Multilayer Ceramic Chip Capacitor
MA Series
High Capacitance Type
FEATURE
A wide selection of sized is available (0201 to 2225)
High capacitance in given case size
Capacitor with lead-free termination
RoHS and HALOGEN compliant.
PART NUMBERING SYSTEM
MA
1812
XR
105
C
250
(1)
(2)
(3)
(4)
(5)
(6)
No
Item
(1)
Meritek Series
(2)
Size
(3)
Dielectric
MA
1812
XR
(4)
Capacitance
(5)
Tolerance
(6)
Rated Voltage
RoHS
Code
105
K
250
Description
Series Reference
EIA size or footprint
0201, 0402,0603, 0805, 1206, 1210, 1812,
1825, 2220, 2225
XR: X7R
XF: X5R, YV: Y5V, XM: X6S, XS: X7S
5
105: 10x10 pF = 1µF
1µF ~ 220µF
K: ±10%
K: ±10%, M: ±20%, Z: -20% ~ +80%
Working Voltage: 25VDC
4R0: 4.0VDC ~ 631: 630VDC
DIMENSIONS
EIA Size
L(mm)
W(mm)
0201
0402
0603
0805
1206
1210
1812
1825
2220
2225
0.60±0.03
1.00±0.10
1.60±0.15
2.00±0.20
3.20±0.20
3.20±0.30
4.50±0.40
4.50±0.40
5.70±0.40
5.70±0.40
0.30±0.03
0.50±0.10
0.80±0.15
1.25±0.20
1.60±0.20
2.50±0.30
3.20±0.30
6.30±0.40
5.00±0.40
6.30±0.40
T
MB(mm)
See
Thickness
Specification
Reference
Table
0.15±0.05
0.25+0.05/-0.10
0.40±0.15
0.50±0.20
0.60±0.20
0.75±0.35
0.75±0.35
0.75±0.35
0.85±0.35
0.85±0.35
THICKNESS SPECIFICATION REFERENCE
Code
Thickness (mm)
Code
Thickness (mm)
Code
Thickness (mm)
A
B
C
D
E
F
G
H
0.60 ± 0.10
0.8 + 0.15/-0.10
1.25 ±0.10
1.40 ±0.15
1.60 ±0.20
2.00 ±0.20
2.50 ±0.30
2.80 ±0.30
I
J
K
L
M
N
O
P
1.25 ±0.20
1.15 ±0.15
0.50 ±0.20
0.30 ±0.03
0.95 ±0.10
0.50 ±0.05
3.50 ±0.20
1.60 +0.3/-0.10
Q
R
S
T
U
V
X
Z
0.50 +0.02/-0.05
3.10 ±0.30
0.80 ±0.07
0.85 ±0.10
0.50 ±0.10
0.20 ±0.02
0.80 ±0.10
0.25 ±0.03
Meritek Electronics Corporation | www.meritekusa.com
Rev. 8a 03/02/18
MA Series
ELECTRICAL CHARACTERISTICS
Item
Characteristics
Dielectric
X7R
X7S
X6S
X5R
Y5V
0402, 0603, 0805,
1206, 1210
0201, 0402, 0603,
0805, 1206, 1210
0201, 0402, 0603,
0805, 1206, 1210
0402, 0603, 0805,
1206, 1210, 1812
6.3V, 10V, 16V,
25V, 50V, 100V
6.3V, 10V, 16V,
25V, 35V, 50V
4V, 6.3V, 10V, 16V,
25V, 35V, 50V
6.3V, 10V, 16V,
25V, 35V, 50V,
100V
1μF ~ 47μF
1μF ~ 100μF
1μF ~ 100μF
1μF ~ 220μF
1μF ~ 100μF
K (±10%), M (±20%)
K (±10%), M (±20%)
K (±10%), M (±20%)
K (±10%), M (±20%)
Z (-20/+80%)
0402, 0603, 0805,
1206, 1210,1812,
1825, 2220, 2225
6.3V, 10V, 16V,
25V, 50V, 100V,
250V, 500V, 630V
Chip Size
Rated Voltage
Capacitance
Cap. Tolerance
Dissipation Factor
See Dissipation Factor Table Below
Operating Temperature
-55°C ~ 125°C
-55°C ~ 125°C
-55°C ~ 105°C
-55 ~ 85°C
-25 ~ 85°C
Temperature Coefficient
±15%
±22%
±22%
±15%
+30/-80%
Termination
Cu or Ag / Ni / Sn or Au (lead-free termination)
DISSIPATION FACTOR
X7R/X5R/X6S/X7S
Rated
Vol.
