BLF884P,112
BLF884P,112
    AMPLEON(安谱隆)
    SOT-1121A
    BLF884P,112
BLF884P,112 数据手册
BLF884P; BLF884PS UHF power LDMOS transistor Rev. 3 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description A 350 W LDMOS RF power transistor for broadcast transmitter applications and industrial applications. The excellent ruggedness of this device makes it ideal for digital and analog transmitter applications. Table 1. Application information RF performance at VDS = 50 V unless otherwise specified. Mode of operation f PL(AV) PL(M) Gp (MHz) (W) (W) D IMD3 IMDshldr PAR (dBc) (dB) 32 - - - 31[1] 8.2 [2] (dB) (%) (dBc) RF performance in a common source 860 MHz narrowband test circuit 2-tone, class-AB DVB-T (8k OFDM) f1 = 860; f2 = 860.1 858 150 70 - 21 21 46 33 RF performance in a common source 470 MHz to 860 MHz broadband test circuit DVB-T (8k OFDM) 858 70 - 20 32 - 32 [1] 8.0 [2] [1] Measured [dBc] with delta marker at 4.3 MHz from center frequency. [2] PAR (of output signal) at 0.01 % probability on CCDF; PAR of input signal = 9.5 dB at 0.01 % probability on CCDF. 1.2 Features and benefits          Excellent ruggedness Optimum thermal behavior and reliability, Rth(j-c) = 0.22 K/W High power gain High efficiency Designed for broadband operation (470 MHz to 860 MHz) Internal input matching for high gain and optimum broadband operation Excellent reliability Easy power control Compliant to Restriction of Hazardous Substances (RoHS) Directive 2002/95/EC 1.3 Applications  Communication transmitter applications in the UHF band  Industrial applications in the UHF band BLF884P; BLF884PS UHF power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF884P (SOT1121A) 1 drain1 2 drain2 3 gate1 4 gate2 5 1 1 2 3 [1] source 5 3 5 4 4 2 sym117 BLF884PS (SOT1121B) 1 drain1 2 drain2 3 gate1 4 gate2 5 1 3 5 4 [1] source 2 sym117 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF884P - flanged LDMOST ceramic package; 2 mounting holes; 4 leads SOT1121A BLF884PS - earless flanged LDMOST ceramic package; 4 leads SOT1121B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). BLF884P_BLF884PS#3 Product data sheet Symbol Parameter Min Max Unit VDS drain-source voltage Conditions - 104 V VGS gate-source voltage 0.5 +11 V Tstg storage temperature 65 +150 C Tj junction temperature - 200 C All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 15 BLF884P; BLF884PS UHF power LDMOS transistor 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-c) [1] Conditions Typ thermal resistance from junction to case Tcase = 80 C; PL(AV) = 70 W [1] Unit 0.22 K/W Rth(j-c) is measured under RF conditions. 6. Characteristics Table 6. DC characteristics Tj = 25 C; per section unless otherwise specified. Symbol Parameter Conditions V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 1.2 mA [1] [1] Min Typ Max Unit 104 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 120 mA 1.4 1.9 2.4 V IDSS drain leakage current VGS = 0 V; VDS = 50 V - - 1.4 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 19 - A IGSS gate leakage current VGS = 10 V; VDS = 0 V - - 140 nA RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 4.25 A [1] - 240 - m Ciss input capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz [2] - 105 - pF Coss output capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 34 - pF Crss reverse transfer capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 0.7 - pF [1] ID is the drain current. [2] Capacitance values without internal matching. Table 7. RF characteristics RF characteristics in Ampleon production narrowband test circuit; Tcase = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit 2-Tone, class-AB BLF884P_BLF884PS#3 Product data sheet VDS drain-source voltage IDq quiescent drain current PL(AV) average output power f1 = 860 MHz; f2 = 860.1 MHz 150 - - W Gp power gain