SL3732H-R28KHF
SL3732H-R28KHF
    ITG
    SMD,9.4x6.2mm
    固定电感器 Nonstandard 280nH ±10% 51A 0.29mΩ
SL3732H-R28KHF 数据手册
SL3732H Series 1. Features of SL3732H Series: • • • • • • • • • Ferrite based SMD inductor with lower core loss. Inductance range: 100.0 nH to 470.0 nH , custom values are welcomed. High current output chokes,up to 95.0 Amp with approx. 20% roll off. Low Profile 7.80/7.90/8.00mm typical height. 9.60 x 6.40 mm Foot Print. Ideal for Buck Converter, VRM & High Density Board Design. Operating frequency of up to 5.0MHz. Operating temperature range of -55°C to + 130°C. RoHS & HF compliant. T & R Qty’s: 650pcs, 13'' Reel. 2. Electrical Characteristics of SL3732H Series: ITG Part Number SL3732H-R10KHF OCL 1 (nH) L @ Isat1 2 (nH) DCR 3 (mΩ) Isat1 4 (A) Isat2 4 (A) Irms 5 (A) Dim. C (mm) ± 10% or 15% Min. ± 5.0% @25℃ @100℃ @25℃ ± 0.20 100.00, 10% 72.00 0.29 95.00 85.00 51.00 8.00 SL3732H-R12KHF 120.00, 10% 86.40 0.29 81.00 70.00 51.00 7.90 SL3732H-R15KHF 150.00, 10% 108.00 0.29 66.00 56.00 51.00 7.80 SL3732H-R18KHF 180.00, 10% 129.60 0.29 55.00 49.00 51.00 7.80 SL3732H-R22KHF 220.00, 10% 158.40 0.29 45.00 41.00 51.00 7.80 SL3732H-R28KHF 280.00, 10% 201.60 0.29 35.00 32.00 51.00 7.80 SL3732H-R30KHF 300.00, 10% 216.00 0.29 33.00 30.00 51.00 7.80 SL3732H-R33LHF 330.00, 15% 237.60 0.29 26.00 22.00 51.00 7.80 SL3732H-R39LHF 390.00, 15% 280.80 0.29 22.00 19.00 51.00 7.80 SL3732H-R47LHF 470.00, 15% 338.40 0.29 18.00 15.00 51.00 7.80 3. Mechanical Dimension of SL3732H Series: A B C D E F S RxxH ITGYYWW G D B ± 0.20 (Max.) ± 0.20 ± 0.20 (Ref.) ± 0.20 ± 0.30 6.20 9.50 See table above 9.40 4.40 2.20 A 10.40 C 2.50 a Notes: Glue E 2.54 3.20 b G F Suggested Pad Layout Part Marking: S RxxH: S is part size code, Rxx is inductance value in uH(R:decimal point), H is special code. ITGYYWW: ITG is Company name , YYWW is date code. 1. Open Circuit Inductance (OCL) test condition: 100KHz,1.0Vrms,0Adc at 25Ԩ. 2. L @ Isat and L @ Irms Test condition: 100KHz,1.0Vrms (Ta=25Ԩ). 3. The nominal DCR is measured from point "a" to point"b",as shown above on the mechanical drawing (Ta=25Ԩ). 4. Isat1 & Isat2 : DC current that will cause inductance to drop approximately by 20%. 5. Irms: DC current for an approximate temperature rise of 40Ԩ without core loss. Derating is necessary for AC currents. PCB pad layout,trace thickness and width,air-flow and proximity of other heat generating components will affect the temperature rise. 6. It is recommended the part temperature not exceed 130°C under worst case operating conditions as verified in the end application. ● ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision C: July 06 , 2016 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SL3732H Series L (nH) 4. Inductance Characteristics of SL3732H Series (Inductance vs Current): SL3732H-R10KHF 112.5 100.0 87.5 75.0 62.5 50.0 37.5 25.0 12.5 0.0 25Ԩ 100Ԩ L (nH) 0.0 20.0 40.0 60.0 70.0 80.0 84.0 86.0 