KD U-M83W-V2110-100
KD U-M83W-V2110-100
    LEUZE(劳易测)
    CONNECTION CABLE
KD U-M83W-V2110-100 数据手册
Technical data sheet Connection cable Part no.: 50140222 KD U-M83W-V2110-100 Contents - Technical data - Electrical connection - Circuit diagrams Figure can vary Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 1/3 Connection cable • Part no.: 50140222 • KD U-M83W-V2110-100 Technical data Electrical data Mechanical data Performance data Operating voltage Width across flats 9.6 mm Bending cycles 1,000,000 Piece(s) Max. 60 V AC/DC Operation and display Connection Environmental data Connection 1 Type of connection Connector Thread size M8 Type Female Handle body material TPU No. of pins 3 -pin Version Angled Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking -10 ... 80 °C Ambient temperature, operation, stationary use -30 ... 80 °C Certifications IP 65 Degree of protection Connection 2 Type of connection Ambient temperature, operation, flexible use IP 67 NEMA 6P Classification Open end Cable properties Customs tariff number 85444290 eCl@ss 5.1.4 27279201 Number of conductors 3 Piece(s) eCl@ss 8.0 27279218 Wire cross section 0.34 mm² eCl@ss 9.0 27060311 AWG 22 eCl@ss 10.0 27060311 Sheathing color Yellow eCl@ss 11.0 27060311 Shielded No ETIM 5.0 EC001855 Silicone-free Yes ETIM 6.0 EC001855 Cable design Connection cable (open on one end) ETIM 7.0 EC001855 Cable length 10,000 mm Sheathing material TPE Wire insulation SR-PVC Suitability for drag chains No Electrical connection Connection 1 Type of connection Connector Thread size M8 Type Female Handle body material TPU No. of pins 3 -pin Version Angled Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Connection 2 Open end Type of connection Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 2/3 Connection cable • Part no.: 50140222 • KD U-M83W-V2110-100 Circuit diagrams Wiring schematic 1 D 4 E a Brown wire b Black wire c Blue wire 3 F Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 3/3
KD U-M83W-V2110-100 价格&库存
很抱歉,暂时无法提供与“KD U-M83W-V2110-100”相匹配的价格&库存,您可以联系我们找货
