KD U-M124A-T2104-050
    LEUZE(劳易测)
    CONNECTION CABLE
KD U-M124A-T2104-050 数据手册
Technical data sheet Connection cable Part no.: 50140457 KD U-M124A-T2104-050 Contents - Technical data - Electrical connection - Circuit diagrams Figure can vary Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 1/3 Connection cable • Part no.: 50140457 • KD U-M124A-T2104-050 Technical data Electrical data Mechanical data Performance data Operating voltage Width across flats 14.5 mm Bending cycles 1,000,000 Piece(s) Max. 250 V AC/DC Operation and display Connection Environmental data Connection 1 Type of connection Connector Thread size M12 Type Female Handle body material TPU No. of pins 4 -pin Encoding A-coded Version Axial Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking -15 ... 90 °C Ambient temperature, operation, stationary use -35 ... 105 °C Certifications IP 65 Degree of protection IP 67 NEMA 6P Classification Connection 2 Type of connection Ambient temperature, operation, flexible use Open end Cable properties Customs tariff number 85444290 eCl@ss 5.1.4 27279201 eCl@ss 8.0 27279218 Number of conductors 4 Piece(s) eCl@ss 9.0 27060311 Wire cross section 0.82 mm² eCl@ss 10.0 27060311 AWG 18 eCl@ss 11.0 27060311 Sheathing color Yellow ETIM 5.0 EC001855 Shielded No ETIM 6.0 EC001855 Silicone-free Yes ETIM 7.0 EC001855 Cable design Connection cable (open on one end) Cable length 5,000 mm Sheathing material TPE Wire insulation PVC Suitability for drag chains Yes Traverse rate Max. 3.3 m/s with horiz. traverse path of 5m and and max. acceleration of 5m/s² Electrical connection Connection 1 Type of connection Connector Thread size M12 Type Female Handle body material TPU No. of pins 4 -pin Encoding A-coded Version Axial Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Connection 2 Open end Type of connection Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 2/3 Connection cable • Part no.: 50140457 • KD U-M124A-T2104-050 Circuit diagrams Wiring schematic 1 D 2 E 4 a Brown wire b White wire c Black wire d Blue wire F 3 G Leuze electronic GmbH + Co. KG info@leuze.com • www.leuze.com We reserve the right to make technical changes In der Braike 1, 73277 Owen Phone: +49 7021 573-0 • Fax: +49 7021 573-199 eng • 2021-01-13 3/3
KD U-M124A-T2104-050 价格&库存
很抱歉,暂时无法提供与“KD U-M124A-T2104-050”相匹配的价格&库存,您可以联系我们找货
