BLP15M7160PY
BLP15M7160PY
    AMPLEON(安谱隆)
    SOT-1223-2
    BLP15M7160PY
BLP15M7160PY 数据手册
BLP15M7160P Power LDMOS transistor Rev. 5 — 8 January 2016 Product data sheet 1. Product profile 1.1 General description A 160W LDMOS RF power transistor for broadcast transmitter and industrial applications. The transistor is suitable for the frequency range HF to 1500 MHz. The excellent ruggedness and broadband performance of this device makes it ideal for digital applications. Table 1. Typical performance RF performance at Th = 25 C in a common source test circuit. VDS IDq PL(AV) PL(M) Gp D Test signal f (MHz) (V) (mA) (W) (W) (dB) (%) pulsed, class-B 860 28 100 - 160 20 62 1.2 Features and benefits        Integrated ESD protection Excellent ruggedness High power gain High efficiency Excellent reliability Easy power control Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  Communication transmitter applications in the HF to 1500 MHz frequency range  Industrial applications in the HF to 1500 MHz frequency range  Single product Doherty applications BLP15M7160P Power LDMOS transistor 2. Pinning information Table 2. Pinning All pins must be connected for correct operation and to prevent damage to the device. Pin Description 1 gate 1 2 gate 2 3 drain 2 4 drain 1 5 Simplified outline 4 Graphic symbol 3 4 1 pin 1 index 5 2 [1] source 1 2 3 aaa-006617 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name BLP15M7160P Description Version HSOP4F plastic, heatsink small outline package; 4 leads (flat) SOT1223-2 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Min Max Unit VDS drain-source voltage - 65 V VGS gate-source voltage 6 +11 V Tstg storage temperature 65 +150 C - 225 C [1] junction temperature Tj [1] Conditions Continuous use at maximum temperature will affect the reliability, for details refer to the on-line MTF calculator. 5. Thermal characteristics Table 5. Symbol Thermal characteristics Parameter Conditions Rth(j-case) thermal resistance from junction to case [1] BLP15M7160P Product data sheet Tcase = 80 C; PL = 160 W [1] Typ Unit 0.5 K/W Rth(j-case) is measured under RF conditions. All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 2 of 11 BLP15M7160P Power LDMOS transistor 6. Characteristics Table 6. DC characteristics Tj = 25 C per section; unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 0.9 mA 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 90 mA 1.5 1.86 2.3 V IDSS drain leakage current VGS = 0 V; VDS = 28 V 1.4 - +1.4 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V 15 16 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 140 nA gfs forward transconductance VDS = 10 V; ID = 3.15 A - 6 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 3.15 A - 0.2 -  Table 7. AC characteristics Tj = 25 C per section; unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Ciss input capacitance VGS = 0 V; VDS = 28 V; f = 1 MHz - 79 - pF Coss output capacitance VGS = 0 V; VDS = 28 V; f = 1 MHz - 32 - pF Crs feedback capacitance VGS = 0 V; VDS = 28 V; f = 1 MHz - 1.5 - pF Table 8. RF characteristics Test signal: pulsed CW; f = 860 MHz; RF performance measured at VDS = 28 V; IDq = 100 mA; Tcase = 25 C; unless otherwise specified; in a class-B production test circuit. Symbol Parameter Conditions Min Typ Max Unit Gp D power gain PL(M) = 160 W 16.5 19.4 - dB drain efficiency PL(M) = 160 W 57.5 59.7 - % 7. Test information 7.1 