BLF182XRSU
BLF182XRSU
    AMPLEON(安谱隆)
    SOT-1121B
    BLF182XRSU
BLF182XRSU 数据手册
BLF182XR; BLF182XRS Power LDMOS transistor Rev. 3 — 3 February 2016 Product data sheet 1. Product profile 1.1 General description A 250 W extremely rugged LDMOS power transistor for broadcast and industrial applications in the HF to 600 MHz band. Table 1. Application information VDS PL Gp D Test signal f (MHz) (V) (W) (dB) (%) pulsed RF 108 50 250 28 75 CW 81.36 50 235 28 82 1.2 Features and benefits        Easy power control Integrated double sided ESD protection Excellent ruggedness High efficiency Excellent thermal stability Designed for broadband operation (HF to 600 MHz) Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  Industrial, scientific and medical applications  Broadcast transmitter applications BLF182XR; BLF182XRS Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF182XR (SOT1121A) 1 drain1 2 drain2 3 gate1 4 gate2 5 1 1 2 3 [1] source 5 5 3 4 4 2 sym117 BLF182XRS (SOT1121B) 1 drain1 2 drain2 3 gate1 4 gate2 5 1 1 2 3 4 5 3 5 4 [1] source 2 sym117 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF182XR - flanged LDMOST ceramic package; 2 mounting holes; 4 leads SOT1121A BLF182XRS - earless flanged ceramic package; 4 leads SOT1121B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Max Unit VDS drain-source voltage - 135 V gate-source voltage 6 +11 V Tstg storage temperature 65 +150 C - 225 C [1] Product data sheet Min VGS Tj BLF182XR_BLF182XRS Conditions junction temperature [1] Continuous use at maximum temperature will affect the reliability, for details refer to the on-line MTF calculator. All information provided in this document is subject to legal disclaimers. Rev. 3 — 3 February 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 2 of 15 BLF182XR; BLF182XRS Power LDMOS transistor 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Tj = 115 C [1][2] Rth(j-c) thermal resistance from junction to case Zth(j-c) transient thermal impedance from junction Tj = 150 C; tp = 100 s; to case  = 20 % [1] [3] Typ Unit 0.29 K/W 0.088 K/W Tj is the junction temperature. [2] Rth(j-c) is measured under RF conditions. [3] See Figure 1. aaa-019921 0.3 Zth(j-c) (K/W) 0.25 (7) (6) (5) (4) (3) (2) (1) 0.2 0.15 0.1 0.05 0 10-7 10-6 10-5 10-4 10-3 10-2 10-1 tp (s) 1 (1)  = 1 % (2)  = 2 % (3)  = 5 % (4)  = 10 % (5)  = 20 % (6)  = 50 % (7)  = 100 % (DC) Fig 1. Transient thermal impedance from junction to case as a function of pulse duration 6. Characteristics Table 6. DC characteristics Tj = 25 C; per section unless otherwise specified. BLF182XR_BLF182XRS Product data sheet Symbol Parameter Conditions Min Typ Max Unit V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 1.0 mA 135 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 100 mA 1.33 1.9 2.33 V VGSq gate-source quiescent voltage VDS = 50 V; ID = 50 mA - 2.1 - V All information provided in this document is subject to legal disclaimers. Rev. 3 — 3 February 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 3 of 15 BLF182XR; BLF182XRS Power LDMOS transistor Table 6. DC characteristics …continued Tj = 25 C; per section unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit IDSS drain leakage current VGS = 0 V; VDS = 50 V - - 1.4 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 15 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 140 nA RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 3.5 A - 0.40 -  Table 7. AC characteristics Tj = 25 C; per section unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Crs feedback capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 0.7 - pF Ciss input capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 116 - pF Coss output capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 37 - pF Table 8. RF characteristics Test signal: pulsed RF; tp = 100 s;  = 20 %; f = 108 MHz; RF performance at VDS = 50 V; IDq = 100 mA; Tcase = 25 C; unless otherwise specified; in a class-AB production test circuit. Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL = 250 W 26.8 28 - dB RLin input return loss PL = 250 W - 12 9 dB D drain efficiency PL = 250 W 72 75 - % aaa-019215 300 Coss (pF) 250 200 150 100 50 0 0 10 20 30 40 50 VDS (V) 60 VGS = 0 V; f = 1 MHz. Fig 2. BLF182XR_BLF182XRS Product data sheet Output capacitance as a function of drain-source voltage; typical values per section All information provided in this document is subject to legal disclaimers. Rev. 3 — 3 February 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 4 of 15 BLF182XR; BLF182XRS Power LDMOS transistor 7. Test information 7.1 Ruggedness in class-AB operation The BLF182XR and BLF182XRS are capable of withstanding a load mismatch corresponding to VSWR > 65 : 1 through all phases under the following conditions: VDS = 50 V; IDq = 100 mA; PL = 250 W pulsed; f = 108 MHz. 7.2 Impedance information drain 1 gate 1 Zi ZL gate 2 drain 2 001aan207 Fig 3. Definition of transistor impedance Table 9. Typical push-pull impedance Simulated Zi and ZL device impedance; impedance info at VDS = 50 V and PL = 250 W. f Zi ZL (MHz) () () 108 14.9  49.5j 15.3 + 3.5j 7.3 UIS avalanche energy Table 10. Typical avalanche data per section Tamb = 25 C; typical test data; test jig without water cooling. IAS EAS (A) (J) 8 2.0 9 1.2 10 0.9 For information see application note AN10273. BLF182XR_BLF182XRS Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 3 February 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 5 of 15 BLF182XR; BLF182XRS Power LDMOS transistor 7.4 Test circuit 95 mm 95 mm C19 +VDS1 C7 C5 R3 L3 T2 L1 R5 C10 R1 C12 C2 C1 C14 C17 C16 C4 80 mm C3 C15 C21 C18 C13 C11 R2 C6 T1 C8 R6 L2 +VDS2 L4 C20 R4 aaa-019956 49 mm Printed-Circuit Board (PCB): Taconic RF-35; thickness = 0.765 mm; r = 3.5 F/m; thickness of copper plating = 35 m See Table 11 for a list of components. Fig 4. Component layout for class-AB production test circuit Table 11. List of components For test circuit see Figure 4. Component Description Value Remarks C1 multilayer ceramic chip capacitor 510 pF [1] C2, C3 multilayer ceramic chip capacitor 220 pF [1] C4 multilayer ceramic chip capacitor 91 pF [1] C5, C6 multilayer ceramic chip capacitor 4.7 F, 50 V [1] C7, C8, C10, C11 multilayer ceramic chip capacitor 820 pF C12, C13 multilayer ceramic chip capacitor 4.7 F, 100 V C14, C15 multilayer ceramic chip capacitor 43 pF [1] C16 multilayer ceramic chip capacitor 6.8 pF [1] C17, C18 multilayer ceramic chip capacitor 130 pF [1] C19, C20 electrolytic capacitor 2200 F, 64 V C21 multilayer ceramic chip capacitor 56 pF L1, L2 copper wire inductor 10 turns, D = 2 mm, d = 0.5 mm L3, L4 copper wire inductor 6 turns, D = 2 mm, d = 0.5 mm R1, R2 chip resistor 4.7 k SMD 1206 Ohmite: FC4L110R010FER R3, R4 shunt resistor 0.01  R5, R6 metal film resistor 10 , 0.6 W T1, T2 semi rigid coax 50 , 160 mm [1] [1] EZ Form: EZ-141-AL-TP-M17 American Technical Ceramics type 100B or capacitor of same quality. BLF182XR_BLF182XRS Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 3 February 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 6 of 15 BLF182XR; BLF182XRS Power LDMOS transistor 7.5 Graphical data aaa-019258 30 Gp (dB) 90 ηD (%) Gp 28 aaa-019259 58 74 PL (dBm) 57 ηD ideal PL (2) 56 26 58 55 24 (1) PL 42 54 22 26 20 0 50 100 150 200 250 300 PL (W) 53 10 350 52 24 VDS = 50 V; IDq = 100 mA; f = 108 MHz; tp = 100 s;  = 20 %. 