BLF574XR,112
BLF574XR,112
    AMPLEON(安谱隆)
    SOT-1214A
    RF Mosfet LDMOS (Dual), Common Source 50V 100mA 225MHz 23.5dB 600W SOT1214A
BLF574XR,112 数据手册
BLF574XR; BLF574XRS Power LDMOS transistor Rev. 2 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description A 600 W extremely rugged LDMOS power transistor for broadcast and industrial applications in the HF to 500 MHz band. This product is an enhanced version of the BLF574 using Ampleon's XR process to provide maximum ruggedness capability in the most severe applications without compromising the RF performance. Table 1. Application information Test signal f VDS PL Gp D (MHz) (V) (W) (dB) (%) CW 225 50 600 23.5 74.5 pulsed RF 225 50 600 24 74.7 1.2 Features and benefits        Easy power control Integrated ESD protection Excellent ruggedness High efficiency Excellent thermal stability Designed for broadband operation (HF to 500 MHz) Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  Industrial, scientific and medical applications  Broadcast transmitter applications BLF574XR; BLF574XRS Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF574XR (SOT1214A) 1 drain1 2 drain2 3 gate1 4 gate2 5 1 2 3 4 1 5 3 5 4 [1] source 2 sym117 BLF574XRS (SOT1214B) 1 drain1 2 drain2 3 gate1 4 gate2 5 1 1 2 3 5 [1] source 4 3 4 5 2 sym117 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF574XR - flanged ceramic package; 2 mounting holes; 4 leads SOT1214A BLF574XRS - earless flanged ceramic package; 4 leads SOT1214B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS Min Max Unit drain-source voltage - 110 V VGS gate-source voltage 6 +11 V Tstg storage temperature 65 +150 C - 225 C Tj [1] BLF574XR_BLF574XRS#2 Product data sheet Conditions junction temperature [1] Continuous use at maximum temperature will affect the reliability. For details refer to the on-line MTF calculator. All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 14 BLF574XR; BLF574XRS Power LDMOS transistor 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-c) Conditions thermal resistance from junction to case [1] Tj is the junction temperature. [2] Rth(j-c) is measured under RF conditions. Tj = 150 C [1][2] Typ Unit 0.18 K/W 6. Characteristics Table 6. DC characteristics Tj = 25 C; per section unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 2.75 mA 110 - - V 2.25 V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 275 mA 1.25 1.7 IDSS drain leakage current VGS = 0 V; VDS = 50 V - - 1.4 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 38 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 140 nA RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 9.625 A - 0.15 -  Table 7. DC characteristics Tj = 25 C; per section unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Crs feedback capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 2.4 - pF Ciss input capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 210 - pF Coss output capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 94 pF - Table 8. RF characteristics Test signal: CW; f = 225 MHz; RF performance at VDS = 50 V; IDq = 100 mA; Tcase = 25 C; unless otherwise specified; in a class-AB production test circuit. BLF574XR_BLF574XRS#2 Product data