BLF871S,112
BLF871S,112
    AMPLEON(安谱隆)
    SOT467B
    BLF871S,112
BLF871S,112 数据手册
BLF871; BLF871S UHF power LDMOS transistor Rev. 5 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description A 100 W LDMOS RF power transistor for broadcast transmitter applications and industrial applications. The transistor can deliver 100 W broadband from HF to 1 GHz. The excellent ruggedness and broadband performance of this device makes it ideal for digital transmitter applications. Table 1. Typical performance RF performance at VDS = 40 V in a common-source 860 MHz test circuit. Mode of operation f PL PL(PEP) D PL(AV) Gp IMD3 PAR (MHz) (W) (W) (W) (dB) (%) (dBc) (dB) CW, class AB 860 100 - - 21 60 - - 2-tone, class AB f1 = 860; f2 = 860.1 - - 21 47 35 - 33 34[1] 8.3[2] DVB-T (8k OFDM) 858 - 100 - 24 22 [1] Measured [dBc] with delta marker at 4.3 MHz from center frequency. [2] PAR (of output signal) at 0.01 % probability on CCDF; PAR of input signal = 9.5 dB at 0.01 % probability on CCDF. CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Therefore care should be taken during transport and handling. 1.2 Features  2-tone performance at 860 MHz, a drain-source voltage VDS of 40 V and a quiescent drain current IDq = 0.5 A:  Peak envelope power load power = 100 W  Power gain = 21 dB  Drain efficiency = 47 %  Third order intermodulation distortion = 35 dBc  DVB performance at 858 MHz, a drain-source voltage VDS of 40 V and a quiescent drain current IDq = 0.5 A:  Average output power = 24 W  Power gain = 22 dB  Drain efficiency = 33 %  Third order intermodulation distortion = 34 dBc (4.3 MHz from center frequency) BLF871; BLF871S UHF power LDMOS transistor        Integrated ESD protection Excellent ruggedness High power gain High efficiency Excellent reliability Easy power control Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  Communication transmitter applications in the UHF band  Industrial applications in the UHF band 2. Pinning information Table 2. Pin Pinning Description Simplified outline Graphic symbol BLF871 (SOT467C) 1 drain 2 gate 3 source 1 1 [1] 3 2 3 2 sym112 BLF871S (SOT467B) 1 drain 2 gate 3 source 1 [1] 1 2 3 3 sym112 2 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description BLF871_BLF871S#5 Product data sheet Version BLF871 - flanged LDMOST ceramic package; 2 mounting holes; 2 leads SOT467C BLF871S - earless LDMOST ceramic package; 2 leads All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 SOT467B © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 20 BLF871; BLF871S UHF power LDMOS transistor 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS VGS Conditions Min Max Unit drain-source voltage - 89 V gate-source voltage 0.5 +13 V Tstg storage temperature 65 +150 C Tj junction temperature - 200 C 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Rth(j-c) thermal resistance from junction to case Tcase = 80 C; PL(AV) = 50 W [1] [1] Typ Unit 0.95 K/W Rth(j-c) is measured under RF conditions. 6. Characteristics Table 6. Characteristics Tj = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 1.12 mA VGS(th) gate-source threshold voltage VDS = 10 V; ID = 112 mA Product data sheet [1] 89 - 105.5 V [1] 1.4 - 2.4 V - IDSS drain leakage current VGS = 0 V; VDS = 40 V - 1.4 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V 16.7 20 - A IGSS gate leakage current VGS = 10 V; VDS = 0 V - - 140 nA - 210 - m [1] RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 3.7 A Ciss input capacitance VGS = 0 V; VDS = 40 V; f = 1 MHz - 95 - pF Coss output capacitance VGS = 0 V; VDS = 40 V; f = 1 MHz - 30 - pF Crss reverse transfer capacitance VGS = 0 V; VDS = 40 V; f = 1 MHz - 1 - pF [1] BLF871_BLF871S#5 