f1 = 860 MHz; f2 = 860.1 MHz 20 21 - dB D drain efficiency f1 = 860 MHz; f2 = 860.1 MHz 42 46 - % IMD3 third-order intermodulation distortion f1 = 860 MHz; f2 = 860.1 MHz - 32 28 [1] All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 - 50 - V - 0.65 - A dBc © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 15 BLF884P; BLF884PS UHF power LDMOS transistor Table 7. RF characteristics …continued RF characteristics in Ampleon production narrowband test circuit; Tcase = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit DVB-T (8k OFDM), class-AB VDS drain-source voltage IDq quiescent drain current PL(AV) average output power Gp power gain f = 858 MHz 20 21 - dB D drain efficiency f = 858 MHz 30 33 - % IMDshldr intermodulation distortion shoulder f = 858 MHz [2] - 31 27 dBc f = 858 MHz [3] - 8.2 dB PAR [1] [1] f = 858 MHz peak-to-average ratio - 50 - V - 0.65 - A 70 - W - - Idq for total device [2] Measured [dBc] with delta marker at 4.3 MHz from center frequency. [3] PAR (of output signal) at 0.01 % probability on CCDF; PAR of input signal = 9.5 dB at 0.01 % probability on CCDF. 001aao028 200 Coss (pF) 150 100 50 0 0 20 40 60 VDS (V) VGS = 0 V; f = 1 MHz. Fig 1. Output capacitance as a function of drain-source voltage; typical values per section 6.1 Ruggedness in class-AB operation The BLF884P and BLF884PS are capable of withstanding a load mismatch corresponding to VSWR of  40 : 1 through all phases under the following conditions: VDS = 50 V; f = 860 MHz at rated power. BLF884P_BLF884PS#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 15 BLF884P; BLF884PS UHF power LDMOS transistor 7. Application information 7.1 Broadband RF figures 7.1.1 DVB-T 001aao029 24 Gp (dB) Gp 20 IMDshldr (dBc) 001aao030 9.5 -10 PAR (dB) ηD (%) 8.5 -20 50 40 PAR IMDshldr 16 7.5 -30 30 ηD 12 6.5 -40 8 400 500 600 700 5.5 400 -50 800 900 f (MHz) DVB-T power gain and intermodulation distortion shoulder as function of frequency; typical values BLF884P_BLF884PS#3 Product data sheet 500 600 700 10 800 900 f (MHz) PL(AV) = 70 W; VDS = 50 V; IDq = 0.65 A; measured in a common source broadband test circuit as described in Section 8. PL(AV) = 70 W; VDS = 50 V; IDq = 0.65 A; measured in a common source broadband test circuit as described in Section 8. Fig 2. 20 Fig 3. DVB-T peak-to-average ratio and drain efficiency as function of frequency; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 15 BLF884P; BLF884PS UHF power LDMOS transistor 7.2 Impedance information drain 1 gate 1 Zi ZL gate 2 drain 2 001aan207 Fig 4. Definition of transistor impedance Table 8. Typical push-pull impedance Simulated Zi and ZL device impedance; impedance info at VDS = 50 V and PL(AV) = 70 W (DVB-T). f BLF884P_BLF884PS#3 Product data sheet Zi ZL MHz   300 0.984  j3.485 8.315 + j1.246 325 1.009  j2.805 8.236 + j1.328 350 1.038  j2.185 8.153 + j1.406 375 1.071  j1.614 8.066 + j1.479 400 1.107  j1.080 7.975 + j1.547 425 1.147  j0.574 7.880 + j1.610 450 1.193  j0.092 7.782 + j1.667 475 1.243 + j0.373 7.682 + j1.720 500 1.300 + j0.826 7.579 + j1.767 525 1.364 + j1.270 7.474 + j1.809 550 1.436 + j1.708 7.367 + j1.846 575 1.517 + j2.144 7.258 + j1.877 600 1.609 + j2.581 7.149 + j1.903 625 1.714 + j3.022 7.038 + j1.925 650 1.834 + j3.469 6.927 + j1.941 675 1.971 + j3.925 6.815 + j1.952 700 2.129 + j4.394 6.703 + j1.958 725 2.313 + j4.879 6.591 + j1.960 750 2.528 + j5.382 6.480 + j1.956 775 2.781 + j5.907 6.368 + j1.949 800 3.081 + j6.458 6.258 + j1.937 825 3.441 + j7.038 6.148 + j1.921 850 3.875 + j7.648 6.040 + j1.901 875 4.404 + j8.291 5.932 + j1.877 900 5.057 + j8.964 5.825 + j1.849 925 5.870 + j9.659 5.720 + j1.818 950 6.892 + j10.358 5.616 + j1.783 975 8.186 + j11.019 5.514 + j1.745 1000 9.829 + j11.566 5.413 + j1.704 All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 15 BLF884P; BLF884PS UHF power