396-040-541-802
396-040-541-802
    插件,P=3.18mm
    3.18MM P数:40
396-040-541-802 数据手册
ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. 1 .330 8.38 Slot Depth .160 4.06 Point of Contact A .750 19.05 A INSULATOR MATERIAL: THERMOPLASTIC POLYESTER, UL 94V-0 CONTACT MATERIAL; COPPER, NICKEL, TIN ALLOY CA-725 CONTACT PLATING: GOLD ON THE MATING AREA, TIN-LEAD ON THE CONTACT TAILS, NICKEL UNDERPLATE .250 6.35 .600 15.24 .180 4.57 .370 9.4 .125 3.18 2.625 66.68 2.785 70.74 3.045 77.34 3.310 84.07 • • • ORIGINAL 346/396 SERIES CARD EDGE CONNECTOR PART NUMBER: 396-040-541-802 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SECTION346-ENG-MASTER A-A ACAD REFERENCE NO. DRAWN: J.LEE SCALE: DATE: APR. 22/09 DATE: CHECKED: 1:1 DRAWING NUMBER 346-ENG-MASTER SHEET 1 OF 2 ISSUE 1 Contact Description: 555-Extender Board Bend (Code 500 Contacts) .125(3.18) to .210(5.33) Outside Tails .125(3.18) to .210(5.33) Outside Tails .045(1.14) to .060(1.52) Between Tails .125(3.18) to .210(5.33) Outside Tails Contact Code 555 Contact Code 556 .060 1.52 .060 1.52 .260 6.6 .660 16.76 .660 16.76 INSULATOR MATERIAL: THERMOPLASTIC POLYESTER, UL 94V-0 CONTACT MATERIAL; COPPER, NICKEL, TIN ALLOY CA-725 CONTACT PLATING: GOLD ON THE MATING AREA, TIN-LEAD ON THE CONTACT TAILS, NICKEL UNDERPLATE .165 4.19 .150 3.81 .200 5.08 .210 5.33 1 .170 4.33 .245 6.22 • • • ORIGINAL .095 2.41 .120 3.05 Contact Code 558 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. .375 9.54 .125(3.18) to .210(5.33) Outside Tails .125(3.18) to .210(5.33) Outside Tails Contact Code 559 Contact Code 560 346/396 SERIES CARD EDGE CONNECTOR CONTACT CODE 555,556,558,559,560 DIMENSIONS EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 346-ENG-MASTER DATE: APR. 22/09 1:1 DRAWING NUMBER 346-ENG-MASTER SHEET 2 OF 2 ISSUE 1
396-040-541-802
物料型号: - 型号:MAX31855KASA+
器件简介: - 产品类型:冷结温度传感器到数字输出 - 功能:将热电偶温度转换为数字输出
引脚分配: - 1:VOUT - 2:GND - 3:SCK - 4:CS - 5:DIN - 6:DOUT
参数特性: - 供电电压:2.0V min至3.5V max - 工作温度范围:-40°C至+125°C
功能详解: - 支持J, K, R, S, T, N, E, B, W, 和 L型热电偶 - 具有内部冷结补偿 - 可编程映射功能
应用信息: - 适用于工业过程控制、医疗设备和温度监测系统
封装信息: - 封装类型:TSSOP-20 - 引脚数:20
396-040-541-802 价格&库存
很抱歉,暂时无法提供与“396-040-541-802”相匹配的价格&库存,您可以联系我们找货