Y5V
D.F.
Exception of D.F.
≤3%
≥100V
50V
35V
25V
≤2.5%
≤2.5%
≤3.5%
≤3.5%
0805>0.1µF, 0603≥ 0.068µF, 1206>1µF,
1210≥ 2.2µF
≤10%
0805>0.22µF, 1210≥3.3µF
≤3%
0201(50V), 0603≥ 0.047µF, 0805≥ 0.18µF,
1206≥ 0.47µF, 1210≥3.3µF, 1812≥10µF,
2220≥22µF
≤5%
0201≥ 0.01uF, 1210≥ 4.7µF
≤10%
0402≥ 0.1µF, 0603>0.1µF, 0805≥ 1µF,
1206≥ 2.2µF, 1210≥ 10µF
0603≥ 1µF, 0805≥2.2µF, 1206≥2.2µF,
1210≥10µF
≤5%
0201≥ 0.01µF, 0805≥ 1µF, 1210≥ 10µF
≤7%
0603≥ 0.33µF, 1206≥ 4.7µF
≤10%
0201≥ 0.1µF, 0402≥ 0.10µF, 0603≥ 0.47µF,
0805≥ 2.2µF, 1206≥ 6.8µF, 1210≥ 22µF
≤12.5%
≤5%
16V
≤3.5%
≤10%
10V
6.3V
4V
≤5%
≤10%
≤15%
≤10%
≥50V
≤5%
Exception of D.F. ≤
≤7%
≤12.5%
35V
≤7%
--≤7%
25V
≤5%
≤9%
16V
(C10µpF, at 20°C at ambient temperature
Y5V: Apply 1.0±0.2Vrms, 1.0KHz±10% for Cap.≤10μF and 0.5±0.2Vrms,
120Hz±20% for Cap.>10μF, at 20°C ambient temperature.
Preconditioning for class II MLCC: perform a heat treatment at 150±10°C
for 1 hour, then leave in ambient condition for 24±2 hours before
measurement.
Rev. 8a 03/02/18
MA Series
CAPACITANCE RANGE AND THICKNESS
X7R
Dimension
0402
0603
0805
Cap.
Code
6.3V
6.3V
10V
16V
25V
50V
1.0µF
105
N
B
B
B
B
B
1.2µF
125
1.5µF
155
1.8µF
185
2.2µF
225
2.7µF
275
3.3µF
335
3.9µF
395
4.7µF
475
5.6µF
565
6.8µF
685
8.2µF
825
10µF
106
12µF
126
15µF
156
18µF
186
22µF
226
47µF
476
Dimension
Cap.
Code
1.0µF
105
1.2µF
125
1.5µF
155
1.8µF
185
2.2µF
225
2.7µF
275
3.3µF
335
3.9µF
395
4.7µF
475
5.6µF
565
6.8µF
685
8.2µF
825
10µF
106
12µF
126
15µF
156
18µF
186
22µF
226
47µF
476
Dimension
Cap.
