BLF573S,112
BLF573S,112
    AMPLEON(安谱隆)
    SOT502B
    BLF573S,112
BLF573S,112 数据手册
BLF573; BLF573S HF / VHF power LDMOS transistor Rev. 4 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description A 300 W LDMOS RF power transistor for broadcast applications and industrial, scientific and medical applications in the HF to 500 MHz band. Table 1. Production test information D Mode of operation f VDS PL Gp (MHz) (V) (W) (dB) (%) CW 225 50 300 27.2 70 CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Therefore care should be taken during transport and handling. 1.2 Features and benefits  Typical CW performance at frequency of 225 MHz, a supply voltage of 50 V and an IDq of 900 mA:  Average output power = 300 W  Power gain = 27.2 dB  Efficiency = 70 %  Easy power control  Integrated ESD protection  Excellent ruggedness  High efficiency  Excellent thermal stability  Designed for broadband operation (HF and VHF band)  Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  Industrial, scientific and medical applications  Broadcast transmitter applications BLF573; BLF573S HF / VHF power LDMOS transistor 2. Pinning information Table 2. Pin Pinning Description Simplified outline Graphic symbol BLF573 (SOT502A) 1 drain 2 gate 3 source 1 1 3 [1] 2 2 3 sym112 BLF573S (SOT502B) 1 drain 2 gate 3 source 1 1 3 [1] 2 2 3 sym112 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF573 - flanged LDMOST ceramic package; 2 mounting holes; 2 leads SOT502A BLF573S - earless flanged LDMOST ceramic package, 2 leads SOT502B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage - 110 V VGS gate-source voltage 0.5 +11 V ID drain current - 42 A Tstg storage temperature 65 +150 C Tj junction temperature - 225 C 5. Thermal characteristics Table 5. Symbol Rth(j-c) [1] BLF573_BLF573S#4 Product data sheet Thermal characteristics Parameter Conditions thermal resistance from junction to case Tcase = 80 C; PL = 300 W [1] Typ Unit 0.21 K/W Rth(j-c) is measured under RF conditions. All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 16 BLF573; BLF573S HF / VHF power LDMOS transistor 6. Characteristics Table 6. DC characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 3.75 mA Min Typ Max Unit 110 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 375 mA 1.25 1.7 2.25 V VGSq gate-source quiescent voltage VDS = 50 V; ID = 900 mA 1.45 1.95 2.45 V IDSS drain leakage current VGS = 0 V; VDS = 50 V - - 4.2 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V 44 56 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 420 nA gfs forward transconductance VDS = 10 V; ID = 18.75 A - 20 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 12.49 A - 0.09 -  Crs feedback capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 2.3 - pF Ciss input capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 300 - pF Coss output capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 103 - pF Table 7. RF characteristics Mode of operation: CW; f = 225 MHz; RF performance at VDS = 50 V; IDq = 900 mA; Tcase = 25 C; unless otherwise specified; in a class-AB production test circuit. Symbol Parameter BLF573_BLF573S#4 Product data sheet Conditions Min Typ Max Unit Gp power gain PL = 300 W 26 27.2 28.4 dB RLin input return loss PL = 300 W 10 13 - dB D drain efficiency PL = 300 W 67 70 - % All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 16 BLF573; BLF573S HF / VHF power LDMOS transistor 001aaj141 800 Coss (pF) 600 400 200 0 0 10 20 30 40 50 VDS (V) VGS = 0 V; f = 1 MHz. Fig 1. Output capacitance as a function of drain-source voltage; capacitance value without internal matching 6.1 Ruggedness in class-AB operation The BLF573 and BLF573S are capable of withstanding a load mismatch corresponding to VSWR = 13 : 1 through all phases under the following conditions: VDS = 50 V; IDq = 900 mA; PL = 300 W; f = 225 MHz. 7. Application information 7.1 Impedance information Table 8. Typical impedance Measured ZS and ZL test circuit impedances. f ZS ZL MHz   225 0.7 + j2.0 1.95 + j2.0 drain ZL gate ZS 001aaf059 Fig 2. BLF573_BLF573S#4 Product data sheet Definition of transistor