Unit ID is the drain current. All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 20 BLF871; BLF871S UHF power LDMOS transistor 001aaj276 160 Coss (pF) 120 80 40 0 0 20 40 60 VDS (V) VGS = 0 V; f = 1 MHz. Fig 1. Output capacitance as a function of drain-source voltage; typical values 7. Application information Table 7. RF performance in a common-source narrowband 860 MHz test circuit Th = 25 C unless otherwise specified. BLF871_BLF871S#5 Product data sheet Mode of operation f VDS IDq (MHz) (V) 2-tone, class AB f1 = 860; f2 = 860.1 40 DVB-T (8k OFDM) 858 40 PL(PEP) D PL(AV) Gp IMD3 PAR (A) (W) (W) (dB) (%) 0.5 100 - > 19 > 44 < 30 (dBc) (dB) - 0.5 - 24 > 19 > 30 < 31 [1] > 7.8 [2] [1] Measured [dBc] with delta marker at 4.3 MHz from center frequency. [2] PAR (of output signal) at 0.01 % probability on CCDF; PAR of input signal = 9.5 dB at 0.01 % probability on CCDF. All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 20 BLF871; BLF871S UHF power LDMOS transistor 7.1 Narrowband RF figures 7.1.1 CW 001aaj277 24 80 ηD (%) Gp (dB) Gp 22 60 ηD 20 40 18 20 0 180 16 0 60 120 PL (W) VDS = 40 V; IDq = 0.5 A; measured in a common source narrowband 860 MHz test circuit. Fig 2. CW power gain and drain efficiency as a function of load power; typical values 7.1.2 2-Tone 001aaj278 25 80 ηD (%) Gp (dB) 001aaj279 0 IMD3 (dBc) 60 23 −20 Gp ηD 21 40 −40 (1) (2) 20 19 0 120 17 0 40 80 −60 0 40 80 PL(AV) (W) 120 PL(AV) (W) VDS = 40 V; IDq = 0.5 A; measured in a common source narrowband 860 MHz test circuit. VDS = 40 V; IDq = 0.5 A; measured in a common source narrowband 860 MHz test circuit. (1) Low frequency component (2) High frequency component Fig 3. 2-Tone power gain and drain efficiency as functions of average load power; typical values BLF871_BLF871S#5 Product data sheet Fig 4. 2-Tone third order intermodulation distortion as a function of average load power; typical values All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 20 BLF871; BLF871S UHF power LDMOS transistor 7.1.3 DVB-T 001aaj280 24 60 ηD (%) Gp (dB) 001aaj281 −15 IMD3 (dBc) −25 Gp 22 40 −35 ηD 20 20 −45 (1) (2) 18 0 0 20 40 60 −55 0 20 40 PL(AV) (W) 60 PL(AV) (W) VDS = 40 V; IDq = 0.5 A; measured in a common source narrowband 860 MHz test circuit. VDS = 40 V; IDq = 0.5 A; measured in a common source narrowband 860 MHz test circuit. (1) Low frequency component (2) High frequency component Fig 5. DVB-T power gain and drain efficiency as functions of average load power; typical values BLF871_BLF871S#5 Product data sheet Fig 6. DVB-T third order intermodulation distortion as a function of average load power; typical values All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 20 BLF871; BLF871S UHF power LDMOS transistor 7.2 Broadband RF figures 7.2.1 2-Tone 001aaj282 22 Gp (dB) (2) (1) 20 70 ηD (dB) 001aaj283 0 IMD3 (dBc) 60 Gp −20 (2) (1) 50 18 (2) (1) ηD −40 40 16 14 400 500 600 700 30 800 900 f (MHz) −60 400 IDq = 0.5 A; measured in a common source broadband test circuit as described in Section 8. (1) VDS = 40 V; PL(AV) = 45 W Product data sheet 700 800 900 f (MHz) IDq = 0.5 A; measured in a common source broadband test circuit as described in Section 8. (2) VDS = 42 V; PL(AV) = 50 W 2-Tone power gain and drain efficiency as a function of frequency; typical values BLF871_BLF871S#5 600 (1) VDS = 40 V; PL(AV) = 45 W (2) VDS = 42 V; PL(AV) = 50 W Fig 7. 500 Fig 8. 2-Tone third order intermodulation distortion as a function of frequency; typical values All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 20 BLF871; BLF871S UHF power LDMOS transistor 7.2.2 DVB-T 001aaj284 22 Gp (dB) ηD (%) (2) (1) Gp 20 001aaj285 0 50 IMD3 (dBc) −20 40 (2) (1) (1) (2) ηD 18 16 400 500 −40 30 600 −60 400 20 800 900 f (MHz) 700 IDq = 0.5 A; measured in a common source broadband test circuit as described in Section 8. 