2N7639-GA
2N7639-GA
    GENESICSEMICONDUCTOR
    TO257-3
    TRANS SJT 650V 15A TO-257
2N7639-GA 数据手册
2N7639-GA   Normally – OFF Silicon Carbide Junction Transistor VDS VDS(ON) ID RDS(ON) Features Package          RoHS Compliant 250 °C maximum operating temperature Temperature independent switching performance Electrically isolated base-plate Gate oxide free SiC switch Suitable for connecting an anti-parallel diode Positive temperature coefficient for easy paralleling Low gate charge Low intrinsic capacitance = = = = 600 V 1.3 V 20 A 65 mΩ D G S G   D   S TO – 257 (Isolated Base-plate Hermetic Package) Advantages Applications             Low switching losses Higher efficiency High temperature operation High short circuit withstand capability Down Hole Oil Drilling, Geothermal Instrumentation Hybrid Electric Vehicles (HEV) Solar Inverters Switched-Mode Power Supply (SMPS) Power Factor Correction (PFC) Induction Heating Uninterruptible Power Supply (UPS) Motor Drives Maximum Ratings at Tj = 250 °C, unless otherwise specified Parameter Drain – Source Voltage Continuous Drain Current Gate Peak Current Symbol VDS ID IGM Turn-Off Safe Operating Area RBSOA Short Circuit Safe Operating Area SCSOA Reverse Gate – Source Voltage Reverse Drain – Source Voltage Power Dissipation Operating and Storage Temperature VGS VDS Ptot Tj, Tstg Conditions VGS = 0 V 145 °C < TC < 160 °C TVJ = 250 oC, IG = 1 A, Clamped Inductive Load TVJ = 250 oC, IG = 2.5 A, VDS = 400 V, Non Repetitive TC = 25 °C Values 600 20 5 ID,max = 20 @ VDS ≤ VDSmax Unit V A A 20 µs 30 40 22 -55 to 250 V V W °C A Electrical Characteristics at Tj = 250 °C, unless otherwise specified Parameter Symbol Conditions Drain – Source On Voltage VDS(ON) ID = 20 A, IG = 400 mA, Tj = 25 °C ID = 20 A, IG = 500 mA, Tj = 125 °C ID = 20 A, IG = 1000 mA, Tj = 175 °C ID = 20 A, IG = 1000 mA, Tj = 250 °C Drain – Source On Resistance RDS(ON) ID = 20 A, IG = 400 mA, Tj = 25 °C ID = 20 A, IG = 500 mA, Tj = 125 °C ID = 20 A, IG = 1000 mA, Tj = 175 °C ID = 20 A, IG = 1000 mA, Tj = 250 °C Gate Forward Voltage VGS(FWD) IG = 1000 mA, Tj = 25 °C IG = 1000 mA, Tj = 250 °C β VDS = 5 V, ID = 20 A, Tj = 25 °C VDS = 5 V, ID = 20 A, Tj = 125 °C VDS = 5 V, ID = 20 A, Tj = 175 °C VDS = 5 V, ID = 20 A, Tj = 250 °C min. Values typ. max. Unit On Characteristics DC Current Gain Dec 2013   http://www.genesicsemi.com/index.php/hit-sic/sjt 1.3 1.8 2.2 3.3 65 91 110 165 3.0 2.7 110 78 73 69 V mΩ V Pg1 of 7 2N7639-GA   Off Characteristics Drain Leakage Current IDSS Gate Leakage Current ISG 10 50 100 20 VR = 600 V, VGS = 0 V, Tj = 25 °C VR = 600 V, VGS = 0 V, Tj = 175 °C VR = 600 V, VGS = 0 V, Tj = 250 °C VSG = 20 V, Tj = 25 °C µA nA Electrical Characteristics at Tj = 250 °C, unless otherwise specified Parameter Symbol Conditions Cgs Ciss Crss/Coss VGS = 0 V, f = 1 MHz VGS = 0 V, VD = 1 V, f = 1 MHz VD = 1 V, f = 1 MHz min. Values typ. max. Unit Capacitance Characteristics Gate-Source Capacitance Input Capacitance Reverse Transfer/Output Capacitance 2400 3700 840 pF pF pF 92 42 51 31 811 96 