LDMOS transistor 8. Test information Table 9. List of components For test circuit, see Figure 5 and Figure 6. Component Description Value Remarks B1, B2 semi rigid coax 25 ; 49.5 mm C1, C2 multilayer ceramic chip capacitor 5.1 pF [1] C3 multilayer ceramic chip capacitor 6.8 pF [1] C4 multilayer ceramic chip capacitor 8.2 pF [1] C10, C13, C14 multilayer ceramic chip capacitor 100 pF [2] C11, C12 multilayer ceramic chip capacitor 10 pF [1] C15, C16 multilayer ceramic chip capacitor 4.7 F, 50 V C17, C18, C23, C24 multilayer ceramic chip capacitor 100 pF C19, C20 multilayer ceramic chip capacitor 10 F, 50 V C21, C22 electrolytic capacitor 470 F; 63 V C30 multilayer ceramic chip capacitor 13 pF [3] C31 multilayer ceramic chip capacitor 2.2 pF [3] C33, C34, C35 multilayer ceramic chip capacitor 100 pF [3] C36, C37 multilayer ceramic chip capacitor 4.7 F, 50 V L1 microstrip - [4] (W  L) 15 mm  13 mm - [4] (W  L) 5 mm  26 mm (W  L) 2 mm  49.5 mm L2 microstrip UT-090C-25 (EZ 90-25) Kemet C1210X475K5RAC-TU or capacitor of same quality. [1] TDK C570X7R1H106KT000N or capacitor of same quality. TDK C4532X7R1E475MT020U or capacitor of same quality. L3, L32 microstrip - [4] L4 microstrip - [4] (W  L) 1.7 mm  3.5 mm L5 microstrip - [4] (W  L) 2 mm  9.5 mm - [4] (W  L) 5 mm  13 mm (W  L) 2 mm  11 mm (W  L) 2 mm  3 mm L30 microstrip L31 microstrip - [4] L33 microstrip - [4] R1, R2 wire resistor 10  R3, R4 SMD resistor 5.6  R5, R6 wire resistor 100  R7, R8 potentiometer 10 k [1] American technical ceramics type 800B or capacitor of same quality. [2] American technical ceramics type 180R or capacitor of same quality. 0805 [3] American technical ceramics type 100A or capacitor of same quality. [4] Printed-Circuit Board (PCB): Taconic RF35; r = 3.5 F/m; height = 0.762 mm; Cu (top/bottom metallization); thickness copper plating = 35 m. BLF884P_BLF884PS#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 15 xxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxx x x x xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx xx xx xxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx xxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxx x x xxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxx xxx BLF884P_BLF884PS#3 Product data sheet +VG1 R7 C19 +VD1 L5 R3 C21 C11 C34 L32 50 Ω C33 R1 C17 R5 C36 L3 L31 L2 L33 L4 B2 C10 50 Ω B1 C31 C30 C1 C2 C3 C35 C4 C12 C37 C14 C16 C22 R6 C18 R2 C24 +VD2 001aao032 C20 R8 +VG2 See Table 9 for a list of components. Fig 5. Class-AB common source broadband amplifier UHF power LDMOS transistor 8 of 15 © Ampleon The Netherlands B.V. 2015. All rights reserved. BLF884P; BLF884PS Rev. 3 — 1 September 2015 All information provided in this document is subject to legal disclaimers. R4 C15 C13 L1 L30 C23 BLF884P; BLF884PS UHF power LDMOS transistor 48 mm 45.7 mm +VG1 +VD1 C21 R1 C17 R5 + C23 R7 C36 C19 C21 R3 C11 C34 C1 C33 50 Ω C35 C31 C10 C4 C30 50 Ω C14 C2 C3 C12 C16 R4 4 mm C37 C15 C13 C20 R6 R8 C24 R2 C18 C22 + +VG2 6.3 mm +VD2 26 mm 30.5 mm aaa-001709 See Table 9 for a list of components. Fig 6. Component layout for class-AB common source amplifier BLF884P_BLF884PS#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 15 BLF884P; BLF884PS UHF power LDMOS transistor 9. Package outline Flanged LDMOST ceramic package; 2 mounting holes; 4 leads SOT1121A D A F D1 U1 B q C H1 c 2 1 p U2 H E1 E 5 A w1 3 A B 4 b w2 C Q e 0 5 Dimensions Unit(1) mm 10 mm scale A max 4.75 nom min 3.45 b 3.94 c D D1 e 0.18 20.02 19.96 E E1 F H H1 p 9.53 9.53 1.14 19.94 12.83 3.38 Q(2) 0.10 19.61 19.66 U1 U2 33.91 9.65 1.45 max 0.187 0.155 0.007 0.788 0.786 0.375 0.375 0.045 0.785 0.505 0.133 0.067 inches nom 0.35 min 0.136 0.145 0.004 0.772 0.774 0.365 0.365 0.035 0.745 0.495 0.123 0.057 1.345 0.39 1.1 0.01 0.02 1.335 0.38 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. dimension