500 600 700 IDq = 0.5 A; measured in a common source broadband test circuit as described in Section 8. (1) VDS = 40 V; PL(AV) = 22 W (1) VDS = 40 V; PL(AV) = 22 W (2) VDS = 42 V; PL(AV) = 24 W (2) VDS = 42 V; PL(AV) = 24 W Fig 9. DVB-T power gain and drain efficiency as functions of frequency; typical values 800 900 f (MHz) Fig 10. DVB-T third order intermodulation distortion as a function of frequency; typical values 001aaj286 9 PAR (dB) (1) (2) 8 (3) (4) 7 6 5 400 500 600 700 800 900 f (MHz) IDq = 0.5 A; measured in a common source broadband test circuit as described in Section 8. PAR of input signal = 9.5 dB at 0.01 % probability on CCDF. (1) PAR at 0.01 % probability on the CCDF; VDS = 40 V; PL(AV) = 22 W (2) PAR at 0.01 % probability on the CCDF; VDS = 42 V; PL(AV) = 24 W (3) PAR at 0.1 % probability on the CCDF; VDS = 40 V; PL(AV) = 22 W (4) PAR at 0.1 % probability on the CCDF; VDS = 42 V; PL(AV) = 24 W Fig 11. DVB-T PAR at 0.1 % and at 0.01 % probability on the CCDF as function of frequency; typical values BLF871_BLF871S#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 20 BLF871; BLF871S UHF power LDMOS transistor 7.3 Ruggedness in class-AB operation The BLF871 and BLF871S are capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 42 V; f = 860 MHz at rated power. 7.4 Impedance information ZL drain Zi gate 001aai086 Fig 12. Definition of transistor impedance Table 8. Typical impedance Simulated Zi and ZL device impedance; impedance info at VDS = 42 V. BLF871_BLF871S#5 Product data sheet f Zi ZL (MHz) () () 300 0.977  j3.327 5.506 + j1.774 325 0.977  j2.983 5.366 + j1.858 350 0.978  j2.681 5.223 + j1.930 375 0.979  j2.414 5.078 + j1.990 400 0.979  j2.174 4.932 + j2.040 425 0.980  j1.956 4.786 + j2.079 450 0.981  j1.758 4.640 + j2.108 475 0.982  j1.576 4.495 + j2.128 500 0.982  j1.407 4.352 + j2.138 525 0.983  j1.250 4.212 + j2.140 550 0.984  j1.103 4.074 + j2.135 575 0.985  j0.964 3.940 + j2.122 600 0.986  j0.834 3.809 + j2.102 625 0.987  j0.709 3.682 + j2.077 650 0.988  j0.591 3.558 + j2.045 675 0.990  j0.478 3.438 + j2.009 700 0.991  j0.370 3.323 + j1.968 725 0.992  j0.266 3.211 + j1.923 750 0.993  j0.165 3.103 + j1.874 775 0.995  j0.068 3.000 + j1.822 800 0.996 + j0.026 2.900 + j1.766 825 0.997 + j0.117 2.804 + j1.708 850 0.999 + j0.206 2.711 + j1.648 875 1.000 + j0.292 2.623 + j1.586 900 1.002 + j0.376 2.538 + j1.521 All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 20 BLF871; BLF871S UHF power LDMOS transistor Table 8. Typical impedance …continued Simulated Zi and ZL device impedance; impedance info at VDS = 42 V. f Zi ZL (MHz) () () 925 1.004 + j0.459 2.456 + j2.455 950 1.005 + j0.540 2.378 + j2.388 975 1.007 + j0.619 2.303 + j2.320 1000 1.009 + j0.696 2.230 + j2.250 7.5 Reliability 001aaj287 105 Years (1) (2) (3) (4) (5) (6) 104 103 102 10 (7) (8) (9) (10) (11) 1 0 2 4 6 IDS(DC) (A) TTF (0.1 % failure fraction). The reliability at pulsed conditions can be calculated as follows: TTF (0.1 %)  1 / . (1) Tj = 100 C (2) Tj = 110 C (3) Tj = 120 C (4) Tj = 130 C (5) Tj = 140 C (6) Tj = 150 C (7) Tj = 160 C (8) Tj = 170 C (9) Tj = 180 C (10) Tj = 190 C (11) Tj = 200 C Fig 13. Electromigration (IDS(DC)) BLF871_BLF871S#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 20 BLF871; BLF871S UHF power LDMOS transistor 8. Test information Table 9. List of components For test circuit, see Figure 14, Figure 15 and Figure 16. Component Description Value Remarks C1, C2 multilayer ceramic chip capacitor 5.1 pF [1] C3, C4 multilayer ceramic chip capacitor 10 pF [2] C5 