BLL8H0514-25U
BLL8H0514-25U
    AMPLEON(安谱隆)
    SOT467C
    25W LDMOS晶体管,电流:25W,耐压:100V
BLL8H0514-25U 数据手册
BLL8H0514-25 Power LDMOS transistor Rev. 2 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 25 W LDMOS transistor intended for pulsed applications in the 0.5 GHz to 1.4 GHz range. Table 1. Application information Typical RF performance at Tcase = 25 C; IDq = 50 mA; in a class-AB application circuit. Test signal pulsed RF  VDS PL Gp RLin D f tp (MHz) (s) (%) (V) (W) (dB) (dB) (%) (dB) Pdroop(pulse) tr (ns) (ns) tf 960 to 1215 128 10 50 25 21 10 58 0.05 8 6 1200 to 1400 300 10 50 25 19 10 50 0.05 8 6 1.2 Features and benefits         Easy power control Integrated dual side ESD protection High flexibility with respect to pulse formats Excellent ruggedness High efficiency Excellent thermal stability Designed for broadband operation (0.5 GHz to 1.4 GHz) Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  Amplifiers for pulsed applications in the 0.5 GHz to 1.4 GHz frequency range 2. Pinning information Table 2. Pinning Pin Description 1 drain 2 gate 3 source Simplified outline Connected to flange. 1 1 [1] 3 2 [1] Graphic symbol 2 3 sym112 BLL8H0514-25 Power LDMOS transistor 3. Ordering information Table 3. Ordering information Type number BLL8H0514-25 Package Name Description Version - flanged ceramic package; 2 mounting holes; 2 leads SOT467C 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS Min Max Unit drain-source voltage - 100 V VGS gate-source voltage 6 +13 V Tstg storage temperature 65 +150 C Tj junction temperature - 225 C [1] Conditions [1] Continuous use at maximum temperature will affect the reliability, for details refer to the on-line MTF calculator. 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Typ Zth(j-c) transient thermal impedance from junction to case Tcase = 85 C; PL = 25 W Unit tp = 100 s;  = 10 % 0.86 K/W tp = 200 s;  = 10 % 1.11 K/W tp = 300 s;  = 10 % 1.29 K/W tp = 100 s;  = 20 % 1.15 K/W 6. Characteristics Table 6. DC characteristics Tj = 25 C; per section unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit 110 - - V VDS = 10 V; ID = 18 mA 1.4 1.9 2.4 V V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 630 mA BLL8H0514-25#2 Product data sheet VGS(th) gate-source threshold voltage IDSS drain leakage current VGS = 0 V; VDS = 50 V - - 1 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V 2.1 2.5 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 100 nA gfs forward transconductance VDS = 10 V; ID = 18 mA 120 150 - mS RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 63 mA - 1500 2750 m All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 11 BLL8H0514-25 Power LDMOS transistor Table 7. RF characteristics Test signal: pulsed RF; tp = 128 s;  = 10 %; RF performance at VDS = 50 V; IDq = 50 mA; f = 1.2 GHz; Tcase = 25 C; unless otherwise specified, in a class-AB production test circuit. Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage PL = 25 W - - 50 V Gp power gain PL = 25 W 20 21 - dB RLin input return loss PL = 25 W - 15 10 dB D drain efficiency PL = 25 W 57 59 - % Pdroop(pulse) pulse droop power PL = 25 W - 0 0.3 dB tr rise time PL = 25 W - 20 50 ns tf fall time PL = 25 W - 6 50 ns 7. Application information 7.1 Ruggedness in class-AB operation The BLL8H0514-25 is capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 50 V; IDq = 50 mA; PL = 25 W; f = 1.2 GHz; tp = 128 s;  = 10 %. 7.2 Impedance information Table 8. Typical impedance Typical values per section unless otherwise specified. f ZS ZL (MHz) () () 950 2.37 + j3.30 6.11 + j11.1 1000 2.44 + j2.65 7.00 + j16.0 1050 2.34 + j2.67 7.39 + j14.2 1100 2.56 + j2.06 7.00 + j16.0 1150 2.54 + j1.70 5.77 + j13.85 1200 2.25 + j1.29 7.39 + j14.2 1300 2.21 + j0.15 6.11 + j11.1 1400 2.46  j0.52 5.00 + j10.0 drain ZL gate ZS 001aaf059 Fig 1. BLL8H0514-25#2 Product data sheet Definition of transistor impedance All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 11 BLL8H0514-25 Power LDMOS transistor 7.3 Application circuit C4 C9 C6 C2 C3 C7 C5 C8 C10 C11 R1 C1 C12 001aak882 Printed-Circuit Board (PCB) material: Duroid 6006 with r = 6.15 and thickness = 0.64 mm. See Table 9 for list of components. Fig 2. Component layout Table 9. List of components See Figure 2 for component layout. BLL8H0514-25#2 Product data sheet Component Description Value C1, C6, C7, C12 multilayer ceramic chip capacitor 56 pF C2 multilayer ceramic chip capacitor 10 F, 25 V C3, C4, C8, C9 multilayer ceramic chip capacitor 100 pF [1] C5, C10 multilayer ceramic chip