BLF183XRSU
BLF183XRSU
    AMPLEON(安谱隆)
    SOT-1121B
    RF FET LDMOS 135V 28DB SOT1121B
BLF183XRSU 数据手册
BLF183XR; BLF183XRS Power LDMOS transistor Rev. 3 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description A 350 W extremely rugged LDMOS power transistor for broadcast and industrial applications in the HF to 600 MHz band. Table 1. Application information VDS PL Gp D Test signal f (MHz) (V) (W) (dB) (%) pulsed RF 108 50 350 28 75 CW 88 to 108 50 388 26 80 pulsed RF 30 to 512 50 400 15 48 CW 30 to 512 35 193 14 47 1.2 Features and benefits        Easy power control Integrated ESD protection Excellent ruggedness High efficiency Excellent thermal stability Designed for broadband operation (HF to 600 MHz) Compliant to Directive 2002/95/EC, regarding Restriction of Hazardous Substances (RoHS) 1.3 Applications  Industrial, scientific and medical applications  Broadcast transmitter applications BLF183XR; BLF183XRS Power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF183XR (SOT1121A) 1 drain1 2 drain2 3 gate1 4 gate2 5 1 1 2 3 [1] source 5 5 3 4 4 2 sym117 BLF183XRS (SOT1121B) 1 drain1 2 drain2 3 gate1 4 gate2 5 1 2 3 4 5 1 3 5 4 [1] source 2 sym117 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF183XR - flanged LDMOST ceramic package; 2 mounting holes; 4 leads SOT1121A BLF183XRS - earless flanged ceramic package; 4 leads SOT1121B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Max Unit VDS drain-source voltage - 135 V gate-source voltage 6 +11 V Tstg storage temperature 65 +150 C - 225 C [1] Product data sheet Min VGS Tj BLF183XR_BLF183XRS#3 Conditions junction temperature [1] Continuous use at maximum temperature will affect the reliability, for details refer to the on-line MTF calculator. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 15 BLF183XR; BLF183XRS Power LDMOS transistor 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Conditions Tj = 115 C [1][2] Rth(j-c) thermal resistance from junction to case Zth(j-c) transient thermal impedance from junction Tj = 150 C; tp = 100 s; to case  = 20 % [1] [3] Typ Unit 0.25 K/W 0.076 K/W Tj is the junction temperature. [2] Rth(j-c) is measured under RF conditions. [3] See Figure 1. aaa-016794 0.3 Zth(j-c) (K/W) 0.25 (7) (6) (5) (4) (3) (2) (1) 0.2 0.15 0.1 0.05 0 10-7 10-6 10-5 10-4 10-3 10-2 10-1 tp (s) 1 (1)  = 1 % (2)  = 2 % (3)  = 5 % (4)  = 10 % (5)  = 20 % (6)  = 50 % (7)  = 100 % (DC) Fig 1. BLF183XR_BLF183XRS#3 Product data sheet Transient thermal impedance from junction to case as a function of pulse duration All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 15 BLF183XR; BLF183XRS Power LDMOS transistor 6. Characteristics Table 6. DC characteristics Tj = 25 C; per section unless otherwise specified. Symbol Parameter Conditions V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 1.5 mA Min Typ Max Unit 135 - - V VGS(th) gate-source threshold voltage VDS = 10 V; ID = 150 mA 1.33 2.0 2.33 V VGSq gate-source quiescent voltage VDS = 50 V; ID = 50 mA - 1.9 - V IDSS drain leakage current VGS = 0 V; VDS = 50 V - - 1.4 A IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V - 21 - A IGSS gate leakage current VGS = 11 V; VDS = 0 V - - 140 nA RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 5.25 A - 0.29 -  Table 7. AC characteristics Tj = 25 C; per section unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Crs feedback capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 1.1 - pF Ciss input capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 156 - pF Coss output capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 51 - pF Table 8. RF characteristics Test signal: pulsed RF; tp = 100 s;  = 20 %; f = 108 MHz; RF performance at VDS = 50 V; IDq = 100 mA; Tcase = 25 C; unless otherwise specified; in a class-AB production test circuit. BLF183XR_BLF183XRS#3 Product data sheet Symbol Parameter Conditions Min Typ Max Unit Gp power gain PL = 350 W 26.5 28 - dB RLin input return loss PL = 350 W - 10 7 dB D drain efficiency PL = 350 W 71 75 - % All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 15 BLF183XR; BLF183XRS Power LDMOS transistor aaa-016081 300 Coss (pF) 250 200 150 100 50 0 0 10 20 30 40 50 VDS (V) 60 VGS = 0 V; f = 1 MHz. Fig 2. Output capacitance as a function of drain-source voltage; typical values per section 7. Test information 7.1 Ruggedness in class-AB operation The BLF183XR and BLF183XRS are capable of withstanding a load mismatch corresponding to VSWR > 65 : 1 through all phases under the following conditions: VDS = 50 V; IDq = 100 mA; PL = 350 W pulsed; f = 108 MHz. 7.2 Impedance information drain 1 gate 1 Zi ZL gate 2 drain 2 001aan207 Fig 3. Definition of transistor impedance Table 9. Typical push-pull impedance Simulated Zi and ZL device impedance; impedance info at VDS = 50 V and PL = 350 W. BLF183XR_BLF183XRS#3 Product data sheet f Zi ZL (MHz) () () 108 10.3  j35.6 10.9 + j2.5 All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 15 BLF183XR; BLF183XRS Power LDMOS transistor 7.3 UIS avalanche energy Table 10. Typical avalanche data per section Tamb = 25 C; typical test data; test jig without water cooling. IAS EAS (A) (J) 10 2.6 12.5 1.5 15 1.0 For information see application note AN10273. 7.4 Test circuit 95 mm 95 mm C19 R3 - T2 + L3 C7 C5 R5 C10 L1 R1 80 mm C2 C1 C12 C14 C16 C15 C9 C4 C3 R2 C11 R6 L2 C6 C17 C21 C18 C13 C8 + L4 - T1 R4 C20 8.5 mm 56 mm aaa-017585 59 mm Printed-Circuit Board (PCB): Taconic RF-35; r = 3.5 F/m; thickness = 0.765 mm; thickness copper plating = 35 m, gold plated. See Table 11 for a list of components. Fig 4. Component layout for class-AB production test circuit Table 11. List of components For test circuit see Figure 4. Component Description C1, C4 multilayer ceramic chip capacitor 51 pF [1] C2, C3 multilayer ceramic chip capacitor 150 pF [1] C5, C6 multilayer ceramic chip capacitor 4.7 F, 50 V C7, C8 multilayer ceramic chip capacitor 820 pF [1] C9 multilayer ceramic chip capacitor 11 pF [1] C10, C11 multilayer ceramic chip capacitor 820 pF [1] C12, C13 multilayer ceramic chip capacitor 4.7 F, 100 V C14, C15, C21 electrolytic capacitor BLF183XR_BLF183XRS#3 Product data sheet Value 51 pF All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 Remarks [1] © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 15 BLF183XR; BLF183XRS Power LDMOS transistor Table 11. List of components …continued For test circuit see Figure 4. Component Description Value Remarks C16 multilayer ceramic chip capacitor 7.5 pF [1] C17,C18 multilayer ceramic chip capacitor 120 pF [1] C19, C20 electrolytic capacitor 2200 F, 64 V L1, L2, L3, L4 3.0 turn 1.0 mm copper wire D = 3.0 mm R1, R2 resistor 510  SMD 1206 R3, R4 shunt resistor 0.01  Ohmite: FC4L110R010FER R5, R6 metal film resistor 10 , 0.6 W SMD 1206 T1, T2 semi rigid coax 50 , length = 160 mm EZ Form: EZ-141-AL-TP-M17 [1] American Technical Ceramics type 100B or capacitor of same quality. 