RMB2SHRCG
RMB2SHRCG
    TAIWANSEMICONDUCTOR(台湾半导体)
    BESOP4
    BRIDGE RECT TO269AA
RMB2SHRCG 数据手册
RMB2S – RMB6S Taiwan Semiconductor 0.8A, 200V - 600V Fast Recovery Bridge Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Ideal for automated placement Reliable low cost construction utilizing molded plastic technique High surge current capability UL Recognized File # E-326854 Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 0.8 A VRRM 200 - 600 V IFSM 30 A TJ MAX 150 °C Package TO-269AA (MBS) Configuration Quad APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● Lighting application MECHANICAL DATA ● ● ● ● ● ● Case: TO-269AA (MBS) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.120g (approximately) MBS ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device RMB2S RMB4S RMB6S RMB2S RMB4S RMB6S UNIT Repetitive peak reverse voltage VRRM 200 400 600 V Reverse voltage, total rms value VR(RMS) 140 280 420 V Forward current On glass-epoxy On aluminum substrate Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load 0.5 A 0.8 A IFSM 30 A IF Rating for fusing (t
RMB2SHRCG 价格&库存
很抱歉,暂时无法提供与“RMB2SHRCG”相匹配的价格&库存,您可以联系我们找货
