BUK7509-55A
N-channel TrenchMOS standard level FET
Rev. 02 — 2 February 2011
Product data sheet
1. Product profile
1.1 General description
Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product has been designed and qualified to
the appropriate AEC standard for use in automotive critical applications.
1.2 Features and benefits
AEC Q101 compliant
Low conduction losses due to low
on-state resistance
Suitable for standard level gate drive
sources
Suitable for thermally demanding
environments due to 175 °C rating
1.3 Applications
12 V and 24 V loads
General purpose power switching
Automotive systems
Motors, lamps and solenoids
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max Unit
VDS
drain-source
voltage
Tj ≥ 25 °C; Tj ≤ 175 °C
55
V
ID
drain current
VGS = 10 V; Tmb = 25 °C;
see Figure 1; see Figure 3
75
A
Ptot
total power
dissipation
Tmb = 25 °C; see Figure 2
211
W
VGS = 10 V; ID = 25 A;
Tj = 175 °C; see Figure 11;
see Figure 12
18
mΩ
Tj = 25 °C; see Figure 11;
see Figure 12
7.7
9
mΩ
[1]
Static characteristics
RDSon
drain-source
on-state
resistance
BUK7509-55A
Nexperia
Table 1.
Symbol
Quick reference data …continued
Parameter
Conditions
Min
Typ
Max Unit
400
mJ
25
nC
Avalanche ruggedness
EDS(AL)S
non-repetitive
ID = 75 A; Vsup ≤ 55 V;
drain-source
RGS = 50 Ω; VGS = 10 V;
avalanche energy Tj(init) = 25 °C; unclamped
Dynamic characteristics
QGD
[1]
gate-drain charge VGS = 0 V; ID = 25 A;
VDS = 44 V; Tj = 25 °C;
see Figure 13
Continuous current is limited by package.
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
G
gate
Simplified outline
2
D
drain
3
S
source
mb
D
mounting base; connected to
drain
Graphic symbol
mb
D
G
mbb076
S
1 2 3
SOT78A (TO-220AB)
3. Ordering information
Table 3.
Type number
BUK7509-55A
BUK7509-55A
Product data sheet
Package
Name
Description
Version
TO-220AB
plastic single-ended package; heatsink mounted; 1 mounting
hole; 3-lead TO-220AB
SOT78A
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 13
BUK7509-55A
Nexperia
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
drain-source voltage
55
V
VDGR
drain-gate voltage
RGS = 20 kΩ
55
V
VGS
gate-source voltage
ID
drain current
-20
V
Tmb = 25 °C; VGS = 10 V; see Figure 1;
see Figure 3
[1]
75
A
[2]
108
A
Tmb = 100 °C; VGS = 10 V; see Figure 1
[1]
75
A
IDM
peak drain current
Tmb = 25 °C; pulsed; tp ≤ 10 µs;
see Figure 3
433
A
Ptot
total power dissipation
211
W
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
[2]
108
A
[1]
75
A
pulsed; tp ≤ 10 µs; Tmb = 25 °C
433
A
ID = 75 A; Vsup ≤ 55 V; RGS = 50 Ω;
VGS = 10 V; Tj(init) = 25 °C; unclamped
400
mJ
Source-drain diode
source current
IS
Tmb = 25 °C
peak source current
ISM
EDS(AL)S
non-repetitive drain-source
avalanche energy
[1]
[2]
Current is limited by power dissipation chip rating.
03nj22
120
ID
(A)
Pder
Capped at 75 A due to package
80
80
40
40
100
03na19
120
150
200
100
150
Fig 1.
Normalized continuous drain current as a
function of mounting base temperature
BUK7509-55A
Product data sheet
200
Tmb (°C)
Tmb (°C)
Fig 2.
Normalized total power dissipation as a
3 of 13
BUK7509-55A
Nexperia
03nj20
103
ID
(A)
tp = 10 μs
Limit RDSon = VDS/ID
102
100 μs
1 ms
DC
10
10 ms
100 ms
1
10−1
1
102
10
VDS (V)
Fig 3.
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance from
junction to mounting base
see Figure 4
0.71
K/W
Rth(j-a)
junction to ambient
vertical in still air
60
K/W
03nj21
1
Zth(j-mb)
(K/W)
δ = 0.5
0.2
10−1
0.1
0.05
0.02
10−2
single shot
10−3
10−6
10−5
10−4
10−3
10−2
10−1
1
tp (s)
Fig 4.
