SLA36385A-100L
SLA36385A-100L
    ITG
    SMD
    固定电感器 SMD-2 100nH ±15% 63A 0.125mΩ
SLA36385A-100L 数据手册
SLA36385A Series 1. Features of SLA36385A Series : • • • • • • • • • Ferrite based SMD inductor with lower core loss. Inductance Range: 35.0nH to 470.0nH, Custom values are welcomed. High current output chokes, up to 230.0 Amp with approx. 20% roll off. Low Profile 9.50 mm Max. height . Foot Print 9.00 x 5.00 mm . Perfect for high density designs with limited board space. Operating frequency up to 5.0 MHz application. Operating Temperature Range -55°C to + 130°C , RoHs & HF compliance . T & R Qtys: 500 pcs , 13'' Reel ; 2. Electrical Characteristic of SLA36385A Series: OCL 1 (nH) ± 15% or ± 20% 35.00 ± 15% 55.00 ± 15% 63.00 ± 15% 75.00 ± 15% 80.00 ± 15% 90.00 ± 15% 100.00 ± 15% 120.00 ± 15% 150.00 ± 15% 180.00 ± 15% 210.00 ± 15% 240.00 ± 15% 270.00 ± 15% 330.00 ± 15% 470.00 ± 20% ITG Part Number SLA36385A-35L SLA36385A-55L SLA36385A-63L SLA36385A-75L SLA36385A-80L SLA36385A-90L SLA36385A-100L SLA36385A-120L SLA36385A-150L SLA36385A-180L SLA36385A-210L SLA36385A-240L SLA36385A-270L SLA36385A-330L SLA36385A-470M L @ Isat1 (nH) Min. 24.50 38.50 44.10 52.50 56.00 63.00 70.00 84.00 105.00 126.00 147.00 168.00 189.00 231.00 329.00 2 DCR 3 (mΩ) ± 10% 0.125 0.125 0.125 0.125 0.125 0.125 0.125 0.125 0.125 0.125 0.125 0.125 0.125 0.125 0.125 Isat1 (A) @25℃ 230.00 155.00 140.00 110.00 97.00 90.00 80.00 72.00 58.00 49.00 38.00 33.00 30.00 23.00 16.00 Isat2 4 (A) @75℃ 200.00 140.00 130.00 102.00 90.00 82.00 72.00 68.00 53.00 43.00 35.00 31.00 28.00 20.00 15.00 Isat3 4 (A) @100℃ 180.00 130.00 120.00 93.00 85.00 77.00 70.00 64.00 51.00 42.00 33.00 30.00 26.00 19.00 14.00 Irms 5 (A) @25℃ 63.00 63.00 63.00 63.00 63.00 63.00 63.00 63.00 63.00 63.00 63.00 63.00 63.00 63.00 63.00 3. Mechanical Dimension(Unit : mm): 10.2 A B C E F G A Max. Max. Max. ± 0.30 ± 0.20 ± 0.20 S xxx xA ITGYYWW 9.00 5.00 9.50 4.00 2.40 2.50 3.9 2.9x2 B Suggested Pad Layout C Part Marking: S xxx xA: S is part code, xxx is inductance value in nH, x = tolerance, A is special code. ITGYYWW: ITG logo and YYWW is date code. Coplanarity:0.1mm Max. a Notes: b E F G 1. Open Circuit Inductance (OCL) test condition:500KHz,0.25Vrms,0Adc ,at 25 ℃. 2. L @ Isat and L @ Irms Test condition:500KHz,0.25Vrms (Ta=25 ℃). 3. The nominal DCR is measured from point "a" to point "b", as shown above on the mechanical drawing (Ta=25℃). 4. Isat1,Isat2 & Isat3 : DC current that will cause inductance to drop approximately by 20%. 5. Irms : DC current for an approximate temperature rise of 40℃ without core loss , Derating is necessary for AC currents. PCB pad layout , trace thickness and width , air-flow and proximity of other heat generating components will affect the temperature rise. It is recommended the part temperature not exceed 130 ℃ under worst case operating conditions verified in the end application. ● ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www. ITG-Electronics.com Revision C.2: June 03, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SLA36385A Series 4. Inductance Characteristics (Inductance vs Current): SLA36385A-35L 42.0 35.0 25℃ L (nH) 28.0 75℃ 21.0 14.0 100℃ 7.0 0.0 0.0 20.0 40.0 60.0 80.0 100.0 120.0 140.0 Direct Current (A) 160.0 180.0 200.0 220.0 240.0 SLA36385A-55L 82.5 25℃ L (nH) 55.0 75℃ 27.5 100℃ 0.0 0.0 15.0 30.0 45.0 60.0 75.0 90.0 105.0 Direct Current (A) 120.0 135.0 150.0 165.0 180.0 SLA36385A-63J 94.5 L (nH) 25℃ 63.0 75℃ 31.5 100℃ 0.0 0 15 30 45 60 105 120 135 150 SLA36385A-75L 100.0 L (nH) 75 90 Direct Current (A) 75.0 25℃ 50.0 75℃ 25.0 100℃ 0.0 0.0 ● 10.0 20.0 30.0 40.0 50.0 60.0 70.0 Direct Current (A) 80.0 90.0 100.0 110.0 120.0 ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www. ITG-Electronics.com Revision C.2: June 03, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SLA36385A Series 4. Inductance Characteristics (Inductance vs Current): SLA36385A-80L 100.0 L (nH) 80.0 25℃ 60.0 75℃ 40.0 100℃ 20.0 0.0 0.0 10.0 20.0 30.0 40.0 50.0 60.0 70.0 Direct Current (A) 90.0 100.0 110.0 120.0 SLA36385A-90L 120.0 L (nH) 80.0 90.0 25℃ 60.0 75℃ 30.0 100℃ 0.0 0.0 10.0 20.0 30.0 40.0 50.0 60.0 70.0 Direct Current (A) 80.0 90.0 100.0 110.0 SLA36385A-100L 150.0 25C L (nH) 100.0 75C 50.0 100C 0.0 0.0 10.0 20.0 30.0 40.0 50.0 60.0 Direct Current (A) 70.0 80.0 90.0 100.0 SLA36385A-120L 160.0 25℃ L (nH) 120.0 75℃ 80.0 100℃ 40.0 0.0 0.0 ● 5.0 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 55.0 60.0 65.0 70.0 75.0 80.0 85.0 90.0 95.0 Direct Current (A) ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www. ITG-Electronics.com Revision C.2: June 03, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SLA36385A Series 4. Inductance Characteristics (Inductance vs Current): SLA36385A-150L 200.0 25℃ L (nH) 150.0 100.0 75℃ 50.0 100℃ 0.0 0.0 5.0 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 Direct Current (A) 50.0 55.0 60.0 65.0 70.0 SLA36385A-180L 240.0 180.0 L (nH) 25℃ 120.0 75℃ 60.0 100℃ 0.0 0.0 5.0 10.0 15.0 20.0 25.0 30.0 35.0 40.0 Direct Current (A) 45.0 50.0 55.0 60.0 65.0 SLA36385A-210L 280.0 210.0 L (nH) 25℃ 140.0 75℃ 70.0 100℃ 0.0 0.0 5.0 10.0 15.0 20.0 25.0 30.0 Direct Current (A) 35.0 40.0 45.0 50.0 SLA36385A-240L 300.0 240.0 25℃ L (nH) 180.0 75℃ 120.0 100℃ 60.0 0.0 0.0 ● 5.0 10.0 15.0 20.0 25.0 30.0 Direct Current (A) 35.0 40.0 45.0 50.0 ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www. ITG-Electronics.com Revision C.2: June 03, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SLA36385A Series 4. Inductance Characteristics (Inductance vs Current): SLA36385A-270L 360.0 270.0 L (nH) 25℃ 180.0 75℃ 90.0 100℃ 0.0 0.0 5.0 10.0 15.0 20.0 25.0 Direct Current (A) 30.0 35.0 40.0 SLA36385A-330L 440.0 25℃ L (nH) 330.0 220.0 75℃ 110.0 100℃ 0.0 0.0 3.0 6.0 9.0 12.0 15.0 Direct Current (A) 18.0 21.0 24.0 27.0 SLA36385A-470M 564.0 470.0 25℃ L (nH) 376.0 282.0 75℃ 188.0 94.0 100℃ 0.0 0.0 ● 2.0 4.0 6.0 8.0 10.0 12.0 14.0 Direct Current (A) 16.0 18.0 20.0 22.0 ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www. ITG-Electronics.com Revision C.2: June 03, 2021 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase.
SLA36385A-100L 价格&库存
很抱歉,暂时无法提供与“SLA36385A-100L”相匹配的价格&库存,您可以联系我们找货