907 91 17 50 21 100 40 140 ns ns ns ns µJ µJ µJ ns ns ns ns µJ µJ µJ 1.16 °C/W Switching Characteristics Turn On Delay Time Rise Time Turn Off Delay Time Fall Time Turn-On Energy Per Pulse Turn-Off Energy Per Pulse Total Switching Energy Turn On Delay Time Rise Time Turn Off Delay Time Fall Time Turn-On Energy Per Pulse Turn-Off Energy Per Pulse Total Switching Energy td(on) tr td(off) tf Eon Eoff Ets td(on) tr td(off) tf Eon Eoff Ets VDD = 400 V, ID = 20 A, VGS = -8/15 V ,Tj = 175 ºC Refer to Figure 15 for gate drive current waveforms VDD = 400 V, ID = 20 A, VGS = -8/15 V ,Tj = 250 ºC Refer to Figure 15 for gate drive current waveforms Thermal Characteristics Thermal resistance, junction - case RthJC Figures Figure 1: Typical Output Characteristics at 25 °C Dec 2013   Figure 2: Typical Output Characteristics at 125 °C http://www.genesicsemi.com/index.php/hit-sic/sjt Pg2 of 7 2N7639-GA   Figure 3: Typical Output Characteristics at 250 °C Figure 4: Typical Gate Source I-V Characteristics vs. Temperature Figure 5: Normalized On-Resistance and Current Gain vs. Temperature Figure 6: Typical Blocking Characteristics Figure 7: Capacitance Characteristics Figure 8: Capacitance Characteristics Dec 2013   http://www.genesicsemi.com/index.php/hit-sic/sjt Pg3 of 7 2N7639-GA   Figure 9: Typical Hard-switched Turn On Waveforms Figure 10: Typical Hard-switched Turn Off Waveforms Figure 11: Typical Turn On Energy Losses and Switching Times vs. Temperature Figure 12: Typical Turn Off Energy Losses and Switching Times vs. Temperature Figure 13: Typical Turn On Energy Losses vs. Drain Current Figure 14: Typical Turn Off Energy Losses vs. Drain Current Dec 2013   http://www.genesicsemi.com/index.php/hit-sic/sjt Pg4 of 7 2N7639-GA   1 Figure 15: Typical Gate Current Waveform Figure 16: Typical Hard Switched Device Power Loss vs. 1 Switching Frequency Figure 17: Power Derating Curve Figure 18: Forward Bias Safe Operating Area at Tc=145 C Figure 19: Turn-Off Safe Operating Area Figure 20: Transient Thermal Impedance – Representative values based on device switching energy loss. Actual losses will depend on gate drive conditions, device load, and circuit topology. Dec 2013   o http://www.genesicsemi.com/index.php/hit-sic/sjt Pg5 of 7 2N7639-GA   Gate Drive Technique (Option #1) To drive the 2N7639-GA with the lowest gate drive losses, please refer to the dual voltage source gate drive configuration described in Application Note AN-10B (http://www.genesicsemi.com/index.php/references/notes). Gate Drive Technique (Option #2) The 2N7639-GA can be effectively driven using the IXYS IXDN614 / IXDD614 non-inverting gate driver IC or a comparable product. A typical gate driver configuration along with component values using this driver is offered below. Additional information is available in GeneSiC Application Note AN-10A and from the manufacturer at www.ixys.com. Figure 21: Recommended Gate Diver Configuration (Option #2) Parameter Symbol Conditions min. Values typ. max. Unit Option #1 Gate Drive Conditions (IXDD614/IXDN614) Supply