Ruggedness in class-AB operation The BLP15M7160P is capable of withstanding a load mismatch corresponding to VSWR = 10 : 1 through all phases under the following conditions: VDS = 28 V; f = 860 MHz at rated load power. BLP15M7160P Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 3 of 11 BLP15M7160P Power LDMOS transistor 7.2 Demo circuit information 35 mm 60 mm C16 R1 R5 C20 R7 C36 T2 C22 C18 C10 R3 C34 50 mm C33 C14 C32 C30 C1 C2 C9 C31 C35 C12 C5 C4 C13 C15 R4 C11 T1 C37 C19 R8 R6 C23 C21 C17 R2 aaa-010486 Printed-Circuit Board (PCB): Taconic RF35; r = 3.5; thickness = 0.76 mm; thickness copper plating = 35 m. See Table 9 for a list of components. Fig 1. Component layout for class-AB production test circuit Table 9. List of components For test circuit see Figure 1. BLP15M7160P Product data sheet Component Description Value Remarks C1, C2 multilayer ceramic chip capacitor 5.6 pF ATC800B C4, C5 multilayer ceramic chip capacitor 4.7 pF ATC800B C9 multilayer ceramic chip capacitor 100 pF ATC180R C10, C11 multilayer ceramic chip capacitor 10 pF ATC800B C12, C13 multilayer ceramic chip capacitor 100 pF ATC180R C14, C15 multilayer ceramic chip capacitor 4.7 F, 50 V TDK C16, C17 multilayer ceramic chip capacitor 100 pF ATC800B C18, C19 multilayer ceramic chip capacitor 10 F TDK C20, C21 electrolytic capacitor C22, C23 multilayer ceramic chip capacitor 1 nF ATC800B C30 multilayer ceramic chip capacitor 33 pF ATC800A C31 multilayer ceramic chip capacitor 10 pF ATC800A C32 multilayer ceramic chip capacitor 11 pF ATC800A C33, C34, C35 multilayer ceramic chip capacitor 91 pF ATC800A 470 F, 63 V C36, C37 electrolytic capacitor 4.7 F, 50 V T1 semi rigid coax 25  Micro-Coax UT-090C-25 T2 semi rigid coax 25  Micro-Coax UT-090C-25 R1, R2 resistor 10  Vishay MRS25 R3, R4 resistor 5.6  SMD 1206 R5, R6 resistor 100  Vishay MRS25 R7, R8 potentiometer 10 k Bourns All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 4 of 11 BLP15M7160P Power LDMOS transistor 7.3 Graphical data 7.3.1 1-Tone pulsed aaa-010435 24 80 Gp (dB) ηD (%) ηD 22 60 20 40 18 20 Gp 16 0 40 80 120 160 200 PL (W) 0 240 VDS = 28 V; IDq = 200 mA; f = 860 MHz. Fig 2. Power gain and drain efficiency as function of output power; typical values aaa-010436 23 Gp (dB) aaa-010437 80 (1) (2) (3) (4) (5) (6) ηD (%) 21 60 (6) (5) (4) (3) (2) (1) 19 40 17 20 15 0 0 40 80 120 160 200 PL (W) 240 0 VDS = 28 V; f = 860 MHz. 40 (1) IDq = 50 mA (2) IDq = 100 mA (2) IDq = 100 mA (3) IDq = 200 mA (3) IDq = 200 mA (4) IDq = 400 mA (4) IDq = 400 mA (5) IDq = 600 mA (5) IDq = 600 mA (6) IDq = 800 mA (6) IDq = 800 mA Power gain as a function of output power; typical values BLP15M7160P Product data sheet 120 160 200 PL (W) 240 VDS = 28 V; f = 860 MHz. (1) IDq = 50 mA Fig 3. 80 Fig 4. Drain efficiency as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 5 of 11 BLP15M7160P Power LDMOS transistor aaa-010438 23 Gp (dB) aaa-010439 80 ηD (%) (1) (2) (3) (4) (5) (6) (7) (8) 21 60 19 40 (4) 17 (1) (2) (5) (6) (7) (8) (3) 20 15 0 0 40 80 120 160 200 PL (W) 240 0 40 (1) VDS = 16 V (2) VDS = 18 V (2) VDS = 18 V (3) VDS = 20 V (3) VDS = 20 V (4) VDS = 22 V (4) VDS = 22 V (5) VDS = 24 V (5) VDS = 24 V (6) VDS = 26 V (6) VDS = 26 V (7) VDS = 28 V (7) VDS = 28 V (8) VDS = 30 V (8) VDS = 30 V Power gain as a function of output power; typical values BLP15M7160P Product data sheet 120 160 200 PL (W) 240 IDq = 200 mA; f = 860 MHz. IDq = 200 mA; f = 860 MHz. (1) VDS = 16 V Fig 5. 