AH3740A-220K
AH3740A-220K
    ITG
    SMD,9.6x6.4mm
    固定电感器 Nonstandard 220nH ±10% 78A 0.145mΩ
AH3740A-220K 数据手册
AH3740 Series 1. Features of AH3740 Series: • • • • • • • • • Ferrite based SMD inductor with lower core loss. Inductance range: 45.0 nH to 330.0 nH , custom values are welcomed. High current output chokes, up to 155.0 Amp with approx. 20% roll off. Low profile 10.00 mm Max. height (60nH,70nH,80nH and 90nH is 10.40mm Max. , 100nH is 10.20mm Max. ,120nH is 10.10mm Max.,45L,50L is 10.70mm Max.). 9.60 x 6.40 mm Foot Print. Perfect for high density designs with limited board space. Operating frequency of up to 5.0MHz. Operating temperature range of -55°C to + 130°C. RoHS & HF compliant. T & R Qty’s: 500pcs, 13'' Reel. 2. Electrical Characteristics of AH3740 Series: AH3740A-45L OCL 1 (nH) ± 10% or 15% 45.00 , 15% AH3740A-50L 50.00 , 15% ITG Part Number 60.00 70.00 80.00 90.00 100.00 120.00 150.00 180.00 220.00 270.00 300.00 330.00 AH3740A-60L AH3740A-70K AH3740A-80K AH3740A-90K AH3740A-100K AH3740A-120K AH3740A-150K AH3740A-180K AH3740A-220K AH3740A-270K AH3740A-300K AH3740A-330L , 15% , 10% , 10% , 10% , 10% , 10% , 10% , 10% , 10% , 10% , 10% , 15% L @ lsat2 (nH) Min. 32.40 DCR 3 (mΩ) ± 5% 0.145 Isat1 4 (A) @25℃ 240.00 Isat2 4 (A) @75℃ 205.00 Isat3 4 (A) @100℃ 200.00 Irms 5 (A) @25℃ 78.00 C (mm) Max. 10.70 36.00 0.145 210.00 200.00 180.00 78.00 10.70 43.20 50.40 57.60 64.80 72.00 86.40 108.00 129.60 158.40 194.40 216.00 237.60 0.145 0.145 0.145 0.145 0.145 0.145 0.145 0.145 0.145 0.145 0.145 0.145 155.00 124.00 118.00 106.00 95.00 78.00 60.00 49.00 38.00 30.00 27.00 20.00 150.00 120.00 110.00 98.00 88.00 71.00 54.00 45.00 36.00 29.00 24.00 19.00 140.00 115.00 102.00 92.00 82.00 67.00 52.00 43.00 34.00 27.00 23.00 17.00 78.00 78.00 78.00 78.00 78.00 78.00 78.00 78.00 78.00 78.00 78.00 78.00 10.40 10.40 10.40 10.40 10.20 10.10 10.00 10.00 10.00 10.00 10.00 10.00 3. Mechanical Dimension of AH3740 Series: A B Max. 6.40 C Max. Max. 9.50 See table above D Max. E (Ref.) F 10.40 A xxxxx ITGYYWW G 2.54 D B ± 0.20 ± 0.30 3.20 A Suggested Pad Layout 9.60 6.60 2.20 1.50 C a b Part Marking: A xxx x x: A is part code, xxx is inductance value in nH, x = tolerance, x is special code. ITGYYWW: ITG logo and YYWW is date code. 0.80Nom. E Notes: G F 1. Open Circuit Inductance (OCL) test condition: 500KHz , 0.25Vrms , 0A DC at 25℃. 2. L @ Isat and L @ Irms Test condition: 500KHz , 0.25Vrm (Ta=25℃). 3. The nominal DCR is measured from point “a” to point “b” as shown above in the mechanical drawing (Ta=25℃). 4. Isat1, Isat2 & Isat3: DC current that will cause inductance to drop approximately by 20%. 5. Irms: DC current for an approximate temperature rise of 40℃ without core loss. 6. Derating is necessary for AC currents. Verify and check PCB pad layout, trace thickness, width, air-flow and proximity of other heat generating components as it will have an effect on the temperature rise. 7. It is recommended that the part temperature should not exceed 130°C under worst operating conditions. ● ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision E.2: January 19, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. AH3740 Series 4. Inductance Characteristics of AH3740 Series (Inductance vs Current): AH3740A-45L 90.0 L (nH) 25℃ 45.0 75℃ 100℃ 0.0 0.0 20.0 40.0 60.0 80.0 100.0 120.0 140.0 160.0 Direct Current (A) 180.0 200.0 220.0 240.0 260.0 AH3740A-50L 75.0 L (nH) 25℃ 50.0 75℃ 25.0 100℃ 0.0 0.0 20.0 40.0 60.0 80.0 100.0 120.0 140.0 Direct Current (A) 160.0 180.0 200.0 220.0 AH3740A-60L 90.0 L (nH) 25℃ 60.0 75℃ 30.0 100℃ 0.0 L (nH) 0.0 40.0 60.0 80.0 100.0 Direct Current (A) 120.0 140.0 160.0 180.0 AH3740A-70K 80.0 70.0 60.0 50.0 40.0 30.0 20.0 10.0 0.0 25℃ 75℃ 100℃ 0.0 ● 20.0 10.0 20.0 30.0 40.0 50.0 60.0 70.0 80.0 Direct Current (A) 90.0 100.0 110.0 120.0 130.0 ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision E.2: January 19, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. AH3740 Series 4. Inductance Characteristics of AH3740 Series (Inductance vs Current): AH3740A-80K 100.0 L (nH) 80.0 25℃ 60.0 75℃ 40.0 100℃ 20.0 0.0 0.0 10.0 20.0 30.0 40.0 50.0 60.0 70.0 80.0 Direct Current (A) 90.0 100.0 110.0 120.0 130.0 AH3740A-90K 135.0 L (nH) 25℃ 90.0 75℃ 45.0 100℃ 0.0 0.0 15.0 30.0 45.0 60.0 75.0 Direct Current (A) 90.0 105.0 120.0 135.0 AH3740A-100K 120.0 L (nH) 100.0 25℃ 80.0 60.0 75℃ 40.0 100℃ 20.0 0.0 0.0 10.0 20.0 30.0 40.0 50.0 60.0 70.0 Direct Current (A) 80.0 90.0 100.0 110.0 AH3740A-120K 150.0 L (nH) 120.0 25℃ 90.0 75℃ 60.0 100℃ 30.0 0.0 0.0 ● 5.0 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 70.0 75.0 80.0 85.0 90.0 Direct Current (A) ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision E.2: January 19, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. AH3740 Series 4. Inductance Characteristics of AH3740 Series (Inductance vs Current): AH3740A-150K 180.0 L (nH) 150.0 25℃ 120.0 90.0 75℃ 60.0 100℃ 30.0 0.0 0.0 5.0 10.0 15.0 20.0 25.0 30.0 35.0 Direct Current (A) 40.0 45.0 50.0 55.0 60.0 AH3740A-180K 210.0 180.0 25℃ L (nH) 150.0 120.0 75℃ 90.0 60.0 100℃ 30.0 0.0 0.0 4.0 8.0 12.0 16.0 20.0 24.0 28.0 32.0 Direct Current (A) 36.0 40.0 44.0 48.0 52.0 56.0 AH3740A-220K 255.5 219.0 25℃ L (nH) 182.5 146.0 75℃ 109.5 73.0 100℃ 36.5 0.0 L (nH) 0.0 8.0 12.0 16.0 20.0 24.0 28.0 Direct Current (A) 32.0 36.0 40.0 44.0 48.0 AH3740A-270K 300.0 270.0 240.0 210.0 180.0 150.0 120.0 90.0 60.0 30.0 0.0 25℃ 75℃ 100℃ 0.0 ● 4.0 4.0 8.0 12.0 16.0 20.0 Direct Current (A) 24.0 28.0 32.0 36.0 ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision E.2: January 19, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. AH3740 Series L (nH) 4. Inductance Characteristics of AH3740 Series (Inductance vs Current): AH3740A-300K 340.0 297.5 255.0 212.5 170.0 127.5 85.0 42.5 0.0 25℃ 75℃ 100℃ 0.0 2.0 4.0 6.0 8.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 32.0 Direct Current (A) AH3740A-330L 385.0 330.0 25℃ L (nH) 275.0 220.0 75℃ 165.0 110.0 100℃ 55.0 0.0 0.0 ● 2.0 4.0 6.0 8.0 10.0 12.0 14.0 16.0 Direct Current (A) 18.0 20.0 22.0 24.0 26.0 28.0 ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision E.2: January 19, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase.
AH3740A-220K 价格&库存
很抱歉,暂时无法提供与“AH3740A-220K”相匹配的价格&库存,您可以联系我们找货