sheet Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL = 600 W 21.65 23.5 - dB RLin input return loss PL = 600 W - 17 13 dB D drain efficiency PL = 600 W 70 74.5 - % All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 14 BLF574XR; BLF574XRS Power LDMOS transistor aaa-008096 600 Coss (pF) 450 300 150 0 0 20 40 60 VDS (V) VGS = 0 V; f = 1 MHz. Fig 1. Output capacitance as a function of drain-source voltage; typical values per section 7. Test information 7.1 Ruggedness in class-AB operation The BLF574XR and BLF574XRS are capable of withstanding a load mismatch corresponding to VSWR > 65 : 1 through all phases under the following conditions: VDS = 50 V; IDq = 100 mA; PL = 600 W pulsed; f = 225 MHz. 7.2 Impedance information drain 1 gate 1 Zi ZL gate 2 drain 2 001aan207 Fig 2. Definition of transistor impedance Table 9. Typical push-pull impedance Simulated Zi and ZL device impedance; impedance info at VDS = 50 V and PL = 600 W. BLF574XR_BLF574XRS#2 Product data sheet f Zi ZL (MHz) () () 225 4.67  j5.47 5.66 + j2.05 All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 14 BLF574XR; BLF574XRS Power LDMOS transistor 7.3 Test circuit 95 mm 95 mm C21 L3 L2 R3 C19 C8 C10 C12 C2 80 mm T2 R4 C17 C14 C26 C4 C6 C1 C3 C7 C23 C24 C15 C5 C13 C16 C18 C9 R1 T1 C11 R2 L1 C28 C27 C25 R5 L4 C20 C22 42.5 mm 28 mm 41.5 mm 15 mm aaa-008104 Printed-Circuit Board (PCB) Rogers 5880: r = 2.2 F/m; thickness = 0.79 mm; thickness copper plating = 35 m. See Table 10 for a list of components. Fig 3. Component layout for class-AB production test circuit Table 10. List of components For test circuit see Figure 3. Component BLF574XR_BLF574XRS#2 Product data sheet Description Value Remarks C1, C2, C3, C10, multilayer ceramic chip capacitor 1 nF C11, C17, C18 [1] C4, C5 multilayer ceramic chip capacitor 62 pF [1] C6, C7 multilayer ceramic chip capacitor 51 pF [1] C8, C9 multilayer ceramic chip capacitor 4.7 F, 50 V C12, C13 multilayer ceramic chip capacitor 33 pF [2] C14, C16 multilayer ceramic chip capacitor 43 pF [1] C15 multilayer ceramic chip capacitor 20 pF [1] C19, C20 multilayer ceramic chip capacitor 4.7 F; 100 V Kemet C1210X475K5RAC-T4 470 F; 63 V C21, C22 electrolytic capacitor C23 multilayer ceramic chip capacitor 5  12 pF [3] C24, C25 multilayer ceramic chip capacitor 4  16 pF [3] C26, C27 multilayer ceramic chip capacitor 2  510 pF [3] C28 multilayer ceramic chip capacitor 56 pF [1] L1, L2 2 turn 1 mm copper wire D = 3 mm, length = 3 mm L3, L4 3 turn 1 mm copper wire D = 3 mm, length = 3 mm R1 chip resistor 0 All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 14 BLF574XR; BLF574XRS Power LDMOS transistor Table 10. List of components …continued For test circuit see Figure 3. Component Description Value Remarks R2, R3 chip resistor 10  SMD 1206 R4, R5 metal film resistor 2 , 0.6 W T1, T2 semi rigid coax 50 , 58 mm [1] American Technical Ceramics type 100B or capacitor of same quality. [2] American Technical Ceramics type 100A or capacitor of same quality. [3] American Technical Ceramics type 800B or capacitor of same quality. HUBER+SUHNER EZ-141-AL-TP-M17 7.4 Graphical data The following figures are measured in a class-AB production test circuit. 