PH20100S,115
PH20100S,115
    NEXPERIA(安世)
    SOT669
    MOSFET N-CH 100V 34.3A LFPAK
PH20100S,115 数据手册
PH20100S N-channel TrenchMOS standard level FET Rev. 03 — 2 February 2009 Product data sheet 1. Product profile 1.1 General description Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product is designed and qualified for use in computing, communications, consumer and industrial applications only. 1.2 Features and benefits „ Higher operating power due to low thermal resistance „ Simple gate drive required due to low gate charge current „ Low conduction losses due to low on-state resistance 1.3 Applications „ DC-to-DC convertors „ Switched-mode power supplies 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C - - 100 V ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 2; see Figure 1 - - 34.3 A Ptot total power dissipation Tmb = 25 °C - - 62.5 W VGS = 10 V; ID = 20 A; VDS = 50 V; Tj = 25 °C; see Figure 11 - 8.9 - nC VGS = 10 V; ID = 10 A; Tj = 25 °C; see Figure 8; see Figure 9 - 19 23 mΩ Dynamic characteristics QGD gate-drain charge Static characteristics RDSon drain-source on-state resistance PH20100S Nexperia N-channel TrenchMOS standard level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 S source 2 S source 3 S source 4 G gate mb D mounting base; connected to drain Graphic symbol mb D G S mbb076 1 2 3 4 SOT669 (LFPAK) 3. Ordering information Table 3. Ordering information Type number Package Name Description PH20100S LFPAK plastic single-ended surface-mounted package (LFPAK); 4 leads Version SOT669 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 150 °C - 100 V VGS gate-source voltage -20 20 V ID drain current VGS = 10 V; Tmb = 100 °C; see Figure 2 - 21.6 A VGS = 10 V; Tmb = 25 °C; see Figure 2; see Figure 1 - 34.3 A IDM peak drain current tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 1 - 137 A Ptot total power dissipation Tmb = 25 °C - 62.5 W Tstg storage temperature -55 150 °C Tj junction temperature -55 150 °C Source-drain diode IS source current Tmb = 25 °C - 52 A ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C - 137 A - 250 mJ Avalanche ruggedness EDS(AL)S non-repetitive VGS = 10 V; Tj(init) = 25 °C; ID = 12 A; Vsup ≤ 100 V; drain-source avalanche unclamped; tp = 0.3 ms energy PH20100S_3 Product data sheet Rev. 03 — 2 February 2009 2 of 12 © Nexperia B.V. 2017. All rights reserved PH20100S Nexperia N-channel TrenchMOS standard level FET 003aaa406 103 ID (A) Limit RDSon = VDS / ID 2 10 tp = 10 μs 100 μs 10 1 ms DC 10 ms 1 100 ms 10-1 1 Fig 1. 102 10 103 VDS (V) Safe operating area; continuous and peak drain currents as a function of drain-source voltage 03aa23 120 Ider (%) 80 40 0 0 50 100 150 200 Tmb (°C) Fig 2. Normalized continuous drain current as a function of mounting base temperature PH20100S_3 Product data sheet Rev. 03 — 2 February 2009 3 of 12 © Nexperia B.V. 2017. All rights reserved PH20100S Nexperia N-channel TrenchMOS standard level FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Rth(j-mb) thermal resistance from see Figure 3 junction to mounting base Min Typ Max Unit - - 2 K/W 003aaa407 10 Zth(j-mb) (K/W) 1 δ = 0.5 0.2 0.1 0.05 0.02 10-1 δ= P tp T single pulse t tp T 10-2 10-5 Fig 3. 10-4 10-3 10-2 10-1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration PH20100S_3 Product data sheet Rev. 03 — 2 February 2009 4 of 12 © Nexperia B.V. 2017. All rights reserved PH20100S Nexperia N-channel TrenchMOS standard level FET 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS drain-source breakdown voltage ID = 1 mA; VGS = 0 V; Tj = 25 °C 100 - - V VGS(th) gate-source threshold voltage ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 7 2 3 4 V ID = 1 mA; VDS = VGS; Tj = 150 °C; see Figure 7 1.2 - - V VDS = 100 V; VGS = 0 V; Tj = 25 °C - 0.06 1 µA VDS = 100 V; VGS = 0 V; Tj = 150 °C - - 500 µA VGS = 20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = -20 V; VDS = 0 V; Tj = 25 °C - 2 100 nA VGS = 10 V; ID = 10 A; Tj = 150 °C; see Figure 8; see Figure 9 - 43 53 mΩ VGS = 10 V; ID = 10 A; Tj = 25 °C; see Figure 8; see Figure 9 - 19 23 mΩ ID = 20 A; VDS = 50 V; VGS = 10 V; Tj = 25 °C; see Figure 11 - 39 - nC - 6.9 - nC - 8.9 - nC - 2264 - pF - 290 - pF - 111 - pF - 23 - ns - 15 - ns IDSS IGSS RDSon drain leakage current gate leakage current drain-source on-state resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time - 47 - ns tf fall time - 9.3 - ns VDS = 25 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 12 VDS = 50 V; RL = 5 Ω; VGS = 10 V; RG(ext) = 4.7 Ω; ID = 10 A; Tj = 25 °C Source-drain diode VSD source-drain voltage IS = 10 A; VGS = 0 V; Tj = 25 °C; see Figure 10 - 0.8 1.2 V trr reverse recovery time IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 25 V; Tj = 25 °C - 110 - ns PH20100S_3 Product data sheet Rev. 03 — 2 February 2009 5 of 12 © Nexperia B.V. 2017. All rights reserved PH20100S Nexperia N-channel TrenchMOS standard level FET 003aaa408 40 6V 10 V ID (A) 003aaa409 40 ID (A) VGS = 5.5 V 30 30 20 20 5.2 V 25 °C Tj = 150 °C 5V 10 10 4.8 V 4.5 V 0 0 0 Fig 4. 1 2 3 VDS (V) 4 Output characteristics: drain current as a function of drain-source voltage; typical values 2 Fig 5. 03aa35 10−1 ID (A) 4 5 VGS (V) 6 Transfer characteristics: drain current as a function of gate-source voltage; typical values 03aa32 5 VGS(th) (V) min 10−2 typ max 4 10−3 3 10−4 2 10−5 1 10−6 0 2 4 0 −60 6 VGS (V) Fig 6. 3 Sub-threshold drain current as a function of gate-source voltage Fig 7. max typ min 0 60 120 180 Tj (°C) Gate-source threshold voltage as a function of junction temperature PH20100S_3 Product data sheet Rev. 03 — 2 February 2009 6 of 12 © Nexperia B.V. 2017. All rights reserved PH20100S Nexperia N-channel TrenchMOS standard level FET 003aaa410 60 RDSon (mΩ) VGS = 5 V 5.2 V 03aa31 3 5.5 V a 50 2 40 30 6V 1 7V 20 10 V 10 0 Fig 8. 10 20 30 Drain-source on-state resistance as a function of drain current; typical values 003aaa412 40 0 -60 40 ID (A) Fig 9. 0 60 120 Tj (°C) 180 Normalized drain-source on-state resistance factor as a function of junction temperature 003aaa413 10 VGS (V) IS (A) 8 30 6 20 4 150 °C Tj = 25 °C 10 2 0 0.2 0 0.4 0.6 0.8 VSD (V) 1 Fig 10. Source current as a function of source-drain voltage; typical values 0 10 20 30 QG (nC) 40 Fig 11. Gate-source voltage as a function of gate charge; typical values PH20100S_3 Product data sheet Rev. 03 — 2 February 2009 7 of 12 © Nexperia B.V. 2017. All rights reserved PH20100S Nexperia N-channel TrenchMOS standard level FET 003aaa411 104 C (pF) Ciss 103 Coss 102 10-1 Crss 1 10 VDS (V) 102 Fig 12. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values PH20100S_3 Product data sheet Rev. 03 — 2 February 2009 8 of 12 © Nexperia B.V. 2017. All rights reserved PH20100S Nexperia N-channel TrenchMOS standard level FET 7. Package outline Plastic single-ended surface-mounted package (LFPAK); 4 leads A2 A E SOT669 C c2 b2 E1 b3 L1 mounting base b4 D1 D H L2 1 2 3 e 4 w M A b 1/2 X c e A (A 3) A1 C θ L detail X y C 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT mm A A1 A2 A3 b b2 1.20 0.15 1.10 0.50 4.41 0.25 1.01 0.00 0.95 0.35 3.62 b3 b4 2.2 2.0 0.9 0.7 c D (1) c2 D1(1) E(1) E1(1) max 0.25 0.30 4.10 4.20 0.19 0.24 3.80 5.0 4.8 3.3 3.1 e H L L1 L2 w y θ 1.27 6.2 5.8 0.85 0.40 1.3 0.8 1.3 0.8 0.25 0.1 8° 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. OUTLINE VERSION SOT669 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 04-10-13 06-03-16 MO-235 Fig 13. Package outline SOT669 (LFPAK) PH20100S_3 Product data sheet Rev. 03 — 2 February 2009 9 of 12 © Nexperia B.V. 2017. All rights reserved PH20100S Nexperia N-channel TrenchMOS standard level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PH20100S_3 20090202 Product data sheet - PH20100S_2 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. PH20100S_2 (9397 750 13698) 20040817 Product data sheet - PH20100S_1 PH20100S_1 (9397 750 12815) 20040305 Preliminary data sheet - - PH20100S_3 Product data sheet Rev. 03 — 2 February 2009 10 of 12 © Nexperia B.V. 2017. All rights reserved PH20100S Nexperia N-channel TrenchMOS standard level FET 9. Legal information 9.1 Data sheet status Document status [1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 9.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PH20100S_3 Product data sheet Rev. 03 — 2 February 2009 11 of 12 © Nexperia B.V. 2017. All rights reserved Nexperia PH20100S N-channel TrenchMOS standard level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . . 11 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 02 February 2009
PH20100S,115 价格&库存
很抱歉,暂时无法提供与“PH20100S,115”相匹配的价格&库存,您可以联系我们找货
