SC1606-220
SC1606-220
    SIGNAL
    非标准
    FIXED IND 22UH 720MA 540MOHM SMD
SC1606-220 数据手册
SC1606 SMD POWER INDUCTORS XXX MARKING Part Number Inductance Test (uH) Frequency DC Resistance (Ω MAX) (2) 100KHZ 90m 2.50 2.45 SC1606-1R5 1.5 100KHZ 100m 2.20 1.90 SC1606-2R2 2.2 100KHZ 110m 1.80 1.78 SC1606-3R3 3.3 100KHZ 120m 1.40 1.65 SC1606-4R7 4.7 100KHZ 160m 1.20 1.40 SC1606-6R8 6.8 100KHZ SC1606-100 10 100KHZ SC1606-150 15 100KHZ 22 100KHZ SC1606-330 33 100KHZ SC1606-470 47 SC1606-680 1.18 300m 1.00 1.05 400m 0.80 0.88 540m 0.60 0.72 820m 0.50 0.58 100KHZ 1.20 0.45 0.47 68 100KHZ 1.60 0.35 0.40 SC1606-101 100 100KHZ 2.60 0.30 0.30 SC1606-151 150 100KHZ 3.50 0.25 0.26 SC1606-221 220 100KHZ 5.70 0.20 0.21 BS SC1606-220 1.10 330 100KHZ 9.30 0.16 SC1606-471 470 100KHZ 12.6 0.14 0.14 SC1606-681 680 100KHZ 17.5 0.12 0.12 SC1606-102 1000 100KHZ 26.8 0.08 0.10 O SC1606-331 0.16 102 100 330 10 1 1R0 0. 1 10 100 10000 1000 100000 DCcurrent cur r ent(mA) ( mA) DC BC1606 Tem per at ur e r i serise by by cur rcurrent ent SC1606 Temperature 80 °C ℃ TemTemperature per at ur e rrise i se 1.0 240m BC 1606 I nduct ance decrdecrease ease by by curcurrent r ent SC1606 Inductance 10000 1000 SC1606-1R0 O (1) Saturation Temperature (3) (4) Current Current (A) (A) I nduct ance( Inductance (µH) uH) ELECTRICAL CHARACTERISTICS LE TE ● Features 1. Non-magnetically shielded construction – Low EMI 2 Excellent Power Density 3 Engineered to Provide High Efficiency 70 102 60 330 1R0 50 40 30 20 10 0 500 1000 1500 2000 2500 3000 3500 4000 4500 5000 DC current cur r ent ( mA) DC (mA) (1). Inductance tolerance for 1.0uH: ±30%, for 1.5uH~1000uH: ±20%. Tested at 0.25V, 0ADC and 25℃. (2). DCR measured at 25℃. (3). The DC current at which the inductance decreases by 10% from its initial value. (4). The DC current that results in a 40℃ temperature rise from 25℃ ambient. Click here for QUANTITY PER REEL & PACKING INFORMATION Custom versions available upon request. belfuse.com/signal © 2019 Signal Transformer –Specification subject to change without notice. 12.19 75 128 Atlantic Avenue, Lynbrook, NY 11563 Toll Free 866-239-5777 • Tel 516-239-5777 • Fax 516-239-7208 Sales@signaltransformer.com • techhelp@signaltransformer.com
SC1606-220
1. 物料型号:SC1606,为SMD功率电感器。 2. 器件简介:该电感器具有非磁性屏蔽结构,低电磁干扰(EMI),优秀的功率密度和高效率。 3. 引脚分配:文档中没有明确说明引脚分配。 4. 参数特性:包含电感值、测试频率、直流电阻、饱和电流和工作温度下的电流值。例如,SC1606-1R0型号的电感值为1.0uH,100kHz测试频率下,直流电阻为90毫欧,饱和电流为2.5A。 5. 功能详解:文档提供了电感值随直流电流变化的图表和电感值随温度变化的图表,以及温度随直流电流变化的图表。 6. 应用信息:文档中没有具体说明应用信息,但根据电感器的特性,它们通常用于开关电源、电源转换器等。 7. 封装信息:封装类型为1606,但具体的封装尺寸和外形没有详细说明。
SC1606-220 价格&库存
很抱歉,暂时无法提供与“SC1606-220”相匹配的价格&库存,您可以联系我们找货
