E33201
E33201
    IFM(易福门)
    PROCESS ADAPTER TRI-CLAMP; SENSO
E33201 数据手册
E33201 Process adapter Tri-Clamp ADAPT IFM-CLAMP ISO2852 1-1.5" Application Pressure rating [bar] 16 Tests / approvals Pressure Equipment Directive A possible classification to PED depends on the application and has to be carried out by the user / operator. Pressure Equipment Directive EAC The adapter is intended for use in devices, machines and installations that do not fall under the categories of the technical rule TR CU 032/2013. The compatibility between medium and product material has to be checked in all applications. Safety instructions Mechanical data Weight [g] Materials (wetted parts) 100.5 stainless steel (1.4435 / 316L) ; surface characteristics : Ra
E33201 价格&库存
很抱歉,暂时无法提供与“E33201”相匹配的价格&库存,您可以联系我们找货