25 26 27 28 29 Pi (dBm) 30 VDS = 50 V; IDq = 100 mA; f = 108 MHz; tp = 100 s;  = 20 %. (1) PL(1dB) = 54.3 dBm (269 W) (2) PL(3dB) = 54.8 dBm (304 W) Fig 5. Power gain and drain efficiency as function of output power; typical values BLF182XR_BLF182XRS Product data sheet Fig 6. Output power as a function of input power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 3 February 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 7 of 15 BLF182XR; BLF182XRS Power LDMOS transistor aaa-019274 32 Gp (dB) 30 80 28 60 26 (1) (2) (3) (4) (5) (6) (7) 40 (7) (6) (5) (4) (3) (2) (1) 24 aaa-019275 100 ηD (%) 20 22 0 0 50 100 150 200 250 300 PL (W) 350 0 VDS = 50 V; f = 108 MHz; tp = 100 s;  = 20 %. 50 100 (1) IDq = 20 mA (2) IDq = 100 mA (2) IDq = 100 mA (3) IDq = 200 mA (3) IDq = 200 mA (4) IDq = 400 mA (4) IDq = 400 mA (5) IDq = 600 mA (5) IDq = 600 mA (6) IDq = 800 mA (6) IDq = 800 mA (7) IDq = 1000 mA Product data sheet 250 300 PL (W) 350 (7) IDq = 1000 mA Power gain as a function of output power; typical values BLF182XR_BLF182XRS 200 VDS = 50 V; f = 108 MHz; tp = 100 s;  = 20 %. (1) IDq = 20 mA Fig 7. 150 Fig 8. Drain efficiency as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 3 February 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 8 of 15 BLF182XR; BLF182XRS Power LDMOS transistor aaa-019276 30 Gp (dB) 28 aaa-019277 100 ηD (%) 82 26 (7) (6) (5) (4) (3) 150 200 (2) (1) 64 (2) 24 (4) (1) (3) 46 (5) (6) 22 28 (7) 20 10 0 50 100 150 200 250 300 PL (W) 350 IDq = 100 mA; f = 108 MHz; tp = 100 s;  = 20 %. 0 50 (1) VDS = 50 V (2) VDS = 45 V (2) VDS = 45 V (3) VDS = 40 V (3) VDS = 40 V (4) VDS = 35 V (4) VDS = 35 V (5) VDS = 30 V (5) VDS = 30 V (6) VDS = 25 V (6) VDS = 25 V (7) VDS = 20 V Product data sheet 350 (7) VDS = 20 V Power gain as a function of output power; typical values BLF182XR_BLF182XRS 250 300 PL (W) IDq = 100 mA; f = 108 MHz; tp = 100 s;  = 20 %. (1) VDS = 50 V Fig 9. 100 Fig 10. Drain efficiency as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 3 February 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 9 of 15 BLF182XR; BLF182XRS Power LDMOS transistor 8. Package outline Flanged LDMOST ceramic package; 2 mounting holes; 4 leads SOT1121A D A F D1 U1 B q C H1 c 1 2 p U2 H E1 E 5 A w1 3 A B 4 b w2 C Q e 0 5 Dimensions Unit(1) mm 10 mm scale A max 4.75 nom min 3.45 b c D D1 3.94 0.18 20.02 19.96 3.68 0.10 19.61 19.66 E e E1 F H H1 p Q(2) 9.53 9.53 1.14 19.94 12.83 3.38 1.70 9.27 9.27 0.89 18.92 12.57 3.12 1.45 q U1 U2 max 0.187 0.155 0.007 0.788 0.786 0.375 0.375 0.045 0.785 0.505 0.133 0.067 inches nom 0.35 min 0.136 0.145 0.004 0.772 0.774 0.365 0.365 0.035 0.745 0.495 0.123 0.057 33.91 9.65 1.345 0.39 0.01 0.02 1.1 1.335 0.38 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. dimension is measured 0.030 inch (0.76 mm) from the body. Outline version References IEC JEDEC JEITA w2 0.25 0.51 27.94 8.89 w1 34.16 9.91 sot1121a_po European projection Issue date 09-10-12 10-02-02 SOT1121A Fig 11. Package outline SOT1121A BLF182XR_BLF182XRS Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 3 February 