Transient thermal impedance from junction to mounting base as a function of pulse duration
BUK7509-55A
Product data sheet
4 of 13
BUK7509-55A
Nexperia
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source
breakdown voltage
ID = 0.25 mA; VGS = 0 V; Tj = 25 °C
55
V
ID = 0.25 mA; VGS = 0 V; Tj = -55 °C
50
V
VGS(th)
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 25 °C;
see Figure 10
2
3
4
V
ID = 1 mA; VDS = VGS; Tj = -55 °C;
see Figure 10
4.4
V
ID = 1 mA; VDS = VGS; Tj = 175 °C;
see Figure 10
1
V
500
µA
IDSS
drain leakage current
VDS = 55 V; VGS = 0 V; Tj = 175 °C
VDS = 55 V; VGS = 0 V; Tj = 25 °C
0.05
10
µA
IGSS
gate leakage current
VGS = 20 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = 10 V; ID = 25 A; Tj = 175 °C;
see Figure 11; see Figure 12
18
mΩ
VGS = 10 V; ID = 25 A; Tj = 25 °C;
7.7
9
mΩ
ID = 25 A; VDS = 44 V; VGS = 0 V;
Tj = 25 °C; see Figure 13
62
nC
12
nC
25
nC
2453
3271
pF
540
662
pF
299
427
pF
17
ns
RDSon
drain-source on-state
resistance
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
VGS = 0 V; VDS = 25 V; f = 1 MHz;
Tj = 25 °C; see Figure 14
VDS = 30 V; RL = 1.2 Ω; VGS = 10 V;
RG(ext) = 10 Ω; Tj = 25 °C
tr
rise time
58
ns
td(off)
turn-off delay time
78
ns
tf
fall time
55
ns
LD
internal drain
inductance
from drain lead 6 mm from package to
centre of die ; Tj = 25 °C
4.5
nH
from contact screw on mounting base to
3.5
nH
from source lead to source bond pad ;
Tj = 25 °C
7.5
nH
0.85
1.2
V
LS
internal source
inductance
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS 0 V; Tj = 25 °C;
see Figure 15
trr
reverse recovery time
Qr
recovered charge
IS = 20 A; dIS/dt = -100 A/µs;
VGS = -10 V; VDS = 30 V; Tj = 25 °C
BUK7509-55A
Product data sheet
55
ns
43
nC
5 of 13
BUK7509-55A
Nexperia
03nj17
400
03nj16
12
label is VGS (V)
ID
(A)
14
RDSon
(mΩ)
12
10
9.5
9
8.5
10
8
200
7.5
7
8
6.5
100
6
4
5.5
5
4.5
6
6
8
10
5
10
15
VDS (V)
Fig 5.
VGS (V)
Output characteristics: drain current as a
function of drain-source voltage; typical values
Fig 6.
03aa35
10−1
ID
(A)
min
10−2
typ
Drain-source on-state resistance as a function
of gate-source voltage; typical values
03nj14
60
gfs
(S)
max
40
10−3
10−4
10−5
10−6
4
6
60
ID (A)
VGS (V)
Fig 7.
Sub-threshold drain current as a function of
gate-source voltage
BUK7509-55A
Product data sheet
Fig 8.
Forward transconductance as a function of
drain current; typical values
6 of 13
BUK7509-55A
Nexperia
03nj15
100
03aa32
5
VGS(th)
(V)
ID
(A)
4
max
75
3
typ
50
2
min
25
Tj = 175 °C
1
Tj = 25 °C
4
6
8
VGS (V)
Fig 9.
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
−60
60
120
180
Tj (°C)
Fig 10. Gate-source threshold voltage as a function of
03nj18
03ne89
2
label is VGS (V)
6
RDSon
(mΩ)
6.5
7
7.5
8
a
9
10
1.5
15
1
0.5
5
200
300
400
120
ID (A)
Fig 11. Drain-source on-state resistance as a function
of drain current; typical values
BUK7509-55A
Product data sheet
Tj (°C)
180
Fig 12. Normalized drain-source on-state resistance
factor as a function of junction temperature
7 of 13
BUK7509-55A
Nexperia
03nj13
10
03nj19
5000
VGS
(V)
Ciss
C
(pF)
8
Coss
3750
VDD = 14 V
VDD = 44 V
6
Crss
2500
4
1250
2
60
10−2
80
10−1
1
102
10
VDS (V)
QG (nC)
Fig 13. Gate-source voltage as a function of gate
charge; typical values
Fig 14. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
03nj12
100
IS
(A)
75
50
Tj = 175 °C
Tj = 25 °C
25
0.3
0.6
0.9
1.2
VSD (V)
Fig 15. Reverse diode current as a function of reverse diode voltage; typical values
BUK7509-55A
Product data sheet
8 of 13
BUK7509-55A
Nexperia
7. Package outline
Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB
E
SOT78A
A
A1
p
q
mounting
base
D1
D
L2
L1(1)
Q
b1
L
1
2
3
c
b
e
e
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1
c
D
D1
E
e
L
L1(1)
L2
max.
p
q
Q
mm
4.5
4.1
1.39
1.27
0.9
0.6
1.3
1.0
0.7
0.4
15.8
15.2
6.4
5.9
10.3
9.7
2.54
15.0
13.5
3.30
2.79
3.0
3.8
3.6
3.0
2.7
2.6
2.2
Note
1. Terminals in this zone are not tinned.
OUTLINE
VERSION
SOT78A
REFERENCES
IEC
JEDEC
JEITA
3-lead TO-220AB
SC-46
EUROPEAN
PROJECTION
ISSUE DATE
03-01-22
05-03-14
Fig 16. Package outline SOT78A (TO-220AB)
BUK7509-55A
Product data sheet
9 of 13
BUK7509-55A
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BUK7509-55A v.2
20110202
Product data sheet
BUK75_7609_55A v.1
Modifications:
BUK75_7609_55A v.1
BUK7509-55A
Product data sheet
The format of this data sheet has been redesigned to comply with the new identity guidelines
of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Type number BUK7509-55A separated from data sheet BUK75_7609_55A v.1.
20020806
Product specification
10 of 13
BUK7509-55A
Nexperia
9. Legal information
9.1
Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
BUK7509-55A
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. The product is not designed, authorized or warranted to be
suitable for use in medical, military, aircraft, space or life support equipment,
nor in applications where failure or malfunction of a Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia accepts no
liability for inclusion and/or use of Nexperia products in such
equipment or applications and therefore such inclusion and/or use is at the
customer’s own risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
11 of 13
BUK7509-55A
Nexperia
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
BUK7509-55A
Product data sheet
12 of 13
Nexperia
BUK7509-55A
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10
Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12
Contact information. . . . . . . . . . . . . . . . . . . . . .12
Date of release: 02 February 2011
很抱歉,暂时无法提供与“BUK7509-55A,127”相匹配的价格&库存,您可以联系我们找货
