BLF882SU
BLF882SU
    AMPLEON(安谱隆)
    SOT502B
    BLF882SU
BLF882SU 数据手册
BLF882; BLF882S UHF power LDMOS transistor Rev. 3 — 1 September 2015 Product data sheet 1. Product profile 1.1 General description A 200 W LDMOS RF power transistor for broadcast transmitter applications and industrial applications. The transistor can deliver 200 W in broadband applications from HF to 860 MHz. The excellent ruggedness and broadband performance of this device makes it ideal for digital transmitter applications. Table 1. Test information RF performance at Tcase = 25 C in a class-AB test circuit. Test signal f VDS PL(AV) Gp D PAR (MHz) (V) (W) (dB) (%) (dB) RF performance in a class-AB 705 MHz narrowband test circuit CW, class-AB 705 50 180 21 62 - CW pulsed, class-AB 705 50 200 21 63 - RF performance in a class-AB 470 MHz to 705 MHz broadband test circuit DVB-T (8k OFDM) [1] 470 to 705 50 33 20 28 to 31 8.0 to 8.4 [1] PAR of output signal at 0.01% probability on CCDF; PAR of input signal = 9.5 dB at 0.01% probability on CCDF. 1.2 Features and benefits        Integrated ESD protection Excellent ruggedness High power gain High efficiency Excellent reliability Easy power control Compliant to Directive 2002/95/EC, regarding restriction of hazardous substances (RoHS) 1.3 Applications  Transmitter applications in the HF to 860 MHz frequency range  Industrial applications in the HF to 860 MHz frequency range  Broadcast transmitters BLF882; BLF882S UHF power LDMOS transistor 2. Pinning information Table 2. Pinning Pin Description Simplified outline Graphic symbol BLF882 (SOT502A) 1 drain 2 gate 3 source 1 1 3 [1] 2 2 3 sym112 BLF882S (SOT502B) 1 drain 2 gate 3 source 1 1 3 [1] 2 2 3 sym112 [1] Connected to flange. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BLF882 - flanged ceramic package; 2 mounting holes; 2 leads SOT502A BLF882S - earless flanged ceramic package; 2 leads SOT502B 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDS Min Max Unit drain-source voltage - 104 V VGS gate-source voltage 0.5 +13 V Tstg storage temperature 65 +150 C - 225 C [1] junction temperature Tj [1] Conditions Continuous use at maximum temperature will affect the reliability, for details refer to the on-line MTF calculator. 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-c) thermal resistance from junction to case Tcase = 85 C; PL = 180 W [1] BLF882_BLF882S#3 Product data sheet Conditions [1] Typ Unit 0.56 K/W Rth(j-c) is measured under RF conditions. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 2 of 12 BLF882; BLF882S UHF power LDMOS transistor 6. Characteristics Table 6. DC characteristics Tj = 25 C; unless otherwise specified. Symbol Parameter Conditions V(BR)DSS drain-source breakdown voltage VGS = 0 V; ID = 1.2 mA VGS(th) gate-source threshold voltage VDS = 10 V; ID = 120 mA IDSS drain leakage current VGS = 0 V; VDS = 50 V IDSX drain cut-off current VGS = VGS(th) + 3.75 V; VDS = 10 V IGSS gate leakage current VGS = 10 V; VDS = 0 V RDS(on) drain-source on-state resistance VGS = VGS(th) + 3.75 V; ID = 4.25 A [1] Min Typ Max Unit [1] 104 - - V [1] 1.4 1.9 2.4 V - - 1.4 A - 19 - A - - 140 nA - 240 - [1] [1] m ID is the drain current Table 7. AC characteristics Tj = 25 C; unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VGS = 0 V; VDS = 50 V; f = 1 MHz - 105 - pF Ciss input capacitance Coss output capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 34 - pF Crs feedback capacitance VGS = 0 V; VDS = 50 V; f = 1 MHz - 0.7 - pF Table 8. RF characteristics Test signal: CW pulsed; RF characteristics in Ampleon production narrowband test circuit; Tj = 25 C; unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage - 50 - V IDq quiescent drain current - 100 - mA 196 200 f = 705 MHz; tp = 100 s;  = 