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 10 of 15 BLF182XR; BLF182XRS Power LDMOS transistor Earless flanged ceramic package; 4 leads SOT1121B D A F 5 D1 D U1 w2 H1 1 H c D 2 U2 E1 3 E 4 b y w3 e Q 0 5 10 mm scale Dimensions Unit(1) mm A max 4.75 nom min 3.45 b 3.94 c D D1 E e E1 F H H1 Q U1 U2 w2 w3 9.53 9.53 1.14 19.94 12.83 1.70 20.70 9.91 0.51 0.25 0.18 20.02 19.96 y 0.10 8.89 3.68 0.08 19.61 19.66 9.27 9.27 0.89 18.92 12.57 1.45 20.45 9.65 max 0.187 0.155 0.007 0.788 0.786 0.375 0.375 0.045 0.785 0.505 0.067 0.815 0.39 0.02 0.01 0.004 0.35 inches nom min 0.136 0.145 0.003 0.772 0.774 0.365 0.365 0.035 0.745 0.495 0.057 0.805 0.38 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. dimension is measured 0.030 inch (0.76 mm) from the body. Outline version References IEC JEDEC JEITA sot1121b_po European projection Issue date 12-06-07 15-07-21 SOT1121B Fig 12. Package outline SOT1121B BLF182XR_BLF182XRS Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 3 February 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 11 of 15 BLF182XR; BLF182XRS Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 12. Abbreviations Acronym Description CW Continuous Wave ESD ElectroStatic Discharge HF High Frequency LDMOS Laterally Diffused Metal-Oxide Semiconductor LDMOST Laterally Diffused Metal-Oxide Semiconductor Transistor MTF Median Time to Failure SMD Surface Mounted Device UIS Unclamped Inductive Switching VSWR Voltage Standing-Wave Ratio 11. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF182XR_BLF182XRS v.3 20160203 Product data sheet - BLF182XR_BLF182XRS#2 Modifications: • • • • • • • • • • Table 1 on page 1: table has been updated Section 1.2 on page 1: section has been updated Table 5 on page 3: table has been updated Figure 1 on page 3: figure has been added Table 6 on page 3: table has been updated Table 8 on page 4: table has been updated Table 9 on page 5: some values have been added Table 10 on page 5: table has been updated Section 7.4 on page 6: section has been added Section 7.5 on page 7: section has been added BLF182XR_BLF182XRS#2 20150901 Objective data sheet - BLF182XR_BLF182XRS v.1 BLF182XR_BLF182XRS v.1 20150723 Objective data sheet - - BLF182XR_BLF182XRS Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 3 February 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 12 of 15 BLF182XR; BLF182XRS Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF182XR_BLF182XRS Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 3 February 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 13 of 15 BLF182XR; BLF182XRS Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 13. Contact information For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales BLF182XR_BLF182XRS Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 3 February 2016 © Ampleon Netherlands B.V. 2016. All rights reserved. 14 of 15 BLF182XR; BLF182XRS Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 7.5 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 5 Ruggedness in class-AB operation . . . . . . . . . 5 Impedance information . . . . . . . . . . . . . . . . . . . 5 UIS avalanche energy . . . . . . . . . . . . . . . . . . . 5 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Handling information. . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon Netherlands B.V. 2016. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 3 February 2016 Document identifier: BLF182XR_BLF182XRS
BLF182XRSU 价格&库存
很抱歉,暂时无法提供与“BLF182XRSU”相匹配的价格&库存,您可以联系我们找货
