BLF7G10LS-250,118
BLF7G10LS-250,118
    AMPLEON(安谱隆)
    SOT502B
    BLF7G10LS-250,118
BLF7G10LS-250,118 数据手册
BLF7G10L-250; BLF7G10LS-250 Power LDMOS transistor Rev. 6 — 7 November 2016 Product data sheet 1. Product profile 1.1 General description 250 W LDMOS power transistor for base station applications at frequencies from 869 MHz to 960 MHz. Table 1. Typical performance Test signal: 3GPP; test model 1; 64 DPCH; PAR = 7.5 dB at 0.01 % probability on CCDF per carrier; carrier spacing = 5 MHz. Typical RF performance at Tcase = 25 C. Test signal f (MHz) 2-carrier W-CDMA 2-carrier W-CDMA IDq VDS PL(AV) Gp D ACPR (mA) (V) (W) (dB) (%) (dBc) 869 to 894 [1] 1800 30 60 19.5 27.4 35.6 920 to 960 [2] 1800 30 60 19.5 30.5 34 [1] In a common source class-AB application test circuit. [2] In a common source class-AB production test circuit. 1.2 Features and benefits          Excellent ruggedness High efficiency Low thermal resistance providing excellent thermal stability Designed for broadband operation (869 MHz to 960 MHz) Lower output capacitance for improved performance in Doherty applications Designed for low memory effects providing excellent pre-distortability Internally matched for ease of use (input and output) Integrated ESD protection Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  RF power amplifiers for W-CDMA base stations and multi carrier applications in the 869 MHz to 960 MHz frequency range BLF7G10L-250; BLF7G10LS-250 Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF7G10L-250 (SOT502A) 1 drain 2 gate 3 source 1 1 3 [1] 2 2 3 sym112 BLF7G10LS-250 (SOT502B) 1 drain 2 gate 3 source 1 1 3 [1] 2 2 3 sym112 [1] Connected to flange 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF7G10L-250 - flanged ceramic package; 2 mounting holes; 2 leads SOT502A BLF7G10LS-250 - earless flanged ceramic package; 2 leads SOT502B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS Conditions Min Max Unit drain-source voltage - 65 V VGS gate-source voltage 0.5 +13 V Tstg storage temperature 65 +150 C Tj junction temperature - 200 C 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-c) BLF7G10L-250_7G10LS-250 Product data sheet Conditions Typ thermal resistance from junction to case Tcase = 80 C; PL = 60 W (CW); VDS = 30 V; IDq = 1800 mA All information provided in this document is subject to legal disclaimers. Rev. 6 — 7 November 2016 Unit 0.38 K/W © Ampleon Netherlands B.V. 2016. All rights reserved. 2 of 13 BLF7G10L-250; BLF7G10LS-250 Power LDMOS transistor 6. Characteristics Table 6. DC characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions Min V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 3.3 mA Typ Max Unit 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 330 A 1.50 1.9 2.30 V VGSq gate-source quiescent voltage VDS = 30 V; ID = 1.8 A 1.63 2.03 2.43 V IDSS drain leakage current VGS = 0 V; VDS = 28 V - - 5 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 56 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 0.5 mA gfs forward transconductance VDS = 10 V; ID = 11.55 A - 22 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 11.55 A - 57 - m Table 7. RF characteristics Test signal: 2-carrier W-CDMA; PAR = 7.5 dB at 0.01 % probability on the CCDF; 3GPP test model 1; 64 DPCH; f1 = 920 MHz; f2 = 925 MHz; f3 = 955 MHz; f4 = 960 MHz; RF performance at VDS = 30 V; IDq = 1800 mA; Tcase = 25 C; unless otherwise specified; in a class-AB production test circuit. Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL(AV) = 60 W 18.5 19.5 - dB RLin input return loss PL(AV) = 60 W - 15.5 10 dB D drain efficiency PL(AV) = 60 W 27 30.5 - % ACPR adjacent channel power ratio PL(AV) = 60 W - 34 31 dBc 7. Test information 7.1 Ruggedness in class-AB operation The BLF7G10L-250 and BLF7G10LS-250 are capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 30 V; IDq = 1800 mA; PL = 200 W (CW); f = 920 MHz to 960 MHz. 7.2 Impedance information Table 8. Typical impedance information IDq = 1800 mA; main transistor VDS = 30 V. ZS and ZL defined in Figure 1. BLF7G10L-250_7G10LS-250 Product data sheet f ZS (MHz) () () 925 3.1  j3.3 1.0  j1.7 942 3.2  j3.3 1.0  j1.6 960 3.4  j3.5 0.9  j1.4 All information provided in this document is subject to legal disclaimers. Rev. 6 — 7 November 2016 ZL © Ampleon Netherlands B.V. 2016. All rights reserved. 