PMXB56EN
30 V, N-channel Trench MOSFET
27 October 2020
Product data sheet
1. General description
N-channel enhancement mode Field-Effect Transistor (FET) in a leadless ultra small DFN1010D-3
(SOT1215) Surface-Mounted Device (SMD) plastic package using Trench MOSFET technology.
2. Features and benefits
Leadless ultra small and thin SMD plastic package: 1.1 × 1.0 × 0.37 mm
Exposed drain pad for excellent thermal conduction
Very low Drain-Source on-state resistance RDSon = 49 mΩ
Very fast switching
3. Applications
Low-side load switch and charging switch for portable devices
Power management in battery-driven portables
LED driver
DC-to-DC converters
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj = 25 °C
30
V
VGS
gate-source voltage
-20
V
ID
drain current
3.2
A
49
55
mΩ
VGS = 10 V; Tamb = 25 °C
[1]
Static characteristics
RDSon
[1]
drain-source on-state
resistance
VGS = 10 V; ID = 3.2 A; Tj = 25 °C
2
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for drain 6 cm .
PMXB56EN
Nexperia
5. Pinning information
Table 2. Pinning information
Pin
Symbol
Description
1
G
gate
2
S
source
3
D
drain
4
D
drain
Simplified outline
Graphic symbol
D
1
4
G
3
S
017aaa253
2
Transparent top view
DFN1010D-3 (SOT1215)
6. Ordering information
Table 3. Ordering information
Type number
Package
PMXB56EN
Name
Description
Version
DFN1010D-3
plastic, leadless thermal enhanced ultra thin small outline
package with side-wettable flanks (SWF); 3 terminals; 0.75 mm
pitch; 1.1 mm x 1 mm x 0.37 mm body
SOT1215
7. Marking
Table 4. Marking codes
Type number
Marking code
PMXB56EN
01
10
10
MARKING CODE
(EXAMPLE)
READING
DIRECTION
YEAR DATE
CODE
VENDOR CODE
PIN 1
INDICATION MARK
MARK-FREE AREA
READING EXAMPLE:
11
01
10
Fig. 1.
aaa-008041
DFN1010D-3 (SOT1215) binary marking code description
PMXB56EN
Product data sheet
All information provided in this document is subject to legal disclaimers.
27 October 2020
Nexperia B.V. 2020. All rights reserved
2 / 14
PMXB56EN
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
Tj = 25 °C
30
V
VGS
gate-source voltage
-20
V
ID
drain current
[1]
3.2
A
VGS = 10 V; Tamb = 100 °C
[1]
2.8
A
15
A
[2]
0.4
W
[1]
1.07
W
IDM
peak drain current
Tamb = 25 °C; single pulse; tp ≤ 10 µs
Ptot
total power dissipation
Tamb = 25 °C
8.33
W
Tj
junction temperature
Tsp = 25 °C
-55
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
1
A
Source-drain diode
IS
[1]
[2]
source current
Tamb = 25 °C
[1]
2
Device mounted on an FR4 Printed Circuit Board (PCB), single-sided copper, tin-plated and standard footprint.
017aaa123
120
Pder
Ider
80
80
40
40
Fig. 2.
017aaa124
120
- 25
25
75
125
Tj (°C)
Normalized total power dissipation as a
function of junction temperature
PMXB56EN
Product data sheet
175
Fig. 3.
- 25
75
125
Tj (°C)
175
Normalized continuous drain current as a
27 October 2020
25
3 / 14
PMXB56EN
Nexperia
aaa-009040
102
lD
(A)
tp = 10 µs
10
tp = 100 µs
1
tp = 1 ms
DC; Tamb = 25 °C; 6 cm2
tp = 10 ms
DC; Tsp = 25 °C
10-1
tp = 100 ms
10-2
10-1
1
10
102
VDS (V)
IDM = single pulse
Fig. 4.
Safe operating area; junction to ambient; continuous and peak drain currents as a function of drainsource voltage
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Rth(j-a)
thermal resistance from in free air
junction to ambient
Rth(j-sp)
[1]
[2]
Conditions
junction to solder point
Min
Typ
Max
Unit
[1]
271
312
K/W
[2]
102
117
K/W
10
15
K/W
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint.