Voltage, High Side Driver Supply Voltage, Low Side Driver Off State Voltage, Both Drivers Gate Control Input Signal, Low Gate Control Input Signal, High Enable, Low Enable, High Output Voltage, Low Output Voltage, High Output Current, Peak Output Current, Continuous VCC VCC GND IN IN EN EN VOUT VOUT IOUT IOUT VGH VGL VEE 15 5 -5.0 4 IXDD614 Only IXDD614 Only 20 6.5 -10 0 5.0 30 0 0.8 VCC+0.3 1/3*VCC 2/3*VCC 0.025 VCC-0.025 Package Limited 0.5 14 4.0 V V V V V V V V V A A Passive Gate Components Gate Resistance Gate Capacitance Dec 2013   RG CG VGL = 6.0 V, IG ≈ 0.5 A VGH = 20 V, IG,pk ≈ 4.0 A http://www.genesicsemi.com/index.php/hit-sic/sjt 20 1.6 35 5 Ω nF Pg6 of 7 2N7639-GA   Package Dimensions: TO-257 PACKAGE OUTLINE NOTE 1. CONTROLLED DIMENSION IS INCH. DIMENSION IN BRACKET IS MILLIMETER. 2. DIMENSIONS DO NOT INCLUDE END FLASH, MOLD FLASH, MATERIAL PROTRUSIONS Revision History Date Revision Comments 2013/12/09 2 Updated Electrical Characteristics 2013/11/18 1 Updated Electrical Characteristics 2012/08/24 0 Initial release Supersedes Published by GeneSiC Semiconductor, Inc. 43670 Trade Center Place Suite 155 Dulles, VA 20166 GeneSiC Semiconductor, Inc. reserves right to make changes to the product specifications and data in this document without notice. GeneSiC disclaims all and any warranty and liability arising out of use or application of any product. No license, express or implied to any intellectual property rights is granted by this document. Unless otherwise expressly indicated, GeneSiC products are not designed, tested or authorized for use in life-saving, medical, aircraft navigation, communication, air traffic control and weapons systems, nor in applications where their failure may result in death, personal injury and/or property damage. Dec 2013   http://www.genesicsemi.com/index.php/hit-sic/sjt Pg7 of 7 2N7639-GA   SPICE Model Parameters Copy the following code into a SPICE software program for simulation of the 2N7639-GA device. * MODEL OF GeneSiC Semiconductor Inc. * * $Revision: 1.0 $ * $Date: 06-SEP-2013 $ * * GeneSiC Semiconductor Inc. * 43670 Trade Center Place Ste. 155 * Dulles, VA 20166 * http://www.genesicsemi.com/index.php/hit-sic/sjt * * COPYRIGHT (C) 2013 GeneSiC Semiconductor Inc. * ALL RIGHTS RESERVED * * These models are provided "AS IS, WHERE IS, AND WITH NO WARRANTY * OF ANY KIND EITHER EXPRESSED OR IMPLIED, INCLUDING BUT NOT LIMITED * TO ANY IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A * PARTICULAR PURPOSE." * Models accurate up to 2 times rated drain current. * .model 2N7639-GA NPN + IS 6.03E-47 + ISE 1.72E-28 + EG 3.23 + BF 122 + BR 0.55 + IKF 300 + NF 1 + NE 1.868 + RB 0.26 + RE 0.088 + RC 0.01 + CJC 5.68E-10 + VJC 2.978967839 + MJC 0.466424924 + CJE 1.72E-09 + VJE 2.77859888 + MJE 0.48415 + XTI 3 + XTB -0.78 + TRC1 7.00E-02 + VCEO 600 + ICRATING 20 + MFG GeneSiC_Semiconductor * * End of 2N7639-GA SPICE Model Dec 2013   http://www.genesicsemi.com/index.php/hit-sic/sjt Pg1 of 1
2N7639-GA 价格&库存
很抱歉,暂时无法提供与“2N7639-GA”相匹配的价格&库存,您可以联系我们找货
