MGV High Current Molded SMT Power Inductors
MGV0302 Series
FEATURES AND APPLICATIONS
Laird MGV series high current power inductors improve performance, reliability and power efficiency.
A lower profile benefits consumer electronics and telecom design. Products feature extremely low
DCR with greater efficiency and enable a large current in a small size. Inductors are of magnetic
shielding and molded construction and perform in operating temperatures ranging from -40 C to 125 C
including self-heating rise in temperature.
FEATURES
Magnetic shielded structure
Low DCR and high efficiency
Low profile and miniaturization
High reliability
APPLICATIONS
DC-DC Converter and Power Suppliers
LCD TV’S and Gaming Console
Tablet, Notebooks, Servers and Printers
Networking and Data storage
GPS, Set-top-box and Base stations
Smart meters and Medical instruments
PART NUMBER EXPLANATION
MGV 0302
Product series
code
Product size
code
4R7
Inductance
value code
(i.e. 4R7: 4.7
M - 10
Tolerance %
(i.e. M:
20%)
Standard
Catalog P.N
Note: Automotive grade parts are also available, a specific P.N will be assigned upon request.
Please contact laird local sales for details.
ELECTRICAL SPECIFICATIONS
• Tolerance: M: ±20% or N: ±30%
• Inductance tested at 100KHz, 1.0V
• Heat Rated Current (Irms) is defined based on temperature rise approximate 40°C without core loss
(ambient temperature 25±5°C)
• Saturation Current (Isat) is the DC current at which the inductance drops off approximately 30% from
its value without current. (ambient temperature 25±5°C)
• Operating temperature range: -40°C~+125°C (including self-heating temperature rise)
• Storage temperature range (packaging conditions): -10°C~+40°C and RH 60%(MAX.)
Note: Heat Rated Current (Irms) is tested on a typical PCB and apply a constant current in still air.
The temperature rise is dependent on the application system condition including PCB PAD pattern,
trace width and thickness and adjacent components etc. It’s suggested to verify the temperature
rise of the component under the real operation application conditions.
Laird Performance Materials
www.laird.com
MGV0302 Series
Rev: B
SPECIFICATION FOR APPROVAL
(UNIT: mm)
A
100
1.MECHANICAL & DIMENSIONS
E
B
C
D
A
3.50±0.20
B
3.20±0.20
C
1.80±0.20
D
1.20±0.20
E
0.70±0.20
L
4.10 ref
G
1.90 ref
H
1.45 ref
L
REMARK
G
H
2.PART NUMBER NOMENCLATOR:
MGV 0302
A
B
100
C
A: Product Series.
M - 1X
D
E
D: Inductance Tolerance. (M=±20% ,N=±30%)
E: "X"=0:Standard catalog part number
"X"=1-9:Controlled customized part or different
B: Series number, part size
performance than std catalog part. And "5-9" is
C: Inductance code
for automotive grade.
3.EQUIVALENT CIRCUIT:
www.laird.com
MGV0302 Series
Rev: B
PART NUMBER
INDUCTANCE
(uH)
MGV0302R10N-10
0.10±30%
10.5
14.0
6.6
9.0
MGV0302R22N-10
0.22±30%
9.0
11.2
11.0
14.0
MGV0302R47M-10
0.47±20%
7.0
9.0
19.7
23.0
MGV0302R68M-10
0.68±20%
5.5
7.0
25.5
29.0
MGV0302R82M-10
0.82±20%
4.8
6.0
27.0
32.0
MGV03021R0M-10
1.00±20%
4.0
5.0
32.0
38.0
MGV03021R2M-10
1.20±20%
3.9
4.5
39.0
47.0
MGV03021R5M-10
1.50±20%
3.8
4.0
42.0
50.0
MGV03022R2M-10
2.20±20%
3.5
3.7
65.0
75.0
MGV03023R3M-10
3.30±20%
3.0
3.5
125
145
MGV03024R7M-10
4.70±20%
2.6
3.0
172
200
MGV03026R8M-10
6.80±20%
1.9
2.2
260
300
MGV0302100M-10
10.0±20%
1.4
1.6
366
422
Irms(A) Typ. Isat(A) Typ. DCR(mΩ) Typ DCR(mΩ) Max
REMARK
GENERAL SPECIFICATION:
1, Test conditions(L): 100KHz, 1Vrms
2, Operating temperature: -55℃ to +125℃(Including self-heating)
3, Storage temperature: -10℃ to +40℃
4, Humidity range: 60% RH Max.
5, Heat Rated Current (Irms) will cause the coil temperature rise approximately ∆t of 40°C
6, Saturation Current (Isat) will cause L0 to drop approximately 30%.
7, Part Temperature (Ambient+Temp. Rise) : Should not exceed 125°C under worst case operating conditions.