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for drain 6 cm .
aaa-008918
103
Zth(j-a)
(K/W)
102
duty cycle = 1
0.5
0.25
0.75
0.33
0.1
10
0.2
0.05
0.02
1
10-3
10-2
10-1
1
10
102
tp (s)
103
FR4 PCB, standard footprint
Fig. 5.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
PMXB56EN
Product data sheet
27 October 2020
4 / 14
PMXB56EN
Nexperia
103
aaa-008919
duty cycle = 1
0.75
0.5
0.33
Zth(j-a)
(K/W)
102
10
0.02
0.01
10-3
0.25
0.2
0.1
0.05
10-2
10-1
FR4 PCB, mounting pad for drain 6 cm
Fig. 6.
1
10
102
tp (s)
2
103
PMXB56EN
Product data sheet
27 October 2020
5 / 14
PMXB56EN
Nexperia
10. Characteristics
Table 7. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source
breakdown voltage
ID = 250 µA; VGS = 0 V; Tj = 25 °C
30
V
VGSth
gate-source threshold
voltage
ID = 250 µA; VDS=VGS; Tj = 25 °C
1
1.5
2
V
IDSS
drain leakage current
VDS = 30 V; VGS = 0 V; Tj = 25 °C
1
µA
IGSS
gate leakage current
VGS = 20 V; VDS = 0 V; Tj = 25 °C
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
-100
nA
RDSon
resistance
49
55
mΩ
VGS = 10 V; ID = 2.8 A; Tj = 150 °C
77
87
mΩ
VGS = 4.5 V; ID = 3.2 A; Tj = 25 °C
56
65
mΩ
gfs
forward
transconductance
VDS = 10 V; ID = 3.2 A; Tj = 25 °C
13
S
RG
gate resistance
f = 1 MHz; Tj = 25 °C
2.3
Ω
VDS = 15 V; ID = 3.2 A; VGS = 10 V;
Tj = 25 °C
3.6
6.3
nC
0.5
nC
0.4
nC
209
pF
50
pF
17
pF
3
ns
12
ns
Dynamic characteristics
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
turn-off delay time
11
ns
tf
fall time
2
ns
0.7
1.2
V
VDS = 15 V; f = 1 MHz; VGS = 0 V;
Tj = 25 °C
RG(ext) = 6 Ω; Tj = 25 °C
Source-drain diode
VSD
source-drain voltage
PMXB56EN
Product data sheet
IS = 1 A; VGS = 0 V; Tj = 25 °C
27 October 2020
6 / 14
PMXB56EN
Nexperia
aaa-009041
12
5.0 V
aaa-009043
10-2
3.5 V
ID
(A)
ID
(A)
10-3
3.2 V
min
8
typ
max
3.0 V
10-4
4
10-5
2.6 V
Fig. 7.
2.8 V
VGS = 2.5 V
2.7 V
2
3
VDS (V)
10-6
4
1.5
2.0
2.5
VGS (V)
Tj = 25 °C
Tj = 25 °C; VDS = 5 V
Output characteristics: drain current as a
Fig. 8.
function of drain-source voltage; typical values
Sub-threshold drain current as a function of
gate-source voltage
aaa-009044
300
2.5 V
2.8 V
3.1 V
RDSon
(mΩ)
200
200
4.5 V
100
aaa-009045
300
3.5 V
RDSon
(mΩ)
Tj = 150 °C
100
Tj = 25 °C
VGS = 10 V
8
ID (A)
Tj = 25 °C
Fig. 9.
