AC0201FR-071R54L
AC0201FR-071R54L
    YAGEO(国巨)
    贴片电阻 0201 1.54Ω ±1% 1/20W -100~+350ppm/℃
AC0201FR-071R54L 数据手册
DATA SHEET THICK FILM CHIP RESISTORS AUTOMOTIVE GRADE AC series ±5%, ±1%, ±0.5% Sizes 0201/0402/0603/0805/1206/ 1210/1218/2010/2512 Product specification – March 19, 2021 V.8 RoHS compliant & Halogen free 2 Product specification Chip Resistor Surface Mount AC 12 0201 to 2512 SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes AC0201 to AC2512 chip resistors with leadfree terminations made by thick film process. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. APPLICATIONS ⚫ ⚫ All general purpose applications Car electronics, industrial application FEATURES ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ AEC-Q200 qualified Moisture sensitivity level: MSL 1 AC series soldering is compliant with J-STD-020D Halogen free epoxy RoHS compliant - Products with lead-free terminations meet RoHS requirements - Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS Reduce environmentally hazardous waste High component and equipment reliability The resistors are 100% performed by automatic optical inspection prior to taping. GLOBAL PART NUMBER AC XXXX X X X XX XXXX L (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0201/ 0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512 (2) TOLERANCE D = ± 0.5% J = ± 5% (for Jumper ordering, use code of J) F = ± 1% (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec (5) TAPING REEL 07 = 7 inch dia. Reel 10 = 10 inch dia. Reel 13 = 13 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power 3W = 13 inch dia. Reel & 2 x standard power (6) RESISTANCE VALUE 1Ω to 22 MΩ There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed coding rules of resistance are shown in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) Resistance rule of global part number Resistance coding Example rule XRXX (1 to 9.76Ω) 1R = 1Ω 1R5 = 1.5Ω 9R76 = 9.76Ω XXRX (10 to 97.6Ω) 10R = 10Ω 97R6 = 97.6Ω XXXR (100 to 976Ω) 100R = 100Ω 976R = 976Ω XKXX (1 to 9.76 KΩ) 1K = 1,000Ω 9K76 = 9760Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000Ω 9M76= 9,760,000Ω XXMX (10 MΩ) 10M = 10,000,000Ω ORDERING EXAMPLE The ordering code for an AC0402 chip resistor, value 100 KΩ with ± 1% tolerance, supplied in 7-inch tape reel is: AC0402FR-07100KL. NOTE 1. All our R-Chip products are RoHS compliant and Halogen free. "LFP" of the internal 2D reel label states "Lead-Free Process". 2. On customized label, "LFP" or specific symbol can be printed. 3. AC series with ±0.5% tolerance is also available. For further information, please contact sales. www.yageo.com Mar. 19,2021 V.8 Product specification Chip Resistor Surface Mount AC SERIES 3 12 0201 to 2512 MARKING AC0201 / AC0402 No marking ynsc007 Fig. 1 AC0603 / AC0805 / AC1206 / AC1210 / AC2010 / AC2512 03 Fig. 2 YNSC001 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Value=10 KΩ AC0603 0 YNSC037 Fig. 3 E-24 series: 3 digits, ± 1% & ± 0.5% One short bar under marking letter Value = 24 Ω E-96 series: 3 digits, ± 1% & ± 0.5% First two digits for E-96 marking rule and 3rd letter for number of zeros Fig. 4 Value = 12.4 KΩ AC0805 / AC1206 / AC1210 / AC2010 / AC2512 Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros Fig. 5 Value = 10 KΩ AC1218 YNSC099 E-24 series: 3 digits, ± 5% First two digits for significant figure and 3rd digit for number of zeros Fig. 6 Value = 10 KΩ 00 YNSC103 Both E-24 and E-96 series: 4 digits, ± 1% & ± 