KD U-M123W-T2105-050
    LEUZE(劳易测)
    CONNECTION CABLE
KD U-M123W-T2105-050 数据手册
Part no.: 50140335 – KD U-M123W-T2-050 – Connection cable Technical data Electrical data Performance data Operating voltage Max. 250 V AC/DC Connection Connection 1 Type of connection Connector Thread size M12 Type Female Handle body material TPU No. of pins 3 -pin Encoding A-coded Design Angled Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Connection 2 Type of connection Open end Cable properties Number of conductors 3 Piece(s) Wire cross section 0.82 mm² AWG 18 Sheathing color Yellow Shielded No Silicone-free Yes Cable design Connection cable (open on one end) Cable length 5,000 mm Sheathing material TPE Wire insulation PVC Suitability for drag chains Yes Mechanical data Width across flats 14.5 mm Bending cycles 1,000,000 Piece(s) Operation and display Environmental data Certifications Degree of protection IP 67 NEMA 6P IP 65 Classification eCl@ss 8.0 27279218 eCl@ss 9.0 27060311 ETIM 5.0 EC001855 Leuze electronic GmbH + Co. KG, In der Braike 1, 73277 Owen Phone: +49 7021 573-0, Fax +49 7021 573-199 info@leuze.com • www.leuze.com We reserve the right to make technical changes • eng 2018-08-14 2/3 Part no.: 50140335 – KD U-M123W-T2-050 – Connection cable Electrical connection Connection 1 Type of connection Connector Thread size M12 Type Female Handle body material TPU No. of pins 3 -pin Encoding A-coded Design Angled Connector, LED Lock Screw fitting, nickel-plated brass, recommended torque 0.5 Nm, self-locking Connection 2 Type of connection Open end Accessories General Part no. 50132265 Designation TT-Set 0,4-9 Article Tool Leuze electronic GmbH + Co. KG, In der Braike 1, 73277 Owen Phone: +49 7021 573-0, Fax +49 7021 573-199 Description Type: Torque key Width across flats: 9 mm Torque: 0.4 N·m Material: Plastic, Stainless steel Ambient temperature: -40 ... 120 °C info@leuze.com • www.leuze.com We reserve the right to make technical changes • eng 2018-08-14 3/3
物料型号为50140335 KD U-M123W-T2-050,属于连接线缆。
器件简介包括操作电压最大为250 V AC/DC,连接类型包括M12螺纹尺寸的连接器和开口端。
引脚分配为3针A编码,设计为直角。
参数特性包括线缆长度为5000毫米,线材截面为0.82毫米²,线材颜色为黄色,无屏蔽,无硅胶,线缆材料为TPE,线材绝缘为PVC,适合拖链使用。
功能详解涵盖弯曲周期为100万次。
应用信息指出该产品适用于保护等级IP 67 NEMA 6P,IP 65,eCl@ss 8.0 27279218,eCl@ss 9.0 27060311,ETIM 5.0 EC001855。
封装信息包括线缆设计为连接线缆(一端开口),线宽为14.5毫米。
配件信息包括50132265型号的TT-Set 0.4-9工具,用于安装和调整扭矩。
更多详细信息可访问Leuze electronic官网或联系客服。
KD U-M123W-T2105-050 价格&库存
很抱歉,暂时无法提供与“KD U-M123W-T2105-050”相匹配的价格&库存,您可以联系我们找货