7.4.1 1-Tone CW aaa-008105 32 aaa-008106 66 80 Gp (dB) ηD (%) PL (dBm) 64 28 60 Ideal PL 62 Gp 24 60 40 (2) (1) 58 20 PL 20 ηD 56 16 0 100 200 300 400 500 600 PL (W) 54 0 700 28 VDS = 50 V; IDq = 100 mA; f = 225 MHz. 30 32 34 36 38 Pi (dBm) 40 VDS = 50 V; IDq = 100 mA; f = 225 MHz. (1) PL(1dB) = 57.56 dBm (570 W) (2) PL(3dB) = 58.13 dBm (649 W) Fig 4. Power gain and drain efficiency as function of output power; typical values BLF574XR_BLF574XRS#2 Product data sheet Fig 5. Output power as a function of input power; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 14 BLF574XR; BLF574XRS Power LDMOS transistor aaa-008107 28 Gp (dB) aaa-008108 80 ηD (%) 26 60 24 40 (6) (5) (4) (3) (2) (1) 22 (1) (2) (3) (4) (5) (6) 20 20 0 0 100 200 300 400 500 600 PL (W) 700 0 VDS = 50 V; f = 225 MHz. 100 200 (1) IDq = 50 mA (2) IDq = 100 mA (2) IDq = 100 mA (3) IDq = 200 mA (3) IDq = 200 mA (4) IDq = 300 mA (4) IDq = 300 mA (5) IDq = 400 mA (5) IDq = 400 mA (6) IDq = 500 mA (6) IDq = 500 mA Power gain as a function of output power; typical values BLF574XR_BLF574XRS#2 Product data sheet 400 500 600 PL (W) 700 VDS = 50 V; f = 225 MHz. (1) IDq = 50 mA Fig 6. 300 Fig 7. Drain efficiency as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 14 BLF574XR; BLF574XRS Power LDMOS transistor aaa-008109 25 Gp (dB) aaa-008110 80 ηD (%) (1) (2) (3) (4) (5) (6) 200 300 400 500 600 700 PL (W) 23 60 21 40 19 (5) (4) (6) (3) (2) 17 20 (1) 15 0 0 100 200 300 400 500 600 700 PL (W) 800 0 IDq = 100 mA; f = 225 MHz. 100 IDq = 100 mA; f = 225 MHz. (1) VDS = 25 V (1) VDS = 25 V (2) VDS = 30 V (2) VDS = 30 V (3) VDS = 35 V (3) VDS = 35 V (4) VDS = 40 V (4) VDS = 40 V (5) VDS = 45 V (5) VDS = 45 V (6) VDS = 50 V (6) VDS = 50 V Fig 8. Power gain as a function of output power; typical values BLF574XR_BLF574XRS#2 Product data sheet 800 Fig 9. Drain efficiency as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 14 BLF574XR; BLF574XRS Power LDMOS transistor 8. Package outline Flanged ceramic package; 2 mounting holes; 4 leads SOT1214A D A F D1 U1 B q C H1 w2 1 H c C 2 p U2 E1 E 5 A 3 w1 4 b A B w3 Q e 0 5 10 mm scale Dimensions Unit(1) mm A max 4.72 nom min 3.43 b 6.17 c D D1 e 0.15 20.02 19.96 E E1 9.53 9.50 F H 1.14 19.94 8.21 5.92 Q(2) 3.38 1.70 14.24 9.27 0.08 19.61 19.66 p H1 9.29 0.89 18.92 q U1 U2 1.45 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. dimension is measured 0.030 inch (0.76 mm) from body. References IEC JEDEC JEITA w3 0.25 0.51 0.25 0.01 0.02 0.01 33.91 9.65 0.375 0.374 0.045 0.785 max 0.187 0.243 0.006 0.788 0.786 0.133 0.067 1.345 0.39 0.323 0.56 1.10 inches nom 0.365 0.366 0.035 0.745 min 0.135 0.233 0.003 0.772 0.774 0.123 0.057 1.335 0.38 Outline version w2 34.16 9.91 27.94 3.12 w1 sot1214a_po European projection Issue date 12-08-16 12-10-10 SOT1214A Fig 10. Package outline SOT1214A BLF574XR_BLF574XRS#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 14 BLF574XR; BLF574XRS Power LDMOS transistor Earless flanged ceramic package; 4 leads SOT1214B D A F 5 C D1 U1 H1 w2 1 H c C 2 E1 U2 3 E 4 b w3 Q e 0 5 10 mm scale Dimensions Unit(1) b c max 4.72 nom min 3.43 6.17 0.15 5.92 0.08 max 0.187 inches nom min 0.135 0.243 0.006 0.788 0.786 mm A D D1 e 20.02 19.96 E E1 F H 9.53 9.50 1.14 19.94 8.21 9.29 0.89 U2 w2 0.51 