0.5% First three digits for significant figure and 4th digit for number of zeros Fig. 7 Value = 10 KΩ NOTE For further marking information, please refer to data sheet “Chip resistors marking”. Marking of AC series is the same as RC series. www.yageo.com Mar. 19,2021 V.8 Product specification Chip Resistor Surface Mount AC SERIES 4 12 0201 to 2512 CONSTRUCTION The resistors are constructed on top of an automotive grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive glaze. The resistive glaze is covered by a protective glass. The composition of the glaze is adjusted to give the approximately required resistance value and laser trimming of this resistive glaze achieves the value within tolerance. The whole element is covered by a protective overcoat. Size 0603 and bigger is marked with the resistance value on top. Finally, the two external terminations (Ni / matte tin) are added, as shown in Fig.8. OUTLINES marking layer overcoat overcoat protective glass protective glass resistive layer (Jumper chip is a conductor) resistive layer (Jumper chip is a conductor) inner electrode termination(Ni/matte tin) inner electrode inner electrode termination(Ni/matte tin) inner electrode ceramic substrate YNSC088 Fig. 8_1 marking layer ceramic substrate YNSC088_1 Fig. 8_2 Chip resistor outlines AC2010/ 2512 double power chip resistor outlines DIMENSIONS Table 1 For outlines, please refer to Fig. 9 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) AC0201 0.60 ± 0.03 0.30 ± 0.03 0.23 ± 0.03 0.12 ± 0.05 0.15 ± 0.05 AC0402 1.00 ± 0.05 0.50 ± 0.05 0.32 ± 0.05 0.20 ± 0.10 0.25 ± 0.10 AC0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10 0.25 ± 0.15 0.25 ± 0.15 AC0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10 0.35 ± 0.20 0.35 ± 0.20 AC1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.40 ± 0.20 AC1210 3.10 ± 0.10 2.60 ± 0.15 0.55 ± 0.10 0.45 ± 0.15 0.50 ± 0.20 AC1218 3.10 ± 0.10 4.60 ± 0.10 0.55 ± 0.10 0.45 ± 0.20 0.40 ± 0.20 AC2010 5.00 ± 0.10 2.50 ± 0.15 0.55 ± 0.10 0.55 ± 0.15 0.50 ± 0.20 AC2512 6.35 ± 0.10 3.10 ± 0.15 0.55 ± 0.10 0.60 ± 0.20 0.50 ± 0.20 For dimension, please refer to Table 1 AC0201/0402 0603/0805/1206/1210/ 2010/2512 I1 AC1218 Side view for all type I1 I1 W W Fig. 9 Chip resistor dimensions H W I2 L L L YNSC096 www.yageo.com Mar. 19,2021 V.8 Product specification Chip Resistor Surface Mount AC SERIES 5 12 0201 to 2512 ELECTRICAL CHARACTERISTICS Table 2 TYPE POWER CHARACTERISTICS Resistance Range Operating Max. Max. Dielectric Temperature Working Overload Withstanding Range Voltage Voltage Voltage 5% (E24) AC0201 1/20 W -55 °C to 155 °C 25V 50V 50V Temperature Coefficient Jumper Criteria 1Ω ≤ R ≤ 10Ω Rated Current 1Ω ≤ R ≤ 10MΩ -100/+350ppm℃ 0.5A 1% (E24/E96) 10Ω < R ≤ 10M Maximum 1Ω ≤ R ≤ 10MΩ ± 200ppm°C Current 1.0A 0.5% (E24/E96) 10Ω ≤ R ≤ 1MΩ Jumper
AC0201FR-071R54L
物料型号:AC系列,尺寸从0201到2512,公差为±5%,±1%,±0.5%。
器件简介:这是一系列由厚膜工艺制成的无铅端子的片式电阻器,符合汽车级标准,适用于汽车电子、工业应用等一般用途。
引脚分配:文档中没有提供具体的引脚分配信息,但通常这类片式电阻器为表面贴装元件,具有两个端子用于连接电路。
参数特性: - 工作温度范围:-55°C 至 155°C - 最大电压:根据型号不同,分别为25V、50V、75V、150V、200V、400V、500V - 额定功率:根据型号不同,分别为1/20W、1/16W、1/10W、1/8W、1/4W、1/2W、3/4W、1W、1.25W、1.5W、2W - 温度系数:5%(E24)、0.5%、1%(E24/E96) - 跳线标准:根据电阻值不同,有不同的电流承载能力
功能详解:电阻器采用陶瓷基底,内部金属电极通过电阻性釉料连接,并通过激光修调以确保精度。电阻体被保护玻璃覆盖,并有外部端子(镍/亚光锡)。
应用信息:适用于一般用途,包括汽车电子和工业应用。
封装信息:提供多种尺寸的封装,从0201至2512,并且有纸带卷装和压花卷装两种包装方式。
AC0201FR-071R54L 价格&库存
很抱歉,暂时无法提供与“AC0201FR-071R54L”相匹配的价格&库存,您可以联系我们找货
AC0201FR-071R54L
  • 10000+0.0743310000+0.00967
