KS U-M125A-T2712-150
    LEUZE(劳易测)
    CONNECTION CABLE
KS U-M125A-T2712-150 数据手册
Technical data sheet Connection cable Part no.: 50140508 KS U-M125A-T2712-150 Contents - Technical data - Electrical connection - Circuit diagrams Figure can vary Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 1/3 Connection cable • Part no.: 50140508 • KS U-M125A-T2712-150 Technical data Electrical data Mechanical data Performance data Operating voltage Width across flats 14.5 mm Bending cycles 1,000,000 Piece(s) Max. 60 V AC/DC Operation and display Connection Environmental data Connection 1 Type of connection Connector Thread size M12 Type Male Handle body material TPU IP 67 No. of pins 5 -pin NEMA 6P Encoding A-coded Version Axial Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Certifications IP 65 Degree of protection Classification Customs tariff number 85444290 eCl@ss 5.1.4 27279201 eCl@ss 8.0 27279218 eCl@ss 9.0 27060311 eCl@ss 10.0 27060311 eCl@ss 11.0 27060311 5 Piece(s) ETIM 5.0 EC001855 Wire cross section 0.34 mm² ETIM 6.0 EC001855 AWG 22 ETIM 7.0 EC001855 Sheathing color Yellow Shielded No Silicone-free Yes Cable design Connection cable (open on one end) Cable length 15,000 mm Sheathing material TPE Wire insulation PVC Suitability for drag chains Yes Traverse rate Max. 3.3 m/s with horiz. traverse path of 5m and and max. acceleration of 5m/s² Connection 2 Type of connection Open end Cable properties Number of conductors Electrical connection Connection 1 Type of connection Connector Thread size M12 Type Male Handle body material TPU No. of pins 5 -pin Encoding A-coded Version Axial Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Connection 2 Open end Type of connection Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 2/3 Connection cable • Part no.: 50140508 • KS U-M125A-T2712-150 Circuit diagrams Wiring schematic 1 D 2 a Brown wire b White wire c Black wire d Blue wire e Gray wire E 4 F 3 G 5 H Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 3/3
KS U-M125A-T2712-150 价格&库存
很抱歉,暂时无法提供与“KS U-M125A-T2712-150”相匹配的价格&库存,您可以联系我们找货
