TSD20H200CW MNG
TSD20H200CW MNG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-263(D²Pak)
    DIODE, SCHOTTKY, TRENCH, 20A, 20
TSD20H200CW MNG 数据手册
TSD20H100CW – TSD20H200CW Taiwan Semiconductor 20A, 100V - 200V Trench Schottky Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Excellent high temperature stability Low forward voltage Low power loss/ high efficiency High forward surge capability RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT IF 20 A VRRM 100 - 200 V IFSM 100 A TJ MAX 150 °C 2 Package TO-263AB (D PAK) Configuration Dual dies ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converters MECHANICAL DATA ● ● ● ● ● ● 2 Case: TO-263AB (D PAK) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Polarity: As marked Weight: 1.60g (approximately) 2 TO-263AB (D PAK) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage VRRM Reverse voltage, total rms value VR(RMS) Forward current Surge peak forward current, 8.3ms single half sine wave superimposed on rated load Critical rate of rise of off-state voltage TSD20H TSD20H TSD20H TSD20H UNIT 100CW 120CW 150CW 200CW TSD20H TSD20H TSD20H TSD20H 100CW 120CW 150CW 200CW 100 120 150 200 V 70 84 105 140 V IF 20 A IFSM 100 A dv/dt 10,000 V/µs Junction temperature TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: G2103 TSD20H100CW – TSD20H200CW Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 3.8 °C/W Junction-to-case thermal resistance RӨJC 2.8 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL TYP MAX UNIT 0.57 - V 0.62 - V 0.72 - V TSD20H200CW 0.77 - V TSD20H100CW 0.67 0.79 V 0.78 0.87 V 0.81 0.90 V 0.83 0.93 V 0.50 - V 0.53 - V 0.58 - V TSD20H200CW 0.62 - V TSD20H100CW 0.59 0.68 V 0.63 0.72 V 0.66 0.75 V 0.68 0.78 V - 200 µA - 100 µA - 25 mA - 15 mA TSD20H100CW TSD20H120CW TSD20H150CW TSD20H120CW TSD20H150CW Forward voltage per diode (1) IF = 5A, TJ = 25°C IF = 10A, TJ = 25°C TSD20H200CW VF TSD20H100CW TSD20H120CW TSD20H150CW TSD20H120CW TSD20H150CW Reverse current @ rated VR per diode (2) TSD20H200CW TSD20H100CW TSD20H120CW TSD20H150CW TSD20H200CW TSD20H100CW TSD20H120CW TSD20H150CW TSD20H200CW IF = 5A, TJ = 125°C IF = 10A, TJ = 125°C TJ = 25°C IR TJ = 125°C Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) TSD20HxCW PACKAGE 2 TO-263AB (D PAK) PACKING 800 / Tape & Reel Notes: 1. "x" defines voltage from 100V(TSD20H100CW) to 200V(TSD20H200CW) 2 Version: G2103 TSD20H100CW – TSD20H200CW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 20 TSD20H100CW CAPACITANCE (pF) 15 10 1000 TSD20H120CW TSD20H200CW 100 5 TSD20H150CW 0 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 CASE TEMPERATURE 125 150 0.1 1 10 REVERSE VOLTAGE (V) (oC) Fig.4 Typical Forward Characteristics 100 TSD20H100CW 10 1 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.3 Typical Reverse Characteristics TJ=150oC TJ=125oC TJ=100oC 0.1 0.01 0.001 TJ=25oC 0.0001 10 20 30 40 50 60 70 80 90 100 100 100 10 TSD20H100CW 10 1 0.1 1 UF1DLW TJ=150oC TJ=125°C TJ=125oC TJ=25°C (A) AVERAGE FORWARD CURRENT (A) 25 TJ=100oC 0.01 0.1 TJ=25oC Pulse width 0.001 0.01 0.3 0.0 0.4 0.5 0.2 0.6 0.4 0.7 0.8 0.9 0.6 0.8 1 1.1 1.0 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 3 Version: G2103 1.2 TSD20H100CW – TSD20H200CW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Typical Forward Characteristics TSD20H120CW TJ 1 TJ=125oC 0.1 TJ =100oC 0.01 0.001 TJ=25oC 0.0001 TJ=150oC TJ=125°C 0.1 1 TJ=25oC 0.3 0.01 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TJ=150oC TJ=100oC 0.001 TJ=25oC 0.0001 30 40 50 60 70 80 90 0.4 0.5 0.2 0.6 0.7 0.4 0.8 0.9 0.6 1 0.8 1.1 1.2 1 Fig.8 Typical Forward Characteristics 0.1 20 Pulse width 0.001 FORWARD VOLTAGE (V) TJ=125oC 10 TJ=100oC 0 10 0.01 TJ=25°C TJ=125oC 0.01 0.1 Fig.7 Typical Reverse Characteristics 1 UF1DLW 101 10 20 30 40 50 60 70 80 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) TSD20H150CW TSD20H120CW 100 10 TSD20H150CW UF1DLW 10 1 TJ=150oC TJ=125°C TJ=100oC 0.01 0.1 TJ=25oC 0.001 0.01 0.3 0 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) TJ=25°C TJ=125oC 0.1 1 (A) 10 =150oC 100 10 (A) 100 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.5 Typical Reverse Characteristics 0.4 0.2 0.5 0.6 0.4 0.7 0.8 Pulse width 0.9 0.6 0.8 1 1.1 1 FORWARD VOLTAGE (V) 4 Version: G2103 1.2 TSD20H100CW – TSD20H200CW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.10 Typical Forward Characteristics 10 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.9 Typical Reverse Characteristics TSD20H200CW TJ=150oC 1 TJ=125oC 0.1 0.01 TJ=100oC 0.001 0.0001 TJ=25oC 0.00001 10 20 30 40 50 60 70 80 90 100 100 10 TSD20H200CW UF1DLW 10 1 TJ=150oC TJ=125°C 0.1 1 TJ=100oC 0.01 0.1 TJ=25oC 0.001 0.01 0.3 0 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) TJ=25°C TJ=125oC 0.4 0.2 0.5 0.6 0.4 0.7 0.8 Pulse width 0.9 0.6 0.8 1 1.1 1 FORWARD VOLTAGE (V) 5 Version: G2103 1.2 TSD20H100CW – TSD20H200CW Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS 2 TO-263AB (D PAK) SUGGESTED PAD LAYOUT MARKING DIAGRAM 6 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: G2103 TSD20H100CW – TSD20H200CW Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version: G2103
TSD20H200CW MNG 价格&库存
很抱歉,暂时无法提供与“TSD20H200CW MNG”相匹配的价格&库存,您可以联系我们找货