3 of 13 BLF7G10L-250; BLF7G10LS-250 Power LDMOS transistor drain ZL gate ZS 001aaf059 Fig 1. Definition of transistor impedance 7.3 Circuit C5 C7 C8 C11 C12 C2 C1 C15 C4 BLF7G10L(S)-250 C9 C10 C3 C6 C13 C14 C16 aaa-001570 Printed-Circuit Board (PCB): Rogers RO3006; r = 6.15 F/m; thickness = 0.635 mm; thickness copper plating = 35 m. The vias can be used as a reference to place components. The above layout shows the test circuit used to measure the devices in production. A more appropriate application demonstration for specific customer needs can be provided. See Table 9 for list of components. Fig 2. Component layout Table 9. List of components See Figure 2 for component layout. BLF7G10L-250_7G10LS-250 Product data sheet Component Description Value Remarks C1, C2, C3, C4, C5, C6 multilayer ceramic chip capacitor 82 pF ATC800B C7, C9, C12, C14 multilayer ceramic chip capacitor 10 F Murata Murata C8, C10, C11, C13 multilayer ceramic chip capacitor 1 F C15, C16 electrolytic capacitor 470 F, 63 V All information provided in this document is subject to legal disclaimers. Rev. 6 — 7 November 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 4 of 13 BLF7G10L-250; BLF7G10LS-250 Power LDMOS transistor 7.4 Graphs 7.4.1 CW pulsed aaa-001555 22 Gp Gp (dB) ηD (%) (1) (2) (3) 18 ηD (%) (1) (2) (3) 18 ηD 14 10 48 52 20 14 0 10 56 20 0 120 0 360 240 PL (dBm) PL (W) VDS = 30 V; IDq = 1800 mA. VDS = 30 V; IDq = 1800 mA. (1) f = 920 MHz (1) f = 920 MHz (2) f = 940 MHz (2) f = 940 MHz (3) f = 960 MHz (3) f = 960 MHz Fig 3. 40 (1) (2) (3) ηD 44 60 Gp Gp (dB) 40 (1) (2) (3) aaa-001556 22 60 Power gain and drain efficiency as function of output power; typical values Fig 4. Power gain and drain efficiency as function of output power; typical values aaa-001559 -12 RLin (dB) -14 (1) (2) -16 (3) -18 -20 44 48 52 56 PL (dBm) VDS = 30 V; IDq = 1800 mA. (1) f = 920 MHz (2) f = 940 MHz (3) f = 960 MHz Fig 5. Input return loss as a function of output power; typical values BLF7G10L-250_7G10LS-250 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 7 November 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 5 of 13 BLF7G10L-250; BLF7G10LS-250 Power LDMOS transistor 7.4.2 2-Carrier W-CDMA aaa-001561 21 Gp (dB) ηD (%) Gp 20 (1) (2) (3) 19 (1) (2) (3) 18 aaa-001562 21 50 Gp (dB) 40 20 30 19 20 18 16 40 42 44 46 48 10 17 0 16 50 52 PL (dBm) (1) (2) (3) 30 (1) (2) (3) 20 10 0 40 0 120 80 PL (W) VDS = 30 V; IDq = 1800 mA. VDS = 30 V; IDq = 1800 mA. (1) f = 920 MHz (1) f = 920 MHz (2) f = 940 MHz (2) f = 940 MHz (3) f = 960 MHz (3) f = 960 MHz Fig 6. 40 ηD 17 38 ηD (%) Gp ηD 50 Power gain and drain efficiency as function of output power; typical values Fig 7. aaa-001564 -10 Power gain and drain efficiency as function of output power; typical values aaa-001566 -20 ACPR (dBc) RLin (dB) -30 ACPR5M -14 (1) (1) (2) (3) -40 (2) ACPR10M (3) -18 -50 (1) (2) (3) -22 -60 38 42 46 50 54 38 42 46 50 PL (dBm) VDS = 30 V; IDq = 1800 mA. VDS = 30 V; IDq = 1800 mA. (1) f = 920 MHz (1) f = 920 MHz (2) f = 940 MHz (2) f = 940 MHz (3) f = 960 MHz (3) f = 960 MHz Fig 8. Input return loss as a function of output power; typical values BLF7G10L-250_7G10LS-250 Product data sheet 54 PL (dBm) Fig 9. Adjacent channel power ratio (5 MHz and 10 MHz) as function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 6 — 7 November 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 6 of 13 BLF7G10L-250; BLF7G10LS-250 Power LDMOS transistor aaa-001568 9 PAR (dB) 8 (1) (2) (3) 7 6 5 38 42 46 50 54 PL (dBm) VDS = 30 V; IDq = 1800 mA. (1) f = 920 MHz (2) f = 940 MHz (3) f = 960 MHz Fig 10. Peak-to-average ratio as a function of output power; typical values BLF7G10L-250_7G10LS-250 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 7 November 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 7 of 13 BLF7G10L-250; BLF7G10LS-250 Power LDMOS transistor 8. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT502A D A F 3 D1 U1 B q c C 1 H L E1 p U2 E w1 M A M B M A 2 w2 M C M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION E E1 F H L p Q q U1 U2 w1 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 3.38 3.12 1.70 1.45 27.94 34.16 33.91 9.91 9.65 0.25 0.51 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.067 1.100 0.057 1.345 1.335 0.390 0.380 0.01 0.02 D D1 0.045 0.785 0.210 0.133 0.035 0.745 0.170 0.123 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 03-01-10 12-05-02 SOT502A Fig 11. Package outline SOT502A BLF7G10L-250_7G10LS-250 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 7 November 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 8 of 13 BLF7G10L-250; BLF7G10LS-250 Power LDMOS transistor Earless flanged ceramic package; 2 leads SOT502B D A F 3 D D1 c U1 1 L H E1 U2 E 2 w2 M D M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION E E1 F H L Q U1 U2 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 1.70 1.45 20.70 20.45 9.91 9.65 0.25 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 D D1 0.045 0.785 0.210 0.035 0.745 0.170 0.067 0.815 0.057 0.805 REFERENCES IEC JEDEC JEITA 0.390 0.010 0.380 EUROPEAN PROJECTION ISSUE DATE 07-05-09 12-05-02 SOT502B Fig 12. Package outline SOT502B BLF7G10L-250_7G10LS-250 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 7 November 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 9 of 13 BLF7G10L-250; BLF7G10LS-250 Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 10. Abbreviations Acronym Description 3GPP Third Generation Partnership Project CCDF Complementary Cumulative Distribution Function CW Continuous Wave DPCH Dedicated Physical CHannel ESD ElectroStatic Discharge LDMOS Laterally Diffused Metal Oxide Semiconductor PAR Peak-to-Average Ratio VSWR Voltage Standing Wave Ratio W-CDMA Wideband Code Division Multiple Access 11. Revision history Table 11. Revision history Document ID Release date Data sheet status BLF7G10L-250_7G10LS-250 v.6 20161107 Modifications: • Product data sheet Change notice Supersedes - BLF7G10L-250_7G10LS-250 v.5 Table 6 on page 3: added VGSq parameter to table BLF7G10L-250_7G10LS-250 v.5 20150901 Product data sheet - BLF7G10L-250_7G10LS-250 v.4 BLF7G10L-250_7G10LS-250 v.4 20120913 Product data sheet - BLF7G10L-250_7G10LS-250 v.3 BLF7G10L-250_7G10LS-250 v.3 20120216 Product data sheet - BLF7G10L-250_7G10LS-250 v.2 BLF7G10L-250_7G10LS-250 v.2 20111114 Preliminary data sheet - BLF7G10L-250_7G10LS-250 v.1 BLF7G10L-250_7G10LS-250 v.1 20110225 Objective data sheet - BLF7G10L-250_7G10LS-250 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 6 — 7 November 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 10 of 13 BLF7G10L-250; BLF7G10LS-250 Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF7G10L-250_7G10LS-250 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 6 — 7 November 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 11 of 13 BLF7G10L-250; BLF7G10LS-250 Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’s standard warranty and Ampleon’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 13. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLF7G10L-250_7G10LS-250 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 7 November 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 12 of 13 BLF7G10L-250; BLF7G10LS-250 Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 7.4.1 7.4.2 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 3 Impedance information . . . . . . . . . . . . . . . . . . . 3 Circuit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Graphs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 CW pulsed . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 2-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Handling information. . . . . . . . . . . . . . . . . . . . 10 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon Netherlands B.V. 2016. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 7 November 2016 Document identifier: BLF7G10L-250_7G10LS-250
BLF7G10LS-250,118 价格&库存
很抱歉,暂时无法提供与“BLF7G10LS-250,118”相匹配的价格&库存,您可以联系我们找货
