Technical Data 10282
Effective April 2016
Supersedes August 2014
HCMA0703
Automotive grade
High current power inductors
Applications
Product features
Body electronics
• Central body control module
Vehicle access control system
Headlamps, tai lamps and interior lighting
Heating ventilation and air conditioning
controllers (HVAC)
Doors, window lift and seat control
Advanced driver assistance systems
• 77 GHz radar systems
Adaptive cruise control (ACC)
Automatic parking control
Collision avoidance system
Car black box system
Automotive grade 3 qualified
High current carrying capacity, low core losses
Infotainment and cluster electronics
• Active noise cancellation (ANC)
Magnetically shielded, low EMI
Audio subsystem: head unit and trunk amp
Frequency range up to 5 MHz
Digital instrument cluster
Inductance range from 0.15 μH to 33 μH
In-vehicle infotainment (IVI) and navigation
Current range from 1.8 A to 52 A
7.4 mm x 7.0 mm footprint surface mount
package in a 3.0 mm height
Port power/USB HUB for front and rear
passengers
Iron powder core material
Chassis and safety electronics
• Airbag control unit
Electronic Stability Control System (ESC)
Environmental Data
Storage temperature range (Component):
-55 °C to +125 °C
Operating temperature range: -55 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (Latest revision) compliant
HALOGEN
Pb HF
FREE
HCMA0703
Automotive grade high current power inductors
Product Specifications
OCL1
(μH) ± 20%
FLL2 (μH)
minimum
Irms3
(A)
Isat4
(A)
DCR (mΩ)
typical
@ +20 °C
DCR (mΩ)
maximum
@ +20 °C
K-factor5
HCMA0703-R15-R
0.15
0.09
26
52
1.9
2.5
1044
HCMA0703-R22-R
0.22
0.13
23
40
2.5
2.8
986
HCMA0703-R47-R
0.47
0.28
17.5
26
4.0
4.2
580
HCMA0703-R68-R
0.68
0.41
15.5
25
5.0
5.5
455
HCMA0703-R82-R
0.82
0.49
13
24
6.7
8.0
439
HCMA0703-1R0-R
1.0
0.60
11
22
9.0
10
374
HCMA0703-1R5-R
1.5
0.90
9.0
18
14
15
366
HCMA0703-2R2-R
2.2
1.32
8.0
14
18
HCMA0703-3R3-R
3.3
1.98
6.0
13.5
28
30
252
HCMA0703-4R7-R
4.7
2.82
5.5
10
37
40
210
HCMA0703-6R8-R
6.8
4.08
4.5
8.0
54
60
151
HCMA0703-8R2-R
8.2
4.92
4.0
7.5
64
68
142
HCMA0703-100-R
10
6.00
3.2
7.0
71
78
132
HCMA0703-220-R
22
14.1
2.3
3.0
135
149
83
HCMA0703-330-R
33
19.8
1.8
2.2
220
242
76
Part Number
6
1. Open Circuit Inductance (OCL) Test Parameters: 100kHz, 0.25 Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, +25 °C
3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating
conditions verified in the end application.
Dimensions (mm)
2
www.eaton.com/electronics
4. Isat: Peak current for approximately 20% rolloff @ +25 °C
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table),
L: (Inductance in μH), ΔI (Peak to peak ripple current in Amps).
6. Part Number Definition: HCMA0703-xxx-R
HCMA0703 = Product code and size
-xxx= inductance value in μH, R= decimal point,
If no R is present then last character equals number of zeros
-R suffix = RoHS compliant
HCMA0703
Packaging information (mm)
Supplied in tape and reel packaging , 1500 parts per 13” diameter reel
Temperature rise vs. total loss
50.0
Temperature Rise ( C)
40.0
30.0
20.0
10.0
0.0
0.0
0.2
0.4
0.6
0.8
1.0
1.2
Total Loss (W)
3
HCMA0703
Core loss vs. Bp-p
10000
1 MHz
500 kHz
300 kHz
200 kHz
1000
Core Loss (mW)
100 kHz
100
10
1
0.1
100
10000
1000
Bp-p (Gauss)
Inductance characteristics
110%
110%
90%
90%
% of OCL
100%
% of OCL
100%
80%
70%
80%
70%
60%
60%
50%
50%
40%
4
HCMA0703-R22-R
HCMA0703-R15-R
30
40
IDC (A)
50
60
70
40%
40
IDC (A)
50
60
70
HCMA0703
HCMA0703-R47-R
110%
90%
90%
% of OCL
100%
% of OCL
100%
80%
70%
80%
70%
60%
60%
50%
50%
40%
10
15
30
35
HCMA0703-R68-R
110%
40
45
50
40%
10
15
IDC (A)
% of OCL
% of OCL
40
45
90%
80%
70%
80%
70%
60%
60%
50%
50%
40%
10
15
30
35
40
45
10
HCMA0703-1R5-R
110%
100%
90%
90%
% of OCL
100%
70%
50%
50%
10
15
IDC (A)
25
30
35
30
35
40
70%
60%
5
25
80%
60%
HCMA0703-2R2-R
110%
80%
15
IDC (A)
IDC (A)
% of OCL
35
100%
90%
40%
30
HCMA0703-1R0-R
110%
100%
40%
25
IDC (A)
HCMA0703-R82-R
110%
40%
10
15
30
IDC (A)
5
HCMA0703
HCMA0703-3R3-R
110%
90%
90%
% of OCL
100%
% of OCL
100%
80%
70%
80%
70%
60%
60%
50%
50%
40%
HCMA0703-4R7-R
110%
4
6
8
10
12
14
16
18
40%
IDC (A)
4
6
HCMA0703-6R8-R
100%
90%
90%
% of OCL
100%
% of OCL
110%
80%
70%
50%
50%
4
6
8
10
IDC (A)
12
HCMA0703-100-R
100%
100%
90%
90%
% of OCL
110%
% of OCL
6
40%
14
110%
80%
70%
50%
50%
40%
40%
4
6
8
IDC (A)
18
12
14
HCMA0703-8R2-R
4
6
8
10
IDC (A)
12
14
HCMA0703-220-R
70%
60%
2
16
80%
60%
70%
60%
2
12
80%
60%
IDC (A)
110%
40%
8
2
3
IDC (A)
4
5
6
HCMA0703
HCMA0703-330-R
110%
100%
% of OCL
90%
80%
70%
60%
50%
40%
2
3
IDC (A)
4
5
6
7
HCMA0703
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“HCMA0703-6R8-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6.775861+0.85046
- 10+5.5419510+0.69559
- 25+5.1266825+0.64347
- 50+4.8326750+0.60657
- 100+4.55653100+0.57191
- 250+4.21520250+0.52907
- 500+3.97436500+0.49884
- 国内价格 香港价格
- 1500+3.802071500+0.47721
- 3000+3.585473000+0.45003
- 4500+3.464694500+0.43487
- 7500+3.318427500+0.41651
- 10500+3.2255810500+0.40486
- 15000+3.1300915000+0.39287