multilayer ceramic chip capacitor 6.8 pF [1] C6 multilayer ceramic chip capacitor 4.7 pF [1] C7 multilayer ceramic chip capacitor 2.7 pF [1] C8, C9, C10, C25, multilayer ceramic chip capacitor C26 100 pF [1] C11, C27 multilayer ceramic chip capacitor 10 F C12 electrolytic capacitor 470 F; 63 V C20 multilayer ceramic chip capacitor 10 pF [3] C21 multilayer ceramic chip capacitor 8.2 pF [3] C22 trimmer 0.6 pF to 4.5 pF C23 multilayer ceramic chip capacitor 6.8 pF [3] C24 multilayer ceramic chip capacitor 3.9 pF [3] L1 stripline - [4] (W  L) 7 mm  15 mm (W  L) 2.4 mm  9 mm TDK C570X7R1H106KT000N or capacitor of same quality. Tekelec L2 stripline - [4] L3 stripline - [4] (W  L) 2.4 mm  10 mm L4 stripline - [4] (W  L) 2.4 mm  25 mm - [4] (W  L) 2.4 mm  10 mm (W  L) 2.0 mm  20 mm L5 stripline L6 stripline - [4] L7 stripline - [4] (W  L) 2.0 mm  21 mm L20 stripline - [4] (W  L) 7 mm  12 mm - [4] (W  L) 2.4 mm  13 mm (W  L) 2.4 mm  31 mm (W  L) 2.4 mm  5 mm L21 stripline L22 stripline - [4] L23 stripline - [4] R1 resistor 100  R2 resistor 10 k [1] American technical ceramics type 100B or capacitor of same quality. [2] American technical ceramics type 180R or capacitor of same quality. [3] American technical ceramics type 100A or capacitor of same quality. [4] Printed-Circuit Board (PCB): Rogers 5880; r = 2.2 F/m; height = 0.79 mm; Cu (top/bottom metallization); thickness copper plating = 35 m. BLF871_BLF871S#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 20 xxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxx x x x xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx xx xx xxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx xxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxx x x xxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxx xxx BLF871_BLF871S#5 Product data sheet VGG R2 C11 C12 C27 VDD Rev. 5 — 1 September 2015 C9 R1 L6 C1 C20 50 Ω C25 C3 L23 C8 L22 C24 L21 C23 C22 L20 L1 C21 C2 L2 C4 L3 C5 L4 C6 50 Ω L5 C7 L7 C10 001aaj288 Fig 14. Class-AB common-source broadband amplifier UHF power LDMOS transistor 12 of 20 © Ampleon The Netherlands B.V. 2015. All rights reserved. See Table 9 for a list of components. BLF871; BLF871S All information provided in this document is subject to legal disclaimers. C26 BLF871; BLF871S UHF power LDMOS transistor 76.2 mm 40 mm 40 mm 001aaj289 Fig 15. Printed-Circuit Board (PCB) for class-AB common source amplifier BLF871_BLF871S#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 20 BLF871; BLF871S UHF power LDMOS transistor R2 C11 C9 C12 C27 L6 C26 R1 C3 C1 C20 C25 L23 C22 L21 L20 L1 L2 C21 C24 C5 C2 C4 C23 C8 L3 L5 L7 C6 L23 C7 C10 L4 001aaj290 See Table 9 for a list of components. Fig 16. Component layout for class-AB common source amplifier BLF871_BLF871S#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 14 of 20 BLF871; BLF871S UHF power LDMOS transistor 9. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT467C D A F 3 D1 U1 B q c C 1 E1 H U2 E A w1 M A M B M p 2 Q w2 M C M b 0 5 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c D D1 E E1 F H p Q q U1 U2 w1 w2 mm 4.67 3.94 5.59 5.33 0.15 0.10 9.25 9.04 9.27 9.02 5.92 5.77 5.97 5.72 1.65 1.40 18.54 17.02 3.43 3.18 2.21 1.96 14.27 20.45 20.19 5.97 5.72 0.25 0.51 inch 0.184 0.220 0.006 0.155 0.210 0.004 0.364 0.365 0.356 0.355 0.233 0.227 0.235 0.065 0.225 0.055 0.73 0.67 0.135 0.087 0.805 0.235 0.562 0.010 0.020 0.125 0.077 0.795 0.225 OUTLINE VERSION REFERENCES IEC JEDEC EIAJ EUROPEAN PROJECTION ISSUE DATE 99-12-28 12-05-02 SOT467C Fig 17. Package outline SOT467C BLF871_BLF871S#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 15 of 20 BLF871; BLF871S UHF power LDMOS transistor Earless ceramic