BLF6G38LS-50,118
BLF6G38LS-50,118
    AMPLEON(安谱隆)
    SOT502B
    TRANS WIMAX PWR LDMOS SOT502B
BLF6G38LS-50,118 数据手册
BLF6G38-50; BLF6G38LS-50 WiMAX power LDMOS transistor Rev. 3 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 50 W LDMOS power transistor for base station applications at frequencies from 3400 MHz to 3800 MHz. Table 1. Typical performance Typical RF performance at Tcase = 25 C in a class-AB production test circuit. VDS (V) PL(AV) (W) PL(M)[1] (W) Gp (dB) D (%) ACPR885k (dBc) ACPR1980k (dBc) Mode of operation f (MHz) 1-carrier N-CDMA[2] 3400 to 3600 28 9 70 14 23 49[3] 64[3] [1] PL(M) stands for peak output power. [2] Single carrier N-CDMA with pilot, paging, sync and 6 traffic channels (Walsh codes 8 - 13). PAR = 9.7 dB at 0.01 % probability on the CCDF. Channel bandwidth is 1.23 MHz. [3] Measured within 30 kHz bandwidth. CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Therefore care should be taken during transport and handling. 1.2 Features and benefits  Typical 1-carrier N-CDMA performance (Single carrier N-CDMA with pilot, paging, synchronization and 6 traffic channels [Walsh codes 8 - 13]. PAR = 9.7 dB at 0.01 % probability on the CCDF. Channel bandwidth is 1.23 MHz) at a frequency of 3400 MHz, 3500 MHz and 3600 MHz, a supply voltage of 28 V, an IDq of 450 mA, a power gain of 14 dB, a drain efficiency of 23 % and a peak output power of 70 W:  Qualified up to a maximum VDS operation of 32 V  Suitable for operation in the 3.4 GHz to 3.8 GHz frequency range  Integrated ESD protection  Excellent ruggedness  High efficiency  Excellent thermal stability  Designed for broadband operation  Internally matched for ease of use  Low gold plating thickness on leads  Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) BLF6G38-50; BLF6G38LS-50 WiMAX power LDMOS transistor 1.3 Applications  RF power amplifiers for base stations and multicarrier applications in the 3400 MHz to 3800 MHz frequency range 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF6G38-50 (SOT502A) 1 drain 2 gate 3 source 1 1 [1] 3 2 2 3 sym112 BLF6G38LS-50 (SOT502B) 1 drain 2 gate 3 source 1 1 [1] 3 2 2 3 sym112 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF6G38-50 - flanged ceramic package; 2 mounting holes; 2 leads SOT502A BLF6G38LS-50 - earless flanged ceramic package; 2 leads SOT502B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions VDS drain-source voltage VGS gate-source voltage 0.5 +13 V ID drain current - 16.5 A Tstg storage temperature 65 +150 C Tj junction temperature - 200 C BLF6G38-50_BLF6G38LS-50#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 Min Max Unit - 65 V © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 13 BLF6G38-50; BLF6G38LS-50 WiMAX power LDMOS transistor 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Rth(j-case) thermal resistance from Tcase = 80 C; junction to case PL = 50 W Type Typ Unit BLF6G38-50 0.9 - BLF6G38LS-50 0.7 - Min Typ Max Unit 65 - - V 6. Characteristics Table 6. Characteristics Tj = 25 C per section; unless otherwise specified. Symbol Parameter Conditions V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 0.4 mA VGS(th) gate-source threshold voltage VDS = 10 V; ID = 80 mA 1.4 2 2.4 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 2.8 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V 