80 Fig 6. Drain efficiency as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 6 of 11 BLP15M7160P Power LDMOS transistor 8. Package outline HSOP4F: plastic, heatsink small outline package; 4 leads(flat) SOT1223-2 D E X c B D3 A E3 y v HE A D1 D2 b w 4 B 3 (8x) METAL PROTRUSIONS (SOURCE) e4 (2x) F (4x) e3 (2x) E2 E1 A A2 A1 pin 1 index Q1 detail X 1 2 e1 (2x) e2 (2x) e Q1 0 10 mm scale Dimensions (mm are the original dimensions) Unit max nom min mm A A1 3.9 0.2 0.1 0 A2 b c D(1) D1 D2 D3 E(1) E1 E2 E3 e e1 e2 e3 References IEC JEDEC JEITA w European projection F y 0.1 HE 16.16 0.4 15.96 15.76 sot1223-2_po Issue date 15-01-12 15-06-04 SOT1223-2 Fig 7. e4 3.65 3.90 0.27 20.62 19.00 16.05 20.44 10.01 8.18 5.89 9.83 3.60 3.85 0.22 20.57 18.95 16.00 20.39 9.96 8.13 5.84 9.78 8.85 8.45 9.55 2.97 4.07 3.55 3.80 0.17 20.52 18.90 15.95 20.34 9.91 8.08 5.79 9.73 Note 1. Package body dimensions “D and “E do not include mold and metal protrusions. Allowable protrusion is 0.25 mm per side. 2. Lead width dimension “b does not include dambar protrusions. Allowable dambar protrusion is 0.25 mm in total per lead. Outline version v 1.62 1.57 0.25 0.25 1.52 Package outline SOT1223-2 (HSOP4F) BLP15M7160P Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 7 of 11 BLP15M7160P Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 10. Abbreviations Acronym Description CW Continuous Wave ESD ElectroStatic Discharge HF High Frequency LDMOS Laterally Diffused Metal-Oxide Semiconductor MTF Median Time to Failure SMD Surface Mounted Device VSWR Voltage Standing-Wave Ratio 11. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BLP15M7160P v.5 20160108 Product data sheet - BLP15M7160P v.4 Modifications • • Table 3 on page 2: table updated Figure 7 on page 7: package outline changed from SOT1223-1 to SOT1223-2 BLP15M7160P v.4 20150901 Product data sheet - BLP15M7160P v.3 BLP15M7160P v.3 20150209 Product data sheet - BLP15M7160P v.2 BLP15M7160P v.2 20140610 Product data sheet - BLP15M7160P v.1 BLP15M7160P v.1 20140110 Objective data sheet - - BLP15M7160P Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 8 of 11 BLP15M7160P Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLP15M7160P Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 9 of 11 BLP15M7160P Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 13. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLP15M7160P Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 8 January 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 10 of 11 BLP15M7160P Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.3.1 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 3 Demo circuit information . . . . . . . . . . . . . . . . . . 4 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 5 1-Tone pulsed . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Handling information. . . . . . . . . . . . . . . . . . . . . 8 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 9 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 9 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Contact information. . . . . . . . . . . . . . . . . . . . . 10 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon Netherlands B.V. 2016. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 8 January 2016 Document identifier: BLP15M7160P
BLP15M7160PY 价格&库存
很抱歉,暂时无法提供与“BLP15M7160PY”相匹配的价格&库存,您可以联系我们找货
