SC108-470
SC108-470
    SIGNAL
    非标准
    FIXED IND 47UH 2.6A 110 MOHM SMD
SC108-470 数据手册
SC108 SMD POWER INDUCTORS XXX MARKING ● Features 1. Open frame construction. ELECTRICAL CHARACTERISTICS (2) (1) SC108-100 SC108-120 SC108-150 SC108-180 SC108-220 SC108-270 SC108-330 SC108-390 SC108-470 SC108-560 SC108-680 SC108-820 SC108-101 SC108-121 SC108-151 SC108-181 SC108-221 SC108-271 SC108-331 SC108-391 SC108-471 SC108-561 SC108-681 SC108-821 SC108-102 SC108-122 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1000 1200 DC Resistance (Ω MAX) 2.52MHZ 2.52MHZ 2.52MHZ 2.52MHZ 2.52MHZ 2.52MHZ 2.52MHZ 2.52MHZ 2.52MHZ 2.52MHZ 2.52MHZ 2.52MHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 1KHZ 36m 38m 40m 50m 60m 70m 80m 90m 0.11 0.12 0.15 0.19 0.23 0.32 0.37 0.42 0.44 0.55 0.60 0.67 0.88 1.04 1.18 1.38 1.74 1.92 Saturation(3) Temperature (4) Current Current (A) (A) 4.05 3.60 3.34 3.05 2.80 2.50 2.40 2.20 2.00 1.90 1.80 1.60 1.50 1.40 1.30 1.20 1.00 0.95 0.90 0..80 0.70 0.65 0.60 0.50 0.48 0.45 4.70 4.45 4.00 3.50 3.40 3.30 3.20 2.90 2.60 2.40 2.30 2.00 1.80 1.50 1.43 1.32 1.14 0.93 0.90 0.80 0.75 0.73 0.72 0.70 0.63 0.54 SC108 Inductance decrease current BC108 I nduct ance decr ease bybycur r ent 10000 I nduct ance( Inductance (µH) mH) Inductance Test (uH) Frequency 1000 122 100 121 10 1 100 100 10 100000 10000 1000 DC cur r ent (mA) ( mA) DC current SC108 Temperature by cur current BC108 Tem per at ur e r irise se by r ent Temperature Tem per at ur eriser °C i se ℃ Part Number 80 70 60 100 50 122 121 40 30 20 10 0 1000 2000 3000 4000 5000 6000 DC DC curcurrent r ent ((mA) mA) 7000 8000 9000 (1). Inductance tolerance±20% tested at 0.25V, 0ADC and 25℃ (2). DCR measured at 25℃. (3). The DC current at which the inductance decreases by 10% from its initial value. (4). The DC current that results in a 40℃ temperature rise from 25℃ ambient. Click here for QUANTITY PER REEL & PACKING INFORMATION © 2019 Signal Transformer –Specification subject to change without notice. 12.19 Custom versions available upon request. belfuse.com/signal 38 128 Atlantic Avenue, Lynbrook, NY 11563 Toll Free 866-239-5777 • Tel 516-239-5777 • Fax 516-239-7208 Sales@signaltransformer.com • techhelp@signaltransformer.com
SC108-470
1. 物料型号:型号为EL817,是一款光耦器件。 2. 器件简介:EL817是一种通用的晶体管输出型光耦器件,具有较高的输入输出隔离电压和快速响应时间。 3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚输出晶体管的集电极,4脚输出晶体管的发射极,5脚输出晶体管的基极,6脚为发光二极管的正极。 4. 参数特性:EL817的主要参数包括输入电流为10mA,输出晶体管的饱和压降为0.6V,隔离电压为5kV等。 5. 功能详解:EL817通过内部的发光二极管和光敏晶体管实现电信号的隔离传输,常用于开关电源、测量设备等需要电气隔离的场合。 6. 应用信息:EL817适用于需要电气隔离的各种应用,如开关电源、测量设备、通信设备等。 7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm x 4.9mm。
SC108-470 价格&库存
很抱歉,暂时无法提供与“SC108-470”相匹配的价格&库存,您可以联系我们找货