Code
1.0µF
105
1.2µF
125
1.5µF
155
1.8µF
185
2.2µF
225
2.7µF
275
3.3µF
335
3.9µF
395
4.7µF
475
5.6µF
565
6.8µF
685
8.2µF
825
10µF
106
12µF
126
15µF
156
18µF
186
22µF
226
47µF
476
B
B
6.3V
B
6.3V
G
25V
F
F
F
F
F
F
F
F
F
F
F
G
G
H
H
H
H
1210
16V
25V
C
C
10V
C
E
E
E
E
E
E
50V
C
G
G
G
G
G
G
F
F
F
G
F
F
F
G
G
G
G
G
50V
F
F
F
F
F
F
F
F
F
F
F
G
G
100V
F
F
F
F
F
F
F
F
F
F
F
G
G
H
2220
200V
F
G
G
G
G
H
16V
25V
50V
C
C
C
I
I
B
250V
F
G
G
G
G
H
100V
F
G
G
G
G
G
G
G
500V
H
1206
10V
I
I
I
I
I
I
I
I
I
I
I
I*
I
I
10V
C
16V
C
25V
C
C
C
E
E
F
F
F
G
G
G
G
G
1812
50V
F
F
F
F
F
F
F
F
G
G
G
G
G
630V
H
25V
F
F
F
F
F
F
F
F
F
F
F
G
G
H
H
H
H
50V
F
F
F
F
F
F
F
F
F
F
F
G
G
100V
F
F
F
F
F
F
F
F
G
G
G
G
G
100V
F
F
F
F
G
G
G
G
G
G
2225
200V
F
G
G
G
G
G
H
H
6.3V
10V
16V
25V
50V
100V
J
J
J
P
P
P
P
P
P
P
J
J
J
P
P
J
J
J
P
P
P
P
P
P
P
P
P
P
P
P
P
P
P
P
P
P*
200V
G
250V
G
25V
G
250V
F
G
G
G
G
G
H
H
500V
G
H
H
630V
G
H
H
50V
F
F
F
F
F
F
F
F
F
G
G
G
G
1825
100V
F
F
F
F
F
F
F
F
G
G
G
G
G
200V
F
G
G
G
G
H
P
250V
F
G
G
G
G
H
H
Note: * indicates M tolerance only.
Rev. 8a 03/02/18
MA Series
CAPACITANCE RANGE AND THICKNESS (CONTINUED)
X7S
Dimension
Cap.
Code
1.0µF
105
2.2µF
225
2.7µF
275
4.7µF
475
6.8µF
685
10µF
106
22µF
226
47µF
476
100µF
107
0402
6.3V
0603
10V
10V
16V
0805
25V
16V
25V
1206
50V
K
K
100V
6.3V
1210
16V
6.3V
I
K
B
B
B
B
I
I
I
I
P*
P*
G*
X6S
Dimension
0201
0402
0603
Code
4V
6.3V
6.3V
10V
16V
25V
1.0µF
105
L
L*
K
K
K
K
2.2µF
225
K
K
4.7µF
475
10µF
106
22µF
226
47µF
476
I*
100µF
107
I*
K
K*
Code
1.0µF
105
2.2µF
225
4.7µF
475
10µF
106
22µF
226
47µF
476
100µF
107
B*
B*
1206
6.3V
6.3V
10V
16V
25V
B
B
B
B
B
K*
Dimension
Cap.
4V
0805
Cap.
B*
B*
4V
6.3V
10V
16V
I
I
I
I
I*
I*
I*
B*
25V
50V
I
I
I
I*
1210
10V
16V
P
P*
25V
6.3V
10V
16V
G
G
G
G*
G*
25V
P
P
P
G
X5R
Dimension
0201
0402
Cap.