10 % PL(AV) average output power - W Gp power gain 19.6 20.6 - dB D drain efficiency 60 % 63 - 7. Test information 7.1 Ruggedness in class-AB operation The BLF882 and BLF882S are capable of withstanding a load mismatch corresponding to VSWR  20 : 1 through all phases under the following conditions: VDS = 50 V; f = 705 MHz at rated PL(1dB). BLF882_BLF882S#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 3 of 12 BLF882; BLF882S UHF power LDMOS transistor 7.2 Test circuit 90 mm R2 C1 C8 C2 C10 C11 C12 L2 R1 L1 70 mm C3 C9 C6 R3 L3 C13 C4 C5 C14 C15 C7 C17 C16 aaa-018618 Printed-Circuit Board (PCB): Taconic RF-35; r = 3.5 F/m; thickness = 0.765 mm; thickness copper plating = 35 m, gold plated. See Table 9 for a list of components. Fig 1. Component layout for class-AB production test circuit Table 9. List of components For test circuit see Figure 1. BLF882_BLF882S#3 Product data sheet Component Description Value C1 multilayer ceramic chip capacitor 62 pF C2 multilayer ceramic chip capacitor 100 nF C3, C9 multilayer ceramic chip capacitor 56 pF [1] C4 multilayer ceramic chip capacitor 12 pF [2] C5 multilayer ceramic chip capacitor 11 pF [2] C6, C7 multilayer ceramic chip capacitor 24 pF [2] C8 electrolytic capacitor 220 F C10, C11, C12 electrolytic capacitor 750 pF [1] C13 multilayer ceramic chip capacitor 16 pF [3] C14 multilayer ceramic chip capacitor 18 pF [3] C15 multilayer ceramic chip capacitor 5.6 pF [3] C16 multilayer ceramic chip capacitor 6.8 pF [3] C17 multilayer ceramic chip capacitor 56 pF [3] L1, L2, L3 3 turn 1 mm spiral coil D = 3.0 mm; 120 nH R1, R2 resistor 10  SMD 1206 R3 resistor 15  SMD 1206 [1] American Technical Ceramics type 100B. [2] American Technical Ceramics type 800A. [3] American Technical Ceramics type 800B. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 Remarks [1] © Ampleon The Netherlands B.V. 2015. All rights reserved. 4 of 12 BLF882; BLF882S UHF power LDMOS transistor 7.3 Graphical data 7.3.1 DVB-T aaa-018283 23 50 Gp (dB) ηD (%) 22 PAR (dB) -17 ACPR (dBc) 9 -21 7 -25 5 -29 30 20 ACPR 20 3 ηD 0 20 40 60 80 PL (W) 10 100 1 VDS = 50 V; IDq = 100 mA; f = 705 MHz. Fig 2. PAR 40 Gp 21 19 aaa-018282 11 -33 0 20 40 60 80 100 PL (W) -37 120 VDS = 50 V; IDq = 100 mA; f = 705 MHz; PAR of input signal = 9.5 dB at 0.01 % probability on CCDF. Power gain and drain efficiency as function of output power; typical values Fig 3. Peak-to-average ratio and adjacent channel power ratio as function of output power; typical values 7.3.2 CW pulsed aaa-018284 23 Gp (dB) aaa-018285 70 ηD (%) (3) 60 (2) 22 50 (1) 21 (1) (2) (3) 40 30 20 20 19 0 50 100 150 200 PL (W) 10 250 VDS = 50 V; f = 705 MHz; tp = 100 s;  = 10 %. 0 50 (1) IDq = 100 mA (2) IDq = 200 mA (2) IDq = 200 mA (3) IDq = 300 mA (3) IDq = 300 mA Power gain as a function of output power; typical values BLF882_BLF882S#3 Product data sheet 150 200 PL (W) 250 VDS = 50 V; f = 705 MHz; tp = 100 s;  = 10 %. (1) IDq = 100 mA Fig 4. 100 Fig 5. Drain efficiency as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 5 of 12 BLF882; BLF882S UHF power LDMOS transistor aaa-018286 22.5 Gp (dB) 22 (1) 60 21.5 50 21 40 20.5 20 (3) (4) (1) 0 50 100 150 (2) (4) 20 200 250 PL (W) 10 300 IDq = 100 mA; f = 705 MHz; tp = 100 s;  = 10 %. 