TKS 40X60
TKS 40X60
    LEUZE(劳易测)
    REFLECTOR
TKS 40X60 数据手册
Technical data sheet Reflector Part no.: 50040820 TKS 40X60 Contents - Technical data - Dimensioned drawings Figure can vary Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-03-25 1/2 Reflector • Part no.: 50040820 • TKS 40X60 Technical data Mechanical data Environmental data Design Rectangular Triple reflector size 4 mm Mounting dimension, width 41 mm Certifications Mounting dimension, height 60 mm Degree of protection Mounting dimension, thickness 8 mm Reflection surface height 56 mm Reflection surface width 37 mm Reflector material Plastic Material of base material Plastic Polarization-changing Yes Chemical designation, reflector material PMMA8N Structure, active surface Net weight Type of fastening Triple 14 g Adhesive Through-hole mounting Ambient temperature, operation -40 ... 65 °C IP 67 Classification Customs tariff number 90029000 eCl@ss 5.1.4 27279203 eCl@ss 8.0 27279203 eCl@ss 9.0 27273601 eCl@ss 10.0 27273601 eCl@ss 11.0 27273601 ETIM 5.0 EC002467 ETIM 6.0 EC002467 ETIM 7.0 EC002467 Dimensioned drawings All dimensions in millimeters Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-03-25 2/2
TKS 40X60 价格&库存
很抱歉,暂时无法提供与“TKS 40X60”相匹配的价格&库存,您可以联系我们找货