0.5
Product data sheet
2
4
6
8
10
VGS (V)
ID = 3.2 A
Drain-source on-state resistance as a function
of drain current; typical values
PMXB56EN
Fig. 10. Drain-source on-state resistance as a function
of gate-source voltage; typical values
27 October 2020
7 / 14
PMXB56EN
Nexperia
aaa-009046
12
aaa-009047
1.8
a
ID
(A)
1.5
8
1.2
Tj = 150 °C
4
0.9
Tj = 25 °C
2
3
4
VGS (V)
0.6
-60
5
120
Tj (°C)
180
VDS > ID × RDSon
Fig. 11. Transfer characteristics: drain current as a
function of gate-source voltage; typical values
Fig. 12. Normalized drain-source on-state resistance
as a function of junction temperature; typical
values
aaa-009048
3
aaa-009049
103
C
(pF)
VGS(th)
(V)
max
2
Ciss
102
Coss
typ
min
1
120
Tj (°C)
1
180
Fig. 13. Gate-source threshold voltage as a function of
Product data sheet
10-1
1
10
VDS (V)
102
ID = 0.25 mA; VDS = VGS
PMXB56EN
Crss
10
Fig. 14. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
27 October 2020
8 / 14
PMXB56EN
Nexperia
aaa-009050
10
VGS
(V)
VDS
8
ID
6
VGS(pl)
4
VGS(th)
VGS
2
QGS2
QGS1
2
3
QG (nC)
QGS
4
QGD
QG(tot)
ID = 3.2 A; VDS = 15 V; Tamb = 25 °C
003aaa508
Fig. 16. Gate charge waveform definitions
Fig. 15. Gate-source voltage as a function of gate
charge; typical values
aaa-009052
4
IS
(A)
3
Tj = 150 °C
2
Tj = 25 °C
1
0.8
VSD (V)
1.2
VGS = 0 V
Fig. 17. Source current as a function of source-drain voltage; typical values
11. Test information
P
t2
duty cycle δ =
t1
t2
t1
t
006aaa812
Fig. 18. Duty cycle definition
PMXB56EN
Product data sheet
27 October 2020
9 / 14
PMXB56EN
Nexperia
12. Package outline
DFN1010D-3: plastic thermal enhanced ultra thin small outline package; no leads;
3 terminals; body: 1.1 x 1.0 x 0.37 mm
SOT1215
visible depend upon
used manufacturing
technology (2x)
solderable lead
end, protrusion
max. 0.02 mm (3x)
pin 1
index area
visible depend upon
used manufacturing
technology (4x)
e
b (2x)
1
2
L (2x)
E
E1
e1
L1
D
A1
3
b1
A
D1
1 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A
A1
b
b1
D
D1
E
E1
e
e1
min 0.34
0.22 0.245 1.05 0.87 0.95 0.16
nom 0.37
0.25 0.275 1.10 0.90 1.00 0.19 0.75
max 0.40 0.04 0.30 0.325 1.15 0.95 1.05 0.24
0.1
L
L1
0.17 0.195
0.20 0.225
0.25 0.275
Note
1. Dimension A is including plating thickness.
Outline
version
sot1215_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
13-03-05
13-03-06
SOT1215
Fig. 19. Package outline DFN1010D-3 (SOT1215)
PMXB56EN
Product data sheet
27 October 2020
10 / 14
PMXB56EN
Nexperia
13. Soldering
Footprint information for reflow soldering of DFN1010D-3 package
SOT1215
1.2
0.45 (2x)
0.3
1.1
0.35 (2x)
0.4
0.25 (2x)
0.75
0.3
0.5
1.5
1.4
0.4
0.5
0.4
0.3
0.5
1.3
0.4
0.3
0.4
0.5
1.3
solder land
solder land plus solder paste
occupied area
solder resist
Dimensions in mm
Issue date
12-11-23
13-03-06
sot1215_fr
Fig. 20. Reflow soldering footprint for DFN1010D-3 (SOT1215)
PMXB56EN
Product data sheet
27 October 2020
11 / 14
PMXB56EN
Nexperia
14. Revision history
Table 8. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PMXB56EN v.4
20201027
Product data sheet
PMXB56EN v.3
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
PMXB56EN v.3
20170111
Product data sheet
PMXB56EN v.2
PMXB56EN v.2
20140430
Product data sheet
PMXB56EN v.1
PMXB56EN v.1
20130925
Product data sheet
PMXB56EN
Product data sheet
27 October 2020
12 / 14
PMXB56EN
Nexperia
15. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
PMXB56EN
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
27 October 2020
13 / 14
PMXB56EN
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Thermal characteristics............................................... 4
10. Characteristics............................................................ 6
11. Test information.......................................................... 9
12. Package outline........................................................ 10
13. Soldering................................................................... 11
14. Revision history........................................................12
15. Legal information......................................................13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 27 October 2020
PMXB56EN
Product data sheet
27 October 2020
14 / 14