0 50 (1) VDS = 40 V (2) VDS = 45 V (2) VDS = 45 V (3) VDS = 50 V (3) VDS = 50 V (4) VDS = 55 V (4) VDS = 55 V Power gain as a function of output power; typical values BLF882_BLF882S#3 Product data sheet 100 150 200 250 PL (W) 300 IDq = 100 mA; f = 705 MHz; tp = 100 s;  = 10 %. (1) VDS = 40 V Fig 6. (2) 30 (3) 19.5 aaa-018287 70 ηD (%) Fig 7. Drain efficiency as a function of output power; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 6 of 12 BLF882; BLF882S UHF power LDMOS transistor 8. Package outline Flanged ceramic package; 2 mounting holes; 2 leads SOT502A D A F 3 D1 U1 B q c C 1 H L E1 p U2 E w1 M A M B M A 2 w2 M C M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION E E1 F H L p Q q U1 U2 w1 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 3.38 3.12 1.70 1.45 27.94 34.16 33.91 9.91 9.65 0.25 0.51 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 0.067 1.100 0.057 1.345 1.335 0.390 0.380 0.01 0.02 D D1 0.045 0.785 0.210 0.133 0.035 0.745 0.170 0.123 REFERENCES IEC JEDEC JEITA ISSUE DATE 03-01-10 12-05-02 SOT502A Fig 8. EUROPEAN PROJECTION Package outline SOT502A BLF882_BLF882S#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 7 of 12 BLF882; BLF882S UHF power LDMOS transistor Earless flanged ceramic package; 2 leads SOT502B D A F 3 D D1 c U1 1 L H E1 U2 E 2 w2 M D M b 0 5 Q 10 mm scale DIMENSIONS (millimetre dimensions are derived from the original inch dimensions) UNIT A b c mm 4.72 3.43 12.83 12.57 0.15 0.08 inches 0.186 0.135 0.505 0.006 0.495 0.003 OUTLINE VERSION E E1 F H L Q U1 U2 w2 20.02 19.96 19.61 19.66 9.50 9.30 9.53 9.25 1.14 0.89 19.94 18.92 5.33 4.32 1.70 1.45 20.70 20.45 9.91 9.65 0.25 0.788 0.786 0.772 0.774 0.374 0.375 0.366 0.364 D D1 0.045 0.785 0.210 0.035 0.745 0.170 0.067 0.815 0.057 0.805 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 07-05-09 12-05-02 SOT502B Fig 9. 0.390 0.010 0.380 Package outline SOT502B BLF882_BLF882S#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 8 of 12 BLF882; BLF882S UHF power LDMOS transistor 9. Handling information CAUTION This device is sensitive to ElectroStatic Discharge (ESD). Observe precautions for handling electrostatic sensitive devices. Such precautions are described in the ANSI/ESD S20.20, IEC/ST 61340-5, JESD625-A or equivalent standards. 10. Abbreviations Table 10. Abbreviations Acronym Description CCDF Complementary Cumulative Distribution Function CW Continuos Wave ESD ElectroStatic Discharge DVB-T Digital Video Broadcast - Terrestrial HF High Frequency LDMOS Laterally Diffused Metal-Oxide Semiconductor MTF Median Time to Failure OFDM Orthogonal Frequency Division Multiplexing PAR Peak-to-Average Ratio SMD Surface Mounted Device UHF Ultra High Frequency VSWR Voltage Standing-Wave Ratio 11. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes BLF882_BLF882S#3 20150901 Product data sheet - BLF882_BLF882S v.2 Modifications: • The format of this document has been redesigned to comply with the new identity guidelines of Ampleon. • Legal texts have been adapted to the new company name where appropriate. BLF882_BLF882S v.2 20150703 Product data sheet - BLF882_BLF882S v.1 BLF882_BLF882S v.1 20141219 Objective data sheet - - BLF882_BLF882S#3 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 9 of 12 BLF882; BLF882S UHF power LDMOS transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ampleon.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Ampleon does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Ampleon sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Ampleon and its customer, unless Ampleon and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Ampleon product is deemed to offer functions and qualities beyond those described in the Product data sheet. 12.