8, Storage condition (component in its packaging)
www.laird.com
MGV0302 Series
Rev: B
Characteristics Curve
40
0.09
30
0.06
10
12
40
0.15
30
0.10
10
3
6
0.48
40
0.36
30
0.24
10
0.00
Inductance (uH)
50
6
8
1.00
50
0.80
40
0.60
30
0.40
10
0.00
10
IDC(A)
40
0.60
30
0.40
10
0.00
IDC(A)
6.4
8
Inductance (uH)
0.80
3.2
6
8
10
MGV03021R0M-10
50
Temperature Rise (℃)
Inductance (uH)
MGV0302R82M-10
1.6
4
IDC(A)
1.00
MGV0302R68M-10
0.60
Inductance (uH)
MGV0302R47M-10
2
12
IDC(A)
IDC(A)
6
0.20
1.50
50
1.20
40
0.90
30
0.60
10
0.00
3.2
4.8
IDC(A)
6.4
8
3
50
0.00
0.12
Inductance (uH)
MGV0302R22N-10
50
Inductance (uH)
MGV0302R10N-10
0.15
www.laird.com
MGV0302 Series
Rev: B
40
0.90
30
0.60
10
0.00
4.8
6.4
50
1.60
40
1.20
30
0.80
10
0.00
1.2
2.4
50
2.40
40
1.80
30
1.20
10
0.00
Inductance (uH)
3.00
5.00
50
4.00
40
3.00
30
2.00
10
0.00
6
IDC(A)
40
3.60
30
2.40
10
0.00
6
Inductance (uH)
4.80
Inductance (uH)
50
IDC(A)
6
MGV03026R8M-10
6.00
2
4
IDC(A)
MGV03024R7M-10
MGV03023R3M-10
Inductance (uH)
MGV03022R2M-10
2
4.8
IDC(A)
IDC(A)
1.6
2.00
10.00
50
8.00
40
6.00
30
4.00
10
0.00
1.6
2.4
IDC(A)
3.2
4
Inductance (uH)
1.20
Inductance (uH)
50
MGV03021R5M-10
MGV03021R2M-10
1.50
www.laird.com
15.00
50
12.00
40
9.00
30
6.00
10
0.00
0.8
1.2
IDC(A)
1.6
2
Inductance (uH)
MGV0302100M-10
MGV0302 Series
Rev: B
www.laird.com
MGV0302 Series
Recommended Soldering Conditions
■ For Lead-Free Application
Figure 1 . Re-flow Soldering
Within 4 sec
Reflow times: 3 times max
Figure 2 . Hand Soldering
P R E - H E A T IN G
S O L D E R IN G
NATURAL
C O O L IN G
280
TEMPERATURE C
150
O v e r 1 m in .
G r a d u a l C o o lin g
W ith in 3 s e c .
Hand solder times: 1 time max
Rev: B
www.laird.com MGV0302 Series
Reliability and Testing Conditions / Pin Type Power Inductors
Rev: B
SMD series(Consumer)
Item
Reference
Additional Requirements
-55℃~ +125℃(Including self-temperature rise)
range
Storage temperature
and humidity range
High Temperature
Exposure
(Storage)
-10℃ to +40℃ , 60% RH Max
MIL-STD-202 Method 108
85±2℃, 168+24hours
JESD22 Method JA-104
-40℃→+85, transforming interval:20s, 100cycles
Operational Life
MIL-PRF-2
85±℃, 168+24hours
Apply maximum rated voltage and current according part drawing
External Visual
MIL-STD-883 Method 2009
Inspect device construction, marking and workmanship. Electrical
Test not required.
JESD22 Method JB-100
Verify physical dimensions to the applicable device detail
specification. Note: User(s) and Suppliers spec. Electrical Test
not required
MIL-STD-202
Method 204
10~55Hz,1.5mm,
2 hours in each 3mutually
perpendicular directions
(total of 6 hours)
Temperature Cycling
Physical Dimension
Vibration
Resistance to Soldering MIL-STD-202
Method 210
Heat
1. Max. 260±5℃,10±1s, 2 times
2.Solder Composition: Sn/3Ag/0.5Cu
Solderability
J-STD-002
245±5℃, 5±1sec, Solder: Sn/3.0Ag/0.5Cu
Electrical
Characterization
Print Spec
Parametrically test per lot and sample size requirements,
summary to show Min, Max, Mean and Standard deviation at
room as well as Min and Max Operating temperatures
AEC-Q200-005
2mm,30±1s
Board Flex
Terminal Strength(SMD) AEC-Q200-006
10N, 5S, X,Y direct
www.laird.com
MGV0302 Series
Rev: B
PACKAGING
Reel Dimension
Type A(mm) B(mm)
C(mm)
D(mm)
13'x12 12.4+2/-0 100 ± 2
13+0.5/-0.2
330
B
D
C
A
Tape Dimension
W
E
F
P
A0
B0
P2
12.0±0.3
1.75±0.1
5.5±0.1
8±0.1
3.5±0.1
3.8±0.1
2.0±0.1
P0
K0
t
D0
4.0±0.1 2.3±0.1 0.35±0.05 1.5Ref.
Packaging Quantity
P/N
MGV0302 Series
Size
Chip/Reel
Inner Box
Outer Box
3000pcs
6000pcs
12000pcs
Peeling Off Force
The force peeling off cove tape is 10 to 100 grams
in the arrow direction under the following conditions
Room Temp
Room
Humidity
Room atrn
(hPa)
Teaming
Speed
5~35
45~85
860~1060
300
※Storage Conditions
1. Temperature and humidity conditions: -10-+40℃
and 60% RH.
2. Recommended products should be used within 12 months
from the time of manufacturing.
3. The packaging material should be kept where no chlorine
or sulfur exists in the air.
4. Allowable stacking condition of Packaging box:max height 1.5m or 5 boxes stacking
很抱歉,暂时无法提供与“MGV0302R47M-10”相匹配的价格&库存,您可以联系我们找货
