KD U-M124A-T2100-020
    LEUZE(劳易测)
    CONNECTION CABLE
KD U-M124A-T2100-020 数据手册
Part no.: 50140391 – KD U-M124A-T2-020 – Connection cable Technical data Electrical data Performance data Operating voltage Max. 250 V AC/DC Connection Connection 1 Type of connection Connector Thread size M12 Type Female Handle body material TPU No. of pins 4 -pin Encoding A-coded Design Axial Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Connection 2 Type of connection Open end Cable properties Number of conductors 4 Piece(s) Wire cross section 0.34 mm² AWG 22 Sheathing color Yellow Shielded No Silicone-free Yes Cable design Connection cable (open on one end) Cable length 2,000 mm Sheathing material TPE Wire insulation PVC Suitability for drag chains Yes Mechanical data Width across flats 14.5 mm Bending cycles 1,000,000 Piece(s) Operation and display Environmental data Ambient temperature, operation, flexible use -15 ... 90 °C Ambient temperature, operation, stationary use -35 ... 105 °C Certifications Degree of protection IP 67 NEMA 6P IP 65 Classification eCl@ss 8.0 27279218 eCl@ss 9.0 27060311 ETIM 5.0 EC001855 Leuze electronic GmbH + Co. KG, In der Braike 1, 73277 Owen Phone: +49 7021 573-0, Fax +49 7021 573-199 info@leuze.com • www.leuze.com We reserve the right to make technical changes • eng 2018-08-14 2/3 Part no.: 50140391 – KD U-M124A-T2-020 – Connection cable Electrical connection Connection 1 Type of connection Connector Thread size M12 Type Female Handle body material TPU No. of pins 4 -pin Encoding A-coded Design Axial Connector, LED Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Connection 2 Type of connection Open end Accessories General Part no. 50132265 Designation TT-Set 0,4-9 Article Tool Leuze electronic GmbH + Co. KG, In der Braike 1, 73277 Owen Phone: +49 7021 573-0, Fax +49 7021 573-199 Description Type: Torque key Width across flats: 9 mm Torque: 0.4 N·m Material: Plastic, Stainless steel Ambient temperature: -40 ... 120 °C info@leuze.com • www.leuze.com We reserve the right to make technical changes • eng 2018-08-14 3/3
KD U-M124A-T2100-020 价格&库存
很抱歉,暂时无法提供与“KD U-M124A-T2100-020”相匹配的价格&库存,您可以联系我们找货