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Ampleon does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Ampleon takes no responsibility for the content in this document if provided by an information source outside of Ampleon. In no event shall Ampleon be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Ampleon’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Ampleon. Right to make changes — Ampleon reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Ampleon products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an BLF882_BLF882S#3 Product data sheet Ampleon product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Ampleon and its suppliers accept no liability for inclusion and/or use of Ampleon products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Ampleon makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Ampleon products, and Ampleon accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Ampleon product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Ampleon does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Ampleon products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Ampleon does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Ampleon products are sold subject to the general terms and conditions of commercial sale, as published at http://www.ampleon.com/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Ampleon hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Ampleon products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 10 of 12 BLF882; BLF882S UHF power LDMOS transistor Non-automotive qualified products — Unless this data sheet expressly states that this specific Ampleon product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Ampleon accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Ampleon’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Ampleon’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Ampleon for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Ampleon’ standard warranty and Ampleon’ product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 12.4 Licenses ICs with DVB-T or DVB-T2 functionality Use of this product in any manner that complies with the DVB-T or the DVB-T2 standard may require licenses under applicable patents of the DVB-T respectively the DVB-T2 patent portfolio, which license is available from Sisvel S.p.A., Via Sestriere 100, 10060 None (TO), Italy, and under applicable patents of other parties. 12.5 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own Any reference or use of any ‘NXP’ trademark in this document or in or on the surface of Ampleon products does not result in any claim, liability or entitlement vis-à-vis the owner of this trademark. Ampleon is no longer part of the NXP group of companies and any reference to or use of the ‘NXP’ trademarks will be replaced by reference to or use of Ampleon’s own trademarks. 13. Contact information For more information, please visit: http://www.ampleon.com BLF882_BLF882S#3 Product data sheet For sales office addresses, please visit: http://www.ampleon.com/sales All information provided in this document is subject to legal disclaimers. Rev. 3 — 1 September 2015 © Ampleon The Netherlands B.V. 2015. All rights reserved. 11 of 12 BLF882; BLF882S UHF power LDMOS transistor 14. Contents 1 1.1 1.2 1.3 2 3 4 5 6 7 7.1 7.2 7.3 7.3.1 7.3.2 8 9 10 11 12 12.1 12.2 12.3 12.4 12.5 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 3 Ruggedness in class-AB operation . . . . . . . . . 3 Test circuit. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Graphical data . . . . . . . . . . . . . . . . . . . . . . . . . 5 DVB-T . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 CW pulsed . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Handling information. . . . . . . . . . . . . . . . . . . . . 9 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Licenses . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Ampleon The Netherlands B.V. 2015. All rights reserved. For more information, please visit: http://www.ampleon.com For sales office addresses, please visit: http://www.ampleon.com/sales Date of release: 1 September 2015 Document identifier: BLF882_BLF882S#3
BLF882SU 价格&库存
很抱歉,暂时无法提供与“BLF882SU”相匹配的价格&库存,您可以联系我们找货