impedance All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 16 BLF573; BLF573S HF / VHF power LDMOS transistor 7.2 Reliability 001aaj142 105 Years (1) (2) (3) (4) (5) (7) (8) (9) (10) (11) (6) 104 103 102 10 1 0 4 8 12 16 20 Idc (A) TTF (0.1 % failure fraction). (1) Tj = 100 C (2) Tj = 110 C (3) Tj = 120 C (4) Tj = 130 C (5) Tj = 140 C (6) Tj = 150 C (7) Tj = 160 C (8) Tj = 170 C (9) Tj = 180 C (10) Tj = 190 C (11) Tj = 200 C Fig 3. BLF573_BLF573S#4 Product data sheet BLF573 and BLF573S electromigration (ID, total device) All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 16 BLF573; BLF573S HF / VHF power LDMOS transistor 8. Test information 8.1 RF Performance The following figures are measured in a class-AB production test circuit. 8.1.1 1-Tone CW 001aaj612 30 ηD (%) Gp (dB) 28 001aaj613 30 80 (7) (6) (5) Gp (dB) 60 28 40 26 20 24 Gp ηD 26 24 22 0 100 200 0 400 300 (1) (2) (3) (4) 22 0 100 200 PL (W) 300 400 PL (W) VDS = 50 V; IDq = 900 mA; f = 225 MHz. VDS = 50 V; f = 225 MHz. (1) IDq = 500 mA (2) IDq = 700 mA (3) IDq = 900 mA (4) IDq = 1100 mA (5) IDq = 1300 mA (6) IDq = 1500 mA (7) IDq = 1700 mA Fig 4. Power gain and drain efficiency as functions of load power; typical values BLF573_BLF573S#4 Product data sheet Fig 5. Power gain as function of load power; typical values All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 16 BLF573; BLF573S HF / VHF power LDMOS transistor 001aaj614 60 PL (dBm) Ideal PL 58 (2) 56 (1) PL 54 52 50 24 26 28 30 32 34 Pi (dBm) VDS = 50 V; IDq = 900 mA; f = 225 MHz. (1) PL(1dB) = 55.2 dBm (330 W) (2) PL(3dB) = 55.8 dBm (380 W) Fig 6. Load power as function of input power; typical values BLF573_BLF573S#4 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 16 BLF573; BLF573S HF / VHF power LDMOS transistor 8.1.2 2-Tone CW 001aaj615 30 ηD (%) Gp (dB) 28 ηD 26 24 −20 40 −40 20 22 0 100 200 300 IMD3 (dBc) 60 Gp VDS = 50 V; IDq = 900 mA; f1 = 224.95 MHz; f2 = 225.05 MHz. (1) (2) (3) (4) (5) (8) (7) (6) −60 −80 0 400 500 PL(PEP) (W) 001aaj616 0 80 0 100 200 300 400 500 PL(PEP) (W) VDS = 50 V; f1 = 224.95 MHz; f2 = 225.05 MHz. (1) IDq = 500 mA (2) IDq = 700 mA (3) IDq = 900 mA (4) IDq = 1100 mA (5) IDq = 1300 mA (6) IDq = 1500 mA (7) IDq = 1700 mA (8) IDq = 1800 mA Fig 7. Power gain and drain efficiency as functions of peak envelope load power; typical values Fig 8. Third order intermodulation distortion as a function of peak envelope load power; typical values 8.2 Test circuit Table 9. List of components For production test circuit, see Figure 9 and Figure 10. Printed-Circuit Board (PCB): Rogers 5880; r = 2.2 F/m; height = 0.79 mm; Cu (top/bottom metallization); thickness copper plating = 35 m. Component Description Value B1 ferrite SMD bead 100 ; 100 MHz Remarks Ferroxcube BDS3/3/8.9-4S2 or equivalent C1, C18 multilayer ceramic chip capacitor 100 pF [1] C2 multilayer ceramic chip capacitor 39 pF [1] C3, C4 multilayer ceramic chip capacitor 180 pF [1] C5, C6, C7 multilayer ceramic chip capacitor 220 pF [1] C8, C20 multilayer ceramic chip capacitor 1 nF [1] C9 multilayer ceramic chip capacitor 4.7 F C10 multilayer ceramic chip capacitor 30 pF [1] C11, C12, C13 multilayer ceramic chip capacitor 51 pF [1] C14 43 pF [1] multilayer ceramic chip capacitor BLF573_BLF573S#4 Product data sheet TDK C4532X7R1E475MT020U or equivalent All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 16 BLF573; BLF573S HF / VHF power LDMOS transistor Table 9. List of components …continued For production test circuit, see Figure 9 and Figure 10. Printed-Circuit Board (PCB): Rogers 5880; r = 2.2 F/m; height = 0.79 mm; Cu (top/bottom metallization); thickness copper plating = 35 m. Component Description Value C15 multilayer ceramic chip capacitor 33 pF [1] Remarks C16 multilayer ceramic chip capacitor 36 pF [1] C17 multilayer ceramic chip capacitor 16 pF [1] C19 electrolytic capacitor 220 F; 63 V L1 2 turns enamelled copper wire D = 3 mm; d = 1 mm; length = 2 mm; leads = 2  6 mm L2 4 turns enamelled copper wire D = 2 mm; d = 1 mm; length = 13 mm; leads = 2  5 mm L3 stripline - (L  W) 96 mm  3 mm L4, L5 stripline - (L  W) 15 mm  8 mm L6 stripline - (L  W) 105 mm  6 mm L7 stripline - (L  W) 3 mm  6 mm L8 stripline - (L  W) 12 mm  6 mm R1 metal film resistor 100 ; 0.6 W [1] American Technical Ceramics type 100B or capacitor of same quality. VDD C19 VGG C9 B1 C8 C20 L1 R1 C13 input 50 Ω C1 C3 C14 C7 L7 L3 L4 C2 L5 C4 C5 C6 L2 L6 C16 C10 C11 L8 C18 output 50 Ω C17 C12 C15 001aaj148 Fig 9. Class-AB common-source production test circuit BLF573_BLF573S#4 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 16 BLF573; BLF573S HF / VHF power LDMOS transistor B1 C19 C9 C8 C7 C3 C20 C13 C14 R1 L2 L1 C18 C1 C2 C4 C5 C6 C17 C16 C11 C12 C10 C15 001aaj149 Fig 10. Component layout for class-AB production test circuit BLF573_BLF573S#4 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 16 BLF573; BLF573S HF / VHF power LDMOS transistor 9. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT502A D A F 3 D1 U1 B q c C 1 H L E1 p U2 E w1 M A M B M A 2 w2 M C M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION D E E1 F H L p Q q U1 U2 w1 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 3.38 3.12 1.70 1.45 27.94 34.16 33.91 9.91 9.65 0.25 0.51 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.067 1.100 0.057 1.345 1.335 0.390 0.380 0.01 0.02 D1 0.045 0.785 0.035 0.745 0.210 0.133 0.170 0.123 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 03-01-10 12-05-02 SOT502A Fig 11. Package outline SOT502A BLF573_BLF573S#4 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 16 BLF573; BLF573S HF / VHF power LDMOS transistor Earless flanged ceramic package; 2 leads SOT502B D A F 3 D D1 c U1 1 L H E1 U2 E 2 w2 M D M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION D E E1 F H L Q U1 U2 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 1.70 1.45 20.70 20.45 9.91 9.65 0.25 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.045 0.785 0.035 0.745 0.210 0.170 0.067 0.815 0.057 0.805 D1 REFERENCES IEC JEDEC JEITA 0.390 0.010 0.380 EUROPEAN PROJECTION ISSUE DATE 07-05-09 12-05-02 SOT502B Fig 12. Package outline SOT502B BLF573_BLF573S#4 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 16 BLF573; BLF573S HF / VHF power LDMOS transistor 10. Abbreviations Table 10. Abbreviations Acronym Description CW Continuous Wave EDGE Enhanced Data rates for GSM Evolution GSM Global System for Mobile communications HF High Frequency LDMOS Laterally Diffused Metal-Oxide Semiconductor LDMOST Laterally Diffused Metal-Oxide Semiconductor Transistor RF Radio Frequency SMD Surface Mount Device TTF Time To Failure VHF Very High Frequency VSWR Voltage Standing-Wave Ratio 11. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF573_BLF573S#4 20150901 Product data sheet - BLF573_BLF573S v.3 Modifications: • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF573_BLF573S v.3 20100708 Product data sheet - BLF573S v.2 BLF573S v.2 20090217 Product data sheet - BLF573S v.1 BLF573S v.1 20081208 Preliminary data sheet - - BLF573_BLF573S#4 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 16 BLF573; BLF573S HF / VHF power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF573_BLF573S#4 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 14 of 16 BLF573; BLF573S HF / VHF power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 13. Contact information For more information, please visit: http://www.ampleon.com BLF573_BLF573S#4 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 4 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 15 of 16 BLF573; BLF573S HF / VHF power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 6.1 7 7.1 7.2 8 8.1 8.1.1 8.1.2 8.2 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 4 Application information. . . . . . . . . . . . . . . . . . . 4 Impedance information . . . . . . . . . . . . . . . . . . . 4 Reliability . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6 RF Performance . . . . . . . . . . . . . . . . . . . . . . . . 6 1-Tone CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 2-Tone CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF573_BLF573S#4
BLF573S,112 价格&库存
很抱歉,暂时无法提供与“BLF573S,112”相匹配的价格&库存,您可以联系我们找货