0.25 0.067 0.815 0.39 0.56 0.365 0.366 0.035 0.745 0.02 0.01 0.057 0.805 0.38 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. dimension is measured 0.030 inch (0.76 mm) from body. Outline version References IEC JEDEC w3 1.45 20.45 9.65 0.375 0.374 0.045 0.785 0.003 0.772 0.774 U1 1.70 20.70 9.91 18.92 0.323 0.233 Q(2) 14.24 9.27 19.61 19.66 H1 JEITA sot1214b_po European projection Issue date 12-10-10 14-03-27 SOT1214B Fig 11. Package outline SOT1214B BLF574XR_BLF574XRS#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 14 BLF574XR; BLF574XRS Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 11. Abbreviations Acronym Description CW Continuous Wave ESD ElectroStatic Discharge HF High Frequency LDMOS Laterally Diffused Metal-Oxide Semiconductor MTF Median Time to Failure SMD Surface Mounted Device VSWR Voltage Standing-Wave Ratio XR eXtremely Rugged 11. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF574XR_BLF574XRS#2 20150901 Product data sheet - BLF574XR_BLF574XRS v.1 Modifications: BLF574XR_BLF574XRS v.1 BLF574XR_BLF574XRS#2 Product data sheet • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. 20130620 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 - © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 14 BLF574XR; BLF574XRS Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF574XR_BLF574XRS#2 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 14 BLF574XR; BLF574XRS Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13. Contact information For more information, please visit: http://www.ampleon.com BLF574XR_BLF574XRS#2 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 14 BLF574XR; BLF574XRS Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 7.4.1 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 4 Ruggedness in class-AB operation . . . . . . . . . 4 Impedance information . . . . . . . . . . . . . . . . . . . 4 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 6 1-Tone CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Handling information. . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF574XR_BLF574XRS#2
BLF574XR,112
物料型号: - BLF574XR - BLF574XRS
器件简介: 一种用于广播和工业应用的600W超耐用LDMOS功率晶体管,工作频率范围从HF至500MHz。
该产品是BLF574的增强版,使用Ampleon的XR工艺提供最大的耐用性能力,同时不牺牲射频性能。
引脚分配: - BLF574XR (SOT1214A): - 1: drain1 - 2: drain2 - 3: gate1 - 4: gate2 - 5: source - BLF574XRS (SOT1214B): - 1: drain1 - 2: drain2 - 3: gate1 - 4: gate2 - 5: source
参数特性: - 存储温度范围:-65°C至+150°C - 结温范围:连续使用最大温度会影响可靠性,具体细节请参阅在线MTF计算器
功能详解: - 易于控制功率 - 集成的ESD保护 - 出色的耐用性 - 高效率和热稳定性 - 为宽带操作设计(HF至500MHz) - 符合有害物质限制指令2002/95/EC(RoHS)
应用信息: - 工业、科学和医疗应用 - 广播发射机应用
封装信息: - BLF574XR: 带法兰的陶瓷封装;2个安装孔;4个引脚 - BLF574XRS: 无耳带法兰的陶瓷封装;4个引脚
热特性: - 热阻从结到外壳(Rth(j-c)):0.18 K/W
直流特性: - 漏源击穿电压(V(BR)DSS):110V - 栅源阈值电压(VGS(th)):1.25V至2.25V - 漏极漏电流(IDSS):1.4μA - 漏极截止电流(IDSX):38A - 栅源漏电流(IGSS):140nA - 漏源导通电阻(RDS(on)):0.15Ω
射频特性: - 在225MHz下,功率增益(Gp)典型值:23.5dB - 在225MHz下,输入回波损耗(RLin)典型值:-13dB - 在225MHz下,漏极效率(ηD)典型值:74.5%
测试信息: - 能够承受至少65:1的VSWR负载失配 - 设备阻抗信息在VDS=50V和PL=600W条件下的模拟值
图形数据: - 输出功率、功率增益和漏极效率与输出功率的关系图
封装轮廓: - SOT1214A和SOT1214B的封装尺寸和引脚排列图。
处理信息: - 该设备对静电放电(ESD)敏感。
处理时要遵守ANSI/ESD S20.20、IEC/ST 61340-5、JESD625-A或同等标准的预防措施。
BLF574XR,112 价格&库存
很抱歉,暂时无法提供与“BLF574XR,112”相匹配的价格&库存,您可以联系我们找货