capacitor 1 nF [2] C11 electrolytic capacitor 68 F, 63 V R1 SMD resistor 10  [1] American Technical Ceramics type 100A or capacitor of same quality. [2] American Technical Ceramics type 100B or capacitor of same quality. All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 Remarks [1] SMD 0603 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 11 BLL8H0514-25 Power LDMOS transistor 8. Test information 8.1 Performance curves 001aak883 35 PL (W) 30 (1) (2) 001aak884 24 Gp (dB) (3) (1) 25 (2) 16 (3) 20 15 8 10 5 0 0 0 200 400 600 0 5 10 Pi (mW) VDS = 50 V; IDq = 50 mA; tp = 300 s;  = 10 %. (1) f = 1200 MHz (2) f = 1300 MHz (2) f = 1300 MHz (3) f = 1400 MHz (3) f = 1400 MHz Output power as a function of input power; typical values BLL8H0514-25#2 Product data sheet 20 25 30 PL (W) 35 VDS = 50 V; IDq = 50 mA; tp = 300 s;  = 10 %. (1) f = 1200 MHz Fig 3. 15 Fig 4. Power gain as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 11 BLL8H0514-25 Power LDMOS transistor 001aak885 70 001aak886 25 65 Gp (dB) ηD (%) 60 (1) 50 ηD (%) ηD 23 55 (2) (3) 21 40 45 Gp 30 19 35 17 25 20 10 0 0 5 10 15 20 25 30 PL (W) 15 1.15 35 1.25 15 1.45 1.35 f (GHz) VDS = 50 V; IDq = 50 mA; tp = 300 s;  = 10 %. VDS = 50 V; IDq = 50 mA; tp = 300 s;  = 10 %. (1) f = 1200 MHz (2) f = 1300 MHz (3) f = 1400 MHz Fig 5. Drain efficiency as a function of output power; typical values Fig 6. Power gain and drain efficiency as function of frequency; typical values 001aak887 25 RLin (dB) 20 15 10 5 0 1.15 1.25 1.35 1.45 f (GHz) PL = 25 W; VDS = 50 V; IDq = 50 mA; tp = 300 s;  = 10 %. Fig 7. BLL8H0514-25#2 Product data sheet Input return loss as a function of frequency; typical values All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 11 BLL8H0514-25 Power LDMOS transistor 9. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT467C D A F 3 D1 U1 q B C c 1 E1 H U2 E A w1 M A M B M p 2 Q w2 M C M b 0 5 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c D D1 E E1 F H p Q q U1 U2 w1 w2 mm 4.67 3.94 5.59 5.33 0.15 0.10 9.25 9.04 9.27 9.02 5.92 5.77 5.97 5.72 1.65 1.40 18.54 17.02 3.43 3.18 2.21 1.96 14.27 20.45 20.19 5.97 5.72 0.25 0.51 inch 0.184 0.220 0.006 0.155 0.210 0.004 0.364 0.365 0.356 0.355 0.233 0.227 0.235 0.065 0.225 0.055 0.73 0.67 0.135 0.087 0.805 0.562 0.125 0.077 0.795 0.235 0.010 0.225 0.020 OUTLINE VERSION REFERENCES IEC JEDEC EIAJ ISSUE DATE 99-12-28 12-05-02 SOT467C Fig 8. EUROPEAN PROJECTION Package outline SOT467C BLL8H0514-25#2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 11 BLL8H0514-25 Power LDMOS transistor 10. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 11. Abbreviations Table 10. Abbreviations Acronym Description ESD ElectroStatic Discharge LDMOS Laterally Diffused Metal-Oxide Semiconductor MTF Median Time to Failure SMD Surface Mounted Device VSWR Voltage Standing-Wave Ratio 12. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BLL8H0514-25#2 20150901 Product data sheet - BLL8H0514-25 #1 Modifications: BLL8H0514-25 #1 BLL8H0514-25#2 Product data sheet • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. 20150209 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 - © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 11 BLL8H0514-25 Power LDMOS transistor 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLL8H0514-25#2 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 11 BLL8H0514-25 Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14. Contact information For more information, please visit: http://www.ampleon.com BLL8H0514-25#2 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 2 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 11 BLL8H0514-25 Power LDMOS transistor 15. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Application information. . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 3 Impedance information . . . . . . . . . . . . . . . . . . . 3 Application circuit . . . . . . . . . . . . . . . . . . . . . . . 4 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 5 Performance curves . . . . . . . . . . . . . . . . . . . . . 5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Handling information. . . . . . . . . . . . . . . . . . . . . 8 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 9 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 9 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Contact information. . . . . . . . . . . . . . . . . . . . . 10 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLL8H0514-25#2
BLL8H0514-25U 价格&库存
很抱歉,暂时无法提供与“BLL8H0514-25U”相匹配的价格&库存,您可以联系我们找货
