BLF9G38LS-90PJ
BLF9G38LS-90PJ
    AMPLEON(安谱隆)
    SOT-1121B
    TRANS RF LDMOS 90W SOT1121
BLF9G38LS-90PJ 数据手册
BLF9G38LS-90P Power LDMOS transistor Rev. 3 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description 90 W LDMOS power transistor for base station applications at frequencies from 3400 MHz to 3600 MHz. Table 1. Typical performance Typical RF performance at Tcase = 25 C in the Doherty application demo circuit. Test signal IS-95 [1] f VDS PL(AV) Gp D ACPR (MHz) (V) (W) (dB) (%) (dBc) 3400 to 3600 28 15.1 12.7 37.0 37 [1] Test signal: IS-95; pilot, paging, sync, 6 traffic channels with Walsh codes 8  13; PAR = 9.7 dB at 0.01 % probability. 1.2 Features and benefits         Excellent ruggedness High efficiency Low thermal resistance providing excellent thermal stability Lower output capacitance for improved performance in Doherty applications Designed for low memory effects providing excellent pre-distortability Internally matched for ease of use Integrated ESD protection Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  RF power amplifier for LTE base stations and multi carrier applications in the 3400 MHz to 3600 MHz frequency range BLF9G38LS-90P Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description 1 drain1 2 drain2 3 gate1 4 gate2 5 Simplified outline 1 2 1 5 3 5 4 [1] source 3 [1] Graphic symbol 2 4 sym117 Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package BLF9G38LS-90P Name Description Version - earless flanged ceramic package; 4 leads SOT1121B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS Min Max Unit drain-source voltage - 65 V VGS gate-source voltage 5 +13 V Tstg storage temperature 65 +150 C Tj junction temperature - 225 C [1] Conditions [1] Continuous use at maximum temperature will affect the reliability, for details refer to the on-line MTF calculator. 5. Thermal characteristics Table 5. Conditions Rth(j-case) thermal resistance from junction to case Tcase = 80 C; VDS = 28 V; IDq = 300 mA; VGS(amp)peak = 1.0 V [1] BLF9G38LS-90P#3 Product data sheet Thermal characteristics Symbol Parameter Typ Unit [1] PL = 18 W (CW) 0.37 K/W PL = 56 W (CW) 0.22 K/W Measured in Doherty development circuit for thermal measurement All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 15 BLF9G38LS-90P Power LDMOS transistor 6. Characteristics Table 6. DC characteristics Tj = 25 C unless otherwise specified. Symbol Parameter V(BR)DSS drain-source breakdown voltage Conditions Min Typ Max Unit VGS = 0 V; ID = 0.513 mA 65 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 51.3mA 1.5 2.1 3.1 V VGSq gate-source quiescent voltage VDS = 28 V; ID = 307.8 mA 1.7 2.3 3.3 V IDSS drain leakage current VGS = 0 V; VDS = 32 V - - 1.4 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 11 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 140 nA gfs forward transconductance VDS = 10 V; ID = 51.3 mA - 0.45 - S RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 1.8 A - 236 m 449 Table 7. RF characteristics Test signal: 1-carrier W-CDMA; PAR = 7.2 dB at 0.01 % probability on the CCDF; 3GPP test model 1; 1 to 64 DPCH; f1 = 3400 MHz; f2 = 3500 MHz; f3 = 3600 MHz; RF performance at VDS = 28 V; IDq = 600 mA; Tcase = 25 C; unless otherwise specified; in a class-AB production test circuit at frequencies from 3400 MHz to 3600 MHz. Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL(AV) = 20 W 13.8 15.0 - dB RLin input return loss PL(AV) = 20 W - 10 6 dB D drain efficiency PL(AV) = 20 W 23 28 - % ACPR adjacent channel power ratio PL(AV) = 20 W - 26 21 dBc 7. Test information 7.1 Ruggedness in Doherty operation The BLF9G38LS-90P is capable of withstanding a load mismatch corresponding to a VSWR = 10 : 1 through all phases under the following conditions: VDS = 28 V; IDq = 300 mA; VGS(amp)peak = 0.7 V; PL = 56 W (CW); f = 3400 MHz; tested on the Doherty development test circuit. BLF9G38LS-90P#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 15 BLF9G38LS-90P Power LDMOS transistor 7.2 Impedance information Table 8. Typical impedance of maximum power and drain efficiency Measured load-pull data (half device); IDq = 300 mA; VDS = 28 V; typical values unless otherwise specified. f ZS [1] ZL [1] PL [2] D [2] Gp [2] (MHz) () () (W) (%) (dB) 6.5  j14.1 64 52.8 12.2 Maximum power load 3400 7.0  j20.0 3600 18.1  j29.7 7.9  j15.2 61 50.9 12.5 3800 47.2  j5.9 6.7  j16.7 60 47.4 11.7 9.3  j9.1 50 58.8 14.1 Maximum drain efficiency load 3400 7.0  j20.0 3600 18.1  j29.7 7.5  j10.3 50 55.6 14.1 3800 47.2  j5.9 7.0  j11.7 49 53.4 14.1 [1] ZS and ZL defined in Figure 1. [2] at 3 dB gain compression. Table 9. Typical trade off impedance at 1 : 1 load Measured load-pull data (half device); IDq = 300 mA; VDS = 28 V; typical values unless otherwise specified. f ZS [1] ZL [1] PL [2] D [2] Gp [2] (MHz) () () (dBm) (%) (dB) 3400 7.0  j20.0 8.5  j12.3 60 57.9 13.3 3600 18.1  j29.7 7.3  j12.7 59 54.7 13.2 3800 47.2  j5.9 7.7  j13.9 56 52.3 13.1 [1] ZS and ZL defined in Figure 1. [2] at 3 dB gain compression. drain ZL gate ZS 001aaf059 Fig 1. Definition of transistor impedance 7.3 VBW in Doherty operation The BLF9G38LS-90P shows 100 MHz (typical) video bandwidth in Doherty development test circuit in 3500 MHz at VDS = 28 V; IDq = 300 mA and VGS(amp)peak = 0.6 V. BLF9G38LS-90P#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 15 BLF9G38LS-90P Power LDMOS transistor 7.4 Test circuit 40 mm 40 mm C13 C1 R1 P3 P4 C2 C17 C15 C11 C7 C3 R2 C9 P7 80 mm P1 C10 C4 P2 P5 R3 C5 C14 C8 P6 C6 C16 C12 C18 aaa-018784 Printed-Circuit Board (PCB): Rogers RO4350B; r = 3.5; thickness = 0.508 mm; thickness copper plating = 35 m. See Table 10 for a list of components. Fig 2. Component layout for Doherty development test circuit Table 10. List of components See Figure 3 for component layout. BLF9G38LS-90P#3 Product data sheet Component Description Value Remarks C1, C3, C4, C6, C7, C8, C10 multilayer ceramic chip capacitor 9.1 pF ATC 600F C2, C5 multilayer ceramic chip capacitor 0.9 pF ATC 600F C9 multilayer ceramic chip capacitor 1.3 pF ATC 600F C11, C12, C13, C14 multilayer ceramic chip capacitor 1 F, 50 V Murata C15, C16 multilayer ceramic chip capacitor 10 F, 50 V Murata C17, C18 electrolytic capacitor 2200 F, 63 V P1, P2, P3, P4, P5, P6, P7 copper foil strip - R1 SMD resistor 50  SMD 2512 R2, R3 SMD resistor 5.1  SMD 0805 All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 needed for tuning © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 15 BLF9G38LS-90P Power LDMOS transistor 40 mm 40 mm C11 C3 R1 C17 C14 C13 C7 P4 C9 C1 C5 P1 P5 80 mm C6 C2 P2 C10 P3 R2 C4 C8 C16 C15 C18 C12 aaa-018785 Printed-Circuit Board (PCB): Rogers RO4350B; r = 3.5; thickness = 0.508 mm; thickness copper plating = 35 m. See Table 11 for a list of components. Fig 3. Component layout for class-AB production test circuit Table 11. List of components See Figure 3 for component layout. BLF9G38LS-90P#3 Product data sheet Component Description Value Remarks