TPSM-350X6-ADAPTERKIT
    TYCON(泰康)
    6X360W ADAPTER KIT, FOR 350X2-TP
TPSM-350X6-ADAPTERKIT 数据手册
TPSM-350x6-AdapterKit DATA SHEET 6 Panel Adapter Kit for TPSM-350x2-TP Features • • All components required to add an additional 4x 60-72 cell panels (nominally 230-360 watt) to the TPSM-350x2-TP 2 panel mount Stainless Steel, Galvanized Steel, and Anodized Aluminum construction Description Tycon Solar’s TPSM-350x6-AdapterKit has all components needed to convert the TPSM-350x2-TP 2 panel solar mount to a 6 panel solar mount. The kit consists of Qty 10 mounting rails, Qty 2 cross beam extensions and all the hardware needs for assembly including solar panel mounting brackets. Contents Quantity Item U-Bracket with Grounding Plate U-Bracket 76 x 1300mm Extension Cross Beam M8*30 Stainless Bolt with Flat Washer, Lock Washer and Nut M12*36 Stainless Bolt with Flat Washer, Lock Washer and Nut Vertical Rail – 1828mm Length Vertical Rail Extension – 1370mm Length Rail Couplers Solar Panel End Clamps (35-50mm) Solar Panel Inner Clamps (35-50mm) Crate Outside Dimensions Shipping Weight Warranty 2 6 2 16 8 4 6 8 8 10 1828 x 203 x 203mm (72 x 8 x 8”) 30kg (65lbs) 3 years System Ordering: TPSM-350x6-AdapterKit 350x2-TP solar mount. Adapter Kit to add 4 additional solar panels to the TPSM- For further information contact: Tyconsystems.com 14641 S 800 W Bluffdale, UT 84065 PH: 801-432-0003 FAX: 801-618-4220 TPSM-350x6-AdapterKit Spec Sheet Rev 1 27-Jan-22 Specifications Subject to Change Without Notice
TPSM-350X6-ADAPTERKIT 价格&库存
很抱歉,暂时无法提供与“TPSM-350X6-ADAPTERKIT”相匹配的价格&库存,您可以联系我们找货