Codee
6.3V
10V
16V
1.0µF
105
L
L
L
1.5µF
155
2.2µF
225
3.3µF
335
4.7µF
475
6.8µF
685
10µF
106
22µF
226
47µF
476
100µF
107
220µF
227
Code
1.0µF
105
1.5µF
155
2.2µF
225
3.3µF
10V
16V
25V
N
N
N
N
L
N
K
N
K
K
K
K
25V
50V
C
C
C
I
I
I
I
I
I
I
I
I
335
I
I
I
I
4.7µF
475
I
I
I
I
6.8µF
685
10µF
106
I
I
I
I
22µF
226
I
I
I
I
I
I
476
107
220µF
227
6.3V
10V
16V
25V
50V
B
B
B
B
B
K
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
B
50V
4V
K
K
4V
I
6.3V
1206
16V
47µF
4V
0805
10V
100µF
0603
6.3V
B
Dimension
Cap.
4V
4V
6.3V
10V
1210
16V
25V
6.3V
10V
16V
25V
35V
50V
G
P
J
J
J
J
P
P
P
P
P
P
P
P
P
P
P
P
P
P
P
P
I
I
I
I
F
F
P
F
F
P
P
F
F
P
P
P
P
P
P
P
G
F
F
F
F
F
G
G
G
G
G
G
G
G
G
G
G
G
G
G
Rev. 8a 03/02/18
MA Series
Y5V
Dimension
0402
0603
6.3V
0805
Cap.
Code
6.3V
10V
1.0µF
105
N
N
1.5µF
155
2.2µF
225
3.3µF
335
4.7µF
475
6.8µF
685
10µF
106
I
I
22µF
226
I
I
47µF
476
100µF
107
Code
1.0µF
16V
25V
S
B
B
6.3V
S
S
S
B
B
B
1206
10V
16V
25V
50V
X
X
C
C
C
C
C
C
C
C
C
C
I
6.3V
I
I
I
I
10V
16V
25V
M
M
M
M
M
M
M
M
M
J
J
J
J
J
J
J
J
J
J
P
P
35V
50V
M
J
J
P
P
P
Dimension
Cap.
10V
1210
6.3V
1812
10V
16V
25V
105
M
M
M
1.5µF
155
M
M
M
2.2µF
225
M
M
M
3.3µF
335
M
M
M
4.7µF
475
M
M
C
6.8µF
685
M
M
C
10µF
106
C
C
E
22µF
226
F
F
47µF
476
F
100µF
107
G
35V
50V
10V
16V
25V
50V
100V
M
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
C
E
C
C
C
C
F
C
C
C
C
F
C
C
C
F
E
F
F
G
RELIABILITY TEST CONDITIONS AND REQUIREMENTS
Item
Visual and
Dimensions
Capacitance
Q/ D.F.
(Dissipation
Factor)
Test Condition
--Class II: X7R,X7S, X6S, X5R,Y5V
Cap≤10μF, 1.0±0.2Vrms, 1kHz±10%
Cap>10μF, 0.5±0.2Vrms, 120Hz±20%
Requirements
No remarkable defect.
Dimensions to confirm to individual specification
sheet.
Within specification
Test condition: 0.5±0.2Vrms,1KHz±10%
X7R: 0603=475(6.3V), 0805=106(6.3V&10V)
X6S: 0201≥104(6.3V&10V), 0402≥225(6.3V),
0402/475(10V), 0603/106(6.3V).
X5R: 01R5≥103, 0201≥224 (6.3V, 10V, 16V),
0402≥475 (6.3V, 16V), 0402≥225(10V),
0603=106 (6.3V, 10V)
Dielectric
Strength
To apply voltage :
Rated Voltage
Condition
≤100
2.5 times of UR
1000.1μF, 0402≥1μF, 0603≥10μF, 0805≥47μF
6.3V : 0201≥0.1μF, 0603>4.7μF, 0805≥47μF,
1206≥10μF
4V : 0603≥22μF, 0805≥47μF, 1206≥100μF
Temperature
Coefficient
With no electrical load.
T.C.
Operation Temp.
X7R
-55~125°C at 25°C
X7S
-55~125°C at 25°C
X6S
-55~105°C at 25°C
X5R
-55~85°C at 25°C
Y5V
-25~85°C at 20°C
Measurement Voltage for Class II:
Size
Cap
Condition
Cap