C1, C2, C3, C4, C5, C6, C7, C8 multilayer ceramic chip capacitor 9.1 pF ATC 600F C9, C10 multilayer ceramic chip capacitor 0.6 pF ATC 600F C11, C12, C13, C15 multilayer ceramic chip capacitor 1 F, 50 V Murata Murata C14, C16 multilayer ceramic chip capacitor 10 F, 50 V C17, C18 electrolytic capacitor 1000 F, 63 V P1, P2, P3, P4, P5 copper foil strip - needed for tuning R1, R2 SMD resistor 5.1  SMD 0805 All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 15 BLF9G38LS-90P Power LDMOS transistor 7.5 Graphical data All data are measured on the Doherty development test circuit. 7.5.1 CW aaa-017957 16 Gp (dB) Gp 80 (1) (2) (3) aaa-017958 30 ηD (%) RLin (dB) 25 (2) 12 60 20 (1) ηD 8 (1) (2) (3) 40 15 (3) 10 4 20 5 0 0 20 40 60 80 PL (W) 0 100 0 0 VDS = 28 V; IDq = 300 mA (main device); VGS(amp)peak = 0.7 V. 20 (1) f = 3400 MHz (2) f = 3500 MHz (2) f = 3500 MHz (3) f = 3600 MHz (3) f = 3600 MHz Power gain and drain efficiency as function of output power; typical values BLF9G38LS-90P#3 Product data sheet 60 80 PL (W) 100 VDS = 28 V; IDq = 300 mA (main device); VGS(amp)peak = 0.7 V. (1) f = 3400 MHz Fig 4. 40 Fig 5. Input return loss as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 15 BLF9G38LS-90P Power LDMOS transistor 7.5.2 Pulsed CW aaa-017959 16 Gp (dB) Gp 80 (1) (2) (3) 12 aaa-017960 40 ηD (%) RLin (dB) 60 30 (2) ηD 8 (1) (2) (3) 40 20 (1) (3) 4 20 0 0 20 40 60 80 PL (W) 10 0 100 0 0 VDS = 28 V; IDq = 300 mA (main device); VGS(amp)peak = 0.7 V; tp = 100 s;  = 10 %. 20 (1) f = 3400 MHz (2) f = 3500 MHz (2) f = 3500 MHz (3) f = 3600 MHz Product data sheet 80 PL (W) 100 (3) f = 3600 MHz Power gain and drain efficiency as function of output power; typical values BLF9G38LS-90P#3 60 VDS = 28 V; IDq = 300 mA (main device); VGS(amp)peak = 0.7 V; tp = 100 s;  = 10 %. (1) f = 3400 MHz Fig 6. 40 Fig 7. Input return loss as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 15 BLF9G38LS-90P Power LDMOS transistor 7.5.3 1-Carrier W-CDMA aaa-017961 20 Gp (dB) (1) (2) (3) 50 ηD 16 aaa-017962 8 PAR (dB) ηD (%) 40 6 12 (1) (2) (3) 30 Gp (1) (2) (3) 4 8 20 4 10 2 0 0 0 5 10 15 20 25 30 PL(AV) (W) 0 35 0 VDS = 28 V; IDq = 300 mA (main device); VGS(amp)peak = 0.7 V. 5 10 20 25 30 PL(AV) (W) 35 VDS = 28 V; IDq = 300 mA (main device); VGS(amp)peak = 0.7 V. (1) f = 3400 MHz (1) f = 3400 MHz (2) f = 3500 MHz (2) f = 3500 MHz (3) f = 3600 MHz Fig 8. 15 (3) f = 3600 MHz Power gain and drain efficiency as function of average output power; typical values Fig 9. Peak-to-average power ratio as a function of average output power; typical values aaa-017963 30 RLin (dB) (2) 25 20 (1) 15 (3) 10 5 0 0 5 10 15 20 25 30 PL(AV) (W) 35 VDS = 28 V; IDq = 300 mA (main device); VGS(amp)peak = 0.7 V. (1) f = 3400 MHz (2) f = 3500 MHz (3) f = 3600 MHz Fig 10. Input return loss as a function of average output power; typical values BLF9G38LS-90P#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 15 BLF9G38LS-90P Power LDMOS transistor aaa-017964 -15 ACPR5M (dBc) aaa-017965 -25 ACPR10M (dBc) -25 -35 -35 -45 (1) (2) (3) (1) (2) (3) -45 -55 -55 -65 0 5 10 15 20 25 30 PL(AV) (W) 35 0 VDS = 28 V; IDq = 300 mA (main device); VGS(amp)peak = 0.7 V. 5 10 15 20 25 30 PL(AV) (W) 35 VDS = 28 V; IDq = 300 mA (main device); VGS(amp)peak = 0.7 V. (1) f = 3400 MHz (1) f = 3400 MHz (2) f = 3500 MHz (2) f = 3500 MHz (3) f = 3600 MHz (3) f = 3600 MHz Fig 11. Adjacent channel power ratio (5 MHz) as a function of average output power; typical values Fig 12. Adjacent channel