is measured 0.030 inch (0.76 mm) from the body. Outline version References IEC JEDEC JEITA sot1121a_po European projection Issue date 09-10-12 10-02-02 SOT1121A Fig 7. w2 0.25 0.51 27.94 9.27 9.27 0.89 18.92 12.57 3.12 w1 34.16 9.91 1.70 8.89 3.68 q Package outline SOT1121A BLF884P_BLF884PS#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 15 BLF884P; BLF884PS UHF power LDMOS transistor Earless flanged ceramic package; 4 leads SOT1121B D A F 5 D1 D U1 w2 H1 H c D 2 1 U2 E1 E 4 3 b y w3 e Q 0 5 10 mm scale Dimensions Unit(1) mm A max 4.75 nom min 3.45 b 3.94 c D D1 e 0.18 20.02 19.96 E E1 F H H1 Q U1 U2 w2 w3 9.53 9.53 1.14 19.94 12.83 1.70 20.70 9.91 0.51 0.25 3.68 0.08 19.61 19.66 9.27 9.27 0.89 18.92 12.57 1.45 20.45 9.65 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. dimension is measured 0.030 inch (0.76 mm) from the body. References IEC JEDEC JEITA 0.01 sot1121b_po European projection Issue date 09-12-14 12-06-07 SOT1121B Fig 8. 0.25 8.89 max 0.187 0.155 0.007 0.788 0.786 0.375 0.375 0.045 0.785 0.505 0.067 0.815 0.39 0.02 0.01 0.35 inches nom min 0.136 0.145 0.003 0.772 0.774 0.365 0.365 0.035 0.745 0.495 0.057 0.805 0.38 Outline version y Package outline SOT1121B BLF884P_BLF884PS#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 15 BLF884P; BLF884PS UHF power LDMOS transistor 10. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 11. Abbreviations Table 10. Abbreviations Acronym Description CCDF Complementary Cumulative Distribution Function DVB Digital Video Broadcast DVB-T Digital Video Broadcast - Terrestrial LDMOS Laterally Diffused Metal-Oxide Semiconductor LDMOST Laterally Diffused Metal-Oxide Semiconductor Transistor OFDM Orthogonal Frequency Division Multiplexing PAR Peak-to-Average power Ratio RF Radio Frequency SMD Surface Mounted Device UHF Ultra High Frequency VSWR Voltage Standing-Wave Ratio 12. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF884P_BLF884PS#3 20150901 Product data sheet - BLF884P_BLF884PS v.2 Modifications: • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF884P_BLF884PS v.2 20111216 Product data sheet - BLF884P_BLF884PS v.1 BLF884P_BLF884PS v.1 20111013 Objective data sheet - - BLF884P_BLF884PS#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 15 BLF884P; BLF884PS UHF power LDMOS transistor 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF884P_BLF884PS#3 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 15 BLF884P; BLF884PS UHF power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Licenses ICs with DVB-T or DVB-T2 functionality Use of this product in any manner that complies with the DVB-T or the DVB-T2 standard may require licenses under applicable patents of the DVB-T respectively the DVB-T2 patent portfolio, which license is available from Sisvel S.p.A., Via Sestriere 100, 10060 None (TO), Italy, and under applicable patents of other parties. 13.5 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 14. Contact information For more information, please visit: http://www.ampleon.com BLF884P_BLF884PS#3 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 14 of 15 BLF884P; BLF884PS UHF power LDMOS transistor 15. Contents 1 1.1 1.2 1.3 2 3 4 5 6 6.1 7 7.1 7.1.1 7.2 8 9 10 11 12 13 13.1 13.2 13.3 13.4 13.5 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 4 Application information. . . . . . . . . . . . . . . . . . . 5 Broadband RF figures . . . . . . . . . . . . . . . . . . . 5 DVB-T . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Impedance information . . . . . . . . . . . . . . . . . . . 6 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Handling information. . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Licenses . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF884P_BLF884PS#3
BLF884P,112 价格&库存
很抱歉,暂时无法提供与“BLF884P,112”相匹配的价格&库存,您可以联系我们找货
