TSD30H100CW – TSD30H200CW
Taiwan Semiconductor
30A, 100V - 200V Trench Schottky Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low forward voltage
Low power loss/ high efficiency
High forward surge capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
30
A
VRRM
100 - 200
V
IFSM
200
A
TJ MAX
150
°C
2
Package
TO-263AB (D PAK)
Configuration
Dual dies
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
2
Case: TO-263AB (D PAK)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Polarity: As marked
Weight: 1.60g (approximately)
2
TO-263AB (D PAK)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak reverse voltage
VRRM
Reverse voltage, total rms value
VR(RMS)
Forward current
Surge peak forward current, 8.3ms single
half sine wave superimposed on rated load
Critical rate of rise of off-state voltage
TSD30H TSD30H TSD30H TSD30H
UNIT
100CW 120CW 150CW 200CW
100CW
120CW
150CW
200CW
100
120
150
200
V
70
84
105
140
V
IF
30
A
IFSM
200
A
dv/dt
10,000
V/µs
Junction temperature
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: E2103
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJC
2.8
°C/W
Junction-to-case thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TSD30H100CW
TSD30H120CW
TSD30H150CW
Forward voltage per
(1)
diode
TSD30H200CW
VF
TSD30H100CW
TSD30H120CW
TSD30H150CW
Reverse current @
(2)
rated VR per diode
IF = 15A, TJ = 25°C
TSD30H200CW
TSD30H100CW
TSD30H120CW
TSD30H150CW
TSD30H200CW
TSD30H100CW
TSD30H120CW
TSD30H150CW
TSD30H200CW
IF = 15A, TJ = 125°C
TYP
MAX
UNIT
0.69
0.78
V
0.75
0.84
V
0.81
0.90
V
0.84
0.92
V
0.61
0.68
V
0.64
0.73
V
0.68
0.77
V
0.70
0.79
V
250
µA
150
µA
35
mA
mA
TJ = 25°C
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
TSD30HxCW
PACKAGE
2
TO-263AB (D PAK)
PACKING
800 / Tape & Reel
Notes:
1. "x" defines voltage from 100V(TSD30H100CW) to 200V(TSD30H200CW)
2
Version: E2103
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
TSD30H100CW
TSD30H120CW
TSD30H100CW
CAPACITANCE (pF)
30
TSD30H150CW
TSD30H200CW
15
1000
TSD30H120CW
100
TSD30H150CW
10
75
100
125
0.1
150
1
CASE TEMPERATURE ( C)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
TJ=150°C
10
TJ=125°C
1
TJ=100°C
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
90
100
10010
TSD30H100CW
UF1DLW
10 1
TJ=125°C
TJ=150°C
TJ=125°C
TJ=100°C
0.1
0.01
TJ=25°C
0.01
0.001
00.3
TSD30H120CW
TJ=150°C
TJ=125°C
TJ=100°C
0.01
0.001
TJ=25°C
0.0001
10
40
50
60
70
80
0.2 0.5 0.40.6
0.4
0.6 0.8 0.80.9
0.7
11
1.1
1.2
1.1
1.2
Fig.6 Typical Forward Characteristics
100
0.1
Pulse width 300μs
1% duty cycle
Pulse width
FORWARD VOLTAGE (V)
Fig.5 Typical Reverse Characteristics
1
TJ=25°C
1
0.1
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
TSD30H100CW
10
(A)
25
TSD30H200CW
f=1.0MHz
Vsig=50mVp-p
90 100
10010
TSD30H120CW
UF1DLW
10 1
TJ=125°C
TJ=125°C
TJ=150°C
TJ=25°C
1
0.1
(A)
AVERAGE FORWARD CURRENT (A)
45
TJ=100°C
0.1
0.01
0.01
0.001
TJ=25°C
Pulse width 300μs
1% duty cycle
Pulse width
00.3
0.2 0.5 0.4
0.4
0.6
0.6 0.8 0.8
0.7
0.9
11
FORWARD VOLTAGE (V)
3
Version: E2103
1
TJ=150°C
TJ=125°C
0.1
TJ=100°C
0.01
0.001
TJ=25°C
0.0001
40
50
60
70
80
90 100
10010
TSD30H150CW
UF1DLW
10 1
TJ=125°C
TJ=125°C
TJ=150°C
1
0.1
TJ=25°C
TJ=100°C
0.1
0.01
TJ=25°C
Pulse width 300μs
1% duty cycle
Pulse width
0.01
0.001
00.3
0.2 0.5 0.4
0.4
0.6
0.6 0.8 0.8
0.7
0.9
11
FORWARD VOLTAGE (V)
Fig.9 Typical Reverse Characteristics
Fig.10 Typical Forward Characteristics
10
TSD30H200CW
TJ=150°C
1
TJ=125°C
0.1
TJ=100°C
0.01
0.001
0.0001
TJ=25°C
0.00001
10
40
50
60
70
80
90 100
(A)
TSD30H150CW
1.1
1.2
1.1
1.2
10010
TSD30H200CW
10 1
1
0.1
UF1DLW
TJ=125°C
TJ=125°C
TJ=150°C
0.1
0.01
0.01
0.001
TJ=25°C
(A)
10
10
Fig.8 Typical Forward Characteristics
Fig.7 Typical Reverse Characteristics
TJ=100°C
TJ=25°C
Pulse width 300μs
1% duty cycle
Pulse width
0.2
0.4
0.5
0.4
0.6
0.6
0.7
0.8
0.8
0.9
1
1
FORWARD VOLTAGE (V)
4
Version: E2103
PACKAGE OUTLINE DIMENSIONS
2
TO-263AB (D PAK)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: E2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: E2103
很抱歉,暂时无法提供与“TSD30H150CW MNG”相匹配的价格&库存,您可以联系我们找货