package; 2 leads SOT467B D A F 3 D1 D U1 c 1 E1 U2 H E 2 w2 b A 0 5 mm scale Dimensions Unit(1) mm Q A b max 4.67 5.59 nom min 3.94 5.33 c D D1 E E1 0.15 9.25 9.27 5.92 5.97 0.10 9.04 9.02 5.77 5.72 F H Q U1 U2 1.65 18.29 2.21 9.78 5.97 1.40 17.27 1.96 9.53 5.72 w2 0.25 max 0.184 0.22 0.006 0.364 0.365 0.233 0.235 0.065 0.72 inches nom min 0.155 0.21 0.004 0.356 0.355 0.227 0.225 0.055 0.68 0.087 0.385 0.235 0.01 0.077 0.375 0.225 Note 1. millimeter dimensions are derived from the original inch dimensions. Outline version References IEC JEDEC JEITA sot467b_po European projection Issue date 11-08-18 12-05-01 SOT467B Fig 18. Package outline SOT467B BLF871_BLF871S#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 16 of 20 BLF871; BLF871S UHF power LDMOS transistor 10. Abbreviations Table 10. Abbreviations Acronym Description CW Continuous Wave CCDF Complementary Cumulative Distribution Function DVB Digital Video Broadcast DVB-T Digital Video Broadcast - Terrestrial ESD ElectroStatic Discharge HF High Frequency IMD3 Third order InterModulation Distortion LDMOS Laterally Diffused Metal-Oxide Semiconductor LDMOST Laterally Diffused Metal-Oxide Semiconductor Transistor OFDM Orthogonal Frequency Division Multiplexing PAR Peak-to-Average power Ratio PEP Peak Envelope Power RF Radio Frequency TTF Time To Failure UHF Ultra High Frequency VSWR Voltage Standing-Wave Ratio 11. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF871_BLF871S#5 20150901 Product data sheet - BLF871_BLF871S_4 Modifications: • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF871_BLF871S_4 20091119 Product data sheet - BLF871_3 BLF871_3 20090921 Product data sheet - BLF871_2 BLF871_2 20090305 Preliminary data sheet - BLF871_1 BLF871_1 20081218 Objective data sheet - - BLF871_BLF871S#5 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 17 of 20 BLF871; BLF871S UHF power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF871_BLF871S#5 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 18 of 20 BLF871; BLF871S UHF power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13. Contact information For more information, please visit: http://www.ampleon.com BLF871_BLF871S#5 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 5 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 19 of 20 BLF871; BLF871S UHF power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.1.1 7.1.2 7.1.3 7.2 7.2.1 7.2.2 7.3 7.4 7.5 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Application information. . . . . . . . . . . . . . . . . . . 4 Narrowband RF figures . . . . . . . . . . . . . . . . . . 5 CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 2-Tone. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 DVB-T . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Broadband RF figures . . . . . . . . . . . . . . . . . . . 7 2-Tone. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 DVB-T . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Ruggedness in class-AB operation . . . . . . . . . 9 Impedance information . . . . . . . . . . . . . . . . . . . 9 Reliability . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Test information . . . . . . . . . . . . . . . . . . . . . . . . 11 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 15 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 17 Legal information. . . . . . . . . . . . . . . . . . . . . . . 18 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 18 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Contact information. . . . . . . . . . . . . . . . . . . . . 19 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF871_BLF871S#5
BLF871S,112 价格&库存
很抱歉,暂时无法提供与“BLF871S,112”相匹配的价格&库存,您可以联系我们找货
