MMD-05CZ-3R3M-M2-RU
MMD-05CZ-3R3M-M2-RU
    MAGLAYERS(美磊科技)
    SMD,5.5x5.2mm
    FIXED IND 3.3UH 5A 38 MOHM SMD
MMD-05CZ-3R3M-M2-RU 数据手册
Mag Layers USA, INC Specification Sheet P/N : MMD-05CZ-SERIES-M2-RU Products: Certifications: Molded Power Chokes ISO9001 Multilayer Chip Inductors IATF16949 Lan Transformer ISO14001 RF Passive / Antennas QC080000 Automotive US Office 5406 Bolsa Ave., Huntington Beach, CA 92649 (714) 898-8377 Contact Us www.maglayersusa.com info@maglayersusa.com ■ Application Laptop, desktop and server applications High current power supplies Battery powered devices PMIC ■ Features RoHS compliant & halogen free Low resistance and high current rating Magnetic core made by high performance magnetic metal powder ■ Product Identification ① ② ③ ④ ⑤ MMD - 05CZ - R22 M - M2-RU ① Product Code ② Dimensions ③ Inductance: R22 = 0.22 μH ④ Inductance Tolerance: M = ±20% ⑤ Series Type: M2 Type Note: Please refer to the “Product Dimension” for detail dimensions. M AG .LAY ER S MMD-05CZ-SERIES-M2-RU 1 of 9 ■ Electrical Performance Inductance Heat rating Saturation Rdc(mΩ) Part number current (Idc)1 current (Isat)2 ±20%@0A (µH) Typ. Max. DC amps (A) DC amps (A) MMD-05CZ-R22M-M2-RU 0.22 4.2 4.5 15 21 MMD-05CZ-R47M-M2-RU 0.47 6.4 7 12.5 17 MMD-05CZ-R68M-M2-RU 0.68 10 12 8.5 14 MMD-05CZ-R80M-M2-RU 0.8 5.14 5.65 13 18.5 MMD-05CZ-1R0M-M2-RU 1 12.6 13.86 7 11 MMD-05CZ-1R2M-M2-RU 1.2 15 16 6.5 11 MMD-05CZ-1R5M-M2-RU 1.5 20 25 6 10 MMD-05CZ-2R2M-M2-RU 2.2 29 35 5.5 9 MMD-05CZ-3R3M-M2-RU 3.3 34 38 5 7 MMD-05CZ-4R7M-M2-RU 4.7 59 64.9 3.5 4.1 M AG .LAY ER S MMD-05CZ-SERIES-M2-RU 2 of 9 ■ Note Test frequency: 100KHz, 0.25V. Test instruments: Inductance/saturation current: Keysight 4285A or equivalent. Rdc: ADEX AX1152D or equivalent. Notes: The heat rating current (Idc) will cause temperature rise approximate 40°C. The saturation current (Isat) will cause initial inductance drop approximate 30%. All test data is referenced at 25°C ambient. Operating temperature range -55°C to +125°C. The part temperature (ambient + temp rise) should not exceed 125°C under the worst condition. 6. The temperature of component is affected by application conditions, e.g. circuit design, copper thickness of PCB and cooling conditions, the actual component temperature should be tested in the end application. 1. 2. 3. 4. 5. M AG .LAY ER S MMD-05CZ-SERIES-M2-RU 3 of 9 ■ Electrical Characteristics M AG .LAY ER S MMD-05CZ-SERIES-M2-RU 4 of 9 M AG .LAY ER S MMD-05CZ-SERIES-M2-RU 5 of 9 ■ Product Dimension Code: XXX = R22 = 0.22 µH Dimension Part number A B MMD-05CZ-SERIES-M2-RU 5.49 ± 0.25 5.18 ± 0.22 C D E 3.0 Max 2.0 ± 0.3 1.0 ± 0.3 Unit: mm M AG .LAY ER S MMD-05CZ-SERIES-M2-RU 6 of 9 ■ Recommended PCB Layout Type A B C 05CZ 2.79 2.16 5.99 Unit: mm Safety precaution 1. Do not make any through holes and copper pattern in the dotted line area. Except a copper pattern to the electrode. 2. Don’t design/mount any components in contact with this product. This power choke do not have any protective function in abnormal condition such as overload, short circuit, open conditions and etc, it shall be confirmed as the end product that there is no risk of smoking, fire, dielectric withstand voltage, insulation resistance etc. in abnormal conditions to provide protective devices and/or protection circuit in the end product.It is recommended the temperature rise of choke during operation is less than 50°C. M AG .LAY ER S MMD-05CZ-SERIES-M2-RU 7 of 9 ■ Packaging Peel-off force 165° TO 180° TOP COVER TAPE BASE TAPE The peel off force of cover tape is 10 to 70 grams in the arrow direction. Dimensions F A B C Type A B C D E F 330mm 330±2 100±1 21.5±0.5 13±1.0 12.4 +2.0/-0 17.4±2 D Unit: mm E TYPE MMD SIZE 05CZ A B W P1 K 5.4±0.1 5.9±0.1 12.0±0.3 8.0±0.1 3.3±0.1 P0 P2 D E T 4.0±0.1 2.0±0.1 1.5±0.1 1.75±0.1 0.35±0.05 Unit: mm M AG .LAY ER S MMD-05CZ-SERIES-M2-RU 8 of 9 Taping quantity Series 05CZ PCS/Reel 1000 M AG .LAY ER S MMD-05CZ-SERIES-M2-RU 9 of 9
MMD-05CZ-3R3M-M2-RU 价格&库存
很抱歉,暂时无法提供与“MMD-05CZ-3R3M-M2-RU”相匹配的价格&库存,您可以联系我们找货
