.7 1.7 15.0 13.5 L1 (1) 2.4 1.6 (2) L2 0.5 m ∅p p1 q Q w 0.8 0.6 3.8 3.6 4.3 4.1 3.0 2.7 2.6 2.2 0.4 Notes 1. Terminal dimensions are uncontrolled in this zone. 2. Positional accuracy of the terminals is controlled in this zone. OUTLINE VERSION SOT263B REFERENCES IEC JEDEC EIAJ EUROPEAN PROJECTION ISSUE DATE 01-01-11 5-lead TO-220 Fig 18. Package outline SOT263B (TO-220) © BUK7905-40ATE_2 Product data sheet Rev. 02 — 10 February 2009 Nexperia B.V. 2017. All rights reserved 12 of 15 BUK7905-40ATE Nexperia N-channel TrenchPLUS standard level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes BUK7905-40ATE_2 20090210 Product data sheet - BUK71_7905_40ATE-01 Modifications: BUK71_7905_40ATE-01 (9397 750 11694) • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Type number BUK7905-40ATE separated from data sheet BUK71_7905_40ATE-01. 20030820 Product data sheet - © BUK7905-40ATE_2 Product data sheet - Rev. 02 — 10 February 2009 Nexperia B.V. 2017. All rights reserved 13 of 15 BUK7905-40ATE Nexperia N-channel TrenchPLUS standard level FET 9. Legal information 9.1 Data sheet status Document status [1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 9.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com © BUK7905-40ATE_2 Product data sheet Rev. 02 — 10 February 2009 Nexperia B.V. 2017. All rights reserved 14 of 15 Nexperia BUK7905-40ATE N-channel TrenchPLUS standard level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .5 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . .12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .13 Legal information. . . . . . . . . . . . . . . . . . . . . . . .14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .14 Contact information. . . . . . . . . . . . . . . . . . . . . .14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 February 2009
BUK7905-40ATE,127 价格&库存
很抱歉,暂时无法提供与“BUK7905-40ATE,127”相匹配的价格&库存,您可以联系我们找货
