PH3120L
N-channel TrenchMOS logic level FET
Rev. 03 — 30 March 2009
Product data sheet
1. Product profile
1.1 General description
Logic level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product is designed and qualified for use in
computing, communications, consumer and industrial applications only.
1.2 Features and benefits
Higher operating power due to low
thermal resistance
Suitable for logic level gate drive
sources
Low conduction losses due to low
on-state resistance
1.3 Applications
DC-to-DC convertors
Portable equipment
Notebook computers
Switched-mode power supplies
1.4 Quick reference data
Table 1.
Quick reference
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C
V
ID
drain current
Tmb = 25 °C; VGS = 10 V;
see Figure 1; see Figure 3
100
A
Ptot
total power
dissipation
Tmb = 25 °C; see Figure 2
62.5
W
VGS = 4.5 V; ID = 50 A;
VDS = 10 V; Tj = 25 °C;
see Figure 11
12.8
nC
VGS = 10 V; ID = 25 A;
Tj = 25 °C; see Figure 9;
see Figure 10
2.25
2.65
mΩ
Dynamic characteristics
QGD
gate-drain charge
Static characteristics
RDSon
drain-source
on-state resistance
PH3120L
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol
Description
Simplified outline
1
S
source
2
S
source
3
S
source
4
G
gate
mb
D
mounting base; connected to
drain
Graphic symbol
mb
D
G
S
mbb076
1 2 3 4
SOT669
(LFPAK)
3. Ordering information
Table 3.
Type number
Package
Name
Description
PH3120L
LFPAK
plastic single-ended surface-mounted package (LFPAK); 4 leads
Version
SOT669
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
V
VGS
gate-source voltage
-20
V
ID
drain current
VGS = 10 V; Tmb = 25 °C; see Figure 1;
see Figure 3
100
A
VGS = 10 V; Tmb = 100 °C; see Figure 1
76
A
IDM
peak drain current
tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3
300
A
Ptot
total power dissipation
62.5
W
Tstg
storage temperature
-55
150
°C
Tj
junction temperature
-55
150
°C
Source-drain diode
IS
source current
Tmb = 25 °C
52
A
ISM
peak source current
152
A
210
mJ
Avalanche ruggedness
EDS(AL)S
non-repetitive
VGS = 10 V; Tj(init) = 25 °C; ID = 46.2 A; Vsup ≤ 20 V;
drain-source avalanche unclamped; tp = 0.32 ms; RGS = 50 Ω
energy
PH3120L_3
Product data sheet
2 of 12
Nexperia B.V. 2017. All rights reserved
PH3120L
Nexperia
003aaa628
120
03aa15
120
I der
Pder
80
80
40
40
Fig 1.
50
100
150
200
Tmb (°C)
100
150
200
Tmb (°C)
Normalized continuous drain current as a
function of mounting base temperature
Fig 2.
Normalized total power dissipation as a
003aaa360
103
ID
(A)
Limit RDSon = VDS / ID
102
tp = 10 μ s
100 μ s
1 ms
10 ms
DC
10
100 ms
1
10-1
1
102
10
VDS (V)
Fig 3.
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
PH3120L_3
Product data sheet
3 of 12
PH3120L
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance from junction to
mounting base
see Figure 4
2
K/W
003aaa361
10
Zth(j-mb)
(K/W)
δ = 0.5
1
0.2
δ=
P
0.1
0.05
0.02
tp
T
single pulse
t
tp
T
10-1
10-5
Fig 4.
10-4
10-3
10-2
10-1
tp (s)
1
Transient thermal impedance from junction to mounting base as a function of pulse duration
PH3120L_3
Product data sheet
4 of 12
PH3120L
Nexperia
6. Characteristics
Table 6.