88.0 90.0 92.0 94.0 96.0 98.0 100.0106.0108.0110.0112.0 Direct Current (A) SL3732H-R12KHF 135.0 120.0 105.0 90.0 75.0 60.0 45.0 30.0 15.0 0.0 25Ԩ 100Ԩ 0.0 10.0 20.0 30.0 40.0 50.0 60.0 70.0 72.0 74.0 76.0 78.0 80.0 82.0 84.0 86.0 88.0 Direct Current (A) SL3732H-R15KHF 180.0 150.0 L (nH) 120.0 25Ԩ 90.0 100Ԩ 60.0 30.0 0.0 0.0 10.0 20.0 30.0 40.0 50.0 52.0 54.0 56.0 58.0 60.0 62.0 63.0 64.0 65.0 66.0 67.0 68.0 69.0 70.0 Direct Current (A) SL3732H-R18KHF 216.0 180.0 25Ԩ L (nH) 144.0 108.0 100Ԩ 72.0 36.0 0.0 0.0 ● 10.0 20.0 30.0 35.0 40.0 45.0 49.0 50.0 51.0 52.0 53.0 54.0 55.0 56.0 58.0 60.0 62.0 Direct Current (A) ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision C: July 06 , 2016 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SL3732H Series L (nH) 4. Inductance Characteristics of SL3732H Series (Inductance vs Current): SL3732H-R22KHF 240.0 216.0 192.0 168.0 144.0 120.0 96.0 72.0 48.0 24.0 0.0 25Ԩ 100Ԩ L (nH) 0.0 10.0 20.0 25.0 30.0 35.0 38.0 40.0 41.0 42.0 43.0 44.0 45.0 46.0 47.0 48.0 49.0 50.0 51.0 Direct Current (A) SL3732H-R28KHF 315.0 280.0 245.0 210.0 175.0 140.0 105.0 70.0 35.0 0.0 25Ԩ 100Ԩ 0.0 5.0 10.0 15.0 20.0 25.0 30.0 31.0 32.0 33.0 34.0 35.0 36.0 37.0 38.0 39.0 40.0 41.0 Direct Current (A) SL3732H-R30KHF 350.0 300.0 L (nH) 250.0 25Ԩ 200.0 150.0 100Ԩ 100.0 50.0 0.0 0.0 10.0 20.0 22.0 24.0 26.0 28.0 30.0 31.0 Direct Current (A) 32.0 33.0 34.0 35.0 36.0 38.0 SL3732H-R33LHF 385.0 330.0 L (nH) 275.0 25Ԩ 220.0 165.0 100Ԩ 110.0 55.0 0.0 0.0 ● 5.0 10.0 15.0 20.0 18.0 21.0 22.0 23.0 Direct Current (A) 24.0 25.0 26.0 28.0 30.0 ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision C: July 06 , 2016 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase. SL3732H Series L (nH) 4. Inductance Characteristics of SL3732H Series (Inductance vs Current): SL3732H-R39LHF 430.0 387.0 344.0 301.0 258.0 215.0 172.0 129.0 86.0 43.0 0.0 25Ԩ 100Ԩ L (nH) 0.0 4.0 8.0 10.0 12.0 14.0 16.0 18.0 20.0 Direct Current (A) 22.0 24.0 26.0 28.0 30.0 SL3732H-R47LHF 517.0 470.0 423.0 376.0 329.0 282.0 235.0 188.0 141.0 94.0 47.0 0.0 25Ԩ 100Ԩ 0.0 2.0 4.0 8.0 10.0 12.0 14.0 15.0 16.0 Direct Current (A) 17.0 18.0 20.0 22.0 24.0 5. Core Loss: SL3732H-XXX Core Loss 0 500 1000 1500 2000 2500 3000 3500 4000 1300.0 1200.0 1100.0 Core Loss (mW) 1000.0 900.0 1MHz 800.0 500KHz 700.0 300KHz 600.0 200KHz 500.0 100KHz 400.0 300.0 200.0 100.0 0.0 △B(Guass) Where △B=0.40*L(nH)*△I ● ● New York 1 914 347 2474 ● Taipei 886 2 2698 8669 ● Kaohsiung 886 7 350 2275 Japan 81 568 85 2830 ● Shenzhen 86 755 8418 6263 ● Shanghai 86 21 5424 5141 ● Hong Kong 852 9688 9767 ● sales@ITG-Electronics.com ● www.ITG-Electronics.com Revision C: July 06 , 2016 *Due to continuous product improvement, all specifications are subject to change without prior notice. Kindly contact an ITG field application engineer or a sales representative prior to purchase.
SL3732H-R28KHF 价格&库存
很抱歉,暂时无法提供与“SL3732H-R28KHF”相匹配的价格&库存,您可以联系我们找货