11.8 16.4 - A IGSS gate leakage current VGS = +11 V; VDS = 0 V - - 280 nA gfs forward transconductance VDS = 10 V; ID = 2.8 A - 5.6 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 2.8 A - 0.18 0.29  Crs feedback capacitance - 1.17 - pF VGS = 0 V; VDS = 28 V; f = 1 MHz 7. Application information Table 7. Application information Mode of operation: 1-carrier N-CDMA; Single carrier N-CDMA with pilot, paging, sync and 6 traffic channels (Walsh codes 8 - 13). PAR = 9.7 dB at 0.01 % probability on the CCDF; Channel bandwidth is 1.23 MHz; f1 = 3400 MHz; f2 = 3500 MHz; f3 = 3600 MHz; RF performance at VDS = 28 V; IDq = 450 mA; Tcase = 25 C; unless otherwise specified, in a class-AB production circuit. Symbol Parameter Conditions Min Typ Max Unit PL(M) peak output power PL(AV) = 9 W 65 70 - W Gp power gain PL(AV) = 9 W 12.5 14 - dB RLin input return loss PL(AV) = 9 W - 10 - dB D drain efficiency PL(AV) = 9 W 20 23 - % PL(AV) = 9 W [1] 46 49 - dBc ACPR1980k adjacent channel power ratio (1980 kHz) PL(AV) = 9 W [1] 62 64 - dBc ACPR885k [1] adjacent channel power ratio (885 kHz) Measured within 30 kHz bandwidth. 7.1 Ruggedness in class-AB operation The BLF6G38-50 and BLF6G38LS-50 are capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 28 V; IDq = 450 mA; PL = PL(1dB); f = 3600 MHz. BLF6G38-50_BLF6G38LS-50#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 13 BLF6G38-50; BLF6G38LS-50 WiMAX power LDMOS transistor 7.2 Ampleon WiMAX signal 7.2.1 WiMAX signal description Frame duration = 5 ms; bandwidth = 10 MHz; sequency = 1 frame; frequency band = WCS; sampling rate = 11.2 MHz; n = 8 / 7; G = Tg / Tb = 1 / 8; FFT = 1024; zone type = PUSC;  = 97.7 %; number of symbols = 46; number of subchannels = 30; PAR = 9.5 dB. Preamble: 1 symbol  30 subchannels; PL = PL(nom) + 3.86 dB. Table 8. Frame structure Frame contents Modulation technique Data length Zone 0 FCH 2 symbols  4 subchannels QPSK1/2 3 bit Zone 0 data 2 symbols  26 subchannels 64QAM3/4 692 bit Zone 0 data 44 symbols  30 subchannels 64QAM3/4 10000 bit 7.2.2 Graphs 001aah395 5 001aah396 15 Gp Gp (dB) EVM (%) 30 ηD (%) 4 13 24 3 11 18 2 9 12 1 7 6 ηD 5 0 0 4 8 12 0 PL(AV) (W) 0 12 8 PL(AV) (W) VDS = 28 V; IDq = 450 mA; f = 3500 MHz. Fig 1. 4 VDS = 28 V; IDq = 450 mA; f = 3500 MHz. EVM as a function of average load power; typical values Fig 2. Power gain and drain efficiency as functions of average load power; typical values BLF6G38-50_BLF6G38LS-50#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 13 BLF6G38-50; BLF6G38LS-50 WiMAX power LDMOS transistor 001aah397 −20 ACPR (dBc) −30 (1) −40 −50 (2) (3) −60 −70 0 4 8 12 PL(AV) (W) VDS = 28 V; IDq = 450 mA; f = 3500 MHz. (1) f = 10 MHz (2) f = 20 MHz (3) f = 30 MHz Fig 3. Adjacent channel power ratio as a function of average load power; typical values 7.3 Single carrier N-CDMA broadband performance at 9 W average 7.3.1 Graphs 001aah398 16 Gp (dB) 15 26 ηD (%) 25 Gp 24 14 13 001aah399 −40 ACPR (dBc) (2) −50 ACPR1500k 23 ηD ACPR885k (1) (1) (2) 22 12 −60 ACPR1980k (1) 11 21 10 3400 3450 3500 20 3600 3550 (2) −70 3400 3450 3500 f (MHz) 3550 3600 f (MHz) VDS = 28 V; IDq = 450 mA; Single Carrier N-CDMA; PAR = 9.7 dB at 0.01 % probability; IBW = 30 kHz. VDS = 28 V; IDq = 450 mA; Single Carrier N-CDMA; PAR = 9.7 dB at 0.01 % probability; IBW = 30 