Symbol
Characteristics
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source
breakdown voltage
ID = 10 mA; VGS = 0 V; Tj = 25 °C
V
VGS(th)
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 150 °C;
see Figure 7; see Figure 8
0.65
V
ID = 1 mA; VDS = VGS; Tj = 25 °C;
1
1.5
2
V
VDS = 20 V; VGS = 0 V; Tj = 150 °C
500
µA
VDS = 20 V; VGS = 0 V; Tj = 25 °C
0.06
1
µA
VGS = 15 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -15 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = 10 V; ID = 25 A; Tj = 25 °C;
see Figure 9; see Figure 10
2.25
2.65
mΩ
VGS = 4.5 V; ID = 25 A; Tj = 150 °C;
5.1
6.3
mΩ
VGS = 4.5 V; ID = 25 A; Tj = 25 °C;
3
3.7
mΩ
ID = 50 A; VDS = 10 V; VGS = 4.5 V;
Tj = 25 °C; see Figure 11
48.5
nC
12.7
nC
12.8
nC
IDSS
IGSS
RDSon
drain leakage current
gate leakage current
drain-source on-state
resistance
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
tf
VDS = 10 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; see Figure 12
4457
pF
1480
pF
940
pF
34
ns
90
ns
turn-off delay time
114
ns
fall time
88
ns
VDS = 10 V; RL = 0.4 Ω; VGS = 4.5 V;
RG(ext) = 4.7 Ω; Tj = 25 °C; ID = 25 A
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS = 0 V; Tj = 25 °C;
see Figure 13
0.77
1.2
V
trr
reverse recovery time
IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 20 V; Tj = 25 °C
63
ns
PH3120L_3
Product data sheet
5 of 12
PH3120L
Nexperia
003aaa362
ID
(A)
ID
(A)
VGS (V) = 2.1
4.5
10
15
003aaa363
40
2.5
30
2
10
Tj = 150 °C
25 °C
1.9
5
10
1.8
Fig 5.
0.2
0.4
0.6
0.8
VDS (V)
1
Output characteristics: drain current as a
function of drain-source voltage; typical values
03aa33
2.5
1.5
Fig 6.
1
max
10-2
typ
10-3
Fig 7.
3
03aa36
typ
max
10-4
min
10-5
0.5
VGS (V)
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
min
1
2
10-1
ID
(A)
VGS(th)
(V)
2
120
Tj (°C)
180
Gate-source threshold voltage as a function of
Fig 8.
1
2
VGS (V)
3
Sub-threshold drain current as a function of
gate-source voltage
PH3120L_3
Product data sheet
6 of 12
PH3120L
Nexperia
003aaa364
40
1.9
RDSon
(mΩ)
2
03aa27
2
2.1
a
30
1.5
0.5
10
VGS (V) = 2.5
4.5
10
Fig 9.
10
ID (A)
30
Drain-source on-state resistance as a function
of drain current; typical values
003aaa367
10
VGS
(V)
8
120
Tj (°C)
180
Fig 10. Normalized drain-source on-state resistance
factor as a function of junction temperature
003aaa365
104
C
(pF)
Ciss
103
Coss
6
Crss
4
2
50
75
QG (nC)
100
Fig 11. Gate-source voltage as a function of gate
charge; typical values
102
10-1
1
10
VDS (V)
102
Fig 12. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
PH3120L_3
Product data sheet
7 of 12
PH3120L
Nexperia
003aaa366
40
IS
(A)
30
150 °C
Tj = 25 °C
10
0.4
0.6
0.8
VSD (V)
1
Fig 13. Source current as a function of source-drain voltage; typical values
PH3120L_3
Product data sheet
8 of 12
PH3120L
Nexperia
7. Package outline
Plastic single-ended surface-mounted package (LFPAK); 4 leads
A2
A
E
SOT669
C
c2
b2
E1
b3
L1
mounting
base
b4
D1
D
H
L2
1
2
3
e
4
w M A
b
1/2
X
c
e
A
(A 3)
A1
C
θ
L
detail X
y C
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
mm
A
A1
A2
A3
b
b2
1.20 0.15 1.10
0.50 4.41
0.25
1.01 0.00 0.95
0.35 3.62
b3
b4
2.2
2.0
0.9
0.7
c
D (1)
c2
D1(1)
E(1) E1(1)
max
0.25 0.30 4.10
4.20
0.19 0.24 3.80
5.0
4.8
3.3
3.1
e
H
L
L1
L2
w
y
θ
1.27
6.2
5.8
0.85
0.40
1.3
0.8
1.3
0.8
0.25
0.1
8°
0°
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
OUTLINE
VERSION
SOT669
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-10-13
06-03-16
MO-235
Fig 14. Package outline SOT669 (LFPAK)
PH3120L_3
Product data sheet
9 of 12
PH3120L
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release
date
Data sheet status
Change notice
Supersedes
PH3120L_3
20090330
Product data sheet
PH3120L_2
Modifications:
PH3120L_2 (9397 750 14089)
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
20050120
PH3120L-01 (9397 750 12812) 20040304
Product data sheet
PH3120L-01
Preliminary data sheet
PH3120L_3
Product data sheet
10 of 12
PH3120L
Nexperia
9. Legal information
9.1
Data sheet status
Document status [1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
9.3
Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PH3120L_3
Product data sheet
11 of 12
Nexperia
PH3120L
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10
Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . . 11
Date of release: 30 March 2009
很抱歉,暂时无法提供与“PH3120L,115”相匹配的价格&库存,您可以联系我们找货