power ratio (10 MHz) as a function of average output power; typical values 7.5.4 2-Tone VBW aaa-017966 0 IMD (dBc) (1) (2) -20 IMD3 -40 (1) (2) IMD5 (1) (2) IMD7 -60 -80 1 10 102 carrier spacing (MHz) 103 VDS = 28 V; IDq = 300 mA; fc = 3500 MHz. (1) IMD low (2) IMD high Fig 13. VBW capability on Doherty development test circuit BLF9G38LS-90P#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 15 BLF9G38LS-90P Power LDMOS transistor 8. Package outline Earless flanged ceramic package; 4 leads SOT1121B D A F 5 D1 D U1 w2 H1 1 H c D 2 U2 E1 3 E 4 b y w3 e Q 0 5 10 mm scale Dimensions Unit(1) mm A max 4.75 nom min 3.45 b 3.94 c D D1 E e E1 F H H1 Q U1 U2 w2 w3 9.53 9.53 1.14 19.94 12.83 1.70 20.70 9.91 0.51 0.25 0.18 20.02 19.96 y 0.10 8.89 3.68 0.08 19.61 19.66 9.27 9.27 0.89 18.92 12.57 1.45 20.45 9.65 max 0.187 0.155 0.007 0.788 0.786 0.375 0.375 0.045 0.785 0.505 0.067 0.815 0.39 0.02 0.01 0.004 0.35 inches nom min 0.136 0.145 0.003 0.772 0.774 0.365 0.365 0.035 0.745 0.495 0.057 0.805 0.38 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. dimension is measured 0.030 inch (0.76 mm) from the body. Outline version References IEC JEDEC JEITA sot1121b_po European projection Issue date 12-06-07 15-07-21 SOT1121B Fig 14. Package outline SOT1121B BLF9G38LS-90P#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 15 BLF9G38LS-90P Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 12. Abbreviations Acronym Description 3GPP 3rd Generation Partnership Project CCDF Complementary Cumulative Distribution Function CW Continuous Wave DPCH Dedicated Physical CHannel ESD ElectroStatic Discharge IS-95 Interim Standard 95 LDMOS Laterally Diffused Metal-Oxide Semiconductor LTE Long Term Evolution MTF Median Time to Failure PAR Peak-to-Average Ratio SMD Surface Mounted Device VBW Video BandWidth VSWR Voltage Standing Wave Ratio W-CDMA Wideband Code Division Multiple Access 11. Revision history Table 13. Revision history Document ID Release date Data sheet status BLF9G38LS-90P#3 20150901 Product data sheet Modifications: Change notice Supersedes BLF9G38LS-90P v.2 • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF9G38LS-90P v.2 20150703 Product data sheet - BLF9G38LS-90P v.1 BLF9G38LS-90P v.1 20141215 Objective data sheet - - BLF9G38LS-90P#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 15 BLF9G38LS-90P Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF9G38LS-90P#3 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 15 BLF9G38LS-90P Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13. Contact information For more information, please visit: http://www.ampleon.com BLF9G38LS-90P#3 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 14 of 15 BLF9G38LS-90P Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 7.5 7.5.1 7.5.2 7.5.3 7.5.4 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 3 Ruggedness in Doherty operation . . . . . . . . . . 3 Impedance information . . . . . . . . . . . . . . . . . . . 4 VBW in Doherty operation . . . . . . . . . . . . . . . . 4 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 7 CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Pulsed CW . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 1-Carrier W-CDMA . . . . . . . . . . . . . . . . . . . . . . 9 2-Tone VBW . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11 Handling information. . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF9G38LS-90P#3
BLF9G38LS-90PJ 价格&库存
很抱歉,暂时无法提供与“BLF9G38LS-90PJ”相匹配的价格&库存,您可以联系我们找货
