KD U-M83W-V2110-050
KD U-M83W-V2110-050
    LEUZE(劳易测)
    CONNECTION CABLE
KD U-M83W-V2110-050 数据手册
Technical data sheet Connection cable Part no.: 50140221 KD U-M83W-V2110-050 Contents - Technical data - Electrical connection - Circuit diagrams Figure can vary Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 1/3 Connection cable • Part no.: 50140221 • KD U-M83W-V2110-050 Technical data Electrical data Mechanical data Performance data Operating voltage Width across flats 9.6 mm Bending cycles 1,000,000 Piece(s) Max. 60 V AC/DC Operation and display Connection Environmental data Connection 1 Type of connection Connector Thread size M8 Type Female Handle body material TPU No. of pins 3 -pin Version Angled Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking -10 ... 80 °C Ambient temperature, operation, stationary use -30 ... 80 °C Certifications IP 65 Degree of protection Connection 2 Type of connection Ambient temperature, operation, flexible use IP 67 NEMA 6P Classification Open end Cable properties Customs tariff number 85444290 eCl@ss 5.1.4 27279201 Number of conductors 3 Piece(s) eCl@ss 8.0 27279218 Wire cross section 0.34 mm² eCl@ss 9.0 27060311 AWG 22 eCl@ss 10.0 27060311 Sheathing color Yellow eCl@ss 11.0 27060311 Shielded No ETIM 5.0 EC001855 Silicone-free Yes ETIM 6.0 EC001855 Cable design Connection cable (open on one end) ETIM 7.0 EC001855 Cable length 5,000 mm Sheathing material TPE Wire insulation SR-PVC Suitability for drag chains No Electrical connection Connection 1 Type of connection Connector Thread size M8 Type Female Handle body material TPU No. of pins 3 -pin Version Angled Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Connection 2 Open end Type of connection Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 2/3 Connection cable • Part no.: 50140221 • KD U-M83W-V2110-050 Circuit diagrams Wiring schematic 1 D 4 E a Brown wire b Black wire c Blue wire 3 F Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 3/3
KD U-M83W-V2110-050
1. 物料型号:50140221,KD U-M83W-V2110-050。 2. 器件简介:文档描述了一种连接电缆,适用于电气连接。 3. 引脚分配:电缆具有3个引脚,其中连接1为M8螺纹尺寸的母头,连接2为开口端。 4. 参数特性: - 操作电压:最大60V AC/DC。 - 工作温度范围:-10°C至80°C(灵活使用),-30°C至80°C(固定使用)。 - 弯曲周期:未提供具体数据。 - 保护等级:IP65和IP67,NEMA6P。 5. 功能详解:电缆设计为一端开口,另一端带有3针连接器,适用于拖链。 6. 应用信息:电缆长度为5000mm,护套材料为TPE,导线绝缘材料为SR-PVC,不适用于拖链。 7. 封装信息:电缆的护套颜色为黄色,未屏蔽,无硅。 8. 电气连接:详细描述了两种连接类型,包括连接器的类型、螺纹尺寸、材料等。 9. 电路图:提供了接线图,标识了棕色、黑色和蓝色电线。
KD U-M83W-V2110-050 价格&库存
很抱歉,暂时无法提供与“KD U-M83W-V2110-050”相匹配的价格&库存,您可以联系我们找货