kHz. (1) Low frequency component (2) High frequency component Fig 4. Power gain and drain efficiency as functions of frequency; typical values Fig 5. Adjacent channel power ratio as a function of frequency; typical values BLF6G38-50_BLF6G38LS-50#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 13 BLF6G38-50; BLF6G38LS-50 WiMAX power LDMOS transistor 001aah400 18 40 ηD (%) Gp (dB) 30 16 001aah401 −30 ACPR (dBc) −40 −50 Gp 20 14 −60 12 (1) 10 ηD (1) (2) ACPR885k −70 ACPR1500k (2) (1) (2) ACPR1980k 10 10−1 0 1 102 10 −80 10−1 1 102 10 PL (W) PL (W) VDS = 28 V; IDq = 450 mA; f = 3500 MHz; Single Carrier N-CDMA; PAR = 9.7 dB at 0.01 % probability; Channel Bandwidth = 1.23 MHz; IBW = 30 kHz. VDS = 28 V; IDq = 450 mA; f = 3500 MHz; Single Carrier N-CDMA; PAR = 9.7 dB at 0.01 % probability; Channel Bandwidth = 1.23 MHz; IBW = 30 kHz. (1) Low frequency component (2) High frequency component Fig 6. Power gain and drain efficiency as functions of load power; typical values Fig 7. 001aah402 16 Gp (dB) Adjacent channel power ratio as a function of load power; typical values 001aah403 1.5 Pi (W) 15 1.0 (2) (3) (2) (1) (1) 14 (3) 0.5 13 12 10−1 1 0 10−1 102 10 VDS = 28 V; IDq = 450 mA; Single Carrier N-CDMA; PAR = 9.7 dB at 0.01 % probability; Channel Bandwidth = 1.23 MHz; IBW = 30 kHz. 102 10 VDS = 28 V; IDq = 450 mA; Single Carrier N-CDMA; PAR = 9.7 dB at 0.01 % probability; Channel Bandwidth = 1.23 MHz; IBW = 30 kHz. (1) f = 3400 MHz (1) f = 3400 MHz (2) f = 3500 MHz (2) f = 3500 MHz (3) f = 3600 MHz (3) f = 3600 MHz Fig 8. 1 PL (W) PL (W) Power gain as a function of load power; typical values Fig 9. Input power as a function of load power; typical values BLF6G38-50_BLF6G38LS-50#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 13 BLF6G38-50; BLF6G38LS-50 WiMAX power LDMOS transistor 8. Test information C8 C10 C9 C4 R2 C7 L1 C6 C3 R1 C1 C2 C5 BLF6G38-50 BLF6G38-50 INPUT-REV 1A 30RF35 OUTPUT-REV 1A 30RF35 001aah404 Striplines are on a double copper-clad Taconic RF35 Printed-Circuit Board (PCB) with r = 3.5 and thickness = 0.76 mm. See Table 9 for list of components. Fig 10. Component layout for 3400 MHz to 3600 MHz test circuit Table 9. List of components For test circuit, see Figure 10. Component Description Value Remarks C1, C4, C5, C6 multilayer ceramic chip capacitor 10 pF [1] C2 multilayer ceramic chip capacitor 0.7 pF [1] C3, C8, C9 multilayer ceramic chip capacitor 100 nF [2] C7 multilayer ceramic chip capacitor 10 F; 50 V [3] C10 electrolytic capacitor 470 F; 63 V R1, R2 SMD resistor 9.1  L1 ferrite SMD bead - Ferroxcube BDS 3/3/4.6-4S2 or equivalent [1] American Technical Ceramics type 100A or capacitor of same quality. [2] Vishay VJ1206Y104KXB or capacitor of same quality. [3] TDK C5750X7R1H106M or capacitor of same quality. Table 10. Measured test circuit impedances f Zi Zo (GHz) () () 3.4 5.48  j9.38 12.42  j4.58 3.5 5.39  j9.43 10.41  j5.31 3.6 5.55  j9.15 14.31  j7.04 3.8 9.60  j12.48 17.70  j11.57 BLF6G38-50_BLF6G38LS-50#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 13 BLF6G38-50; BLF6G38LS-50 WiMAX power LDMOS transistor 9. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT502A D A F 3 D1 U1 B q c C 1 H L E1 p U2 E w1 M A M B M A 2 w2 M C M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION D E E1 F H L p Q q U1 U2 w1 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 3.38 3.12 1.70 1.45 27.94 34.16 33.91 9.91 9.65 0.25 0.51 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.067 1.100 0.057 1.345 1.335 0.390 0.380 0.01 0.02 D1 0.045 0.785 0.035 0.745 0.210 0.133 0.170 0.123 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 03-01-10 12-05-02 SOT502A Fig 11. Package outline SOT502A BLF6G38-50_BLF6G38LS-50#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 13 BLF6G38-50; BLF6G38LS-50 WiMAX power LDMOS transistor Earless flanged ceramic package; 2 leads SOT502B D A F 3 D D1 c U1 1 L H E1 U2 E 2 w2 M D M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION D E E1 F H L Q U1 U2 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 1.70 1.45 20.70 20.45 9.91 9.65 0.25 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.045 0.785 0.035 0.745 0.210 0.170 0.067 0.815 0.057 0.805 D1 REFERENCES IEC JEDEC JEITA 0.390 0.010 0.380 EUROPEAN PROJECTION ISSUE DATE 07-05-09 12-05-02 SOT502B Fig 12. Package outline SOT502B BLF6G38-50_BLF6G38LS-50#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 13 BLF6G38-50; BLF6G38LS-50 WiMAX power LDMOS transistor 10. Abbreviations Table 11. Abbreviations Acronym Description CCDF Complementary Cumulative Distribution Function CW Continuous Wave EVM Error Vector Magnitude FCH Frame Control Header FFT Fast Fourier Transform IBW Instantaneous BandWidth LDMOS Laterally Diffused Metal-Oxide Semiconductor LDMOST Laterally Diffused Metal-Oxide Semiconductor Transistor N-CDMA Narrowband Code Division Multiple Access PAR Peak-to-Average power Ratio PUSC Partial Usage of SubChannels RF Radio Frequency SMD Surface Mounted Device VSWR Voltage Standing-Wave Ratio WCS Wireless Communications Service WiMAX Worldwide Interoperability for Microwave Access 11. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF6G38-50_BLF6G38LS-50#3 20150901 Product data sheet - BLF6G38-50_BLF6G38LS-50#2 Modifications: • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF6G38-50_BLF6G38LS-50#2 20100601 Product data sheet - BLF6G38-50_BLF6G38LS-50#1 BLF6G38-50_BLF6G38LS-50#1 20080212 Preliminary data sheet - - BLF6G38-50_BLF6G38LS-50#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 13 BLF6G38-50; BLF6G38LS-50 WiMAX power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. BLF6G38-50_BLF6G38LS-50#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 13 BLF6G38-50; BLF6G38LS-50 WiMAX power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLF6G38-50_BLF6G38LS-50#3 All information provided in this document is subject to legal disclaimers. Product data sheet Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 13 BLF6G38-50; BLF6G38LS-50 WiMAX power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.2.1 7.2.2 7.3 7.3.1 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Application information. . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 3 Ampleon WiMAX signal . . . . . . . . . . . . . . . . . . 4 WiMAX signal description . . . . . . . . . . . . . . . . . 4 Graphs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Single carrier N-CDMA broadband performance at 9 W average . . . . . . . . . . . . . . 5 Graphs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF6G38-50_BLF6G38LS-50#3
BLF6G38LS-50,118 价格&库存
很抱歉,暂时无法提供与“BLF6G38LS-50,118”相匹配的价格&库存,您可以联系我们找货