7.5 Graphical data The following figures are measured in a class-AB production test circuit. 7.5.1 1-Tone CW pulsed aaa-016075 30 Gp (dB) ηD (%) ηD PL (dBm) 28 70 59 26 50 57 Gp aaa-016076 61 90 (2) Ideal PL (1) PL 24 22 0 100 200 300 400 PL (W) 30 55 10 500 53 24 VDS = 50 V; IDq = 100 mA; f = 108 MHz; tp = 100 s;  = 20 %. 25 26 27 28 29 30 31 Pi (dBm) VDS = 50 V; IDq = 100 mA; f = 108 MHz; tp = 100 s;  = 20 %. (1) PL(1dB) = 55.5 dBm (354 W) (2) PL(3dB) = 56.1 dBm (404 W) Fig 5. Power gain and drain efficiency as function of output power; typical values BLF183XR_BLF183XRS#3 Product data sheet Fig 6. Output power as a function of input power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 15 BLF183XR; BLF183XRS Power LDMOS transistor aaa-016077 32 Gp (dB) aaa-016078 80 ηD (%) 30 (1) (2) (3) (4) (5) (6) (7) (8) 60 28 (8) (7) (6) (5) (4) (3) (2) (1) 26 40 20 24 22 0 0 100 200 300 400 PL (W) 500 0 VDS = 50 V; f = 108 MHz; tp = 100 s;  = 20 %. 100 (1) IDq = 20 mA (2) IDq = 100 mA (2) IDq = 100 mA (3) IDq = 200 mA (3) IDq = 200 mA (4) IDq = 400 mA (4) IDq = 400 mA (5) IDq = 600 mA (5) IDq = 600 mA (6) IDq = 800 mA (6) IDq = 800 mA (7) IDq = 1000 mA (7) IDq = 1000 mA (8) IDq = 1200 mA (8) IDq = 1200 mA Power gain as a function of output power; typical values BLF183XR_BLF183XRS#3 Product data sheet 300 400 PL (W) 500 VDS = 50 V; f = 108 MHz; tp = 100 s;  = 20 %. (1) IDq = 20 mA Fig 7. 200 Fig 8. Drain efficiency as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 15 BLF183XR; BLF183XRS Power LDMOS transistor aaa-016079 30 Gp (dB) aaa-016080 90 ηD (%) (7) (6) (5) (4) (3) (2) (1) 28 70 26 (1) (2) 50 (3) (4) 24 (5) (6) 22 30 (7) 20 10 0 100 200 300 400 PL (W) 500 IDq = 100 mA; f = 108 MHz; tp = 100 s;  = 20 %. 0 100 (1) VDS = 50 V (2) VDS = 45 V (2) VDS = 45 V (3) VDS = 40 V (3) VDS = 40 V (4) VDS = 35 V (4) VDS = 35 V (5) VDS = 30 V (5) VDS = 30 V (6) VDS = 25 V (6) VDS = 25 V (7) VDS = 20 V Product data sheet 400 PL (W) 500 (7) VDS = 20 V Power gain as a function of output power; typical values BLF183XR_BLF183XRS#3 300 IDq = 100 mA; f = 108 MHz; tp = 100 s;  = 20 %. (1) VDS = 50 V Fig 9. 200 Fig 10. Drain efficiency as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 15 BLF183XR; BLF183XRS Power LDMOS transistor 8. Package outline Flanged LDMOST ceramic package; 2 mounting holes; 4 leads SOT1121A D A F D1 U1 B q C H1 c 1 2 p U2 H E1 E 5 A w1 3 A B 4 b w2 C Q e 0 5 Dimensions Unit(1) mm 10 mm scale A max 4.75 nom min 3.45 b c D D1 3.94 0.18 20.02 19.96 3.68 0.10 19.61 19.66 E e E1 F H H1 p Q(2) 9.53 9.53 1.14 19.94 12.83 3.38 1.70 9.27 9.27 0.89 18.92 12.57 3.12 1.45 q U1 U2 max 0.187 0.155 0.007 0.788 0.786 0.375 0.375 0.045 0.785 0.505 0.133 0.067 inches nom 0.35 min 0.136 0.145 0.004 0.772 0.774 0.365 0.365 0.035 0.745 0.495 0.123 0.057 33.91 9.65 1.345 0.39 0.01 0.02 1.1 1.335 0.38 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. dimension is measured 0.030 inch (0.76 mm) from the body. Outline version References IEC JEDEC JEITA w2 0.25 0.51 27.94 8.89 w1 34.16 9.91 sot1121a_po European projection Issue date 09-10-12 10-02-02 SOT1121A Fig 11. Package outline SOT1121A BLF183XR_BLF183XRS#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 15 BLF183XR; BLF183XRS Power LDMOS transistor Earless flanged ceramic package; 4 leads SOT1121B D A F 5 D1 D U1 w2 H1 1 H c D 2 U2 E1 3 E 4 b y w3 e Q 0 5 10 mm scale Dimensions Unit(1) mm A max 4.75 nom min 3.45 b 3.94 c D D1 E e E1 F H H1 Q U1 U2 w2 w3 9.53 9.53 1.14 19.94 12.83 1.70 20.70 9.91 0.51 0.25 0.18 20.02 19.96 0.25 8.89 3.68 0.08 19.61 19.66 9.27 9.27 0.89 18.92 12.57 1.45 20.45 9.65 max 0.187 0.155 0.007 0.788 0.786 0.375 0.375 0.045 0.785 0.505 0.067 0.815 0.39 0.02 0.01 0.35 inches nom min 0.136 0.145 0.003 0.772 0.774 0.365 0.365 0.035 0.745 0.495 0.057 0.805 0.38 Note 1. millimeter dimensions are derived from the original inch dimensions. 2. dimension is measured 0.030 inch (0.76 mm) from the body. Outline version y References IEC JEDEC JEITA 0.01 sot1121b_po European projection Issue date 09-12-14 12-06-07 SOT1121B Fig 12. Package outline SOT1121B BLF183XR_BLF183XRS#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 15 BLF183XR; BLF183XRS Power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 12. Abbreviations Acronym Description CW Continuous Wave ESD ElectroStatic Discharge HF High Frequency LDMOS Laterally Diffused Metal-Oxide Semiconductor LDMOST Laterally Diffused Metal-Oxide Semiconductor Transistor MTF Median Time to Failure SMD Surface Mounted Device UIS Unclamped Inductive Switching VSWR Voltage Standing-Wave Ratio 11. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF183XR_BLF183XRS#3 20150901 Product data sheet - BLF183XR_BLF183XRS v.2 Modifications: • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF183XR_BLF183XRS v.2 20150522 Product data sheet - BLF183XR_BLF183XRS v.1 BLF183XR_BLF183XRS v.1 20140819 Objective data sheet - - BLF183XR_BLF183XRS#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 12 of 15 BLF183XR; BLF183XRS Power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF183XR_BLF183XRS#3 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 13 of 15 BLF183XR; BLF183XRS Power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 13. Contact information For more information, please visit: http://www.ampleon.com BLF183XR_BLF183XRS#3 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 14 of 15 BLF183XR; BLF183XRS Power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.4 7.5 7.5.1 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 5 Ruggedness in class-AB operation . . . . . . . . . 5 Impedance information . . . . . . . . . . . . . . . . . . . 5 UIS avalanche energy . . . . . . . . . . . . . . . . . . . 6 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 7 1-Tone CW pulsed . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Handling information. . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12 Legal information. . . . . . . . . . . . . . . . . . . . . . . 13 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Contact information. . . . . . . . . . . . . . . . . . . . . 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF183XR_BLF183XRS#3
BLF183XRSU 价格&库存
很抱歉,暂时无法提供与“BLF183XRSU”相匹配的价格&库存,您可以联系我们找货
